I am using 4x DRV8711 connected to a single SPI bus to an MCU. Per typical fashion, the SCS/SDATI/SCLK are operated as push-pull IO's but the SDATO is open-drain which is a bit puzzling to me.
My assumption is that I can connect all four SDATO lines together, and use a single pull-up resistor. Will this cause any issue?
What is the specific rise/fall times that should be met in order to size this resistor (could be quite a bit of parasitic cap on SDATO)? How much current can the SDATO pins sink while driving the bus?
Thanks.
