Hi all,
I have a query related to AFE4490 module.
I have tested the attached "PulseOxy.c" file to calculate heart rate using AFE4490 and it gives me very well values using the algorithm shown in this file.
Which i got it from
Now my query is when i take my finger from the module and put any other object , it does the same , i mean it count the HR using reflection and calculation.
So can any body help me to find a way in which it works only upon detection of human / living being and on other objects/non living being it discard the calculation ?
Please let me know if is there any documentation or any guidances are available on the same .
Also please let me know if i can provide any more details.
Thanks & Regards,
Rutvij
/* * Copyright (C) 2013 University of Texas at Dallas * Embedded Systems and Signal Processing Lab * and * Texas Instruments Incorporated * * All rights reserved. * * * * * * * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * Neither the names of Texas Instruments Incorporated nor * The University of Texas at Dallas nor the names of * their contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** * @file PulseOx_HRM.c * @brief This class contains the signal processing algorithms * @details Filters incoming data from AFE4400 and calculates SpO2 and Heart rate values * @version 1.0 * @date 2012 */ #include "PulseOx_HRM.h" int voltageCodeCounter = 0; //Counter for how many times DRDY is received //Variables for heart rate measurement int transitions[2] = {-1,-1}; static unsigned int decision_hist[4] = {0, 0, 0, 0}; static unsigned int hist_sum = 0; static unsigned int hist_count = 0; static unsigned int delta_hr = 0; int heartRateCalc = 0; long previousValue = 0; long currentValue = 0; //Variables for SpO2 measurement long maxIRValue = 0; long minIRValue = 1000000000; long maxRedValue = 0; long minRedValue = 1000000000; int pulseStarted = 0; //Flag to indicate if at least 1 pulse is completed unsigned char voltageCodeBuffer[20]; //Buffer to hold voltage code values to be sent over BLE int bufferCounter = 0; //Counter for indexing into voltage code buffer char filtered = 1; //Flag set to choose between filtered and unfiltered streams unsigned int heartRate = 0; unsigned int heartRate2 = 10; unsigned int heartReport = 10; unsigned int pulseOx = 0; extern long collectRED(); extern long collectIR(); extern long collectIRMinusAMBIR(); extern bool checkStreamStatus(); extern void sendBLEBuffer(unsigned char buffer[]); extern void sendMessage(char msgByte); const long SCALE = 33554432; const double SOS [3][6] = { {1, 0, -1, 1, -1.9725464130456409, 0.97381705538051955}, {1, 0, -1, 1, -1.9950869055123981, 0.99513037435061724}, {1, 0, -1, 1, -1.9688341956177746, 0.96906741719379641}}; /** * @brief Bandpass filter between 0.5 and 3Hz * * @param sample a long * * @return long */ long filter(long sample) { // const long b_int [3][3] = { // {(long) (SOS [0][0] * SCALE), (long) (SOS [0][1] * SCALE), (long) (SOS [0][2] * SCALE)}, // {(long) (SOS [1][0] * SCALE), (long) (SOS [1][1] * SCALE), (long) (SOS [1][2] * SCALE)}, // {(long) (SOS [2][0] * SCALE), (long) (SOS [2][1] * SCALE), (long) (SOS [2][2] * SCALE)}}; // // const long a_int [3][3] = { // {(long) (SOS [0][3] * SCALE), (long) (SOS [0][4] * SCALE), (long) (SOS [0][5] * SCALE)}, // {(long) (SOS [1][3] * SCALE), (long) (SOS [1][4] * SCALE), (long) (SOS [1][5] * SCALE)}, // {(long) (SOS [2][3] * SCALE), (long) (SOS [2][4] * SCALE), (long) (SOS [2][5] * SCALE)}}; long b_int [3][3] = {0,0,0,0,0,0,0,0,0}; long a_int [3][3] = {0,0,0,0,0,0,0,0,0}; int k; int j; for(k=0; k<3; k++) { for(j=0; j<3;j++) { b_int[k][j] = (long) (SOS [k][j] * SCALE); a_int[k][j] = (long) (SOS [k][j+3] * SCALE); } } // long s_int [4] = { // (long) (s[0] * SCALE), (long) (s[1] * SCALE), (long) (s[2] * SCALE), (long) (s[3] * SCALE)}; long