I'm working on TDA2x.The VisionSDK is from TI,and it's version is V 02.10.00.
Now,i'm want to communicate with other devices with DCAN.Can anyone share an example or any experience?
Very thanks.
Lin.
Very thanks.
Lin.
There are couple of Starterware example @ starterware_<version>\examples\dcan\. Kindly have a look at it. The details of the example is given in the Starterware userguide present @ starterware_<version>\docs\StarterWare_UserGuide.pdf
In case if you want to understand how it can be integrated with vision_sdk please look at
vision_sdk/examples/tda2xx/src/modules/dcan
By enabling DCAN_INCLUDE through Rules.make it enables loop back test while vision_sdk is running, that ensures IP is enabled correctly and working fine. You also have an option of defining ENABLE_B2B_DCAN_TEST in vision_sdk/examples/tda2xx/src/modules/dcan/system_dcan.c.
