Other Parts Discussed in Thread: ADS52J90,
Hi Kurtis,
Bypassing supply pins with bypass capacitors is generally used to reduce current loop area and the inductance in current return path. It is commonly used to reduce losses in a power supply besides other benefits. The ADS52J90EVM plugs into a wall socket so power efficiency is not a consideration in its design.
As far as clock termination is concerned, your clock source and logic level determine the type of termination circuit to use. Most clock buffers and clock distribution ICs recommend specific termination circuits for their devices. The datasheet just shows a generic AC coupling capacitor and is not meant to depict clock termination for all possible clock formats/logic levels.
Regarding the schematic symbol, please use the datasheet pin map, names and mechanical data to create an updated symbol as the device datasheet has gone through multiple revisions since that symbol was created.
Sincerely,
Olu
