• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Installing Beaglebone dev env under Windows / Virtual Box - separate USB card reader required?
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
Dan Giorgis
Posted by Dan Giorgis
on Jan 30 2012 14:51 PM
Prodigy20 points
I've installed the TI supplied microSD card into the Beaglebone and connected it to my Windows PC.  I'm able to access the serial shell and get the "am335x-evm login:" prompt.
On my windows box I've opened the /windows_users/windows_users.html file where it states "You will need to insert the USB SD Card Reader into a Linux machine" and provides instructions on setting up a Linux env.
I've installed VirtualBox and have a Ubuntu 10.4 image running.  Next step (I believe) is to install the tool chain via the "START_HERE.sh" script referenced in the documents.
Does this require that I use a separate USB card reader and make it accessible to Virtual Box as described in the wiki?
I'm confused by the statement  "you will need to insert *the* USB SD card reader...." - it makes it sound like the USB card reader is included?  Or is the beaglebone supposed to look like a SD card reader to Windows?
Dan
BeagleBone
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chase Maupin
    Posted by Chase Maupin
    on Jan 31 2012 08:21 AM
    Expert4890 points
    Dan,
    The beaglebone should appear to windows to have a mass storage device (the same one where the START_HERE.sh script is located).  You should pass that device into your virtual box so that you can run the SDK installer.
    You should also probably disconnect your serial console from the beaglebone if you are connecting through windows and instead connect it through your Ubuntu setup.
    But overall, if you pass the START_HERE partition of the beaglebone to the virtual box then you should be able to use the beaglebone as an SD card reader and install the SDK by running the .bin installer.
    Chase
    Report Abuse
    • Reply
  • Dan Giorgis
    on Feb 01 2012 10:17 AM
    Prodigy20 points
    Chase -
    Thanks for your response.  I added the "Linux 3.1.0-rc8 with musb-hdrc Mass Storage Gadget" as a USB device.  Now I can see the START_HERE.sh script in my VirtualBox / Ubuntu environment.
    I was following the process laid out here, which refers to a USB card reader and not the Mass Storage Gadget, so I was a bit confused.
    http://processors.wiki.ti.com/index.php/How_to_Build_a_Ubuntu_Linux_host_under_VirtualBox
    http://processors.wiki.ti.com/index.php/How_to_Build_a_Ubuntu_Linux_host_under_VirtualBox#How_to_Read_a_USB.C2.A0SD.C2.A0Card_Reader_in_VirtualBox
    Thanks for your help.
    - Dan
    Report Abuse
    • Reply
  • David38506
    Posted by David38506
    on Feb 07 2012 08:27 AM
    Intellectual260 points
    I'm having a similar problem.
    I have the Ubuntu Linux virtual machine running under VirtualBox using both Windows 7 and Windows XP.
    I believe I've got the machine defined correctly.
    If I plug the BeableBone in with the SD card holding the Angstrom distribution, it gets recognized immediately and I can use the enet port to get to the Cloud 9 app.
    However, if I start up with the TI AMSDK card in the Bone, it isn't recognized.
    If I put the card in a USB SD reader, it works OK ( I see the boot, fsroot and START.HERE partitions) but I can't get the serial port initialized correctly using the setup.sh.
    Any suggestions?
    Dave
    sdk AM335x BeagleBone SD card AM335x Boot USB Bone setup.sh
    Report Abuse
    • Reply
  • Chase Maupin
    on Feb 07 2012 08:48 AM
    Expert4890 points
    Dave,
    Are you passing the beaglebone device into the virtual machine.  I'm not familiar with VirtualBox but I believe it is like VMWare in that you should pass the hardware to the virtual machine.
    As for getting your serial port setup correctly when you use the setup.sh the serial port will be of the form /dev/ttyUSBx where x is the second port of the FTDI device.  If you have not passed the beaglebone into the virtual machine such that doing lsusb | grep "0403:a6d0" then the script will be unable to determine the port to use.
    Also, when you say the Angstrom image is recognized immediately do you mean by the virtual machine or by Windows itself.  I believe that image ships with drivers for windows and Mac platforms.
    Chase
    Report Abuse
    • Reply
  • David38506
    on Feb 07 2012 10:07 AM
    Chase,
    1/3. Yes, if I power up the Bone with the Angstrom card, the "Linux 3.1.0-rc8 with musb-hdrc Mass Storage Gadget" shows up on the VirtualBox start up screen as a USB device that I can select to pass to the virtual machine. I select it and then also select as a a device once the Linux machine boots. The BeagleBone partition shows up on the Linux desktop.
    2. When I run the startHere.sh/setup.sh from the SD card reader, I do get to the minicom setup that indicates that it sets up ttyUSB1 but when I run minicom, it says that the device doesn't exist.
    I can see the remote desktop via the Firefox browser, but I need to be able to change and download the code base which I'm currently unable to accomplish.
    Dave.
