• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Applications » Motor Drivers » Motor Drivers Forum » Will DRV8833 work for 4 12vDC brushed motors
Share
Motor Drivers
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Jerard Jose
Posted by Jerard Jose
on Nov 10 2011 14:23 PM
Prodigy10 points
Will be using 4 Brushed DC motors
12 vDC
Voltage operating range: 6 - 12 vdc
max current 269mA
It's a simple project, will DRV 8833 work, will I need 2 or only 1. Thanks for any help.
motor driver motor drivers DRV88xx d.c motor driver ic H-Bridge drv8833
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ryan Kehr
    Posted by Ryan Kehr
    on Nov 10 2011 14:35 PM
    Genius13785 points
    Jerard,
    The maximum operating on the DRV8833 is 10.8V, so 12V is going to be a problem.  If you can use a lower voltage, than 2 of the DRV8833 will work.  Do you need 6V on the lower range?
    We have a selection tool that can help you choose another device.  Unfortunately, 6V-12V operation is not available on the current portfolio so one of the voltage limits will have to move in order to find a part that will work.  Please see the link below that will take you directly to the BRUSHED selection guide:
    http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?family=analog&familyId=2007&uiTemplateId=NODE_STRY_PGE_T
    Ryan Kehr
    Motor Drive Application Manager
    Report Abuse
    • Reply
  • Jose Quinones
    Posted by Jose Quinones
    Verified Answer
    Verified by Ryan Kehr
    Expert7390 points
    Hi Jerard,
    The DRV8833 is designed to drive two DC motors. If you want to drive 4 motors, it may still be feasible as long as you sacrifice direction control. For example, you can connect the four motors' first lead to each one of the outputs and the second lead to GND. Then, when the respective output is HI, the motor moves in one direction and when the output is LO, then the motor stops. There is no way to control direction with this scheme.
    If you want to preserve direction control, then you will need two DRV8833 devices.
    Do note this device is rated to an input voltage no larger than 10.8V. So if you apply 12V, you will be outside of Abs Max ratings in which case there is no guarantee as to what will happen. Most likely the device will be adversely affected and will eventually be permanently damaged.
    Hope the info helps. Best regards,
    Jose Quinones
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
