I am working on AM4377 based custom board. Silicon version is 1.2.
Ethernet is working fine on RGMII1. Now I have trying to make ethernet up on RGMII2 port, I have done all required configuration.
"eth1" interface is listing up on ifconfig command. but ping is failing.
Following are my observations
1. In Wireshark I analyzed the packets. I found that some ARP broadcast packets are going from board. Also if I ping from Host PC, ARP response is going from the board. But ping response is not going.
2. ping is working on RGMII2 if I connect Ethernet cable to RGMII1 port and ping is stopping if I remove cable from RGMII1 port.
Let me know If I am missing any configuration and how ping is working if I connect ethernet cable to Port 1.
Thanks and Regards,
Krishna
