• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » ARM® Processors » Sitara™ ARM® » AM3x Sitara ARM Processors Forum » Some questions on UBI
Share
Sitara™ ARM®
  • Forum
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Lihua Zhu
Posted by Lihua Zhu
on Aug 13 2012 21:01 PM
Intellectual820 points
I'm working with UBI these days. Thanks to the wiki page of TI, can make UBI images now.
But there are some questions about relationship between partitions,block devices, volumes:
    I know NAND flash can be divide to several partitions by the kernel, and each of them
    have a device name in the /dev directory, such as mtdblock0, mtdblock1...
    But it seems that UBI doesn't  depend on block device. What the usage of the
    partitions defined by the kernel in this situation? Should we flash the UBI images
    according to the partitions? We specify the volume name in the ubinize process,
    and every time we mount the file system, we should provide volume name of the
    image in mount command line. But after several days, we might forget the volume
    names of the images, How can we get the volume name then? Is there any
    handy tool? or we need to recreate a image?
Thank you.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Renjith Thomas
    Posted by Renjith Thomas
    on Aug 14 2012 14:17 PM
    Verified Answer
    Verified by Lihua Zhu
    Guru23890 points
    Zhu,
    1. Your understanding is partially correct. UBI doesn't depend on the block device doesn't mean that it doesn't use partitions. Instead of mtdblock0 it uses mtd0 which is a character interface to the same NAND partition. When you are creating a UBI volume you are creating it for the NAND partition and not for the entire NAND device.
    2. There are two options here, you can use the volume name in bootargs so that it will get mounted during boot. Another option is to give a generic name like "rootfs" which you'll not forget.
    -Renjith | www.pathpartnertech.com | Verify the answer if you think your query is resolved
    Report Abuse
    • Reply
  • Lihua Zhu
    Posted by Lihua Zhu
    on Aug 16 2012 20:04 PM
    Hi Thomas,
    Thank you very much for your reply. Now I created a ubi image, but after I flash it to Nand, the following message is given. I'm using a samsung mlc2 nand, K9GAG08UOE.
    Creating 3 MTD partitions on "NAND 2GiB 3,3V 8-bit":
    0x000000000000-0x000000400000 : "Bootloader"
    0x000000400000-0x000000c00000 : "Kernel"
    0x000000c00000-0x000080000000 : "File System"
    UBI: attaching mtd2 to ubi0
    UBI: physical eraseblock size:   1048576 bytes (1024 KiB)
    UBI: logical eraseblock size:    1032192 bytes
    UBI: smallest flash I/O unit:    8192
    UBI: VID header offset:          8192 (aligned 8192)
    UBI: data offset:                16384
    UBI warning: process_eb: valid VID header but corrupted EC header at PEB 0
    UBI warning: process_eb: valid VID header but corrupted EC header at PEB 1
    UBI warning: process_eb: valid VID header but corrupted EC header at PEB 2
    UBI error: check_corruption: PEB 13 contains corrupted VID header, and the data does not contain all 0xFF, n
    UBI error: check_what_we_have: 1 PEBs are corrupted and preserved
    Corrupted PEBs are: 13
    UBI: max. sequence number:       0
    UBI error: vtbl_check: volume table check failed: record 0, error 9
    UBI error: ubi_init: cannot attach mtd2
    Blow is how I create the image:
    mkfs.ubifs -r rootfs -m 8KiB -e 1008KiB -F -c 2012 -o rootfs.ubifs
    ubinize -o rootfs.ubi -m 8KiB -p 1024KiB -O 8192 ubinize.cfg
    And the ubinize.cfg:
    [ubifs]
    mode=ubi
    image=rootfs.ubifs
    vol_id=0
    vol_size=2036MiB
    vol_type=dynamic
    vol_name=rootfs
    vol_flags=autoresize
    I  don't  know where I went wrong. Could you help me out?
    Thank you very much!
    Report Abuse
    • Reply
  • santosh vastrad
    Posted by santosh vastrad
    on Aug 17 2012 00:15 AM
    Expert2065 points
    Lihua:
    Have got any solution for your issue?
    regards,
    santosh vastrad
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 17 2012 01:03 AM
    Guru23890 points
    Hi Zhu,
    I don't think AM335x support 8KB NAND page with hardware ecc supported. Check the register GPMC_ECC_CONFIG. Are you able to boot up the device from NAND with BCH8 algorithm?
    Report Abuse
    • Reply
  • Lihua Zhu
    Posted by Lihua Zhu
    on Aug 17 2012 06:01 AM
    Hi Thomas,
    I  made it on 335xEVK last week without any problem following the guidance. Now I do the same on a FriendlyArm 6410 board. it use a 8KB page nand. I can make a correct UBI image with the tool provided by FriendlyArm, but failed by manually make UBI image. the board will display the errors when kernel startup if I flash my own image to nand.
