• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Applications » Motor Drivers » Motor Drivers Forum » Configuration for PMSM motor control
Share
Motor Drivers
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Guilles Romain
Posted by Guilles Romain
on Apr 18 2012 08:32 AM
Prodigy90 points
I have to control a PMSM motor 200W with a sinusoidal control signal (FOC). So, I would like to know if the following configuration is the best :
µC : TMS320F28035PAG
EVM : Motor Control and PFC Developer's Kit
Software : ControlSUITE & Code Composer
Sensors : Halls and resolver
Control loop in position
Futhermore, I would like to know if I can do a simulation of my motor control with the digital motor control library (DMCLib).
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • ChrisClearman
    Posted by ChrisClearman
    on Apr 18 2012 21:48 PM
    Verified Answer
    Verified by Guilles Romain
    Mastermind23195 points
    What is the voltage?  I'm going to assume if 200W you are probably at 12 or 24V.  The HVMTR+PFC is 50-350V bus, 10A.  What I would suggest is the DRV8301-HC-C2-KIT.  This is up to 60V, 60A and also includes the F28035.
    The included projects with this kit are sensorless InstaSPIN-BLDC and sensorless FOC (sliding mode observer technique).  It does include a hall sensor interface if you need to go that route.  No sensored BLDC project, but there is on on the "baby brother" DRV8312-C2-KIT which you can migrate in very quickly.  Actually, I think I already have that if you end up needing it...
    There is not a resolver interface on any of the motor kits currently.  To date we have been using an external resolver board that connects over SPI.  But with Piccolo we have done some interesting work using the PWM and ADC and will release something shortly that will interest you.
    Report Abuse
    • Reply
  • Guilles Romain
    on Apr 19 2012 03:24 AM
    Prodigy90 points
    Thanks for replying quickly.
    In fact, I've just to implement a control motor, so I need a developement board to test it. Afterward, I've to put the Piccolo on my own drive board (IGBT). Is it possible to put the Piccolo on an other driver board ? My own driver board will be powered by 48v.
    Furthermore, I'd like to know if I can simulate my control motor with DMCLib like on Matlab/Simulink or do I need Matlab ?
    If so, is it possible to simulate a resolver ?
    Report Abuse
    • Reply
  • ChrisClearman
    on Apr 19 2012 17:30 PM
    Verified Answer
    Chris: of course
    Chris: to simulate your motor and the control interaction you need Simulink or VisSim
    Chris: I'd say it's possible to EMULATE a resolver feedback
    Report Abuse
    • Reply
  • Guilles Romain
    on Apr 23 2012 06:36 AM
    Prodigy90 points
    Thanks for reply,
    As I said before, I'm going to implement a control motor on the Piccolo MCU. Then, this MCU will be put in my own driver board and I would like to know the best way to integrate the Piccolo.
    Put only the Piccolo MCU or put de Piccolo controlCARD on my driver board ? What do you suggest ?
    Report Abuse
    • Reply
  • ChrisClearman
    on Apr 23 2012 18:22 PM
    straight to MCU would be my recommendation
    Report Abuse
    • Reply
  • Guilles Romain
    on Apr 25 2012 09:28 AM
    Prodigy90 points
    Finally, I'm going to buy the  DRV8312-C2-KIT and I just would like to know if there are hall sensors in the motor included in the package (NEMA17 55W Motor) ?
    Report Abuse
    • Reply
  • ChrisClearman
    on Apr 25 2012 10:17 AM
    yes, the motor has built in hall sensors and there is a sensored BLDC project example.
    Report Abuse
    • Reply
  • Guilles Romain
    on Apr 26 2012 06:58 AM
    Prodigy90 points
    Ok, where can I find the sensored BLDC projet ? in ControlSUITE ?
    Report Abuse
    • Reply
  • ChrisClearman
    on Apr 26 2012 23:44 PM
    it's part of the GUI as well as standalone here
    C:\ti\controlSUITE\development_kits\DRV8312-C2-KIT_v128\BLDC_Sensored
    Report Abuse
    • Reply
  • Guilles Romain
    on Apr 30 2012 09:23 AM
    Prodigy90 points
    I don't find the F28035 Piccolo controlCARD datasheet.
    Could you send it to me by mail or tell me where I can find it ?
    romain.guilles@akka.eu
    Report Abuse
    • Reply
  • ChrisClearman
    on Apr 30 2012 10:36 AM
    Verified Answer
    C:\ti\controlSUITE\development_kits\~controlCARDs\CC2803xHWdevPkg
    Report Abuse
    • Reply
  • Guilles Romain
    on May 11 2012 02:35 AM
    Prodigy90 points
    Unfortunetly, I can't buy the DRV8312-C2-KIT but I have the possibility to buy an other evalution board which is the DK-LM3S-DRV8312.
    I would like to know if with this board I can do everything like the DRV8312-C2-KIT to control a BLDC motor ?
    I suppose I couldn't use controlSUITE with DK-LMS-DRV8312 ?
    Report Abuse
    • Reply
  • Guilles Romain
    on May 11 2012 09:26 AM
    Prodigy90 points
    In fact, I think I'm going to buy the DK-LMS-DRV8312 Dev Kit and also the F28063 Piccolo controlCARD MCU to put on the Dev Kit ?
    Is that good ?
    Report Abuse
    • Reply
  • ChrisClearman
    on May 11 2012 09:35 AM
    Verified Answer
    the DRV8312 board is the same in both, and both controlCARDs will work (LM3S, F28035ISO, and F28069ISO)
    support for different projects are available through StellarisWare and controlSUITE
    Report Abuse
    • Reply
  • Guilles Romain
    on May 15 2012 09:23 AM
    Prodigy90 points
    Which board can I buy to connect a resolver to the DR8312 board by SPI ?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
