• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Issues with DCAN at 1MHz
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
Ayaz Shahid
Posted by Ayaz Shahid
on May 03 2012 00:33 AM
Prodigy120 points
I have a working driver for DCAN on AM335xEVM. It works properly upto 500KHz but it appears that there are a few errors on the line when I try to communicate at 1MHz.
I am using Komodo as both analyzer and network node. The problem specifically arises when I try to send data from Komodo to DCAN at 1MHz. The line shows Form, Stuff and Bit errors but the received data in DCAN is correct with all parameters and flags properly set in the message object.
Is there a known issue with DCAN? Or has anyone tried using DCAN at 1MHz without this issue?
- Ayaz
DCAN 1MHz AM335xEVM
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Darrin Hansen
    Posted by Darrin Hansen
    on May 03 2012 08:36 AM
    Intellectual640 points
    I'd suggest checking for noise or grounding issues: different transceivers can react differently to different conditions (some can "clean up" dirty signals better than others).  Have you looked at the quality of the signal with a scope?
     (admittedly I haven't tried the DCAN at 1MHz, so I can't comment on that: this is just based on my past experiences with CAN in general, which may be of no help to you).
    Darrin
    Report Abuse
    • Reply
  • Stephanie Goedecke
    Posted by Stephanie Goedecke
    on May 03 2012 13:46 PM
    Prodigy165 points
    We are using the DCAN0 port out of the AM3359 processor on a custom board at 1 MHz with no errors.  We have not tried it on the AM335xEVM board.
    AM335x am3359 1MHz
    Report Abuse
    • Reply
  • Ayaz Shahid
    on May 03 2012 23:43 PM
    Prodigy120 points
    @Darrin, thanks for the tip. It is possible that it might be a noise issue and its getting more pronounced at high speeds. I've already tried to increase the tolerance of network but that does not seem to solve the issue. I'll mitigating network noise in connection and see if that helps.
    @Stephanie, I don't get any errors in DCAN controller either but I'm also monitoring the line and it seems that the line has errors (which is probably because write operations of the other node in the network is causing issue). But my concern is that we are using the same node to communicate at 1MHz with HECC and other can controllers as well and the errors pop up only in DCAN's case.
    - Ayaz
    AM335x DCAN 1MHz
    Report Abuse
    • Reply
  • Anil
    Posted by Anil
    on May 04 2012 04:52 AM
    Expert6655 points
    Hi Shahid,
    What about the case if you connect AM335x DCAN with HECC? Are you seeing any issues in this case?
    Are you properly taken case of terminating resistors? How are you connecting AM335x DCAN transceiver with komodo?
    AnilKumar
    Please mark this Forum post as answered via the Verify Answer button below if it helps answer your question.  Thanks!
    AM335x PSP DCAN
    Report Abuse
    • Reply
  • JR Simma
    Posted by JR Simma
    on May 04 2012 08:08 AM
    Intellectual385 points
    Ayaz:
    No problem on contacting me directly.  Here are some ideas that come to mind:
    1) Check that you have two 120 Ohm terminating resistors.
    2) Check the slope settings of the CAN transceivers (i.e. the slope input pin).  Sometimes transceivers are wired for lower speeds, like 250K.  For full speed, you normally ground the slope pin.
    3) I don't think this is it, but it is possible that there is PLL jitter.  PLL jitter does affect higher baud rates more than lower.  You should scope the CAN bus and see if every bit is exactly 1.00 us in length (when running at 1Mbps).
    I hope the above helps.
    JR Simma
    The CAN Experts!
    Report Abuse
    • Reply
  • Ayaz Shahid
    on May 06 2012 23:55 PM
    Prodigy120 points
    Anil/JR,
    Thanks for your suggestions, let me work on these suggestions and I'll share the results.
    Thanks!
    - Ayaz
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
