I want to use DSPDCE in processor SDK 02.00.00. My target platform is AM572x. I want to modify and build DSPDCE. Can anybody point me to the DSPDCE source and the instructions to build the same?
Apoorva
Apoorva
First run:
export ARCH=arm
export PATH=$PATH:$HOME/ti-processor-sdk-linux-am57xx-evm-02.00.00.00/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/
export CROSS_COMPILE=arm-linux-gnueabihf-
Since the DSP_DCE component is part of the glsdk, I would point you to the makefile & rules.make of that linux sdk.
There is a make dspdce command, which executes the following:
# Build dspdce. Also, an explicit cleanup target is defined.
dspdce:ipc_dsp
$(MAKE) -C $(DSPDCE_INSTALL_DIR) $(DSPDCE_BUILD_VARS) $(DEFAULT_DSPDCE_CONFIG)
dspdce_clean:
$(MAKE) -C $(DSPDCE_INSTALL_DIR) $(DSPDCE_BUILD_VARS) clean
dspdce_install:
install -d $(EXEC_DIR)/lib/firmware
install $(DSPDCE_INSTALL_DIR)/$(DSP_FW_GEN) $(EXEC_DIR)/lib/firmware/$(DSP_FW)
From Rules.make, you have the follwoing for the above variables:
# DSPDCE build variables
DSPDCE_BUILD_VARS = BIOSTOOLSROOT=$(BIOSTOOLSROOT_INSTALL_DIR) \
IPCSRC=$(IPC_INSTALL_DIR) \
IPCVERSION=ipc_$(IPC_VERSION) \
BIOSVERSION=bios_$(BIOS_VERSION) \
XDCVERSION=$(XDC_VERSION) \
FCVERSION=$(FC_VERSION) \
C66XCGTOOLSPATH=$(CODEGEN_INSTALL_DIR) \
PLATFORM=$(REVISION)
*_INSTALL_DIR variables above point to the location of the component sources.
DSPDCE_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources/dspdce_$(DSPDCE_VERSION) /* in your case path/to/dsp-dce/sources*/
DEFAULT_DSPDCE_CONFIG=vayu_config
The variables used in DSPDCE_BUILD_VARS are:
# Define target platform.
PLATFORM=dra7xx
REVISION=ES10
DEFAULT_LINUXKERNEL_CONFIG=omap2plus_defconfig
DEFAULT_UBOOT_CONFIG=dra7xx_evm_config
DEFAULT_IPUMM_CONFIG=vayu_smp_config
BIOS_VERSION=6_41_04_54
IPC_VERSION=3_36_01_11
IPUMM_VERSION=3_00_08_02
DSPDCE_VERSION=1_00_00_05
DUCATI_FW_GEN=dra7xx-m4-ipu2.xem4
DUCATI_FW=dra7-ipu2-fw.xem4
DSP_FW_GEN=dra7xx-c66x-dsp.xe66
DSP_FW=dra7-dsp1-fw.xe66
XDC_VERSION=xdctools_3_30_06_67
FC_VERSION=framework_components_3_40_01_04
PLATFORM_IPC=DRA7XX
LINUXUTILS_VERSION=4_10_01_02
I am also attaching the referred makefile & rules.make files:
include Rules.make .PHONY: components components_clean components_linux all clean help linux linux_clean linux_install install u-boot u-boot_clean u-boot_install #============================================================================== # Build everything rebuildable. #============================================================================== all: components apps #============================================================================== # Build components to enable all other build targets. #============================================================================== components: components_linux components_ipu components_dsp components_linux: linux components_ipu: ipumm components_dsp: dspdce #============================================================================== # Install components #============================================================================== components_install: linux_install ipumm_install dspdce_install #============================================================================== # Clean up the targets built by 'make all'. #============================================================================== components_clean: linux_clean ipc_clean ipumm_clean dspdce_clean #============================================================================== # Build all Demos, Examples and Applications #============================================================================== apps: u-boot #============================================================================== # Install everything #============================================================================== apps_install: u-boot_install #============================================================================== # Clean all Demos, Examples and Applications #============================================================================== apps_clean: