Asking the solution to replace VID66
Other Parts Discussed in Thread: DRV8834, DRV8812
Hi Team,
do we have the alt. solution to replace VID6606?
VID6606 Spec.pdf
SHH
  • Hi SHH,
    There is no direct replacement. Four DRV8834 is the closest, but the microstep rate does not match.
    To match the microstep rate, a device with two separate VREF inputs is needed. A device like the DRV8881E or DRV8812 can be used, but the minimum operating voltage is higher.
