• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » AM335x-EVM Linux SDK suspend to RAM broken?
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Peter Lawrence
Posted by Peter Lawrence
on May 04 2012 10:18 AM
Prodigy90 points
The BeagleBone is ostensibly equivalent to the AM335xEVM (it uses the same PSP, etc.).
The procedure for entering Suspend to RAM is documented here:
http://processors.wiki.ti.com/index.php/Sitara_Linux_Training:_Power_Management
Alas, it doesn't work, at least with my test setup:
BeagleBone HW Rev A5
Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.05-beaglebone-2012.04.22.img.xz loaded to the SD card
uname -a output is: Linux beaglebone 3.2.14 #1 Sat Apr 21 10:00:05 CEST 2012 armv7l GNU/Linux
The above documentation implies that the kernel must be recompiled to enable the Suspend/Resume functionality, although the current am335x-evm_defconfig seems to have the desired settings already.
I've tried both the default kernel and a specially compiled kernel, and both exhibit the same failure mode.
To reproduce, the console commands are simply:
echo none > /sys/power/pm_test
echo mem > /sys/power/state
The "echo none..." is optional unless pm_test has already been set to something else.  "none" is the default value.
The behavior is that Linux locks up and the only method of recovery is to perform a hardware reset.  Contrary to the above link, no Linux system messages are shown.
Turning on some of Linux's PM debugging functionality, some other data points are:
echo devices > /sys/power/pm_test
[  599.528480]
[  599.528495] CPSW phy found : id is : 0x7c0f1
[  599.530085] PHY 0:01 not found
[  599.541284] Kernel core reported suspend failure
echo platform > /sys/power/pm_test
[  721.148473]
[  721.148486] CPSW phy found : id is : 0x7c0f1
[  721.150075] PHY 0:01 not found
[  721.161270] Kernel core reported suspend failure
echo core > /sys/power/pm_test
[  239.871978]
[  239.871978] CPSW phy found : id is : 0x7c0f1
[  239.873565] PHY 0:01 not found
[  239.884796] Kernel core reported suspend failure
AM335x
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chase Maupin
    Posted by Chase Maupin
    on May 04 2012 11:01 AM
    Expert4890 points
    Peter,
    Have you tried the SDK from www.ti.com/tool/linuxezsdk-sitara?
    The 05.04.01.00 version has support for suspend to RAM
    Chase
    Report Abuse
    • Reply
  • Peter Lawrence
    on May 04 2012 12:43 PM
    Prodigy90 points
    Oops... I forgot to specifically mention the SDK version that I used to compile the kernel.
    Yes, I'm using the 05.04.01.00 SDK to compile the kernel, and the behavior is faulty as described in the original post.
    Report Abuse
    • Reply
  • Peter Lawrence
    on May 04 2012 13:07 PM
    Prodigy90 points
    FYI, there is a cryptic known issue listed in PSP 04.06.00.07 (the PSP for am335x-evm_defconfig in 05.04.01.00 SDK):
    http://processors.wiki.ti.com/index.php/AM335x-PSP_04.06.00.07_Release_Notes
    SDOCM00090962 Resume operation fails on some beaglebone boards
    However, that ticket says "(mainly rev A3)" and this is a rev A5 board.
    Moreover, the ticket suggests that suspend and resume messages are spit out (including a 'resume of devices complete' message) and I don't even get that much activity.
    Report Abuse
    • Reply
  • Chase Maupin
    on May 04 2012 13:40 PM
    Expert4890 points
    Peter,
    Can you post a full boot log as well as the terminal output when you run the "echo mem > /sys/power/state" command?
    Your original message mentions the angstrom FS.
    Also, what happens when you use the pre-built binaries within the SDK?
    Chase
    Report Abuse
    • Reply
  • Peter Lawrence
    on May 04 2012 14:54 PM
    Verified Answer
    Verified by Peter Lawrence
    Prodigy90 points
    OK, thanks Chase for asking the right question.
    I think what is unnecessarily confusing is that the README.htm onboard the BeagleBone:
    http://beagleboard.org/static/beaglebone/latest/README.htm
    directs users to download this Angstrom image:
    http://downloads.angstrom-distribution.org/demo/beaglebone/
    The TI Sitara Linux SDK page:
    http://software-dl.ti.com/dsps/dsps_public_sw/am_bu/sdk/AM335xSDK/latest/index_FDS.html
    just has a "beaglebone-qsg.pdf" BeagleBone Quick Start Guide that just says "insert provided SD card".
    Apparently the BeagleBone boards are "provided" with a different (Angstrom-based?) SD card?
