I am using the following configuration :
Target : AM335x Sitara evm Customer board
SDK : ti-processor-sdk-linux-am335x-evm-01.00.00.03
Host : Ubuntu 14.04
Kernel used : linux-3.14.43+gitAUTOINC+875c69b2c3-g875c69b (Just added our LCD module)
We also installed the Graphics_SDK_5_01_01_02. I will attach my Rules.make file here. I am unable to run the QT application.
Here is the kernel logs :
[ 9.267673] 0-0018 supply SPLVDD not found, using dummy regulator
[ 9.819307] cryptodev: driver 1.6 loaded.
[ 9.834574] pvrsrvkm: disagrees about version of symbol module_layout
[ 10.131493] pvrsrvkm: disagrees about version of symbol module_layout
[ 10.248354] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 10.276598] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 10.288214] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 10.295395] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 10.307741] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 10.315212] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
Starting PVR
[ 18.280595] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 18.292198] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 18.299398] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 18.311737] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 18.319186] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 18.433614] pvrsrvkm: disagrees about version of symbol module_layout
insmod: ERROR: could not insert module /lib/modules/3.14.43-g875c69b/extra/pvrsrvkm.ko: Invalid module format
Could not find pvrsrvkm driver
Starting Lighttpd Web Server: lighttpd.
& When I run my QT application, I get :
root@am335x-evm:/usr# ./myapp
PVR: Hint: Setting WindowSystem to libpvrPVR2D_FRONTWSEGL.so
PVR:(Error): PVRSRVMetricsTimeNow: using (potentially) low resolution timer [97, /pvr_metrics.c]
PVR:(Error): OpenServices: Cannot open device driver /dev/pvrsrvkm. [79, /pvr_bridge_u.c]
PVR:(Error): PVRSRVConnect: Unable to open connection. [337, /bridged_pvr_glue.c]
PVR:(Error): Couldn't connect to services [58, /srv_sgx.c]
Could not initialize egl display
Aborted
What I dont understand is even though I installed graphics SDK, I still face EGL error.
Please help us.
Thank you
Note :
#Rules.make
################# FIELDS MODIFIABLE BY THE USER ###############################
############### All the fields below are MANDATORY ############################
#By default all below variables have been initialized with equivalent AMSDK variables
# Change them to appropriate paths as per your machine/build environment paths.
# Set home area (ex /home/user/)
#HOME=$(SDK_INSTALL_DIR)/graphics
HOME=/home/vk18434
GRAPHICS_INSTALL_DIR=${HOME}/Graphics_SDK_5_01_01_02
# Set Toolchain path (ex /home/user/toolchain/arago-2011.09/armv7a)
CSTOOL_DIR=/home/vk18434/ti-processor-sdk-linux-am335x-evm-01.00.00.03/linux-devkit/sysroots/i686-arago-linux/usr/bin
# Set Tool chain prefix (ex arm-arago-linux-gnueabi- )
CSTOOL_PREFIX=arm-linux-gnueabihf-
# Set kernel installation path ( ex /home/user/linux-04.00.01.13 )
KERNEL_INSTALL_DIR=/media/vk18434/3c980693-a765-4d02-bd42-128e506d6ea0/cyient/ti-processor-sdk-linux-am335x-evm-01.00.00.03/board-support/linux-3.14.43+gitAUTOINC+875c69b2c3-g875c69b
# Set Target filesystem path ( ex /home/user/targetfs )
TARGETFS_INSTALL_DIR=/media/vk18434/rootfs1
# Set installation folder
GRAPHICS_INSTALL_DIR=$(HOME)/Graphics_SDK_5_01_01_02
U-Boot 2015.04-rc1-dirty (May 21 2015 - 18:32:42)
Watchdog enabled
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
Viswa this is my Image
Net: <ethaddr> not set. Validating first E-fuse MAC
Phy 0 not found
cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
4368432 bytes read in 613 ms (6.8 MiB/s)
36538 bytes read in 48 ms (743.2 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x42a830 ]
Loading Device Tree to 8e6f4000, end 8e6ffeb9 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.43-g875c69b (cyient@cyient-OptiPlex-9010) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.135
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x EVM-SK
[ 0.000000] cma: CMA: reserved 24 MiB at 8c800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64768
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 225184K/261120K available (5883K kernel code, 329K rwdata, 2168K rodata, 262K init, 238K bss, 35936K reserved, 0K highm)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07e50c4 (8053 kB)
[ 0.000000] .init : 0xc07e6000 - 0xc0827aac ( 263 kB)
[ 0.000000] .data : 0xc0828000 - 0xc087a5a0 ( 330 kB)
[ 0.000000] .bss : 0xc087a5a0 - 0xc08b5e78 ( 239 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000033] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[ 0.000078] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000688] Console: colour dummy device 80x30
[ 0.000741] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000757] This ensures that you still see kernel messages. Please
[ 0.000772] update your kernel commandline.
