I'm trying the null src + decode + display use case on A15 + linux.
I am using the test files from e2e.ti.com/.../1018.1280x720_5F00_00.zip as suggested by you.
So I had to edit the use case to change the resolution to 1280x720 and also the path of the input files in apps/src/hlos/adas/src/usecases/null_src_decode_display/chains_nullSrc_Display.c:
#define ENCDEC_MAX_FRAME_WIDTH (1280)
#define ENCDEC_MAX_FRAME_HEIGHT (720)
strncpy(pPrm->channelParams[chId].nameDataFile, "/opt/vision_sdk/1280x720_00.h264", 260);
strncpy(pPrm->channelParams[chId].nameIndexFile, "/opt/vision_sdk/1280x720_00.hdr", 260);
I recompiled, reflashed the filesystem on sd card and ran the use case again but I get the following assertion:
ASSERT (nullSrcLink_tsk.c|NullSrcLink_fillData|202)
Apparently the frame length read from the header file is 0. I have checked that both files are present at the specified location above and the index file doesn't contain zeros.
Attaching the full log file here:
root@dra7xx-evm:/opt/vision_sdk# ./vision_sdk_load.sh [ 116.563853] DMA: Module install successful, device major num = 243 [ 116.570196] DRV: Module install successful [ 116.585238] CMEMK module: reference Linux version 4.4.84 [ 116.591289] cmemk initialized ./disableDssInterruptsOnA15.sh: line 11: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 12: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 13: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 14: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 15: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 16: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 17: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 18: @0x4A002AC4:: command not found ./disableDssInterruptsOnA15.sh: line 19: @0x4A002AC4:: command not found updated 0x4A002AC4 value is 00930000 root@dra7xx-evm:/opt/vision_sdk# ./apps.out [HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb69aa000 of size 0x00100000 [HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa6faa000 of size 0x0fa00000 [HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa6eea000 of size 0x00040000 [HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa6f2a000 of size 0x00080000 [HOST] OSA: MEM: 4: Mapped 0xa0440000 to 0xa6cea000 of size 0x00200000 [HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140 [HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0 [HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280 [HOST] OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20 [HOST] OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0 [HOST] OSA: EVE3 Remote Log Shared Memory @ 0xa0314c60 [HOST] OSA: EVE4 Remote Log Shared Memory @ 0xa033c500 [HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0 [HOST] [HOST ] 127.429207 s: SYSTEM: System A15 Init in progress !!! [HOST] [HOST ] 127.429329 s: SYSTEM: IPC: Init in progress !!! [HOST] [HOST ] 127.429329 s: SYSTEM: IPC: Notify init in progress !!! [HOST] [HOST ] 127.430763 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81) [HOST] [HOST ] 127.430793 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 127.430824 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80) [HOST] [HOST ] 127.430854 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 127.432044 s: SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81) [HOST] [HOST ] 127.432044 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 127.432074 s: SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80) [HOST] [HOST ] 127.432105 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 127.433203 s: SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81) [HOST] [HOST ] 127.433233 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 127.433264 s: SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80) [HOST] [HOST ] 127.433264 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 127.433447 s: SYSTEM: IPC: Notify init DONE !!! [HOST] [HOST ] 127.433447 s: SYSTEM: MSGQ: MsgQ init in progress !!! [HOST] [HOST ] 127.433569 s: SYSTEM: MSGQ: MsgQ init DONE !!! [HOST] [HOST ] 127.433569 s: SYSTEM: IPC: Init DONE !!! [HOST] [HOST ] 127.433599 s: SYSTEM: Initializing A15 Links !!! [HOST] [HOST ] 127.433721 s: IPC_OUT_0 : Init done - linkid-0x2000000 [HOST] [HOST ] 127.433843 s: IPC_OUT_1 : Init done - linkid-0x2000001 [HOST] [HOST ] 127.433965 s: IPC_OUT_2 : Init done - linkid-0x2000002 [HOST] [HOST ] 127.434087 s: IPC_OUT_3 : Init done - linkid-0x2000003 [HOST] [HOST ] 127.434209 s: IPC_OUT_4 : Init done - linkid-0x2000004 [HOST] [HOST ] 127.434331 s: IPC_IN_0 : Init done - linkid-0x200000a [HOST] [HOST ] 127.434453 s: IPC_IN_1 : Init done - linkid-0x200000b [HOST] [HOST ] 127.434606 s: IPC_IN_2 : Init done - linkid-0x200000c [HOST] [HOST ] 127.434728 s: IPC_IN_3 : Init done - linkid-0x200000d [HOST] [HOST ] 127.434880 s: IPC_IN_4 : Init done - linkid-0x200000e [HOST] [HOST ] 127.435002 s: IPC_IN_5 : Init done - linkid-0x200000f [HOST] [HOST ] 127.435124 s: IPC_IN_6 : Init done - linkid-0x2000010 [HOST] [HOST ] 127.435277 s: NULL_0 : Init done - linkid-0x2000014 [HOST] [HOST ] 127.435368 s: NULL_1 : Init done - linkid-0x2000015 [HOST] [HOST ] 127.435551 s: NULL_SRC_0 : Init done - linkid-0x2000039 [HOST] [HOST ] 127.435673 s: SGX3DSRV_0 : Init done - linkid-0x2000041 [HOST] [HOST ] 127.435887 s: ALGORITHM_0 : Init done - linkid-0x2000031 [HOST] [HOST ] 127.436009 s: ALGORITHM_1 : Init done - linkid-0x2000032 [ 119.994102] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable) [ 120.010387] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable) [HOST] [HOST ] 127.436253 s: ALGORITHM_3 : Init done - likid-0x2000034 VX_ZONE_INIT:Enabled VX_ZONE_ERROR:Enabled VX_ZONE_WARNING:Enabled [HOST] [HOST ] 127.436375 s: ALGORITHM_4 : Init done - linkid-0x2000035 [HOST] [HOST ] 127.436497 s: ALGORITHM_5 : Init done - linkid-0x2000036 [HOST] [HOST ] 127.436619 s: ALGORITHM_6 : Init done - linkid-0x2000037 [HOST] [HOST ] 127.436741 s: ALGORITHM_7 : Init done - linkid-0x2000038 [HOST] [HOST ] 127.436924 s: DUP0 : Init done - linkid-0x0 [HOST] [HOST ] 127.437137 s: DUP1 : Init done - linkid-0x0 [HOST] [HOST ] 127.437381 s: DUP2 : Init done - linkid-0x0 [HOST] [HOST ] 127.437625 s: DUP3 : Init done - linkid-0x0 [HOST] [HOST ] 127.437839 s: DUP4 : Init done - linkid-0x0 [HOST] [HOST ] 127.437991 s: SYNC_0 : Init done - linkid-0x0 [HOST] [HOST ] 127.438144 s: SYNC_1 : Init done - linkid-0x0 [HOST] [HOST ] 127.438327 s: SYNC_2 : Init done - linkid-0x0 [HOST] [HOST ] 127.438479 s: SYNC_3 : Init done - linkid-0x0 [HOST] [HOST ] 127.438693 s: MERGE_0 : Init done - linkid-0x0 [HOST] [HOST ] 127.438876 s: MERGE_1 : Init done - linkid-0x0 [HOST] [HOST ] 127.439059 s: MERGE_2 : Init done - linkid-0x0 [HOST] [HOST ] 127.439211 s: MERGE_3 : Init done - linkid-0x0 [HOST] [HOST ] 127.439394 s: MERGE_4 : Init done - linkid-0x0 [HOST] [HOST ] 127.439760 s: SELECT_0 : Init done - linkid-0x0 [HOST] [HOST ] 127.439913 s: SELECT_1 : Init done - linkid-0x0 [HOST] [HOST ] 127.440065 s: GATE_0 : Init done - linkid-0x0 [HOST] [HOST ] 127.440187 s: GATE_1 : Init done - linkid-0x0 [HOST] [HOST ] 127.440340 s: GATE_2 : Init done - linkid-0x0 [HOST] [HOST ] 127.440492 s: GATE_3 : Init done - linkid-0x0 [HOST] [HOST ] 127.440645 s: SGXFRMCPY_0 : Init done - linkid-0x2000040 [HOST] [HOST ] 127.440828 s: SGX3DSFM_0 : Init done - linkid-0x2000042 [HOST] [HOST ] 127.440828 s: SYSTEM: Initializing A15 Links ... DONE !!! [HOST] [HOST ] 127.441804 s: OSA: Adjusting global time, timeH by 0 units!!! [HOST] [DSP1 ] 17.085615 s: ***** DSP1 Firmware build time 12:59:25 Jan 10 2018 [HOST] [DSP1 ] 17.085707 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz> [HOST] [DSP1 ] 17.085951 s: SYSTEM: System Common Init in progress !!! [HOST] [DSP1 ] 17.086195 s: UTILS: CIO: Init Done !!! [HOST] [DSP1 ] 17.086225 s: SYSTEM: IPC init in progress !!! [HOST] [DSP1 ] 17.086256 s: SYSTEM: Attaching to [IPU2] ... [HOST] [DSP1 ] 17.089123 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [DSP1 ] 17.356829 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [DSP1 ] 17.377112 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [DSP1 ] 17.397090 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [DSP1 ] 17.417129 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [DSP1 ] 17.437076 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [DSP1 ] 17.437107 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [DSP1 ] 17.437168 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [DSP1 ] 17.437229 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [DSP1 ] 17.437259 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [DSP1 ] 17.437320 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [DSP1 ] 17.437351 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [DSP1 ] 17.437412 s: SYSTEM: Notify init done !!! [HOST] [DSP1 ] 17.437564 s: SYSTEM: MsgQ init done !!! [HOST] [DSP1 ] 17.437656 s: RpmsgInit in progress... [HOST] [DSP1 ] 17.437686 s: Connection established with HLOS, calling rpmsgInit [HOST] [DSP1 ] 17.437930 s: SYSTEM: IPC init DONE !!! [HOST] [DSP1 ] 17.438601 s: SYSTEM: Initializing TIOVX ... [HOST] [DSP1 ] 17.438662 s: VX_ZONE_INIT:Enabled [HOST] [DSP1 ] 17.438723 s: VX_ZONE_ERROR:Enabled [HOST] [DSP1 ] 17.438784 s: VX_ZONE_WARNING:Enabled [HOST] [DSP1 ] 17.439120 s: VX_ZONE_INIT:[tivxReserveC66xL2MEM:361] BAM memory config: IBUF 180224 bytes @ 0x00800000, WBUF 45056 bytes [HOST] [DSP1 ] 17.439455 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [DSP1 ] 17.439486 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [DSP1 ] 17.439516 s: SYSTEM: System Common Init Done !!! [HOST] [DSP1 ] 17.439516 s: SYSTEM: System DSP Init in progress !!! [HOST] [DSP1 ] 17.439791 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [DSP1 ] 17.439852 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221) [HOST] [DSP1 ] 17.439882 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516176 B (504) [HOST] [DSP1 ] 17.439913 s: SYSTEM: Initializing Links !!! [HOST] [DSP1 ] 17.448758 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [DSP1 ] 17.448789 s: lz4CompDecomp Init [HOST] [DSP1 ] 17.448819 s: SYSTEM: System DSP Init Done !!! [HOST] [DSP1 ] 17.783718 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [HOST] [DSP1 ] 17.783779 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [HOST] [DSP2 ] 17.352406 s: ***** DSP2 Firmware build time 12:59:24 Jan 10 2018 [HOST] [DSP2 ] 17.352467 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz> [HOST] [DSP2 ] 17.352711 s: SYSTEM: System Common Init in progress !!! [HOST] [DSP2 ] 17.352955 s: UTILS: CIO: Init Done !!! [HOST] [DSP2 ] 17.353016 s: SYSTEM: IPC init in progress !!! [HOST] [DSP2 ] 17.353016 s: SYSTEM: Attaching to [IPU2] ... [HOST] [DSP2 ] 17.354907 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [DSP2 ] 17.356829 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [DSP2 ] 17.386994 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [DSP2 ] 17.406972 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [DSP2 ] 17.426981 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [DSP2 ] 17.447020 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [DSP2 ] 17.447050 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [DSP2 ] 17.447111 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [DSP2 ] 17.447172 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [DSP2 ] 17.447203 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [DSP2 ] 17.447264 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [DSP2 ] 17.447294 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [DSP2 ] 17.447325 s: SYSTEM: Notify init done !!! [HOST] [DSP2 ] 17.447508 s: SYSTEM: MsgQ init done !!! [HOST] [DSP2 ] 17.447599 s: RpmsgInit in progress... [HOST] [DSP2 ] 17.447630 s: Connection established with HLOS, calling rpmsgInit [HOST] [DSP2 ] 17.447874 s: SYSTEM: IPC init DONE !!! [HOST] [DSP2 ] 17.448575 s: SYSTEM: Initializing TIOVX ... [HOST] [DSP2 ] 17.448636 s: VX_ZONE_INIT:Enabled [HOST] [DSP2 ] 17.448667 s: VX_ZONE_ERROR:Enabled [HOST] [DSP2 ] 17.448697 s: VX_ZONE_WARNING:Enabled [HOST] [DSP2 ] 17.449063 s: VX_ZONE_INIT:[tivxReserveC66xL2MEM:361] BAM memory config: IBUF 180224 bytes @ 0x00800000, WBUF 45056 bytes [HOST] [DSP2 ] 17.449429 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [DSP2 ] 17.449460 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [DSP2 ] 17.449460 s: SYSTEM: System Common Init Done !!! [HOST] [DSP2 ] 17.449490 s: SYSTEM: System DSP Init in progress !!! [HOST] [DSP2 ] 17.449765 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [DSP2 ] 17.449795 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221) [HOST] [DSP2 ] 17.449856 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516176 