How to use the reg_phy_rd_local_odt Field in the DDR_PHY_CTRL_1 Register.
What is the Full thevenin load (01b)?
In the case of Full thevenin load (01b), is ODT impedance 75ohm, or 150ohm?
What is the Half thevenin load (11b)?
In the case of Half thevenin load (11b), is ODT impedance 50ohm, or 75ohm?
AM335x ARM Cortex-A8 Microprocessors (MPUs) Technical Reference Manual (Rev. F)
http://www.ti.com/lit/ug/spruh73f/spruh73f.pdf
7.3.5.30 DDR_PHY_CTRL_1 Register (offset = E4h) [reset = 0h]
How to use the ddr_wuclk_disable Field in the ddr_io_ctrl Register.
What is the WUCLKIN?
What is the ISOCLKIN?
What is the SLOW (32k) clock?
When clock is synchronously gated, what does the clock synchronize with?
9.3.52 ddr_io_ctrl Register (offset = E04h) [reset = 0h]
How to use the vref_ctrl Register.
What is the BIAS2?
What is the VDDS/2?
Is the VDDS/2 the DDR_VREF?
9.3.54 vref_ctrl Register (offset = E14h) [reset = 0h]
Daisuke