    Report Abuse
    • Reply
  • Chase Maupin
    on Feb 07 2012 10:32 AM
    Expert4890 points
    Dave,
    A couple more questions to help:
    1. when you run the following command is the device found?
    If not then the beaglebone is not being passed through to the virtual machine.
    2. If you do an lsmod is the ftdi_sio module installed?
    If not then try "modprobe ftdi_sio vendor=0x0403 product=0xa6d0"
    3. Does your virtual machine have a /dev/ttyUSB1 device node?
    The above modprobe should have caused that device node to be created.  Now you can connect minicom to it.
    Chase
    Report Abuse
    • Reply
  • David38506
    on Feb 07 2012 13:09 PM
    Chase,
    I stumbled on the ftdi driver info in the Android DevKit wiki. I was able to provide drivers that enabled me to get the SDK card partitions when booting up.
    The setup.sh process completes and I get a boot prompt. However, on subsequent boot ups, even if I umount the boot and START_HERE partitions, I never get the  ttyUSB1 device.
    From viewing the setup.sh file and following your instructions, it appears that I am passing the device through but I can't get the ftdi_module installed.
    See below the output of the terminal window following your instructions.
    Dave
    user@user-desktop:~$ lsusb | grep "0403:a6d0"
    Bus 001 Device 002: ID 0403:a6d0 Future Technology Devices International, Ltd
    user@user-desktop:~$ lsmod
    Module                  Size  Used by
    nls_iso8859_1           3249  1
    nls_cp437               4919  1
    vfat                    8933  1
    fat                    47767  1 vfat
    nls_utf8                1069  1
    isofs                  29250  1
    vboxvideo               1228  1
    drm                   163747  2 vboxvideo
    agpgart                31724  1 drm
    binfmt_misc             6587  1
    vboxsf                 35755  0
    snd_intel8x0           25652  2
    snd_ac97_codec        100646  1 snd_intel8x0
    ac97_bus                1002  1 snd_ac97_codec
    snd_pcm_oss            35308  0
    snd_mixer_oss          13746  1 snd_pcm_oss
    snd_pcm                70694  3 snd_intel8x0,snd_ac97_codec,snd_pcm_oss
    nfsd                  238903  13
    exportfs                3437  1 nfsd
    snd_seq_dummy           1338  0
    snd_seq_oss            26722  0
    nfs                   265434  0
    snd_seq_midi            4557  0
    lockd                  64881  2 nfsd,nfs
    snd_rawmidi            19056  1 snd_seq_midi
    nfs_acl                 2245  2 nfsd,nfs
    auth_rpcgss            33767  2 nfsd,nfs
    snd_seq_midi_event      6003  2 snd_seq_oss,snd_seq_midi
    snd_seq                47263  6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
    sunrpc                193578  12 nfsd,nfs,lockd,nfs_acl,auth_rpcgss
    snd_timer              19130  2 snd_pcm,snd_seq
    snd_seq_device          5700  5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
    joydev                  8740  0
    snd                    54244  14 snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
    ppdev                   5259  0
    usbhid                 36110  0
    usb_storage            40033  1
    hid                    67288  1 usbhid
    parport_pc             25962  0
    soundcore               6620  1 snd
    fbcon                  35102  71
    tileblit                1999  1 fbcon
    font                    7557  1 fbcon
    bitblit                 4707  1 fbcon
    softcursor              1189  1 bitblit
    vboxguest             195799  6 vboxsf
    psmouse                63677  0
    serio_raw               3978  0
    snd_page_alloc          7076  2 snd_intel8x0,snd_pcm
    i2c_piix4               8335  0
    vga16fb                11385  1
    vgastate                8961  1 vga16fb
    lp                      7028  0
    parport                32635  3 ppdev,parport_pc,lp
    ahci                   32680  2
    e1000                  97435  0
    user@user-desktop:~$ modprobe ftdi_sio vendor=0x0403 product=0xa6d0
    FATAL: Error inserting ftdi_sio (/lib/modules/2.6.32-38-generic/kernel/drivers/usb/serial/ftdi_sio.ko): Operation not permitted
    user@user-desktop:~$ df -hT
    Filesystem    Type    Size  Used Avail Use% Mounted on
    /dev/sda1     ext4     29G  9.4G   18G  35% /
    none      devtmpfs    245M  276K  245M   1% /dev
    none         tmpfs    249M  224K  249M   1% /dev/shm
    none         tmpfs    249M  108K  249M   1% /var/run
    none         tmpfs    249M     0  249M   0% /var/lock
    none         tmpfs    249M     0  249M   0% /lib/init/rw
    /dev/sr0   iso9660     44M   44M     0 100% /media/VBOXADDITIONS_4.1.8_75467
    Report Abuse
    • Reply
  • Chase Maupin
    on Feb 07 2012 14:06 PM
    Expert4890 points
    Dave,
    You are almost there I think.  Try adding "sudo" in front of your modprobe command.  You will be prompted for your password but this should allow you to insert the ftdi_sio module.
