• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » how to get full build system on target device
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
Frisky Li
Posted by Frisky Li
on Apr 08 2012 05:54 AM
Prodigy120 points
I want to build apps/utilites on target rootfs (via SDMMC ext3 or nfs filesystem etc.), this is critical for me.
I've downloaded AM335xSDK 05_04_00_00 from http://software-dl.ti.com/dsps/dsps_public_sw/am_bu/sdk/AM335xSDK/latest/index_FDS.html. I found that arm-arago-linux-gnueabi-gcc/-cpp is missed in the target rootfs - tisdk-rootfs-am335x-evm.tar.gz
only the following files in target rootfs /usr/bin/ (I know that /usr/arm-arago-linux-gnueabi/bin/ has symbolic links of ar  as  ld  nm  objcopy  objdump  ranlib  strip to /usr/bin/arm-arago-linux-gnueabi-*):
arm-arago-linux-gnueabi-addr2line  arm-arago-linux-gnueabi-gprof    arm-arago-linux-gnueabi-objdump  arm-arago-linux-gnueabi-strings
arm-arago-linux-gnueabi-ar         arm-arago-linux-gnueabi-ld       arm-arago-linux-gnueabi-ranlib   arm-arago-linux-gnueabi-strip
arm-arago-linux-gnueabi-as         arm-arago-linux-gnueabi-nm       arm-arago-linux-gnueabi-readelf
arm-arago-linux-gnueabi-c++filt    arm-arago-linux-gnueabi-objcopy  arm-arago-linux-gnueabi-size
How can I get full build system on/for target rootfs? Thank you very much!
AM335x EVM AM335x am3359 AM3352
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Frisky Li
    Posted by Frisky Li
    on Apr 08 2012 06:02 AM
    Prodigy120 points
    The cross-compile build system is ok. But I need build system on/for target rootfs too.
    The following files are in <SDK install dir>/linux-devkit/bin/ for cross-compile build system (they are ok):
    arm-arago-linux-gnueabi-addr2line  arm-arago-linux-gnueabi-ld       libtoolize     qdbusxml2cpp
    arm-arago-linux-gnueabi-ar         arm-arago-linux-gnueabi-nm       lrelease       qdbusxml2cpp4
    arm-arago-linux-gnueabi-as         arm-arago-linux-gnueabi-objcopy  lrelease4      qmake
    arm-arago-linux-gnueabi-c++filt    arm-arago-linux-gnueabi-objdump  lupdate        qmake2
    arm-arago-linux-gnueabi-cpp        arm-arago-linux-gnueabi-ranlib   lupdate4       rcc
    arm-arago-linux-gnueabi-g++        arm-arago-linux-gnueabi-readelf  moc            rcc4
    arm-arago-linux-gnueabi-gcc        arm-arago-linux-gnueabi-run      moc4           signGP
    arm-arago-linux-gnueabi-gccbug     arm-arago-linux-gnueabi-size     opkg-cl        uic
    arm-arago-linux-gnueabi-gcov       arm-arago-linux-gnueabi-strings  opkg-key       uic3
    arm-arago-linux-gnueabi-gdb        arm-arago-linux-gnueabi-strip    pkg-config     uic34
    arm-arago-linux-gnueabi-gdbtui     i686-linux-libtool               qdbuscpp2xml   uic4
    arm-arago-linux-gnueabi-gprof      libtool                          qdbuscpp2xml4  update-alternatives
    Report Abuse
    • Reply
  • Chase Maupin
    Posted by Chase Maupin
    on Apr 08 2012 12:50 PM
    Expert4890 points
    Frisky,
    Unfortunately we do not include an ARM side compiler in the SDK.  If you want an ARM compiler you will need to build it yourself using Arago or Angstrom, or you could try a prebuilt toolchain from the Angstrom package feeds, but you need to be careful about compatibility between the SDK toolchain and the toolchain you build.  You can probably look to the Angstrom distribution for beaglebone to find a target side GCC toolchain.
    Chase
    Report Abuse
    • Reply
  • Frisky Li
    Posted by Frisky Li
    on Apr 08 2012 22:14 PM
    Prodigy120 points
    Could you please tell me or give me the steps/guide for building target side build system? Considering using Arago or Angstrom, a prebuilt toolchain from the Angstrom package feeds.
    Is http://www.angstrom-distribution.org/toolchains/ a right place?
    Thank you.
    Report Abuse
    • Reply
  • Chase Maupin
    on Apr 09 2012 07:03 AM
    Expert4890 points
    The toolchains you pointed to above are cross-compile toolchains.  You can try the narcissus tool at http://narcissus.angstrom-distribution.org/ to build an image.  You can also use the Angstrom image for beaglebone since that image has a GCC toolchain already installed.  If you have questions about using these images or tools you should ask on the beagleboard@googlegroups.com mailing list since these are both community tools and distributions.
    Chase
    Report Abuse
    • Reply
  • Frisky Li
    Posted by Frisky Li
    on Apr 11 2012 04:43 AM
    Prodigy120 points
    Sorry for the late reply. Thank you Chase, I will try.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