[ 0.000818] Calibrating delay loop... 298.59 BogoMIPS (lpj=1492992)
[ 0.068450] pid_max: default: 32768 minimum: 301
[ 0.068683] Security Framework initialized
[ 0.068799] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.068827] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.087608] CPU: Testing write buffer coherency: ok
[ 0.088339] Setting up static identity map for 0x805c4560 - 0x805c45b8
[ 0.090560] devtmpfs: initialized
[ 0.094933] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.113784] omap_hwmod: tptc0 using broken dt data from edma
[ 0.113993] omap_hwmod: tptc1 using broken dt data from edma
[ 0.114183] omap_hwmod: tptc2 using broken dt data from edma
[ 0.120733] omap_hwmod: debugss: _wait_target_disable failed
[ 0.190774] pinctrl core: initialized pinctrl subsystem
[ 0.193062] regulator-dummy: no parameters
[ 0.197841] NET: Registered protocol family 16
[ 0.202749] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.208920] cpuidle: using governor ladder
[ 0.208958] cpuidle: using governor menu
[ 0.225100] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered
[ 0.228702] platform 49000000.edma: alias fck already exists
[ 0.228757] platform 49000000.edma: alias fck already exists
[ 0.228794] platform 49000000.edma: alias fck already exists
[ 0.231473] OMAP GPIO hardware version 0.1
[ 0.256637] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe
[ 0.256711] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
[ 0.265752] No ATAGs?
[ 0.265794] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.333219] bio: create slab <bio-0> at 0
[ 0.373708] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.376039] vbat: 5000 mV
[ 0.376945] lis3_reg: no parameters
[ 0.378071] vtt: 1500 mV
[ 0.385825] vgaarb: loaded
[ 0.387098] i2c-core: driver [palmas] using legacy suspend method
[ 0.387125] i2c-core: driver [palmas] using legacy resume method
[ 0.388967] SCSI subsystem initialized
[ 0.392612] usbcore: registered new interface driver usbfs
[ 0.393070] usbcore: registered new interface driver hub
[ 0.393566] usbcore: registered new device driver usb
[ 0.395855] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
[ 0.395919] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[ 0.395985] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c1_pins, deferring probe
[ 0.396022] platform 4802a000.i2c: Driver omap_i2c requests probe deferral
[ 0.396964] pps_core: LinuxPPS API ver. 1 registered
[ 0.396989] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.397332] PTP clock support registered
[ 0.402214] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.404243] Advanced Linux Sound Architecture Driver Initialized.
[ 0.407993] Switched to clocksource timer1
[ 0.456839] NET: Registered protocol family 2
[ 0.458988] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.459075] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.459147] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.459300] TCP: reno registered
[ 0.459331] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.459379] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.459790] NET: Registered protocol family 1
[ 0.460615] RPC: Registered named UNIX socket transport module.
[ 0.460643] RPC: Registered udp transport module.
[ 0.460660] RPC: Registered tcp transport module.