    Chase
    Report Abuse
    • Reply
  • Arielle
    Posted by Arielle
    on Feb 23 2012 20:17 PM
    Prodigy50 points
    I made the following tutorial for getting your host linux machine usb drivers setup for the BeagleBone. For a Linux newbie, this may be helpful. Today is my first time using Linux and this is the procedure I followed.
    In terminal type the following while in the root directory. This opens an editor called ‘nano’ and creates the nano file in the directory specified. This is a rules file for udev.
    sudo nano /etc/udev/rules.d/10-local.rules
    Type this into nano and hit ctrl+o to save then type ctrl+x to exit.
    ACTION=="add", SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_interface", \
            ATTRS{idVendor}=="0403", ATTRS{idProduct}=="a6d0", \
            DRIVER=="", RUN+="/sbin/modprobe -b ftdi_sio"
    ACTION=="add", SUBSYSTEM=="drivers", \
            ENV{DEVPATH}=="/bus/usb-serial/drivers/ftdi_sio", \
            ATTR{new_id}="0403 a6d0"
    ACTION=="add", KERNEL=="ttyUSB*", \
                        ATTRS{interface}=="BeagleBone", \
            ATTRS{bInterfaceNumber}=="00", \
                        SYMLINK+="beaglebone-jtag"
            ATTRS{bInterfaceNumber}=="01", \
                        SYMLINK+="beaglebone-serial"
    To run/load the new udev rule, type the following in the root terminal.
    sudo udevadm control --reload-rules
    To connect the BeagleBone serial console, type this in root.
    sudo screen /dev/ttyusb1 115200
     The code compiled and brought up this.
    I used the following references
    (BeagleBone specific information)
    http://beagleboard.org/static/beaglebone/a3/README.htm#drivers
    (Where to save the new rule)
    http://reactivated.net/writing_udev_rules.html
    (How to use nano)
    http://www.gentoo.org/doc/en/nano-basics-guide.xml
    Report Abuse
    • Reply
  • Tarun Kaushik
    Posted by Tarun Kaushik
    on Apr 04 2012 02:29 AM
    Prodigy155 points
    Hi ,
    may be this is not the right forum to discuss, but I have lost my TI supplied sd card content so I do not have start_here.sh script. Can someone please help me to recreate the sd card for ti linux sdk image boot..
    regards
    Report Abuse
    • Reply
  • Chase Maupin
    on Apr 04 2012 07:27 AM
    Expert4890 points
    Tarun,
    All the content that was on the START_HERE partition of the SD card can also be found on the SDK download page.  Go to www.ti.com/tool/linuxezsdk-sitara and select your processor to get to the download page.  In SDk 5.04 (being released this week) there is a script called create-sdcard.sh in the bin directory that will help you create an SD card (although it can only create 3 partition SD cards if you have access to tarballs for the partitions which is not typical).  You can get this script early at:
    http://arago-project.org/git/?p=arago.git;a=blob;f=recipes/ti/ti-tisdk-setup/create-sdcard.sh;h=2638d354fe1a4cd8a6536e2ff82cd5a8ab449aae;hb=next
    and find instructions on using it at:
    http://processors.wiki.ti.com/index.php/Sitara_Linux_SDK_create_SD_card_script
    Chase
    Report Abuse
    • Reply
  • Tarun Kaushik
    on Apr 04 2012 10:16 AM
    Prodigy155 points
    Thanks Chase,
    On the following link:
    http://processors.wiki.ti.com/index.php/Sitara_Linux_Software_Developer%E2%80%99s_Guide
    under the heading Start your Linux Development for beaglebone (point 3).  I was unable to find the Start_Here.sh script. please help. I was able to partition the sd card. I placed the prebuilt images from linux ez sdk into the sd card boot and rootfs partition. But I am confused about this Start_Here.sh script. Setup.sh is there in sdk but Start_here.sh, I was unable to find out.
    regards
    Report Abuse
    • Reply
  • Chase Maupin
    on Apr 04 2012 10:27 AM
    Expert4890 points
    Tarun,
    start_here.sh only exists for a 3 partition card out of the box and is to help get the SDK installed and perform the out-of-box setup.  Since you have already installed the SDK and booted the board you do not need that script.
    Chase
    Report Abuse
    • Reply
  • Qin Jerry
    Posted by Qin Jerry
    on Apr 28 2012 09:38 AM
    Prodigy10 points
    I have install and setup ti-sdk-am335x-evm-05.04.01.00 in ubuntu 10.04 TLS success, and I use create-sdcard.sh to make a sd card with prebuilt-images, but beaglebone can not start up. When I insert the sd card in the host computer, the files are right. Is there something should I have not to do?
    Report Abuse
    • Reply
  • Chase Maupin
    on May 02 2012 07:31 AM
    Expert4890 points
    Please provide additional information.  Did you connect the XDS100v2/beaglebone device to the VM image?  Do you see /dev/ttyUSB devices in your VM?
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
