• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Kernel crash on USB gadget rmmod with PSP 04.06.00.07
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Qmax
Posted by Qmax
on Apr 17 2012 05:01 AM
Expert2260 points
rmmod_error_log.txt
Hi
I'm using PSP 04.06.00.07 with new power-management features. I've rebuilt the kernel (using am335x default configuration) with just a minor change: the two musb controller are configured as host and peripheral instead of host and otg, thus modifying board-am335xevm.c as:
    .mode           = (MUSB_HOST << 4) | MUSB_PERIPHERAL,
In the EVM, when the USB peripheral port is plugged in and I execute an rmmod command of loaded USB gadget module (any of them: g_mass_storage, g_ether, g_file_storage) I get a kernel error for "Unable to handle kernel NULL pointer dereference at virtual address 0000000c". I've attached the whole error log.
Everything works fine if cable is unplugged when rmmod is executed, or if musb controllers are configured as HOST+OTG. But I need to set them as HOST+PERIP for my custom board, and the issue affects also that board so I do not think it depends on hw.
Max
AM335x PSP linux USB
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sekhar Nori
    Posted by Sekhar Nori
    on Apr 17 2012 05:36 AM
    Expert5680 points
    Hi Max,
    Our USB engineer is on travel and he may not be able to look into this issue this week. I have created a bug ticket for tracking this issue.
    https://cqweb.ext.ti.com/cqweb/main?command=GenerateMainFrame&service=CQ&schema=SDO-Web&contextid=SDOWP&entityID=SDOCM00091275&entityDefName=IncidentReport&username=readonly&password=readonly
    Sekhar
    Report Abuse
    • Reply
  • Qmax
    Posted by Qmax
    on Apr 17 2012 11:53 AM
    Expert2260 points
    Hi Sekhar
    Thanks for opening the ticket, in the meanwhile I've tried to debug a little bit. Please not that musb driver cause crash if built with -DDEBUG: I had to remove dev_dbg call in cppi41dma_Interrupt function. Then I've built usb musb, core and gadget with -DDEBUG.
    The composite_disconnect function is called by usb_gadget_remove_driver. But in PERIPHERAL mode case it is called a second time due to a DISCONNECT interrupt: at this time the usb_composite_dev struct associated to gadget seems to have been already cleaned, but composite_disconnect does not do any check on cdev not null, causing the crash when it calls spin_lock_irqsave(&cdev->lock, flags).
    Gadget code seems a little bit weak from this point of view, but I am not sure this is the right place to fix: something in musb driver code flow seems changed, and maybe it is not the right one. Maybe that fix would mask other potential issues. I am looking for your final patch.
    Logs follow, hope can help to understand.
    Max
    OTG case (fine):
    root@am335x-evm:~# rmmod g_mass_storage
    [   66.481057] g_mass_storage musb-hdrc.0: unregistering UDC driver [musb-hdrc]
    [   66.488581] g cf9151a0 cdev cec3e840 cdev->config bf007b18 composite->disconnect   (null)!
    [   66.497224]  gadget: composite_disconnect gadget cf9151a0 cdev cec3e840 ...
    [   66.504494]  gadget: reset config
    [   66.507967]  gadget: unbind function 'Mass Storage Function'/cfa67ec0
    [   66.514696]  gadget: unbind
    [   66.519081] musb-hdrc musb-hdrc.0: Descriptor (8f8ac000) popped from teardown completion queue
    [   66.528145] musb-hdrc musb-hdrc.0: ep1out request cec3e9c0, 0/512 fault -104
    [   66.535500]  gadget: bulk_out_complete --> -104, 0/31
    [   66.540850]  gadget: reset interface
    [   66.544599] musb-hdrc musb-hdrc.0: ep1in: abort DMA --> 0
    [   66.550239] musb-hdrc musb-hdrc.0: ep1in
    [   66.554340] musb-hdrc musb-hdrc.0: ep1out: abort DMA --> 0
    [   66.560059] musb-hdrc musb-hdrc.0: ep1out
    [   66.570104]  lun0: close backing file
    [   66.574147]  lun1: close backing file
    [   66.578030] musb-hdrc musb-hdrc.0: START musb_gadget_stop...
