• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Applications » Motor Drivers » Motor Drivers Forum » Three Phase Motor Currents - Two Measured, One Calculated - Noise?
Share
Motor Drivers
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
  • Rowan Doherty
    Posted by Rowan Doherty
    on Aug 02 2012 00:37 AM
    Intellectual360 points
    Say I've got a motor drive system where two of the phase currents are measured, and the other is known because the motor is wired in star configuration and so the currents through each phase need to sum to zero.
    So I setup my hardware to measure Iu and Iw, but maybe my Clarke and Park transform software asks for Iu and Iv, so I calculate Iw from my two measured currents and feed Iu(measured) and Iv(calculated) into the software, and the transform works.
    But what happens when the measured signals are noisy (with both correlated noise appearing on Iu and Iw, and also random noise appearing on both channels)? Will the noise cancel out when applying the transform?
    e.g.
    Iu(measured) = Iu(real current) + Iu(noise)
    Iw(measured) = Iw(real current) + Iw(noise)
    Iv(calculated) = Iu(measured) - Iw(measured) = Iu(real current) + Iu(noise) - (Iw(real current) + Iw(noise))
    = Iu(real current) - Iw(real current) + Iu(noise) - Iw(noise)
    Are there any considerations to take into account with this type of setup? Is there an issue with calculating one current from the other two?
    clarke current noise park
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Matt Hein
    Posted by Matt Hein
    on Aug 02 2012 15:12 PM
    Intellectual860 points
    Rowan,
    My understanding of the subject was limited at best, so I consulted someone more knowledgeable.
    Dave told me that there was no difference functionally between using a calculated Iw or a measured Iw:
    Quoted from Dave (davewilson@ti.com):
    Assuming equal amounts of noise on all the phase current measurements, there will be no difference from a performance point of view than if you had measured Iu and Iv, and calculated Iw.  Whenever you have one phase which is reconstructed from the other two, that phase will see the noise from both other phases.  For correlated noise, they must be added algebraically.  For non-correlated noise, they must be added vectorally.
    Also, your customer made a mistake in his equations.  The calculated missing phase is always the algebraic sum of the NEGATIVE of the other two.  So, here is what the equations should look like:
    Iu(measured) = Iu + Iu(noise)
    Iw(measured) = Iw + Iw(noise)
    Iv(calculated) = -Iu(measured) – Iw(measured)  =  -Iu – Iu(noise) – Iw – Iw(noise)
    As you can see, the two noises are of the same polarity, which means the correlated portions add algegraically.
    Then we supply Iu(measured) and Iv(calculated) to our Clarke transform, which will attempt to recreate Iw.  But watch what happens:
    Iu(out) = Iu(measured) = Iu + Iu(noise)
    Iv(out) = Iv(calculated) = -Iu – Iu(noise) – Iw – Iw(noise)
    Iw(out) = -Iu(measured) – Iv(calculated) = -Iu – Iu(noise) +Iu +Iu(noise) +Iw +Iw(noise) = Iw + Iw(noise)
    So, there is no difference.  Two of the phases will have their measurement plus their noise, and the reconstructed phase will have the current plus the noise from both other phases.
    I hope this helps!
    Matt
    Report Abuse
    • Reply
  • Rowan Doherty
    on Aug 02 2012 19:33 PM
    Thanks for the correction. I didn't really check my equations for the calculated current, I was just trying to get the general point across.
    Matt Hein
    So this means that the 'reconstructed phase' with have twice as much noise, which is bad, right? But you say that there is no difference functionally.
    I think I may need to do some simulations to see exactly what happens.
    Report Abuse
    • Reply
  • Matt Hein
    Posted by Matt Hein
    on Aug 03 2012 08:25 AM
    Rowan,
    Based on the Clarke and Park transform equations, I think Dave is getting at the point that even if you had simply measured Iu and Iv from the outset, the transform software still relies on the fact that the missing phase is the algebraic sum of the negative of the other two phases. In this case, Iw sees the noise from both phases.
    So when you measure Iu and Iw to calculate Iv, Iv sees the noise from both phases. As long as you are not measuring all three, then one is going to be reconstructed.
    I completely agree that simulations would help shed some light on this problem.
    Matt
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