B (504) [HOST] [DSP2 ] 17.449887 s: SYSTEM: Initializing Links !!! [HOST] [DSP2 ] 17.458762 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [DSP2 ] 17.458823 s: lz4CompDecomp Init [HOST] [DSP2 ] 17.458823 s: SYSTEM: System DSP Init Done !!! [HOST] [DSP2 ] 17.785731 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [HOST] [DSP2 ] 17.785762 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [HOST] [EVE1 ] 16.990697 s: ***** EVE Firmware build time 12:57:40 Jan 10 2018 [HOST] [EVE1 ] 16.992435 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE1 ] 16.995241 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE1 ] 16.997498 s: UTILS: CIO: Init Done !!! [HOST] [EVE1 ] 16.998413 s: SYSTEM: IPC init in progress !!! [HOST] [EVE1 ] 16.999328 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE1 ] 17.367382 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE1 ] 17.377112 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE1 ] 17.386994 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE1 ] 17.427164 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [EVE1 ] 17.457176 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [EVE1 ] 17.477154 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [EVE1 ] 17.478252 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE1 ] 17.479503 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE1 ] 17.480784 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE1 ] 17.482004 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [EVE1 ] 17.483255 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [EVE1 ] 17.484536 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [EVE1 ] 17.485786 s: SYSTEM: Notify init done !!! [HOST] [EVE1 ] 17.487525 s: SYSTEM: MsgQ init done !!! [HOST] [EVE1 ] 17.488379 s: SYSTEM: IPC init DONE !!! [HOST] [EVE1 ] 17.500976 s: SYSTEM: Initializing TIOVX ... [HOST] [EVE1 ] 17.502409 s: VX_ZONE_INIT:Enabled [HOST] [EVE1 ] 17.503782 s: VX_ZONE_ERROR:Enabled [HOST] [EVE1 ] 17.505246 s: VX_ZONE_WARNING:Enabled [HOST] [EVE1 ] 17.508814 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [EVE1 ] 17.509882 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [EVE1 ] 17.510827 s: SYSTEM: System Common Init Done !!! [HOST] [EVE1 ] 17.511773 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE1 ] 17.513145 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE1 ] 17.514274 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE1 ] 17.515494 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE1 ] 17.517751 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248) [HOST] [EVE1 ] 17.519886 s: SYSTEM: Initializing Links !!! [HOST] [EVE1 ] 17.604678 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE1 ] 17.605715 s: SYSTEM: System EVE Init Done !!! [HOST] [EVE2 ] 16.990941 s: ***** EVE Firmware build time 12:57:39 Jan 10 2018 [HOST] [EVE2 ] 16.992710 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE2 ] 16.995699 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE2 ] 16.997803 s: UTILS: CIO: Init Done !!! [HOST] [EVE2 ] 16.998779 s: SYSTEM: IPC init in progress !!! [HOST] [EVE2 ] 16.999755 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE2 ] 17.387451 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE2 ] 17.397090 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE2 ] 17.406972 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE2 ] 17.427164 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [EVE2 ] 17.477002 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [EVE2 ] 17.496980 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [EVE2 ] 17.498047 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE2 ] 17.499328 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE2 ] 17.500640 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE2 ] 17.501921 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [EVE2 ] 17.503233 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [EVE2 ] 17.504544 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [EVE2 ] 17.505917 s: SYSTEM: Notify init done !!! [HOST] [EVE2 ] 17.507716 s: SYSTEM: MsgQ init done !!! [HOST] [EVE2 ] 17.508601 s: SYSTEM: IPC init DONE !!! [HOST] [EVE2 ] 17.521503 s: SYSTEM: Initializing TIOVX ... [HOST] [EVE2 ] 17.523058 s: VX_ZONE_INIT:Enabled [HOST] [EVE2 ] 17.524522 s: VX_ZONE_ERROR:Enabled [HOST] [EVE2 ] 17.526078 s: VX_ZONE_WARNING:Enabled [HOST] [EVE2 ] 17.530073 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [EVE2 ] 17.531171 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [EVE2 ] 17.532147 s: SYSTEM: System Common Init Done !!! [HOST] [EVE2 ] 17.533123 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE2 ] 17.534526 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE2 ] 17.535716 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE2 ] 17.537027 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE2 ] 17.539193 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248) [HOST] [EVE2 ] 17.541298 s: SYSTEM: Initializing Links !!! [HOST] [EVE2 ] 17.626334 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE2 ] 17.627340 s: SYSTEM: System EVE Init Done !!! [HOST] [EVE3 ] 16.991032 s: ***** EVE Firmware build time 12:57:39 Jan 10 2018 [HOST] [EVE3 ] 16.992771 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE3 ] 16.995760 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE3 ] 16.997834 s: UTILS: CIO: Init Done !!! [HOST] [EVE3 ] 16.998810 s: SYSTEM: IPC init in progress !!! [HOST] [EVE3 ] 16.999786 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE3 ] 17.407430 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE3 ] 17.417129 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE3 ] 17.426981 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE3 ] 17.457176 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [EVE3 ] 17.477002 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [EVE3 ] 17.516988 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [EVE3 ] 17.518056 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE3 ] 17.519429 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE3 ] 17.520801 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE3 ] 17.522235 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [EVE3 ] 17.523638 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [EVE3 ] 17.525010 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [EVE3 ] 17.526444 s: SYSTEM: Notify init done !!! [HOST] [EVE3 ] 17.528426 s: SYSTEM: MsgQ init done !!! [HOST] [EVE3 ] 17.529341 s: SYSTEM: IPC init DONE !!! [HOST] [EVE3 ] 17.542426 s: SYSTEM: Initializing TIOVX ... [HOST] [EVE3 ] 17.543951 s: VX_ZONE_INIT:Enabled [HOST] [EVE3 ] 17.545385 s: VX_ZONE_ERROR:Enabled [HOST] [EVE3 ] 17.546971 s: VX_ZONE_WARNING:Enabled [HOST] [EVE3 ] 17.550692 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [EVE3 ] 17.551759 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [EVE3 ] 17.552766 s: SYSTEM: System Common Init Done !!! [HOST] [EVE3 ] 17.553711 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE3 ] 17.555175 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE3 ] 17.556396 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE3 ] 17.557677 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE3 ] 17.559903 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248) [HOST] [EVE3 ] 17.562008 s: SYSTEM: Initializing Links !!! [HOST] [EVE3 ] 17.645305 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE3 ] 17.646403 s: SYSTEM: System EVE Init Done !!! [HOST] [EVE4 ] 16.991124 s: ***** EVE Firmware build time 12:57:41 Jan 10 2018 [HOST] [EVE4 ] 16.992862 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE4 ] 16.995851 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE4 ] 16.997925 s: UTILS: CIO: Init Done !!! [HOST] [EVE4 ] 16.998871 s: SYSTEM: IPC init in progress !!! [HOST] [EVE4 ] 16.999847 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE4 ] 17.427438 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE4 ] 17.437076 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE4 ] 17.447020 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE4 ] 17.477154 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [EVE4 ] 17.496980 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [EVE4 ] 17.516988 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [EVE4 ] 17.518056 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE4 ] 17.519429 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE4 ] 17.520801 