Hi TI,
I'm planning to use the DVR8835 to drive an output configuration consisting of four independent resistive loads, each connected from a single Output pin to the common Ground reference (GND). Hence in this configuration, all four Output Bridges would operate independently - there is no load connected between a pair of Outputs (e.g. AOUT1 to AOUT2). The Data Sheet infers that this is a legal configuration with the state of each Output being independently set by its associated Input (with consideration for the MODE pin setting). Could you please confirm that this configuration is practical for use of the DRV8835? Many thanks for your assistance.
Colin Campbell
