I saw the application note "High Speed Differential Signal Routing" which was very helpful.
You recommend a minimum spacing between high speed differential pairs (keep out layer).
But I didn't see any recommended specifications for the USB trace length between the USB Phy (microcontroller) and the USB port.
Do you recommended a max. PCB Trace length ? Or is it not so important ?
Thank you in advance,
Younes
