• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Building full EtherCAT application with AM335X ICE
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Scott Nortman
Posted by Scott Nortman
on Aug 07 2012 08:34 AM
Prodigy200 points
I am able to get the 0.03 version of the industrial sdk to patch against the version 5.0 slave stack code, and I am able to import into CSS 5.
when I try to build the application, I receive the following errors, it appears to be a linking error:
**** Build of configuration Debug for project ecat_appl ****
C:\ti\ccsv5\utils\bin\gmake -k all
'Building file: ../app.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_23_03_53/xs" --xdcpath="C:/ti/bios_6_33_05_46/packages;C:/ti/ccsv5/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.A8Fnv -p ti.platforms.evmAM3359 -r release -c "C:/ti/ccsv5/tools/compiler/tms470_4.9.5" --compileOptions "-g --optimize_with_debug" "../app.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring app.xea8fnv from package/cfg/app_pea8fnv.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/src/sysbios/sysbios.lib ...
clea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/BIOS.c ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm.asm ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/TaskSupport_asm.asm ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/exc/Exception_asm.asm ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/a8/TimestampProvider_asm.asm ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/a8/Mmu_asm.asm ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/a8/Cache_asm.asm ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/a8/intcps/Hwi_asm.s470 ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/family/arm/a8/intcps/Hwi_asm_switch.s470 ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/timers/gptimer/Timer_asm.s470 ...
asmea8fnv C:/ti/bios_6_33_05_46/packages/ti/sysbios/timers/dmtimer/Timer_asm.s470 ...
area8fnv BIOS.obj arm_IntrinsicsSupport_asm.obj arm_TaskSupport_asm.obj exc_Exception_asm.obj a8_TimestampProvider_asm.obj a8_Mmu_asm.obj a8_Cache_asm.obj intcps_Hwi_asm.obj intcps_Hwi_asm_switch.obj gptimer_Timer_asm.obj dmtimer_Timer_asm.obj ...
Build of libraries done.
clea8fnv package/cfg/app_pea8fnv.c ...
'Finished building: ../app.cfg'
        1 file(s) copied.
making ../src/sysbios/sysbios.lib ...
gmake[1]: Nothing to be done for `all'.
'Building file: ../EcatStack/tiescappl.c'
'Invoking: TMS470 Compiler'
"C:/ti/ccsv5/tools/compiler/tms470_4.9.5/bin/cl470" -mv7A8 --code_state=32 --float_support=VFPv3D16 --abi=eabi -me -g --include_path="C:/ti/ccsv5/tools/compiler/tms470_4.9.5/include" --include_path="C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/src" --include_path="C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/EcatStack" --include_path="../../firmware" --include_path="../../../../drivers/include" --include_path="../../../../platform/am335x/evmam335x/include" --include_path="../../../../starterware/starterware-starterware-src/include" --include_path="../../../../starterware/starterware-starterware-src/include/hw" --gcc --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="EcatStack/tiescappl.pp" --obj_directory="EcatStack" --cmd_file="./configPkg/compiler.opt"  "../EcatStack/tiescappl.c"
'Finished building: ../EcatStack/tiescappl.c'
'Building file: ../EcatStack/tiescbsp.c'
"C:/ti/ccsv5/tools/compiler/tms470_4.9.5/bin/cl470" -mv7A8 --code_state=32 --float_support=VFPv3D16 --abi=eabi -me -g --include_path="C:/ti/ccsv5/tools/compiler/tms470_4.9.5/include" --include_path="C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/src" --include_path="C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/EcatStack" --include_path="../../firmware" --include_path="../../../../drivers/include" --include_path="../../../../platform/am335x/evmam335x/include" --include_path="../../../../starterware/starterware-starterware-src/include" --include_path="../../../../starterware/starterware-starterware-src/include/hw" --gcc --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="EcatStack/tiescbsp.pp" --obj_directory="EcatStack" --cmd_file="./configPkg/compiler.opt"  "../EcatStack/tiescbsp.c"
"../EcatStack/tiescbsp.c", line 199: warning #1219-D: arithmetic on pointer to void or function type
"../EcatStack/tiescbsp.c", line 207: warning #1219-D: arithmetic on pointer to void or function type
"../EcatStack/tiescbsp.c", line 536: warning #69-D: integer conversion resulted in a change of sign
"../EcatStack/tiescbsp.c", line 826: warning #1219-D: arithmetic on pointer to void or function type
"../EcatStack/tiescbsp.c", line 851: warning #1219-D: arithmetic on pointer to void or function type
"../EcatStack/tiescbsp.c", line 857: warning #1219-D: arithmetic on pointer to void or function type
"../EcatStack/tiescbsp.c", line 880: warning #1219-D: arithmetic on pointer to void or function type
'Finished building: ../EcatStack/tiescbsp.c'
'Building file: ../EcatStack/tieschw.c'
