• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Applications » Motor Drivers » Motor Drivers Forum » DRV8302 or DRV8301
Share
Motor Drivers
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
DRV8302 or DRV8301
DRV8302 or DRV8301
This question is answered
Wang Long
Posted by Wang Long
on Oct 06 2011 06:41 AM
Intellectual675 points
Hello TI experts,
I am getting confused of 2 KITs.
Either DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can be found in ti.com
Are both the same (functional)? Or just with different driver chip but the same function?
Thanks for your reply in advanced.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Wang Long
    Posted by Wang Long
    on Oct 06 2011 07:32 AM
    Verified Answer
    Verified by Wang Long
    I went a step further in DRV8302 and cleared this issue to me.
    So generally, DRV8302 has no SPI interface, but almost the same functions as DRV8301.
    I think, DRV8302 is more easier to be controled/communicated, because of dropping SPI interface.
    Long
    Report Abuse
    • Reply
  • Ryan Kehr
    Posted by Ryan Kehr
    on Oct 06 2011 09:45 AM
    Verified Answer
    Genius13785 points
    Wang,
    You are absolutely correct.  The DRV8302 drops the SPI interface and replaces the 4 SPI pins with logic pins controllable with GPIO or you can just connect them high or low.  You lose some of the functionality of the DRV8301 (i.e 4 gain steps on the current shunts in 8301 vs. 2 in the 8302).  You also lose some of the diagnostic capabilities you have in the DRV8301.
    Other than that, the rest of the device is identical.
    Ryan Kehr
    Motor Drive Application Manager
    Report Abuse
    • Reply
  • Wang Long
    Posted by Wang Long
    on Oct 07 2011 00:38 AM
    Verified Answer
    Verified by Ryan Kehr
    Hi Ryan,
    thanks for your reply. DRV8302 has 2 gain steps, which is enough for me. DRV8301 could be used for the designer, who likes to control chips through commendos.
    Long
    Report Abuse
    • Reply
  • Kelly Meemken
    Posted by Kelly Meemken
    on May 04 2012 09:28 AM
    Intellectual435 points
    Will the DRV8301 come with example software to communcate with the motor over SPI?  Is it required to use the SPI interface to control the motor or is it just an additional feature that we can use if we choose?
    Report Abuse
    • Reply
  • Kelly Meemken
    on May 04 2012 09:36 AM
    Will the DRV8301 come with example code for the SPI interface?  If I order a DRV8301 is it neccessary to use the SPI interface to drive the motor or am I able to drive the motor without the SPI interface (like the DRV8302) but eventually use it later.
    Report Abuse
    • Reply
  • ChrisClearman
    Posted by ChrisClearman
    on May 07 2012 13:34 PM
    Mastermind22775 points
    The DRV8301-HC-C2-KIT comes with two example projects on Piccolo F28035. Both show how to set-up the DRV8301.
    There will be further commands/APIs offered later in the fall through some additional SW being released across MCU.
    Report Abuse
    • Reply
  • Richard Elmquist
    Posted by Richard Elmquist
    on Jun 12 2012 15:06 PM
    Genius10685 points
    Can the DRV8302-HC-C2-KIT be configured to use hall-effect sensors motors?
    Does the software work with these type motors or will one need additional software to control them?
    Is this the right part to use for demonstration of hall effect sensor motors?
    Thanks for your help!
    Richard Elmquist
    Report Abuse
    • Reply
  • ChrisClearman
    on Jun 12 2012 15:13 PM
    Yes it can
    Yes, it needs additional SW (I have an example project running on DRV8301, very similar if you are set on using DRV8302)
    Yes, certainly applicable for hall sensored motors if that's what you need to use.
    Report Abuse
    • Reply
  • Richard Elmquist
    on Jun 12 2012 15:15 PM
    Verified Answer
    Verified by Richard Elmquist
    Genius10685 points
    Thanks for your prompt response!
    Richard Elmquist
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
