I want to run existing EVE application " ImagePyramid_u8" (present at ti_components/algorithms/eve_sw_01_16_00_00/apps/imagePyramid_u8) on simulator.
Building application is successful.
While executing on simulator , it fails at below line ti_components/algorithms/eve_sw_01_16_00_00/apps/imagePyramid_u8/test/src/imagePyramid_u8_tb.c : 833
status = (int)FGETS(configLine,FILE_NAME_SIZE,fp);
It doesn't give any error, but in "configLine" no data is reading from "fp" . return status value is non-negative and non zero.
So it breaks from ti_components/algorithms/eve_sw_01_16_00_00/apps/imagePyramid_u8/test/src/imagePyramid_u8_tb.c : 844 i.e
if(config_cmd == 0)
printf("End of config list found !\n");
break;
So, I am wondering if,
1. is the file operation problem on the platform ( I also tried fread() , but issue is same) ??
2. is the simulator problem ??
I have also try execute "edge_detector " application (present at /home/kajalk/TDA/sdk_installed/ti_components/algorithms/eve_sw_01_16_00_00/apps/edge_detector ) and it behaves same as ImagePyramid_u8.
Details of tools,
1. PROCESSOR_SDK_03_00_00
2. eve_sw_01_16_00_00
3. ccs 5.4 simuator
Need help for same.
Kajal
