We have a problem with DRV8301. Phase A and Phase C work properly but Phase B doen not switch. The fault pin stays high during this situation. What can be the reason of the fault?
Hi Murat,
Some common things to first check.
Can you verify that the issue happens on more than one board? This will help to rule out a soldering/manafacturing defect.
Are you driving a motor? If so, can you try another motor?\
Can you provide a schematic/layout for the DRV8301? Is there any difference between the half-bridges.