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE4 ] 17.522204 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [EVE4 ] 17.523607 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [EVE4 ] 17.524949 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [EVE4 ] 17.526383 s: SYSTEM: Notify init done !!! [HOST] [EVE4 ] 17.528609 s: SYSTEM: MsgQ init done !!! [HOST] [EVE4 ] 17.529524 s: SYSTEM: IPC init DONE !!! [HOST] [EVE4 ] 17.542609 s: SYSTEM: Initializing TIOVX ... [HOST] [EVE4 ] 17.544134 s: VX_ZONE_INIT:Enabled [HOST] [EVE4 ] 17.545629 s: VX_ZONE_ERROR:Enabled [HOST] [EVE4 ] 17.547184 s: VX_ZONE_WARNING:Enabled [HOST] [EVE4 ] 17.550905 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [EVE4 ] 17.551973 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [EVE4 ] 17.552979 s: SYSTEM: System Common Init Done !!! [HOST] [EVE4 ] 17.553925 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE4 ] 17.555389 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE4 ] 17.556670 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE4 ] 17.557921 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE4 ] 17.560147 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248) [HOST] [EVE4 ] 17.562252 s: SYSTEM: Initializing Links !!! [HOST] [EVE4 ] 17.645671 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE4 ] 17.646739 s: SYSTEM: System EVE Init Done !!! [HOST] [IPU2 ] 16.858476 s: [HOST] [IPU2 ] EVE1 Image Load Completed [HOST] [IPU2 ] 16.897395 s: [HOST] [IPU2 ] EVE2 Image Load Completed [HOST] [IPU2 ] 16.935887 s: [HOST] [IPU2 ] EVE3 Image Load Completed [HOST] [IPU2 ] 16.974013 s: [HOST] [IPU2 ] EVE4 Image Load Completed [HOST] [IPU2 ] 16.974135 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 16.974196 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 16.974287 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 16.974379 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 16.974440 s: ***** IPU2 Firmware build time 17:05:29 Jan 19 2018 [HOST] [IPU2 ] 16.974592 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [HOST] [IPU2 ] 16.977886 s: SYSTEM: System Common Init in progress !!! [HOST] [IPU2 ] 16.988836 s: UTILS: CIO: Init Done !!! [HOST] [IPU2 ] 16.988958 s: SYSTEM: IPC init in progress !!! [HOST] [IPU2 ] 16.989019 s: SYSTEM: Attaching to [DSP1] ... [HOST] [IPU2 ] 17.089123 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [IPU2 ] 17.354907 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [IPU2 ] 17.367382 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [IPU2 ] 17.387451 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [IPU2 ] 17.407430 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [IPU2 ] 17.427438 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [IPU2 ] 17.427560 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [IPU2 ] 17.427713 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [IPU2 ] 17.427835 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [IPU2 ] 17.427957 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [IPU2 ] 17.428079 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [IPU2 ] 17.428201 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [IPU2 ] 17.428353 s: SYSTEM: Notify init done !!! [HOST] [IPU2 ] 17.430061 s: SYSTEM: MsgQ init done !!! [HOST] [IPU2 ] 17.431007 s: RpmsgInit in progress... [HOST] [IPU2 ] 17.431098 s: Connection established with HLOS, calling rpmsgInit [HOST] [IPU2 ] 17.431739 s: SYSTEM: IPC init DONE !!! [HOST] [IPU2 ] 17.436893 s: SYSTEM: Initializing TIOVX ... [HOST] [IPU2 ] 17.437076 s: VX_ZONE_INIT:Enabled [HOST] [IPU2 ] 17.437198 s: VX_ZONE_ERROR:Enabled [HOST] [IPU2 ] 17.437351 s: VX_ZONE_WARNING:Enabled [HOST] [IPU2 ] 17.441011 s: VX_ZONE_INIT:[tivxInit:48] Initialization Done !!! [HOST] [IPU2 ] 17.441102 s: SYSTEM: Initializing TIOVX ... Done !!! [HOST] [IPU2 ] 17.441163 s: SYSTEM: System Common Init Done !!! [HOST] [IPU2 ] 17.441285 s: SYSTEM: System Init in progress !!! [HOST] [IPU2 ] 17.441346 s: SYSTEM: BSP Common Init in progress !!! [HOST] [IPU2 ] 17.441407 s: SYSTEM: BSP Common Init Done !!! [HOST] [IPU2 ] 17.441468 s: SYSTEM: BSP Platform Init in progress !!! [HOST] [IPU2 ] 17.443329 s: SYSTEM: BSP Platform Init Done !!! [HOST] [IPU2 ] 17.443390 s: SYSTEM: FVID2 