• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » How to configure the priority between the Ethernet ports
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Daisuke Maeda
Posted by Daisuke Maeda
on May 07 2012 19:15 PM
Genius3040 points
How is the priority between two CPGMAC_SL Ethernet ports configured?
Daisuke
AM335x CPSW Ethernet Subsystem CPSW_3G
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • -DK-
    Posted by -DK-
    on May 08 2012 09:30 AM
    Expert6810 points
    Daisuke,
    Are you wanting to configure the Ethernet Class of Service (CoS) priority levels or the physical port priority levels?
    Report Abuse
    • Reply
  • Daisuke Maeda
    on May 08 2012 19:54 PM
    Genius3040 points
    Hi -DK-,
    Thank you for your reply.
    I am wanting to configure the internal port priority levels.
    I saw the CPSW_3G Block Diagram(Figure 14-6) in the TRM(SPRUH73E) and found out that each CPGMAC_SL has a single GMII interface.
    Therefore, I thought that the internal port priority levels depended on CPGMAC_SL.
    Daisuke
    Report Abuse
    • Reply
  • peaves
    Posted by peaves
    on May 09 2012 00:02 AM
    Genius12795 points
    I would like to clarify something related to the AM335x  Gigabit Media Independent Interface (GMII) signals.
    Each CPGMAC_SL natively contains a GMII port which can be internally multiplexed a GMII to RMII gasket, GMII to RGMII gasket, or to a subset of AM335x MII pins.  Only the GMII signals required to implement MII were multiplexed directly to pins.  This allows each  CPGMAC_SL to be connected to a 10/100 Mbps RMII PHY via the GMII to RMII gasket, a 10/100/1000 Mbps RGMII PHY via the GMII to RGMII gasket, or a 10/100 Mbps MII PHY via the subset of AM335x MII pins.
    We retained the GMII signal names for the pins since this matched the internal signal names which are also references in the CPSW documentation.  However, the upper four bits on each data path and the source-synchronous transmit clock signals were not connected to pins to reduce the number of pins.  This limits the GMII signals to MII operation.
    This may cause someone to think they can connect a GMII PHY.  Therefore, I wanted to clarify this before someone spends time trying to connect a GMII PHY.
    Paul
    Report Abuse
    • Reply
  • -DK-
    Posted by -DK-
    on May 09 2012 16:10 PM
    Verified Answer
    Verified by Daisuke Maeda
    Expert6810 points
    Daisuke,
    There is no way to set internal port priority levels, however, depending on your application you may find that traffic shaping via the Rate Limit Mode discussed in section 14.3.2.10.3 of the TRM (SPRUH73E) could serve your purpose by limiting one port to a lower ingress/egress rate than the other. Again, this would depend on the nature of your application and traffic.
    Report Abuse
    • Reply
  • Daisuke Maeda
    on May 10 2012 23:49 PM
    Genius3040 points
    Hi -DK-,
    Are there the configurations (except the Rate Limit Mode) which affect the internal traffic?
    Daisuke
    Report Abuse
    • Reply
  • -DK-
    Posted by -DK-
    on May 11 2012 13:06 PM
    Verified Answer
    Expert6810 points
    Daisuke,
    The switch also supports QoS (Quality of Service) via the Priority Code Point bits of the 802.1Q header in the Ethernet frame which could be used to shape traffic internally; there are no other methods to control port priority from a hardware standpoint.
    Report Abuse
    • Reply
  • Daisuke Maeda
    on May 13 2012 19:13 PM
    Genius3040 points
    Hi -DK-,
    Thank you for your help.
    Daisuke
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
