The current EtherCAT solution has a Known issue "SDOCM00092510"
in which case we cannot use LRD/LWR commands.
Can we assume this issue will not be fixed in the future releases?
Best Regards
Prad.
Prad1 said:The current EtherCAT solution has a Known issue "SDOCM00092510"
No plans to fix this for AM335x. If there is a compelling need we may consider to fix this for future platforms...
Hi
Our customer has been considering Sitara to build EtherCAT network.
They have concerned that limitations to master side might be occured due to SDOCM00092510 that is known issues and limitations of ISDK.
Their concern is Software PLC might not be able to configure LRD/LWR command that is mentioned as workaround except Beckoff PLC.
Could you please advise the above?
If their understanding is wrong , please let me know.
Best regards
