Part Number: DRA72XEVM
Hi there,
My application is supposed to stream 4 cameras simultaneously. But after few seconds of streaming, the Qt app exits unexpectedly throwing the following error:
MmRpc_use: Error: unable to declare buffer use
../git/libdce_linux.c:115: dce_buf_lock ERROR: Failed eError == DCE_EOK error val -5MmRpc_release: Error: unable to release buffer
../git/libdce_linux.c:145: dce_buf_unlock ERROR: Failed eError == DCE_EOK error val -5MmRpc_use: Error: unable to declare buffer use
../git/libdce_linux.c:115: dce_buf_lock ERROR: Failed eError == DCE_EOK error val -5MmRpc_use: Error: unable to declare buffer use
[ 1539.100785] rpmsg_rpc rpmsg-dce: unwinding UVA to RDA translations! translation = 1
[ 1539.140317] rpmsg_rpc rpmsg-dce: failed to translate all pointers for remote core!
../git/libdce_linux.c:115:d ce_buf_lock ERROR: Failed eError == DE_EOK error val -5MmRpc_call: Error: write failed
QObject::~QObject: Timers cannot be stopped from another thread
../git/libdce.c:965: process ERROR: Failed eError == DCE_EOK error val -5root@dra7xx-evm:~/ITS_HMI_Resltn_1920# [ 1597.783268] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
Is it because ducatidecoder instances which my application needs is 4 but only 2 can be created at a time. If so what can be the solution to this??
