• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Configuring GPIO pins on AM3715
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Sharlin Kothari
Posted by Sharlin Kothari
on Aug 07 2012 07:36 AM
Prodigy30 points
Hey hi,
I am using AM3715 EVM module and i want to configure Gpio pins so can you tell me the complete procedure as I am fresher and i am working on the same.
You told that it's in uboot folder but where this folder is located in MMC card or pre built binaries folder?
Also can you describe the procedure to configure the UART port as I am using them for interfacing other modules.
Sharlin Kothari
GPIO UART
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • santosh vastrad
    Posted by santosh vastrad
    on Aug 07 2012 23:07 PM
    Verified Answer
    Verified by Sharlin Kothari
    Expert2065 points
    Sharlin:
    Not in MMC card, that will be binary!
    Check out the uboot source code, in that specific files to your board AM3715 EVM!
    Which gpio pins want to use, configure as gpio and then request and use it!
    santosh vastrad
    Report Abuse
    • Reply
  • Sharlin Kothari
    on Aug 08 2012 00:30 AM
    Prodigy30 points
    Hi Santosh Vastrad
    Thanks for your help but can you suggest me any website or link which helps me to configure GPIO pins(How to configure and basic commands for configuration)
    Sharlin Kothari
    Report Abuse
    • Reply
  • santosh vastrad
    on Aug 08 2012 02:25 AM
    Verified Answer
    Expert2065 points
    Sharlin:
    In Uboot source code:
    check beagle.c file
    functions:
    1) beagle_identity:
    2) misc_init_r:
    which pin want to control request, and set 0 or 1:
    also see beagle.h file for configuration
     MUX_VAL(CP(PIN_NAME),          (IDIS  | PTU | EN  | M4)) /*PIN_NAME*/\
    PIN_NAME : refer usermanual of AM3715
    santosh vastrad
    Report Abuse
    • Reply
  • Sharlin Kothari
    on Aug 08 2012 04:11 AM
    Prodigy30 points
    Hi Santosh
    thanks for your help.
    Right now I am syncronizing the repo again and redownload the source code as soon as i complete with that i will be working as per your guidance.
    Then also if some problem occurs then  i'll put a query to this post.
    Sharlin Kothari.
    Report Abuse
    • Reply
  • Sharlin Kothari
    on Aug 16 2012 01:02 AM
    Prodigy30 points
    Hi Santosh
    While compiling the U-boot I found the following error on my terminal and I am stuck as I can't move forward for compiling the other things:
    make: arm-eabi-gcc: Command not found
    find . -type f \
            \( -name 'core' -o -name '*.bak' -o -name '*~' \
            -o -name '*.o'  -o -name '*.a'  \) -print \
            | xargs rm -f
    find . -type f \
            \( -name .depend -o -name '*.srec' -o -name '*.bin' \) \
            -print \
            | xargs rm -f
    rm -f cpu/omap3/start.o *.bak tags TAGS
    rm -fr *.*~
    rm -f x-load x-load.map x-load.bin System.map
    rm -f include/asm/proc include/asm/arch
    rm -f include/config.h include/config.mk
    Please help me for the same.
    Sharlin Kothari
    Report Abuse
    • Reply
  • santosh vastrad
    on Aug 16 2012 04:03 AM
    Expert2065 points
    Sharlin:
    Follow below Link:
    http://processors.wiki.ti.com/index.php/AM35x-OMAP35x-PSP_03.00.00.05_UserGuide
    santosh vastrad
    Report Abuse
    • Reply
  • Sharlin Kothari
    on Aug 21 2012 06:40 AM
    Prodigy30 points
    Hi Santosh,
    I am working on JORJIN ATGN441-JS 11330-25 processor having core processor AM/DM 37X & TPS 65950 based COMPANY CUSTOMISED BOARD.
    I have compiled all the binaries successfully and make the MMC card using them still my board cannot be booted and the android screen is not coming up.
    Please help me regarding any end notes you can provide for the jorjin processor and any other help.
    Sharlin Kothari
    Report Abuse
    • Reply
  • Sharlin Kothari
    on Sep 17 2012 02:14 AM
    Prodigy30 points
    Hi
    Please help me regarding the above post of mine as I am stuck and I can't move ahead in my project.
    Sharlin Kothari
    Report Abuse
    • Reply
  • santosh vastrad
    on Sep 17 2012 03:58 AM
    Expert2065 points
    Sharlin:
    In your board, Nand flash is there?
    If Yes , try to boot from it, by flashing binaries onto the Nand flash!
    santosh vastrad
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