    I think it is a UBI making problem. So I asked here.
    Thanks.
    Report Abuse
    • Reply
  • Lihua Zhu
    Posted by Lihua Zhu
    on Aug 17 2012 06:15 AM
    sorry, I have not  got a solution.
    I read the help by run "mkfs.ubifs -h" and "ubinize -h", does it need other options than I used if using a mlc2 nand?
    I also find another item in ubinize.cfg when searching internet. vol_alignment, I noticed a ubinize.cfg of a nor flash is using it. What does it mean? I didn't find any explaination in the internet.
    thank you.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 19 2012 13:54 PM
    Suggested Answer
    Guru23890 points
    Zhu,
    I am not familiar with S3C6410 architecture. Could you please check first whether the NAND controller in 6410 support 8KB page size or not. Can you follow the steps below, which will create the UBI image from kernel itself. This will help you getting the right parameters for creating the UBI image from a PC. Change the commands according to your system.
    1. First you should have your rootfs as a tar ball in your SD card or NFS from where you mount the filesystem.
    2. Boot up the device and the filesystem from NFS or SD card according your preference.
    3. Boot it up and login. Hope you have all the required command binaries like "flash_erase" etc in your filesystem.
    4. Follow the steps below
    $ flash_erase /dev/mtd4 0 0
    $ ubiattach /dev/ubi_ctrl -m 4
    $ ubimkvol /dev/ubi0 -N rootfs -m
    $ mkdir /mnt/nand
    $ mount -t ubifs ubi0:rootfs /mnt/nand
    $ tar xvf rootfs.tar.gz -C /mnt/nand
    5. Change the bootargs like below for booting from UBIFS.
     'ubi.mtd=4 rootfstype=ubifs root=ubi0:rootfs rw'
    Report Abuse
    • Reply
  • Lihua Zhu
    Posted by Lihua Zhu
    on Aug 27 2012 05:19 AM
    HI Thomas,
    Sorry for the late reply, I was in my vacation last week.
    Thank you for your guidance. I made it according your steps. The rootfs is working now. But why it doesn't work when flashing a ubinized image to nand? Does this mean there is something wrong with the parameters of mkfs.ubifs and/or ubinize? How to check the parameters?
    Thank you very much.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 27 2012 07:44 AM
    Guru23890 points
    Hi Lihua,
    There are couple of issues in flashing from u-boot. Are you really looking forward to flash from u-boot?
    Report Abuse
    • Reply
  • Lihua Zhu
    Posted by Lihua Zhu
    on Aug 28 2012 02:38 AM
    Hi Renjith,
    We have a tool which can flash u-boot, kernel and rootfs in one step. It's very convenience for the line workers to produce products. So I prefer to make an image.
    could you please tell me what are the issue in flashing from u-boot., or could you please provide some links for that? I'm new to UBI. Thank you.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Sep 03 2012 02:47 AM
    Suggested Answer
    Guru23890 points
    One major issue with u-boot and UBI combination is that, assume that the given data for a page is 0xFF, which looks like an erased page. But when you write the same page from u-boot, it will calculate valid ECC values and write.
    Since the ubi.img will have pages which are erased(filled with 0xFF), and during bootup it will write these pages without erasing as it assumes these pages are already erased. So what happens here is, the kernel will overwrite the data area as well as spare area. Since the spare area already contains valid values, this write will overwrite it and corrupt it.
    So when it reads the page again, the ECC will mismatch even though the data is proper. It will try to correct (in turn corrupt) the data and if correction algorithm reaches its limit, the page read will fail with ECC errors.
    To avoid this problem you've to add support for a command in u-boot for flashing UBI images. Or else you can hack the u-boot NAND driver to ignore writes to the pages where data is completely 0xFF.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Sep 03 2012 02:48 AM
    Guru23890 points
    Hope the issue with u-boot is clear. Have you also explored the option of using NAND bulk programmer?
    Report Abuse
    • Reply
  • Jan Luebbe
    Posted by Jan Luebbe
    on Sep 03 2012 10:24 AM
    Prodigy70 points
    You might be able to work around this using UBIFS "free space fixup":
    http://www.linux-mtd.infradead.org/faq/ubifs.html#L_free_space_fixup
    Report Abuse
    • Reply
  • Lihua Zhu
    Posted by Lihua Zhu
    on Sep 16 2012 20:06 PM
    Hi Renjith,
    Thank you for the detailed explanation. Now I understand.
    For the K9GAG08uom, the datasheet claims that it need 24 bit ECC per 1KB data. But 6410 can provide only 16 bit ECC per 1KB data. I think it is not very safe to use that CPU with this nand flash. So I quit.
    We have decided to use AM3352 with a SLC nand. Many thanks to all you guys.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