"C:/ti/ccsv5/tools/compiler/tms470_4.9.5/bin/cl470" -mv7A8 --code_state=32 --float_support=VFPv3D16 --abi=eabi -me -g --include_path="C:/ti/ccsv5/tools/compiler/tms470_4.9.5/include" --include_path="C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/src" --include_path="C:/ti/am335x_sysbios_ind_sdk_1.0.0.3/sdk/protocols/ethercat/ecat_appl/EcatStack" --include_path="../../firmware" --include_path="../../../../drivers/include" --include_path="../../../../platform/am335x/evmam335x/include" --include_path="../../../../starterware/starterware-starterware-src/include" --include_path="../../../../starterware/starterware-starterware-src/include/hw" --gcc --diag_warning=225 --display_error_number --preproc_with_compile --preproc_dependency="EcatStack/tieschw.pp" --obj_directory="EcatStack" --cmd_file="./configPkg/compiler.opt"  "../EcatStack/tieschw.c"
"../EcatStack/tieschw.c", line 461: warning #225-D: function declared implicitly
"../EcatStack/tieschw.c", line 563: warning #225-D: function declared implicitly
"../EcatStack/tieschw.c", line 565: warning #225-D: function declared implicitly
"../EcatStack/tieschw.c", line 568: warning #225-D: function declared implicitly
"../EcatStack/tieschw.c", line 570: warning #225-D: function declared implicitly
'Finished building: ../EcatStack/tieschw.c'
'Building target: ecat_appl.out'
'Invoking: TMS470 Linker'
"C:/ti/ccsv5/tools/compiler/tms470_4.9.5/bin/cl470" -mv7A8 --code_state=32 --float_support=VFPv3D16 --abi=eabi -me -g --gcc --diag_warning=225 --display_error_number -z -m"ecat_appl.map" -i"C:/ti/ccsv5/tools/compiler/tms470_4.9.5/lib" -i"C:/ti/ccsv5/tools/compiler/tms470_4.9.5/include" --reread_libs --warn_sections --rom_model -o "ecat_appl.out" -l"./configPkg/linker.cmd"  "./EcatStack/tieschw.obj" "./EcatStack/tiescbsp.obj" "./EcatStack/tiescappl.obj" -l"../../../../platform/am335x/evmam335x/lib/evmam335x.lib" -l"../../../../starterware/starterware-starterware-src/binary/armv7a/cgttms470_ccs/am335x/drivers/drivers.lib" -l"../../../../starterware/starterware-starterware-src/binary/armv7a/cgttms470_ccs/am335x/evmAM335x/platform/platform.lib" -l"../../../../drivers/lib/sys_bios_driver.lib" -l"rtsv7A8_A_le_n_v3_eabi.lib" "../am335x.cmd"
<Linking>
undefined           first referenced
  symbol                 in file
ECAT_CheckTimer     ./EcatStack/tiescappl.obj
MainInit            ./EcatStack/tiescappl.obj
MainLoop            ./EcatStack/tiescappl.obj
OBJ_GetEntryOffset  ./EcatStack/tiescappl.obj
OBJ_GetObjectHandle ./EcatStack/tiescappl.obj
PDI_Isr             ./EcatStack/tieschw.obj
PDO_InputMapping    ./EcatStack/tiescappl.obj
bRunApplication     ./EcatStack/tiescappl.obj
pEEPROM             ./EcatStack/tiescbsp.obj
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "ecat_appl.out" not built
>> Compilation failure
gmake: *** [ecat_appl.out] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Frank Walzer
    Posted by Frank Walzer
    on Aug 07 2012 08:42 AM
    Genius13535 points
    Scott,
    did you copy the patched sources into the project?
    Regards.
    Report Abuse
    • Reply
  • Scott Nortman
    on Aug 07 2012 09:51 AM
    Prodigy200 points
    Yes, I got it to build now.  The README file in the \patches directory for the 0.03 sdk is incorrect; it states to place the EtherCAT source code in to the \ecat_appl directory, but the online instructions state to place the code in the \EcatStack folder. Once all of the *.c and *.h files were in the EcatStack\src folder, it built (although with warnings).
    once I realized that, and deleted / resintalled from scratch, it worked....
    So I have 2 more questions:
    1) Do I need to generate a new ESI header file before building the ecat_appl application?
    2) Once I have the binary file ecat_appl_SD.bin, do I simply copy it to the micro SD card and place the card into the ICE board, or is there a special tool I need to make the SD card bootable with that file?\
    Thank you
    Report Abuse
    • Reply
  • Frank Walzer
    on Aug 07 2012 10:02 AM
    Genius13535 points
    Scott,
    Great!
    1) no, as long as you don't change the application code or any objects you can use the supplied ESI for ecat_appl (see the esi folder). Obviously you need new ESI files for your own products and applications.
    2) Copy and change name to "app". The SPI bootloader will check the SD for that file and load it. So we are not really booting from SD and there is no special bootable SD needed.
    Regards.
    Report Abuse
    • Reply
  • Scott Nortman
    on Aug 07 2012 12:02 PM
    Prodigy200 points
    I've been able to load the default full application to the SD card, and when watching the terminal screen I can see the bootloader is able to find the application, copy to RAM, and run it...
    But, when I go into the Beckhoff tool, I am not able to communicate with the device.  I have other off the shelf EtherCAT slave devices that do indeed work, but I don't seem to have any response from this as a slave device.
    What is the application supposed to do?
    Report Abuse
    • Reply
  • PratheeshGangadhar
    Posted by PratheeshGangadhar
    on Aug 07 2012 13:57 PM
    Intellectual1975 points
    So you get below message in console and see rolling LED pattern in digital output LEDs? Please make sure to connect Ethernet cable from master to J2 port which is EtherCAT IN port of ICE.
    EtherCAT Device
    TI Industrial SDK Version - 1.0.0.4
    Report Abuse
    • Reply
  • Scott Nortman
    on Aug 07 2012 14:00 PM
    Verified Answer
    Verified by Scott Nortman
    Prodigy200 points
    Everything is working, thank you again.
    --Scott
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