Init in progress !!! [HOST] [IPU2 ] 17.443542 s: SYSTEM: FVID2 Init Done !!! [HOST] [IPU2 ] 17.443603 s: SYSTEM: VPS Init in progress !!! [HOST] [IPU2 ] 17.443664 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000] [HOST] [IPU2 ] 17.446837 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 17.446959 s: VPDMA Firmware Address = 0xa035ba40 [HOST] [IPU2 ] 17.447020 s: VPDMA Load Address = 0x4897d004 [HOST] [IPU2 ] 17.447142 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 17.447264 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 17.447355 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 17.447721 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 17.447782 s: VPDMA Firmware Address = 0xa035ba40 [HOST] [IPU2 ] 17.447874 s: VPDMA Load Address = 0x4899d004 [HOST] [IPU2 ] 17.447996 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 17.448057 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 17.448148 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 17.448514 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 17.448606 s: VPDMA Firmware Address = 0xa035ba40 [HOST] [IPU2 ] 17.448697 s: VPDMA Load Address = 0x489bd004 [HOST] [IPU2 ] 17.448789 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 17.448880 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 17.448941 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 17.449307 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 17.449399 s: VPDMA Firmware Address = 0xa035ba40 [HOST] [IPU2 ] 17.449490 s: VPDMA Load Address = 0x489dd004 [HOST] [IPU2 ] 17.449582 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 17.449673 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 17.449734 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 17.509851 s: SYSTEM: VPS Init Done !!! [HOST] [IPU2 ] 17.510766 s: UTILS: DMA: HWI Create for INT25 !!! [HOST] [IPU2 ] 17.511010 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [IPU2 ] 17.511132 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 253744 B (247) [HOST] [IPU2 ] 17.511346 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU2 ] 17.511498 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 262144000 ) [HOST] [IPU2 ] 17.511681 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 851840 B (0 MB) [HOST] [IPU2 ] 17.511834 s: SYSTEM: Initializing Links !!! [HOST] [IPU2 ] 17.775391 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [IPU2 ] 17.855944 s: CHAINS: Application Started !!! [HOST] [IPU2 ] 17.866192 s: BOARD: Board Init in progress !!! [HOST] [IPU2 ] 17.866711 s: BOARD: Board Init Done !!! [HOST] [IPU2 ] 17.874489 s: [HOST] [HOST ] 127.790855 s: SYSTEM: System A15 Init Done !!! [HOST] [HOST ] 127.790977 s: NETWORK_CTRL: Starting Server (port=5000) !!! [HOST] [HOST ] 127.791038 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [HOST] [HOST ] 128.318184 s: [HOST] [HOST ] [HOST] [HOST ] ==================== [HOST] [HOST ] Vision SDK Usecases [HOST] [HOST ] ==================== [HOST] [HOST ] 1: Single Camera Usecases [HOST] [HOST ] 2: Multi-Camera LVDS Usecases [HOST] [HOST ] 3: Open-Compute Usecases [HOST] [HOST ] [HOST] [HOST ] p: CPU Status [HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB) [HOST] [HOST ] [HOST] [HOST ] s: System Settings [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 1 [HOST] [HOST ] 132.204386 s: [HOST] [HOST ] [HOST] [HOST ] Single Camera Usecases [HOST] [HOST ] ------------------------ [HOST] [HOST ] 1: 1CH VIP capture + SGX Copy + DISPLAY [HOST] [HOST ] 2: 1CH VIP capture + Encode + Decode + SGX Copy + DISPLAY [HOST] [HOST ] 3: 1CH VIP capture + Alg FrameCopy (EVE1) + SGX Copy + DISPLAY - (TDA2xx ONLY) [HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported) [HOST] [HOST ] 6: 1CH VIP capture + Alg Frame Copy (A15) + SGX Copy + DISPLAY [HOST] [HOST ] 7: 1CH VIP + Alg Frame Copy (A15) + Connetor Links (Dup, Merge, Select, Gate on A15) + SGX Copy + DISPLAY [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] [HOST] [HOST ] 132.204416 s: [HOST] [HOST ] 132.204447 s: Unsupported option ' [HOST] [HOST ] '. Please try again [HOST] [HOST ] 132.204447 s: [HOST] [HOST ] [HOST] [HOST ] Single Camera Usecases [HOST] [HOST ] ------------------------ [HOST] [HOST ] 1: 1CH VIP