    I must admit that I defaulted to thinking these were based off the same distribution, so I just replaced the existing kernel on the (Angstrom-based?) BeagleBone image with the Sitara Linux SDK kernel image.
    It seems worth someone formally documenting how to replace the factory BeagleBone image with the proper Linux SDK images, since it is not apparent for a new purchaser that the provided images are *not* the TI ones.
    The short version is that I downloaded "am335x-evm-sdk-bin-05.04.01.00.tar.gz" from:
    and broke the archive's contents into two quantities: the tisdk-rootfs-am335x-evm.tar.gz should go into one directory, and the remaining files (MLO, etc.) should go into another directory.
    With those two directories created, one can then use this script (part of the Linux SDK):
    http://processors.wiki.ti.com/index.php/Sitara_Linux_SDK_create_SD_card_script
    and choose the "Enter in custom boot and rootfs file paths" option.
    The Linux SDK image is not without its problems (USB Device Not Recognized error message, etc.), but it DOES do Suspend to RAM.
    Thanks!
    Report Abuse
    • Reply
  • Drew Moore
    Posted by Drew Moore
    on May 04 2012 15:33 PM
    Intellectual330 points
    The kernel source included in the SDK is not the Angstrom distribution, is it? Is it the Arago distribution? Or a third distribution?
    Arago's website says it is more "cutting edge" than the more stable TI SDK, but not as bleeding edge as Angstrom. However, I don't see much new on the Arago site in http://arago-project.org/files/releases/ whereas the TI SDK seems to be getting new versions released monthly or so...
    As near as I can tell, 3.2.14 is the current version of the Angstrom kernel, 3.2.0 is the latest TI SDK kernel, and.. ah.. Chase Maupin is commiting to git on Arago.. in a 3.2.0
    http://arago-project.org/git/?p=arago.git;a=summary
    so the TI SDK is being hosted / developed on Arago?
    I figure if I'm confused about all of this, maybe others are too...
    Report Abuse
    • Reply
  • Drew Moore
    on May 04 2012 15:43 PM
    My Beaglebone came with two cards.. Angstrom and Arago. Angstrom had my favorite language, Python, installed. I updated my Angstrom; it was at 3.2.14.. I noticed the latest TI SDK was at 3.2 but the arago card was at 3.1.0-rc8, so I figured the SDK was Angstrom.. I think I made a similar mistake as you..
    Report Abuse
    • Reply
  • Sekhar Nori
    Posted by Sekhar Nori
    on May 06 2012 04:30 AM
    Expert5680 points
    Hi Peter,
    Peter Lawrence
    Can you provide more details here? Which USB device is this? Are you saying a USB device works correctly with Angstorm, but not with TI SDK?
    Sekhar
    Report Abuse
    • Reply
  • Peter Lawrence
    on May 07 2012 07:59 AM
    Prodigy90 points
    Sekhar, I don't have a complete answer on this, but I think it is just a difference of configurations between the BeagleBone's Angstrom-based distribution and the TI SDK distribution.
    The former is configured to automatically load the g_mass_storage / g_ether Linux modules (and possibly other modules) upon boot.
    The latter does not do this (but the user can insmod these manually or edit the relevant configuration files).
    As a result, when plugs the BeagleBone with the TI SDK distribution into a Windows PC, a new USB device is detected, but the PC is never able to enumerate it.  After a long delay, Windows spits out a "USB Device Not Recognized" error message as a result.
    I don't think there is anything wrong, per se, with the way the TI SDK distribution works.  The only downside is that the configuration just makes the new user initially think something is wrong.
    P.S.: perhaps unlike the AM335xEVM, plugging the BeagleBoard into a PC is largely not optional as its built-in FTDI serial converter is needed to access the console.  Since there is an integrated USB hub on the BeagleBoard, this also means the Sitara AM335x's USB device/OTG port is also connected at the same time.
    Sekhar Nori
    Hi Peter,
    Peter Lawrence
    Sekhar
    Report Abuse
    • Reply
  • Sekhar Nori
    on May 07 2012 11:57 AM
    Expert5680 points
    Hi Peter,
    Thanks for the detailed explanation. I just wanted to make sure we are not missing any patches in the TI SDK. Looks like thats not the case.
    Sekhar
    Report Abuse
    • Reply
  • Daniel Tesema
    Posted by Daniel Tesema
    on May 12 2012 11:33 AM
    Prodigy20 points
    Good discussion topic; with all the information scattered everywhere,it is easy to get lost.
    I hope this will help;
    This is the image that is shipping on All Revsions :
        http://circuitco.com/support/index.php?title=BeagleBone
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