[ 0.460676] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462998] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.469653] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.910550] VFS: Disk quotas dquot_6.5.2
[ 0.910693] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.911833] NFS: Registering the id_resolver key type
[ 0.911994] Key type id_resolver registered
[ 0.912014] Key type id_legacy registered
[ 0.912102] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.912511] msgmni has been set to 487
[ 0.916020] NET: Registered protocol family 38
[ 0.916108] io scheduler noop registered
[ 0.916129] io scheduler deadline registered
[ 0.916180] io scheduler cfq registered (default)
[ 0.920436] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.936682] fb_ph128160 itdb28: Dev Dev fbtft_probe_common()
[ 0.936726] fb_ph128160 itdb28: fbtft_probe_common()
[ 0.936763] fbtft_of_value: buswidth = 8
[ 0.936787] fbtft_of_value: debug = 1
[ 0.936806] fbtft_of_value: rotate = 90
[ 0.937104] fb_ph128160 itdb28: FBTFT Registering Write Resigter with 8 and 8
[ 0.937379] fb_ph128160 itdb28: fbtft_request_one_gpio: 'dc-gpios' = GPIO86
[ 0.937462] fb_ph128160 itdb28: fbtft_request_one_gpio: 'rd-gpios' = GPIO88
[ 0.937531] fb_ph128160 itdb28: fbtft_request_one_gpio: 'wr-gpios' = GPIO87
[ 0.937596] fb_ph128160 itdb28: fbtft_request_one_gpio: 'cs-gpios' = GPIO89
[ 0.937665] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO70
[ 0.937738] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO71
[ 0.937814] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO72
[ 0.937895] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO73
[ 0.938087] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO74
[ 0.938189] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO75
[ 0.938286] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO76
[ 0.938383] fb_ph128160 itdb28: fbtft_request_one_gpio: 'db-gpios' = GPIO77
[ 0.938878] fb_ph128160 itdb28: SANJU Init Display called making RD as High
[ 2.594842] (NULL device *): SANJU, Calling init Display -1070712612 and return is 0
[ 2.594875] fb_ph128160 itdb28: SANJU Init Display called making RD as High
[ 4.250774] (NULL device *): SANJU, Calling init Display -1070712612 and return is 0
[ 4.250806] (NULL device *): SANJU, Done with Display Init Check for logsConsole: switching to colour frame buffer device 20x16
[ 4.351257] graphics fb0: fb_ph128160 frame buffer, 162x128, 40 KiB video memory, 4 KiB DMA buffer memory, fps=20
[ 4.360808] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 4.373472] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a 8250
[ 5.309805] console [ttyS0] enabled
[ 5.316107] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a 8250
[ 5.329395] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 5.336936] [drm] Initialized drm 1.1.0 20060810
[ 5.374989] brd: module loaded
[ 5.392168] loop: module loaded
[ 5.396170] (hci_tty): inside hci_tty_init
[ 5.401550] (hci_tty): allocated 250, 0
[ 5.412874] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 5.429411] usbcore: registered new interface driver asix
[ 5.435372] usbcore: registered new interface driver ax88179_178a
[ 5.441930] usbcore: registered new interface driver cdc_ether
[ 5.448364] usbcore: registered new interface driver smsc95xx
[ 5.454486] usbcore: registered new interface driver net1080
[ 5.460646] usbcore: registered new interface driver cdc_subset
[ 5.467066] usbcore: registered new interface driver zaurus
[ 5.473189] usbcore: registered new interface driver cdc_ncm
[ 5.480192] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.486773] ehci-pci: EHCI PCI platform driver
[ 5.491794] ehci-omap: OMAP-EHCI Host Controller driver
[ 5.498211] usbcore: registered new interface driver cdc_wdm
[ 5.504460] usbcore: registered new interface driver usb-storage
[ 5.513016] mousedev: PS/2 mouse device common for all mice
[ 5.523361] i2c-core: driver [rtc-ds1307] using legacy suspend method
[ 5.529939] i2c-core: driver [rtc-ds1307] using legacy resume method
[ 5.537976] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 5.547182] i2c /dev entries driver
[ 5.551299] Driver for 1-wire Dallas network protocol.
[ 5.561849] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 5.572261] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 5.583833] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 5.591067] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 5.603454] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 5.617771] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 5.629320] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 5.636515] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 5.648885] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 5.656336] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 5.662914] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 5.674417] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 5.681639] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 5.693999] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 5.701475] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 5.708594] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 5.715391] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 5.730400] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.737156] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 5.746038] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 5.755638] usbcore: registered new interface driver usbhid
[ 5.761350] usbhid: USB HID core driver
[ 5.765800] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[ 5.780560] oprofile: using arm/armv7
[ 5.784925] TCP: cubic registered
[ 5.788366] Initializing XFRM netlink socket
[ 5.792832] NET: Registered protocol family 17
[ 5.797394] NET: Registered protocol family 15
[ 5.808312] Key type dns_resolver registered
[ 5.814314] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 5.823189] cpu cpu0: cpu0 clock notifier not ready, retry
[ 5.828795] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 5.837622] PM: bootloader does not support rtc-only!
