i need to connect the am4379 evm with the internet connection, so that i can update my package and install some softwares which i needed
I cannot understand your question. Please describe what you want to do in more detail.
Connect the EVM to your network with Internet access then run # ifup eth0. The DHCP will give it an IP address, Subnet Mask, GW address and DNS address if the DHCP is not provided by the network you will need to assign the network configuration parameters manually by # ifconfig. If you are behind a proxy you will need to enter the proxy settings too. After these configurations you should be able to access the Internet.
Hello Sarathi,
You get this error because of not cross-compiled application. My advice would be to start with the "Hands on with QT" steps. If you encounter difficulties with the steps, please create a new thread for your problem with mentioning the SDK details.
Kemal