s_int[4] = {0,0,0,0}; for(j=0;j<4;j++) { s_int[j] = (long) (s[j] * SCALE); } static long dly [STAGES][2] = {{0,0}, {0,0}, {0,0}}; long result, wn; long mysample = sample; long wa1, wa2, wa3; long wb1, wb2, wb3; int i; for (i = 0; i < STAGES; i++) { //2nd-order LCCDE code //(eqn 8) wa1 = ((long long)mysample * s_int[i]) >> (TRUNC_BITS); wa2 = ((long long)a_int[i][1] * dly[i][0]) >> TRUNC_BITS; wa3 = ((long long)a_int[i][2] * dly[i][1]) >> TRUNC_BITS; wn = wa1 - wa2 - wa3; //(eqn 9) wb1 = ((long long)b_int[i][0] * wn) >> TRUNC_BITS; wb2 = ((long long)b_int[i][1] * dly[i][0]) >> TRUNC_BITS; wb3 = ((long long)b_int[i][2] * dly[i][1]) >> TRUNC_BITS; result = wb1 + wb2 + wb3; //Update filter buffers for stage i dly[i][1] = dly[i][0]; dly[i][0] = wn; mysample = result; //in case we have to loop again } return (long)result; } /** * @brief Calculate heart rate given start and end of pulse * * @param start an int * * @param end an int * * @return unsigned int */ unsigned int calcHeartRate(int start, int end) { int pulseLength = 0; if(start > end) end += 3000; //In case end index of pulse wrapped around 6 -second window pulseLength = end - start; //Calculate length of pulse based on start and end indices //Check if this is reasonable pulse length if((pulseLength >= sampleRate/4) && (pulseLength < sampleRate*3)) { double tempHeartRate = (60.00 * sampleRate)/ pulseLength; tempHeartRate *= 100; //Multiply by 100 to maintain 2 decimal points when casting to integer int heartRate = (int)tempHeartRate; //Cast down to integer to send over BLE return heartRate; } return 0; //Return 0 for invalid pulse length } /** * @brief Calculate SpO2 given max and min Red and IR values * * @param maxIR a long * * @param minIR a long * * @param maxRed a long * * @param minRed a long * * @return unsigned int */ unsigned int calcPulseOx(long maxIR, long minIR, long maxRed, long minRed) { double irDC = minIR; double irAC = maxIR - minIR; double redDC = minRed; double redAC = maxRed - minRed; double ratio = (redAC/redDC)/(irAC/irDC); spO2 = 110 - 25*ratio; double tempSpO2 = 100*spO2; //Multiply by 100 to maintain 2 decimal points when casting down to integer int pulseOx = (int)tempSpO2; //Cast to int to transfer over BLE return pulseOx; } /** * @brief Sends a formatted pulseOx message over BLE * * @param pulseOx an unsigned int * * @return None */ void sendPulseOx(unsigned int pulseOx) { unsigned char pulseOxHigh = pulseOx >> 8; unsigned char pulseOxLow = pulseOx; unsigned char buffer[7]; buffer[0] = 0x0C; //Start byte buffer[1] = 0x35; //Message length buffer[2] = deviceCode; //Device code buffer[3] = 0x43; //PulseOx opcode buffer[4] = pulseOxHigh; //PulseOx high byte buffer[5] = pulseOxLow; //PulseOx low byte buffer[6] = 0x0D; //End byte int i; for(i=0; i<7; i++) { sendMessage(buffer[i]); __delay_cycles(1600); } } /** * @brief Sends a formatted heart rate message over BLE * * @param heartRate an unsigned int * * @return None */ void sendHeartRate(unsigned int heartRate) { unsigned char heartRateHigh = heartRate >> 8; unsigned char heartRateLow = heartRate; unsigned char buffer[7]; buffer[0] = 0x0C; //Start byte buffer[1] = 0x35; //Message length buffer[2] = deviceCode; //Device code buffer[3] = 0x44; //Heart rate opcode buffer[4] = heartRateHigh; //Heart rate high byte buffer[5] = heartRateLow; //Heart rate low byte buffer[6] = 0x0D; //End byte int i; for(i=0; i<7; i++) { sendMessage(buffer[i]); __delay_cycles(1600); } } /** * @brief Processes the collected Red and IR values * * @param None * * @return None */ void processData() { voltageCodeCounter++; //Start calculating data after skipping 2 seconds if(voltageCodeCounter > 1000) { int index = voltageCodeCounter - 1001; //Read Red and IR values from AFE4400 long irSample = collectIR(); long redSample = collectRED(); //Filter the IR value long filtIRSample = filter(irSample); if(checkStreamStatus()) //Send