[ 5.842974] ThumbEE CPU extension supported.
[ 5.847358] Registering SWP/SWPB emulation handler
[ 5.855708] lis3_reg: disabling
[ 5.859127] vbat: disabling
[ 5.861956] regulator-dummy: disabling
[ 5.867236] Error: Driver 'tfp410' is already registered, aborting...
[ 5.876343] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 5.881641] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 5.890045] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 5.896463] nand: Micron MT29F2G08ABAEAWP
[ 5.900601] nand: 256MiB, SLC, page size: 2048, OOB size: 64
[ 5.906302] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 5.912055] 10 ofpart partitions found on MTD device omap2-nand.0
[ 5.918242] Creating 10 MTD partitions on "omap2-nand.0":
[ 5.923695] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 5.932936] 0x000000020000-0x000000040000 : "NAND.SPL.backup1"
[ 5.942665] 0x000000040000-0x000000060000 : "NAND.SPL.backup2"
[ 5.952355] 0x000000060000-0x000000080000 : "NAND.SPL.backup3"
[ 5.961781] 0x000000080000-0x0000000c0000 : "NAND.u-boot-spl-os"
[ 5.971570] 0x0000000c0000-0x0000001c0000 : "NAND.u-boot"
[ 5.981355] 0x0000001c0000-0x0000001e0000 : "NAND.u-boot-env"
[ 5.990778] 0x0000001e0000-0x000000200000 : "NAND.u-boot-env.backup1"
[ 6.007109] 0x000000200000-0x000000a00000 : "NAND.kernel"
[ 6.022983] 0x000000a00000-0x000010000000 : "NAND.rootfs"
[ 6.245182] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz
[ 6.254916] tps65910 1-002d: No interrupt support, no core IRQ
[ 6.267423] vrtc: 1800 mV
[ 6.270687] vrtc: supplied by vbat
[ 6.276583] vio: at 1500 mV
[ 6.285869] vio: supplied by vbat
[ 6.292033] vdd_mpu: 912 <--> 1375 mV at 1100 mV
[ 6.296939] vdd_mpu: supplied by vbat
[ 6.303470] vdd_core: 912 <--> 1150 mV at 1100 mV
[ 6.308530] vdd_core: supplied by vbat
[ 6.314603] vdd3: 5000 mV
[ 6.319602] vdig1: at 1800 mV
[ 6.322854] vdig1: supplied by vbat
[ 6.328662] vdig2: at 1800 mV
[ 6.331913] vdig2: supplied by vbat
[ 6.337648] vpll: at 1800 mV
[ 6.340858] vpll: supplied by vbat
[ 6.346386] vdac: at 1800 mV
[ 6.349695] vdac: supplied by vbat
[ 6.355367] vaux1: at 1800 mV
[ 6.358660] vaux1: supplied by vbat
[ 6.364398] vaux2: at 3300 mV
[ 6.367661] vaux2: supplied by vbat
[ 6.373491] vaux33: at 3300 mV
[ 6.376826] vaux33: supplied by vbat
[ 6.382686] vmmc: 1800 <--> 3300 mV at 3300 mV
[ 6.387415] vmmc: supplied by vbat
[ 6.392637] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[ 6.405504] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 6.417074] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 6.424309] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 6.436682] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 6.444794] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 6.456330] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 6.463559] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 6.475932] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 6.483408] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 6.490003] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 6.501503] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 6.508725] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 6.521089] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 6.528563] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 6.569380] remoteproc0: wkup_m3 is available
[ 6.573888] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 6.582997] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.593807] remoteproc0: Direct firmware load failed with error -2
[ 6.600241] remoteproc0: Falling back to user helper
[ 6.678019] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 6.684168] davinci_mdio 4a101000.mdio: no live phy, scanning all
[ 6.690820] davinci_mdio: probe of 4a101000.mdio failed with error -5
[ 6.698604] cpsw 4a100000.ethernet: Missing slave[0] phy_id property
[ 6.705007] cpsw 4a100000.ethernet: cpsw: platform data missing
[ 6.713838] input: gpio_buttons@0 as /devices/gpio_buttons@0/input/input0
[ 6.721976] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 6.733783] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 6.743136] ALSA device list:
[ 6.746134] No soundcards found.