capture + SGX Copy + DISPLAY [HOST] [HOST ] 2: 1CH VIP capture + Encode + Decode + SGX Copy + DISPLAY [HOST] [HOST ] 3: 1CH VIP capture + Alg FrameCopy (EVE1) + SGX Copy + DISPLAY - (TDA2xx ONLY) [HOST] [HOST ] 5: NullSrc + Decode + Display (Only 1920x1080 H264/MJPEG Video Input Bit-Stream Supported) [HOST] [HOST ] 6: 1CH VIP capture + Alg Frame Copy (A15) + SGX Copy + DISPLAY [HOST] [HOST ] 7: 1CH VIP + Alg Frame Copy (A15) + Connetor Links (Dup, Merge, Select, Gate on A15) + SGX Copy + DISPLAY [HOST] [HOST ] [HOST] [HOST ] x: Exit [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 5 [HOST] [HOST ] 133.299640 s: [HOST] [HOST ] 133.299640 s: [HOST] [HOST ] [HOST] [HOST ] ========================================= [HOST] [HOST ] Chains Run-time Codec Type Selection Menu [HOST] [HOST ] ========================================= [HOST] [HOST ] [HOST] [HOST ] Enter '0' for MJPEG [HOST] [HOST ] [HOST] [HOST ] Enter '1' for H.264 [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] 1 [HOST] [HOST ] 135.572164 s: IPC_OUT_0 : Create in progress !!! [HOST] [HOST ] 135.572225 s: IPC_OUT_0 : Create Done !!! [HOST] [IPU2 ] 135.572378 s: IPC_IN_0 : Create in progress !!! [HOST] [IPU2 ] 135.573598 s: IPC_IN_0 : Create Done !!! [HOST] [IPU2 ] 135.573994 s: DECODE: Create in progress ... !!! [HOST] [IPU2 ] 135.799335 s: DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ... [HOST] [IPU2 ] 135.800189 s: DECODE: All CH Create ... DONE !!! [HOST] [IPU2 ] 135.802080 s: DECODE: Create ... DONE !!! [HOST] [IPU2 ] 135.802568 s: VPE: Create in progress !!! [HOST] [IPU2 ] 135.945830 s: VPE: Loading Down-scaling Co-effs [HOST] [IPU2 ] 135.946074 s: VPE: Co-effs Loading ... DONE !!! [HOST] [IPU2 ] 135.946318 s: VPE: Create Done !!! [HOST] [IPU2 ] 135.946715 s: DISPLAY: Create in progress !!! [HOST] [IPU2 ] 135.947294 s: DISPLAY: Create Done !!! [HOST] [DSP1 ] 136.048099 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [DSP1 ] 136.048130 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221) [HOST] [DSP1 ] 136.048191 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516016 B (503) [HOST] [DSP2 ] 136.048404 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [DSP2 ] 136.048435 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221) [HOST] [DSP2 ] 136.048465 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516016 B (503) [HOST] [EVE1 ] 136.048984 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE1 ] 136.049350 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE1 ] 136.049899 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248) [HOST] [EVE2 ] 136.050905 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE2 ] 136.051210 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE2 ] 136.051759 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248) [HOST] [EVE3 ] 136.052766 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE3 ] 136.053040 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE3 ] 136.053589 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248) [HOST] [EVE4 ] 136.054596 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE4 ] 136.054901 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE4 ] 136.055419 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254160 B (248) [HOST] [IPU2 ] 136.056243 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [IPU2 ] 136.056396 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 247936 B (242) [HOST] [IPU2 ] 136.056579 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU2 ] 136.056731 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 262144000 B (250 MB), Free size = 233523200 ) [HOST] [HOST ] 136.060940 s: [HOST] [HOST ] [HOST] [HOST ] ==================== [HOST] [HOST ] Chains Run-time Menu [HOST] [HOST ] ==================== [HOST] [HOST ] [HOST] [HOST ] 0: Stop Chain [HOST] [HOST ] [HOST] [HOST ] p: Print Performance Statistics [HOST] [HOST ] [HOST] [HOST ] Enter Choice: [HOST] [HOST ] [HOST] [IPU2 ] 136.056914 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 851840 B (0 MB) [HOST] [IPU2 ] 136.057341 s: DISPLAY: Start in progress !!! [HOST] [IPU2 ] 136.057402 s: DISPLAY: Start Done !!! ASSERT (nullSrcLink_tsk.c|NullSrcLink_fillData|202)
Kindly help me out with this issue.
Bhargav