data for graphing only in streaming mode { //Send 1 of every 5 samples for graphing if(voltageCodeCounter % 5 == 0) { if(filtered) //If filtered flag is set stream filtered data { //Do a signed shift to get lower 2 bytes of data voltageCodeBuffer[bufferCounter++] = filtIRSample >> 8; voltageCodeBuffer[bufferCounter++] = filtIRSample; //Pack data in chunks of 20 bytes if(bufferCounter >= 20) { unsigned char tempBuffer[20]; //Transfer data and clear buffer int i; for(i=0; i<20; i++) { tempBuffer[i] = voltageCodeBuffer[i]; voltageCodeBuffer[i] = 0; } bufferCounter = 0; //Reset index counter sendBLEBuffer(tempBuffer); //Call BLE function to send the data } } //Else stream unfiltered data else { //Do a signed shift to get lower 2 bytes of data voltageCodeBuffer[bufferCounter++] = irSample >> 9; voltageCodeBuffer[bufferCounter++] = irSample >> 1; if(bufferCounter >= 20) { unsigned char tempBuffer[20]; //Transfer data and clear buffer int i; for(i=0; i<20; i++) { tempBuffer[i] = voltageCodeBuffer[i]; voltageCodeBuffer[i] = 0; } bufferCounter = 0; //Reset index counter sendBLEBuffer(tempBuffer); //Call BLE function to send the data } } } } //Find max and min IR and Red values in the current pulse if(pulseStarted) { if(irSample > maxIRValue) maxIRValue = irSample; if(irSample < minIRValue) minIRValue = irSample; if(redSample > maxRedValue) maxRedValue = redSample; if(redSample < minRedValue) minRedValue = redSample; } previousValue = currentValue; currentValue = filtIRSample; //If there was a transition from negative to positive in the filtered data if(previousValue < 0 && currentValue > 0) { if(transitions[0] == -1) transitions[0] = index; //If this is the first transition else if(transitions[1] == -1) //If this is the second transition { transitions[1] = index; pulseStarted = 1; //Set pulse started flag only after 2 confirmed transitions } else { //Keep indices of last two transitions to estimate length of pulse transitions[0] = transitions[1]; transitions[1] = index; //Call signal functions to calculate heart rate and SpO2 heartRate = calcHeartRate(transitions[0], transitions[1]); pulseOx = calcPulseOx(maxIRValue, minIRValue, maxRedValue, minRedValue); //Average heart rate with previous history of values if(hist_count < 4) { decision_hist[hist_count] = heartRate; hist_count++; hist_sum = hist_sum + heartRate; heartRate2 = heartRate; } else { if (heartRate > (hist_sum/4+300)) { heartRate2 = decision_hist[3] + (delta_hr)*100; if(delta_hr <3) delta_hr++; } else if(heartRate < (hist_sum/4-300)) { heartRate2 = decision_hist[3] - (300 - (delta_hr)*100); if(delta_hr > 0) delta_hr--; } else { heartRate2 = heartRate; } hist_sum = hist_sum - decision_hist[0] + heartRate2; decision_hist[0] = decision_hist[1]; decision_hist[1] = decision_hist[2]; decision_hist[2] = decision_hist[3]; decision_hist[3] = heartRate2; heartReport = hist_sum/4; } //Reset maximum and minimum defaults for comparison in next cycle maxIRValue = 0; minIRValue = 1000000000; maxRedValue = 0; minRedValue = 1000000000; } } if(voltageCodeCounter >= 1500 && voltageCodeCounter%500 == 0) //Send heart rate and SpO2 values every 1 seconds { GPIO_toggleOutputOnPin(PACKET_LED_PORT_ADDRESS, PACKET_LED_PORT_NUMBER, PACKET_LED_PIN ); if(checkStreamStatus()) { //Send values only if they are within reasonable range if((heartReport/100) > 40 && (heartReport/100) < 150) sendHeartRate(heartReport);//decision_hist[3]); if(((pulseOx/100) <= 100) && deviceCode == 0x32) sendPulseOx(pulseOx); } else { //Send values only if they are within reasonable range if((heartReport/100) > 40 && (heartReport/100) < 150) sendHeartRate(heartReport); if(((pulseOx/100) <= 100) && deviceCode == 0x32) sendPulseOx(pulseOx); } if(voltageCodeCounter >= 4000) { voltageCodeCounter = 1000; } } } //Build a filter history for the initial few samples else { filter(collectIRMinusAMBIR()); } }