[ 6.750600] Waiting for root device /dev/mmcblk0p2...
[ 6.755939] mmc0: new high speed SDHC card at address aaaa
[ 6.762663] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 6.769376] mmcblk0: p1 p2
[ 6.860634] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 6.868063] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 7.210900] EXT4-fs (mmcblk0p2): recovery complete
[ 7.252549] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 7.260884] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 7.271943] devtmpfs: mounted
[ 7.276039] Freeing unused kernel memory: 260K (c07e6000 - c0827000)
INIT: version 2.88 booting
Starting udev
[ 8.246861] udevd[919]: starting version 182
[ 8.591938] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 8.603532] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 8.610731] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 8.623072] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 8.630538] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 8.969984] remoteproc0: powering up wkup_m3
[ 8.975333] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 154412
[ 8.988968] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 9.058397] 0-0018 supply HPVDD not found, using dummy regulator
[ 9.064533] 0-0018 supply SPRVDD not found, using dummy regulator
[ 9.117410] PM: CM3 Firmware Version = 0x190
[ 9.159199] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 9.170755] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 9.177937] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 9.190283] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 9.197717] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 9.238872] remoteproc0: remote processor wkup_m3 is now up
[ 9.258380] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 10.774479] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 10.964061] davinci_evm sound: snd_soc_register_card failed (-517)
[ 11.208819] platform sound: Driver davinci_evm requests probe deferral
Starting Bootlog daemon:
udevadm settle - timeout of 3 seconds reached, the event queue contains:
/sys/devices/ocp/48060000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1 (900)
/sys/devices/ocp/48060000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2 (901)
/sys/devices/virtual/block/loop0 (1046)
/sys/devices/virtual/block/loop3 (1049)
/sys/devices/virtual/block/loop4 (1050)
/sys/devices/virtual/block/loop5 (1051)
/sys/devices/virtual/block/loop6 (1052)
/sys/devices/virtual/block/loop7 (1053)
/sys/devices/virtual/block/ram0 (1054)
/sys/devices/virtual/block/ram1 (1055)
/sys/devices/virtual/block/ram10 (1056)
/sys/devices/virtual/block/ram11 (1057)
/sys/devices/virtual/block/ram12 (1058)
/sys/devices/virtual/block/ram13 (1059)
/sys/devices/virtual/block/ram14 (1060)
/sys/devices/virtual/block/ram15 (1061)
/sys/devices/virtual/block/ram2 (1062)
/sys/devices/virtual/block/ram3 (1063)
/sys/devices/virtual/block/ram4 (1064)
/sys/devices/virtual/block/ram5 (1065)
/sys/devices/virtual/block/ram6 (1066)
/sys/devices/virtual/block/ram7 (1067)
/sys/devices/virtual/block/ram8 (1068)
/sys/devices/virtual/block/ram9 (1069)
/sys/devices/virtual/mtd/mtd0/mtdblock0 (1077)
/sys/devices/virtual/mtd/mtd1/mtdblock1 (1080)
/sys/devices/virtual/mtd/mtd2/mtdblock2 (1083)
/sys/devices/virtual/mtd/mtd3/mtdblock3 (1086)
/sys/devices/virtual/mtd/mtd4/mtdblock4 (1089)
/sys/devices/virtual/mtd/mtd4ro (1090)
/sys/devices/virtual/mtd/mtd5/mtdblock5 (1092)
/sys/devices/virtual/mtd/mtd5ro (1093)
/sys/devices/virtual/mtd/mtd6/mtdblock6 (1095)
[ 12.159570] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 12.171149] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 12.178349] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 12.190689] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 12.198139] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 13.506047] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
[ 13.724108] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 13.848570] random: nonblocking pool is initialized
[ 13.864159] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 13.871128] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.878408] usb usb1: Product: MUSB HDRC host driver
[ 13.883400] usb usb1: Manufacturer: Linux 3.14.43-g875c69b musb-hcd
[ 13.889731] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 14.216764] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 14.239191] hub 1-0:1.0: USB hub found
[ 14.280261] hub 1-0:1.0: 1 port detected
[ 14.339593] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 14.346935] davinci_evm sound: snd_soc_register_card failed (-517)
[ 14.410914] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 14.489076] platform sound: Driver davinci_evm requests probe deferral
[ 14.496730] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 14.504837] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2
[ 14.557216] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 14.564177] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.571457] usb usb2: Product: MUSB HDRC host driver
[ 14.576448] usb usb2: Manufacturer: Linux 3.14.43-g875c69b musb-hcd
