Hi Forum,
I wonder if any one can shed light on my PIN MUXING PROCESS for BB compatible custom board using AM3352 CPU and MICREL KSZ8081RNA chip set for an ether net. The data sheet from Micrel strongly advise to use 25Mhz clock frequency; which available on board of the chip under external-ref.
The extract from board/ti/am335x/mux.c
static struct module_pin_mux rmii1_pin_mux[] = {
{OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* GWCS1X_RMII_1 -> rmii1_crs_dv -> H17 */
{OFFSET(mii1_txen), MODE(1)}, /* GWCS1X_RMII_1 -> rmii1_txen -> J16 */
{OFFSET(mii1_txd0), MODE(1)}, /* GWCS1X_RMII_1 -> rmii1_txd0 -> K17 */
{OFFSET(mii1_txd1), MODE(1) | RXACTIVE}, /* GWCS1X_RMII_1 -> rmii1_txd1 -> K16 */
{OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* GWCS1X_RMII_1 -> rmii1_rxd0 -> M16 */
{OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* GWCS1X_RMII_1 -> rmii1_rxd1 -> L15 */
{OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* GWCS1X_RMII_1 -> rmii1_refclk -> H18 (Pg37dsheet 0=25Mhz,1=50Mhz) */
{OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* GWCS1X_MDIO 1 -> mdio_data -> M17 */
{OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* GWCS1X_MDIO 1 -> mdio_clk -> M18 */
{-1}
/* Initialisaton for the second ethernet port on the board */
static struct module_pin_mux rmii2_pin_mux[] = {
{OFFSET(mii1_crs), MODE(2) | RXACTIVE}, /* GWCS1X_RMII_2 -> rmii2_crs_dv -> T17 */
{OFFSET(mii1_txen), MODE(3)}, /* GWCS1X_RMII_2 -> rmii2_txen -> R13 */
{OFFSET(mii1_txd0), MODE(3)}, /* GWCS1X_RMII_2 -> rmii2_txd0 -> V15 */
{OFFSET(mii1_txd1), MODE(3) | RXACTIVE}, /* GWCS1X_RMII_2 -> rmii2_txd0 -> R14 */
{OFFSET(mii1_rxd0), MODE(3) | RXACTIVE}, /* GWCS1X_RMII_2 -> rmii2_rxd0 -> V17 */
{OFFSET(mii1_rxd1), MODE(3) | RXACTIVE}, /* GWCS1X_RMII_2 -> rmii2_rxd1 -> T16 */
{OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* GWCS1X_RMII_2 -> rmii2_refclk -> H16 (Pg37dsheet 0=25mhz 1=50Mhz) */
{-1},
configure_module_pin_mux(i2c1_pin_mux);
configure_module_pin_mux(rmii1_pin_mux);
configure_module_pin_mux(rmii2_pin_mux);
configure_module_pin_mux(mmc0_pin_mux);
/* We do not have second mmc slot */
// configure_module_pin_mux(mmc1_pin_mux);
