Hello all,
I have a TMDXICE 3359 hardware , CCS 5.1.1.00031 and SYSBIOS Industrial SDK
My first try is using the I2C_LED example from SDK , modify the LED rotation speed and LOAD / RUN the I2C_LED.OUT. no problem , works
First problem , no BIN file was generates. reinstall CSS with CORTEX M MCU support solves this problem.
Now i want to put the new I2C_LED.BIN in SPI Memory and boot from SPI.
Getting Started guide says : write bootloader and application to SPI and reboot the device
start SPI_flashing_tool and enter the filename to flash when promted.
But when i LOAD / RUN SPI_flashing_tool.out no promt appears ?
And where can i found the bootloader.bin
