Other Parts Discussed in Thread: CDCLVP111
Customer is now estimating Power Dissipation for CDCLVP111-EP. Would you provide the information about θjc(top)、θjc(bottom) and θjb?
Toshiyuki
Toshiyuki
Hello Toshiyuki,
You can use the numbers from the commercial datasheet for the VF package:
http://www.ti.com/lit/ds/symlink/cdclvp111.pdf
Those numbers will be added to the EP datasheet at the next revision.
Kirby
Hi Kirby-san,
Thank you for your reply. Customer is considering power dissipation from the bottom of CDCLVP111. They are going to try thermal simulation. So, would you provide θjc(bot) spec for VF PKG?
Toshiyuki
HI Kirby-san,
Thank you for your reply. Which means VF PKG shouldn't be installed a heat sink on the bottom, but on the top as necessary?
Toshiyuki
