Hi, I'm currently working on a system which needs to obtain bio-impedance measurements reasonably fast, system will have up to 35 electrodes I'm planning to use external analog multiplexers to do all the switching, periodically system needs to do impedance measurements across different electrodes with different frequencies.
I would like to know:
1. What is the minimum time required to obtain a valid impedance reading. (settling time, conversion time ? I can only find 860sps sampling frequency)
2. Will this time change if I change excitation frequency ? by how much ?
3. If possible how can I reduce this time?
4. Can you please give some ideas how should I utilise the AFE4300 dev board to achieve this, is there an API so I can control the process with scripting language and so on if so can you please tell me where I can find it.
Kind regards,
