Part Number: TDA3
TDA3 data sheet is defined PHA and POL in QSPI. However there are no register to set them in TRM.
Which registers should I set them?
Kenshow
Just a little clarification;
CKPHx = clock phase
CKPx = clock polarity
where x is chip-select number
You can also set the Chip Select polarity and Data Delay for chip select x.
Stan
Hi Kenshow,
You are correct. I will file a ticket to DM support so they can fix it (move PHA=0/1 to CLK).
Thanks and regards,
Stan