    [   66.583956] musb-hdrc musb-hdrc.0: HNP: Stopping in unknown state b_peripheral
    [   66.591491] musb-hdrc musb-hdrc.0: gadget D+ pullup off
    [   66.599485] musb-hdrc musb-hdrc.0: HDRC disabled
    [   66.604300] musb-hdrc musb-hdrc.0: UNDEFINED active, deleting timer
    [   66.610851] musb-hdrc musb-hdrc.0: unregistering driver g_mass_storage
    [   66.617659] musb-hdrc musb-hdrc.0: UNDEFINED inactive, starting idle timer for 10 ms
    [   66.625759] musb-hdrc musb-hdrc.0: Poll devctl 98 (UNDEFINED)
    [   66.631753] musb-hdrc musb-hdrc.0: remove, state 1
    [   66.636770] musb-hdrc musb-hdrc.0: roothub graceful disconnect
    [   66.642871] usb usb2: USB disconnect, device number 1
    [   66.648137] usb usb2: unregistering device
    [   66.652418] usb usb2: unregistering interface 2-0:1.0
    [   66.657808] musb-hdrc musb-hdrc.0: shutdown urb cfb91340 ep1in-intr
    [   66.664467] usb usb2: usb_disable_device nuking all URBs
    [   66.672872] musb-hdrc musb-hdrc.0: HDRC disabled
    [   66.677692] musb-hdrc musb-hdrc.0: UNDEFINED inactive, starting idle timer for 10 ms
    [   66.685789] musb-hdrc musb-hdrc.0: USB bus 2 deregistered
    [   66.691461] musb-hdrc musb-hdrc.0: ... musb_gadget_stop END
    [   66.697286] musb-hdrc musb-hdrc.0: Poll devctl 98 (UNDEFINED)
    PERIPHERAL case (crash):
    [   70.707391] g_mass_storage musb-hdrc.0: unregistering UDC driver [musb-hdrc]
    [   70.714925] g cf9150b8 cdev cee20f00 cdev->config bf007b18 composite->disconnect   (null)!
    [   70.723564]  gadget: composite_disconnect gadget cf9150b8 cdev cee20f00 ...
    [   70.730828]  gadget: reset config
    [   70.734310]  gadget: unbind function 'Mass Storage Function'/cf3b30c0
    [   70.741028]  gadget: unbind
    [   70.745408] musb-hdrc musb-hdrc.0: Descriptor (8f8ac000) popped from teardown completion queue
    [   70.754475] musb-hdrc musb-hdrc.0: ep1out request ce47d900, 0/512 fault -104
    [   70.761831]  gadget: bulk_out_complete --> -104, 0/31
    [   70.767162]  gadget: reset interface
    [   70.770898] musb-hdrc musb-hdrc.0: ep1in: abort DMA --> 0
    [   70.776552] musb-hdrc musb-hdrc.0: ep1in
    [   70.780646] musb-hdrc musb-hdrc.0: ep1out: abort DMA --> 0
    [   70.786379] musb-hdrc musb-hdrc.0: ep1out
    [   70.796494]  lun0: close backing file
    [   70.800452]  lun1: close backing file
    [   70.804413] musb-hdrc musb-hdrc.0: START musb_gadget_stop...
    [   70.810348] musb-hdrc musb-hdrc.0: usbintr (20) epintr(0)
    [   70.815981] musb-hdrc musb-hdrc.0: ** IRQ peripheral usb0020 tx0000 rx0000
    [   70.823152] musb-hdrc musb-hdrc.0: <== Power=f0, DevCtl=98, int_usb=0x20
    [   70.830142] musb-hdrc musb-hdrc.0: DISCONNECT (b_peripheral) as Peripheral, devctl 98
    [   70.838309] musb g_mass_storage gadget disconnected.
    [   70.845847] musb-hdrc musb-hdrc.0: devctl 98
    [   70.850300] musb-hdrc musb-hdrc.0: musb_g_disconnect calling composite_disconnect...
    [   70.858379] g cf9150b8 cdev   (null) cdev->config 00000001 composite->disconnect 00000002!
    [   70.866999] [ERROR] composite_disconnect gadget cf9150b8 cdev   (null) : return to avoid crash!
    [   70.876114] musb-hdrc musb-hdrc.0: usbintr (1) epintr(0)
    [   70.881658] musb-hdrc musb-hdrc.0: ** IRQ peripheral usb0001 tx0000 rx0000
    [   70.888828] musb-hdrc musb-hdrc.0: <== Power=e0, DevCtl=99, int_usb=0x1
    [   70.895728] musb-hdrc musb-hdrc.0: SUSPEND (b_idle) devctl 99 power e0
    [   70.902572] musb-hdrc musb-hdrc.0: gadget D+ pullup off
    [   70.910568] musb-hdrc musb-hdrc.0: HDRC disabled
    [   70.915382] musb-hdrc musb-hdrc.0: unregistering driver g_mass_storage
    [   70.924759] musb-hdrc musb-hdrc.0: HDRC disabled
    [   70.929575] musb-hdrc musb-hdrc.0: ... musb_gadget_stop END
    Report Abuse
    • Reply
  • Ajay
    Posted by Ajay
    on Apr 24 2012 20:54 PM
    Genius9470 points
    Max,
    Thanks for sharing the details. I will look into this and update sometime next week
    Ajay
    If my reply answers your question then please click on the green button "Verify Answer"
    Report Abuse
    • Reply
  • Qmax
    Posted by Qmax
    on May 14 2012 08:37 AM
    Expert2260 points
    Hi Ajay, any news on this issue? Thanks, regards.
