• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Using TPS65910B with the AM335x - RTC & DDR3
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Stephanie Goedecke
Posted by Stephanie Goedecke
on Dec 07 2011 17:18 PM
Prodigy165 points
I'd like to use the TPS65910B to power the AM335x on a project.  Can the TPS65910B's VRTC output be used to power the AM335X's VRTC?  In the AM335x reference designs, an additional regulator is always added to power the RTC instead of using the VRTC from the TPS65910.  I'd rather not have to add an additional regulator if the one already in the PMIC will work.
Also, is there a reference design for the AM335x with the TPS65910B and DDR3?  Or are there any AM335x/DDR3 routing rules?
thanks
AM335x DDR3 TPS65910B
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kazunobu Shin
    Posted by Kazunobu Shin
    on Dec 08 2011 10:49 AM
    Verified Answer
    Verified by Stephanie Goedecke
    Expert6965 points
    The additional LDO and reset logics are necessary for satisfying power sequence requirements to use PMIC_PWR_EN functionality.  The power sequence is described in Figure 4-1 in the data manual. If the PMIC_PWR_EN function is not required in the system, the additional circuits can be removed.  Please refer to the note E. in Figure 4-1 for additional details.
    Kazunobu Shin
    Please click the Verify Answer button on this post if it answers your question.
    Report Abuse
    • Reply
  • Kazunobu Shin
    on Dec 08 2011 11:40 AM
    Verified Answer
    Expert6965 points
    There is an issue in the reset circuit of the AM335x EVM schematic.  AM335x PWRONRSTn signal should be driven by VDDSHV6 power supply voltage level (1.8 V or 3.3 V) although it's driven by VRTC (1.8V) in the schematic. Please use VDDSHV6 voltage level for PWRONRSTn when you design your schematic.  The reset circuit will be updated for fixing the issue in next AM335x EVM schematic release.
    Kazunobu Shin
    Report Abuse
    • Reply
  • Stephanie Goedecke
    on Dec 08 2011 11:48 AM
    Prodigy165 points
    Thanks.
    Do you happen to know when the updated AM335x EVM schematic will be released?
    Report Abuse
    • Reply
  • Jeff Culverhouse
    Posted by Jeff Culverhouse
    on Dec 08 2011 12:55 PM
    Verified Answer
    Expert7315 points
    Hello Stephanie,
    for the DDr question, We will have the DDR3 guidelines in the next release of the Data Manual which will be out around 12/15/2011.
    Jeff
    Report Abuse
    • Reply
  • Kazunobu Shin
    on Dec 08 2011 14:40 PM
    Expert6965 points
    I don't know the exact date but it will be released soon.
    I have posted this information in your other post but I'll also post here in case the other people just look at this post.
    I have been just informed that the part number for new TPS65910 device to support AM335x + DDR3 is TPS65910A3 instead of TPS65910B. The information in AM335x power solution slide and wiki articles will be updated with TPS65910A3.
    Kazunobu Shin
    Report Abuse
    • Reply
  • Risto Holtta
    Posted by Risto Holtta
    on Dec 12 2011 04:10 AM
    Prodigy30 points
    Thanks for the correction on the supply voltage for the reset circuitry.That will become handy.
    However, it is a bit difficult to understand the need for the external LDO. In the EVM schematics the VRTC LDO is always on when VBAT is present. So is TPS65910A VRTC output. Or am I missing something?
    Report Abuse
    • Reply
  • JJD
    Posted by JJD
    on Dec 12 2011 10:34 AM
    Genius9210 points
    Risto, it is more of a power sequencing issue.  VRTC is not sequenced properly and thus an external LDO is required at power on when the RTC-only feature is needed.
    James
    Report Abuse
    • Reply
  • peaves
    Posted by peaves
    Genius12765 points
    The EXT_WAKEUP output buffer is powered by the VDDS_RTC power domain.  This signal is what controls the TPS65910 when operating in the sleep mode where only the AM335x RTC is powered on.
    Therefore, you must have a separate voltage regulator to source the VDDS-RTC supply form the battery if you plan to use the EXT_WAKEUP output to control the TPS65910.
    Paul
    Report Abuse
    • Reply
    on Dec 12 2011 10:45 AM
    Prodigy165 points
    It sounds like the TPS65910 VDDS_RTC supply is not always powered when the VBACKUP battery is connected, but an external voltage regulator would always be powered when the battery was connected.  Therefore, a design must have an external voltage regulator to source the VDDS_RTC supply from the battery to be able to use the EXT_WAKEUP.
    Or is this not the case?  Thanks for clarifying.
    Report Abuse
    • Reply
  • Peter Reibrt Hansen
    Posted by Peter Reibrt Hansen
    on Mar 02 2012 05:13 AM
    Prodigy50 points
    Hi Kazunobu
    I'm also working on a design with AM335x and DDR3 SDRAM, and would like to use TPS65910A3.
    I'm pleased to see that the SWU93A is updated, so the DDR voltage can be set to 1.5V, but what about the VCtt (0.75V), do I still
    need an additional "SINK/SOURCE DDR TERMINATION REGULATOR" like the TPS51200 or TPS51206?
    http://www.ti.com/lit/ug/swcu093a/swcu093a.pdf
    Kind regards
    Peter
    Report Abuse
    • Reply
  • Noam Weidenfeld
    Posted by Noam Weidenfeld
    on Apr 01 2012 07:34 AM
    Prodigy10 points
    It is still not clear to me, assuming that I want to use the AM335x
    internal RTC and there is a power failure.
    The AM335x RTC voltage domain should be powered by the Battery (Li) connected
    to the 65910A, however if I will use the external LDO instead there will be no
    power supplied to the AM335x.
    How should I connect the VRTC if I want the AM335x RTC zone to operate
    from the battery in case of power fail?
    Noam
    AM335x TPS65910A3
    Report Abuse
    • Reply
  • *** Liu
    Posted by *** Liu
    on Jul 19 2012 06:21 AM
    Prodigy140 points
    EXT_WAKEUP in AM3359 is a input, isn't it?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