[ 14.582765] usb usb2: SerialNumber: musb-hdrc.1.auto
[ 14.607783] davinci_evm sound: snd_soc_register_card failed (-517)
[ 14.624599] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 14.636217] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 14.643419] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 14.655761] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 14.663212] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 14.669899] platform sound: Driver davinci_evm requests probe deferral
[ 14.733393] hub 2-0:1.0: USB hub found
[ 14.744906] hub 2-0:1.0: 1 port detected
[ 14.750878] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 14.798331] davinci_evm sound: snd_soc_register_card failed (-517)
[ 14.804645] platform sound: Driver davinci_evm requests probe deferral
[ 14.899284] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 14.923853] davinci_evm sound: snd_soc_register_card failed (-517)
[ 14.955155] platform sound: Driver davinci_evm requests probe deferral
[ 15.258746] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 15.270316] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 15.277495] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 15.289842] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 15.297277] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 15.359089] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (80, <SessEnd), retry #3, port1 0008010c
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1729: No soundcards found...
Mon Jul 6 21:04:00 UTC 2015
INIT: Entering runlevel: 5
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
done.
[ 16.126173] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 16.137774] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 16.144974] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 16.157314] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 16.164765] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
Starting system message bus: dbus.
UIM SYSFS Node Not Found
[ 17.028926] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 17.040480] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 17.047659] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 17.060024] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 17.067459] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting rpcbind daemon...rpcbind: cannot create socket for udp6
rpcbind: cannot create socket for tcp6
done.
creating NFS state directory: done
starting statd: done
Starting syslogd/klogd: done
Starting thttpd.
Starting PVR
2015-07-06 21:04:02: (/home/gtbldadm/ti/oe-layersetup/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8t2hf-vfp-neon-linux-gnue
Starting Matrix GUI application.
Enabling thermal zones...
/etc/rc5.d/S98thermal-zone-init: line 7: /sys/class/thermal/thermal_zone*/mode: No such file or directory
NOTICE: This file system contains the followin GPLv3 packages[ 22.122359] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested bc
autoconf
binutils
cpp-symlinks
cpp
g++-symlinks
g+[ 22.134027] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
gcc-symlinks
gcc
gdbserver
gstreamer1.0-libav
libgmp[ 22.146776] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pine
10
libmpc3
libmpfr4
make
If you do not wish to distribu[ 22.164675] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
te GPLv3 components please remove
the above packages prior to d[ 22.177687] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
istribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
Stopping Bootlog daemon: bootlogd.
[ 22.357866] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 22.369471] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 22.376653] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 22.388996] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 22.396432] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm /dev/ttyO0
Arago 2015.05 am335x-evm /dev/ttyO0
am335x-evm login: root
[ 24.402593] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 24.414226] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 24.421462] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 24.433835] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 24.441315] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
root@am335x-evm:~# cd /usr/
root@am335x-evm:/usr# ./tailyn
[ 29.322751] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 29.334423] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 29.341661] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 29.354033] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 29.361513] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
[ 29.499819] pinctrl-single 44e10800.pinmux: pin 44e109a0.0 already requested by 44e10800.pinmux; cannot claim for 48060000.mmc
[ 29.511444] pinctrl-single 44e10800.pinmux: pin-104 (48060000.mmc) status -22
[ 29.518679] pinctrl-single 44e10800.pinmux: could not request pin 104 (44e109a0.0) from group pinmux_mmc1_pins on device pinctrl-single
[ 29.531049] omap_hsmmc 48060000.mmc: Error applying setting, reverse things back
[ 29.538526] omap_hsmmc 48060000.mmc: failed to activate pinctrl state
Aborted