    Max
    Report Abuse
    • Reply
  • Joe G.
    Posted by Joe G.
    on May 15 2012 08:09 AM
    Genius14420 points
    I can dig up the logs if it helps you (as a working data point), but this worked fine for us on the AM335x EVM in the default PSP mode with USB0 switching g_ether.ko between g_mass_storage.ko.
    Did you defconfig the initial PSP 04.06.00.07?
    Seemed to make a big difference in USB (and other kernel) stability when I did.
    Report Abuse
    • Reply
  • Qmax
    Posted by Qmax
    on May 15 2012 10:35 AM
    Expert2260 points
    Do you mean you cannot reproduce the issue with AM335x EVM and PSP 04.06.00.07 original code, or even after changing the USB0 role configuration from OTG to PERIPHERAL in board-am335xevm.c file? I know everything is fine with OTG configuration, I'm facing the issue just if USB0 is configured in PERIPHERAL mode.
    What do you mean exactly with "to defconfig the initial PSP 04.06.00.07"? I've run the usual mrproper and then am335x_evm_defconfig... correct?
    Report Abuse
    • Reply
  • Joe G.
    Posted by Joe G.
    on May 15 2012 11:47 AM
    Genius14420 points
    Sorry, once we understood the default EVM config HW doc here:
    http://processors.wiki.ti.com/index.php/AM335X_USB_Driver_User_Guide_04.06.00#Port_mode_configuration
    and SW documented below, we realized we only need OTG on USB0.  Haven't tried peripheral mode.
    Yup, that's it.
    A  key Linux improvement  in PSP-04.06.00.07 came from the file arch/arm/mach-omap2/board-am335xevm.c:
    static struct omap_musb_board_data musb_board_data = {
            .interface_type = MUSB_INTERFACE_ULPI,
             * mode[0:3] = USB0PORT's mode
             * mode[4:7] = USB1PORT's mode
             * AM335X beta EVM has USB0 in OTG mode and USB1 in host mode.
    Report Abuse
    • Reply
  • Ajay
    Posted by Ajay
    on May 18 2012 00:56 AM
    Genius9470 points
    Please use below patch which will come in next version of TI PSP release.
    diff --git a/drivers/usb/musb/musb_gadget.c b/drivers/usb/musb/musb_gadget.c
    index 305d843..47da5ed 100644
    --- a/drivers/usb/musb/musb_gadget.c
    +++ b/drivers/usb/musb/musb_gadget.c
    @@ -2120,11 +2120,6 @@ void musb_g_disconnect(struct musb *musb)
            (void) musb_gadget_vbus_draw(&musb->g, 0);
            musb->g.speed = USB_SPEED_UNKNOWN;
    -       if (musb->gadget_driver && musb->gadget_driver->disconnect) {
    -               spin_unlock(&musb->lock);
    -               musb->gadget_driver->disconnect(&musb->g);
    -               spin_lock(&musb->lock);
            switch (musb->xceiv->state) {
            default:
    I am checking this with musb maintainer and will update if any change.
    Ajay
    Report Abuse
    • Reply
  • Ajay
    Posted by Ajay
    on May 21 2012 02:17 AM
    Verified Answer
    Verified by Qmax
    Genius9470 points
    The correct fix is to use bugfix patches from latest kernel for udc_core.c as available at
    http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=history;f=drivers/usb/gadget/udc-core.c;h=e5e44f8cde9a3c99052e19e5e8c641ab3123a534;hb=76e10d158efb6d4516018846f60c2ab5501900bc
    Apply below 4 patches
    usb: gadget: udc-core: fix incompatibility with dummy-hcd
    usb: gadget: udc-core: fix wrong call order
    usb: gadget: udc-core: fix asymmetric calls in remove_driver
    usb: gadget: udc-core: stop UDC on device-initiated disconnect
    Ajay
    Report Abuse
    • Reply
  • Qmax
    Posted by Qmax
    on May 21 2012 02:49 AM
    Expert2260 points
    Hi Ajay,
    I've patched just udc_core.c as suggested, without changing musb driver code as in previously proposed patch: rmmod does not cause NULL pointer deference any longer, and everything seems working fine in HOST+PERIPHERAL modes such as in HOST+OTG modes case.
    Thanks for your support.
    Max
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