u-boot_clean #============================================================================== # Install everything #============================================================================== install: components_install apps_install #============================================================================== # Clean up all targets. #============================================================================== clean: components_clean apps_clean #============================================================================== # A help message target. #============================================================================== help: @echo @echo "Available build targets are :" @echo @echo " components_linux : Build the Linux components" @echo " components_ipu : Build the IPU components" @echo " components_dsp : Build the DSP components" @echo " components : Build the components for which a rebuild is necessary to enable all other build targets listed below. You must do this at least once upon installation prior to attempting the other targets." @echo " components_clean : Remove files generated by the 'components' target" @echo @echo " apps : Build all Examples, Demos and Applications" @echo " apps_clean : Remove all files generated by 'apps' target" @echo " apps_install : Install all Examples, Demos and Applications the targets in $(EXEC_DIR)" @echo @echo @echo " linux : Build Linux kernel uImage and module" @echo " linux_clean : Remove generated Linux kernel files" @echo " linux_install : Install kernel binary and modules" @echo @echo " ipc_ipu : Build ipc for IPU" @echo " ipc_dsp : Build ipc for DSP" @echo " ipc_clean : Remove generated ipc files" @echo @echo " u-boot : Build the u-boot boot loader" @echo " u-boot_clean : Remove generated u-boot files" @echo " u-boot_install : Install the u-boot image" @echo @echo " ipumm : Build the ipumm firmware" @echo " ipumm_clean : Remove generated ipumm files" @echo " ipumm_install : Install the ipumm firmware" @echo @echo @echo " dspdce : Build the dspdce firmware" @echo " dspdce_clean : Remove generated dspdce files" @echo " dspdce_install : Install the dspdce firmware" @echo @echo @echo " all : Rebuild everything" @echo " clean : Remove all generated files" @echo @echo " install : Install all the targets in " @echo " $(EXEC_DIR)" @echo #============================================================================== # Build the Linux kernel. Also, an explicit cleanup target is defined. #============================================================================== linux: $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) ARCH=arm $(DEFAULT_LINUXKERNEL_CONFIG) cd $(LINUXKERNEL_INSTALL_DIR); pwd ; ./scripts/kconfig/merge_config.sh -m .config ti_config_fragments/audio_display.cfg ti_config_fragments/baseport.cfg ti_config_fragments/connectivity.cfg ti_config_fragments/ipc.cfg ti_config_fragments/power.cfg ti_config_fragments/wlan.cfg ti_config_fragments/system_test.cfg ti_config_fragments/auto.cfg ti_config_fragments/radio.cfg $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) olddefconfig ARCH=arm $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) $(LINUXKERNEL_BUILD_VARS) zImage $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) $(LINUXKERNEL_BUILD_VARS) dtbs $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) $(LINUXKERNEL_BUILD_VARS) modules $(MAKE) -C $(SGX_KERNEL_MODULE_PATH) $(LINUXKERNEL_BUILD_VARS) KERNELDIR=$(LINUXKERNEL_INSTALL_DIR) DISCIMAGE=$(EXEC_DIR) linux_clean: $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) mrproper $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) $(LINUXKERNEL_BUILD_VARS) clean linux_install: install -d $(EXEC_DIR)/boot install $(LINUXKERNEL_INSTALL_DIR)/arch/arm/boot/zImage $(EXEC_DIR)/boot install $(LINUXKERNEL_INSTALL_DIR)/arch/arm/boot/dts/*.dtb $(EXEC_DIR)/boot install $(LINUXKERNEL_INSTALL_DIR)/vmlinux $(EXEC_DIR)/boot install $(LINUXKERNEL_INSTALL_DIR)/System.map $(EXEC_DIR)/boot $(MAKE) -C $(LINUXKERNEL_INSTALL_DIR) $(LINUXKERNEL_BUILD_VARS) INSTALL_MOD_PATH=$(EXEC_DIR)/ modules_install $(MAKE) -C $(SGX_KERNEL_MODULE_PATH) $(LINUXKERNEL_BUILD_VARS) KERNELDIR=$(LINUXKERNEL_INSTALL_DIR) DISCIMAGE=$(EXEC_DIR) kbuild_install #============================================================================== # Build u-boot. Also, an explicit cleanup target is defined. #============================================================================== u-boot: $(MAKE) -C $(UBOOT_INSTALL_DIR) $(UBOOT_BUILD_VARS) $(DEFAULT_UBOOT_CONFIG) $(MAKE) -C $(UBOOT_INSTALL_DIR) $(UBOOT_BUILD_VARS) u-boot_clean: $(MAKE) -C $(UBOOT_INSTALL_DIR) $(UBOOT_BUILD_VARS) distclean u-boot_install: install -d $(EXEC_DIR)/boot install $(UBOOT_INSTALL_DIR)/MLO $(EXEC_DIR)/boot install $(UBOOT_INSTALL_DIR)/u-boot.img $(EXEC_DIR)/boot install $(UBOOT_INSTALL_DIR)/u-boot.map $(EXEC_DIR)/boot #============================================================================== # Build ipc for ipu. Also, an explicit cleanup target is defined. #============================================================================== ipc_ipu: $(MAKE) -C $(IPC_INSTALL_DIR) PLATFORM=${PLATFORM_IPC} ti.targets.arm.elf.M4=${TMS470CGTOOLPATH_INSTALL_DIR} XDC_INSTALL_DIR=${XDC_INSTALL_DIR} BIOS_INSTALL_DIR=${BIOS_INSTALL_DIR} -ef ipc-bios.mak all #============================================================================== # Build ipc for dsp. Also, an explicit cleanup target is defined. #============================================================================== ipc_dsp: $(MAKE) -C $(IPC_INSTALL_DIR) PLATFORM=${PLATFORM_IPC} ti.targets.elf.C66=${CODEGEN_INSTALL_DIR} XDC_INSTALL_DIR=${XDC_INSTALL_DIR} BIOS_INSTALL_DIR=${BIOS_INSTALL_DIR} -f ipc-bios.mak all ipc_mpu: linux_utils $(MAKE) -e -C $(IPC_INSTALL_DIR) PLATFORM=${PLATFORM_IPC} \ CMEM_INSTALL_DIR=${LINUXUTILS_INSTALL_DIR} \ TOOLCHAIN_LONGNAME=arm-linux-gnueabihf \ TOOLCHAIN_PREFIX=${CROSS_COMPILE_PREFIX} \ KERNEL_INSTALL_DIR=${KERNEL_INSTALL_DIR} \ -f ipc-linux.mak config $(MAKE) -C $(IPC_INSTALL_DIR) ipc_clean: $(MAKE) -C $(IPC_INSTALL_DIR) $(IPC_BUILD_VARS) -f ipc-bios.mak clean #============================================================================== # Build ipumm. Also, an explicit cleanup target is defined. #============================================================================== ipumm:ipc_ipu $(MAKE) -C $(IPUMM_INSTALL_DIR) $(IPUMM_BUILD_VARS) $(DEFAULT_IPUMM_CONFIG) $(MAKE) -C $(IPUMM_INSTALL_DIR) $(IPUMM_BUILD_VARS) ipumm_clean: $(MAKE) -C $(IPUMM_INSTALL_DIR) $(IPUMM_BUILD_VARS) clean ipumm_install: install -d $(EXEC_DIR)/lib/firmware install $(IPUMM_INSTALL_DIR)/$(DUCATI_FW_GEN) $(EXEC_DIR)/lib/firmware/$(DUCATI_FW) #============================================================================== # Build dspdce. Also, an explicit cleanup target is defined. #============================================================================== dspdce:ipc_dsp $(MAKE) -C $(DSPDCE_INSTALL_DIR) $(DSPDCE_BUILD_VARS) $(DEFAULT_DSPDCE_CONFIG) $(MAKE) -C $(DSPDCE_INSTALL_DIR) $(DSPDCE_BUILD_VARS) dspdce_clean: $(MAKE) -C $(DSPDCE_INSTALL_DIR) $(DSPDCE_BUILD_VARS) clean dspdce_install: install -d $(EXEC_DIR)/lib/firmware install $(DSPDCE_INSTALL_DIR)/$(DSP_FW_GEN) $(EXEC_DIR)/lib/firmware/$(DSP_FW) #============================================================================== # Build Linux Utils. This is required for using CMEM allocator in user space #============================================================================== linux_utils: cd $(LINUXUTILS_INSTALL_DIR);./configure --prefix=${LINUXUTILS_INSTALL_DIR}/out \ $(CMEM_CONFIG_VARS) make -C $(LINUXUTILS_INSTALL_DIR) make -C $(LINUXUTILS_INSTALL_DIR) install make -e -C $(LINUXUTILS_INSTALL_DIR)/src/cmem/module \ $(CMEM_KO_BUILD_VARS)
# Define target platform. PLATFORM=dra7xx REVISION=ES10 DEFAULT_LINUXKERNEL_CONFIG=omap2plus_defconfig DEFAULT_UBOOT_CONFIG=dra7xx_evm_config DEFAULT_IPUMM_CONFIG=vayu_smp_config DEFAULT_DSPDCE_CONFIG=vayu_config BIOS_VERSION=6_41_04_54 IPC_VERSION=3_36_01_11 IPUMM_VERSION=3_00_08_02 DSPDCE_VERSION=1_00_00_05 DUCATI_FW_GEN=dra7xx-m4-ipu2.xem4 DUCATI_FW=dra7-ipu2-fw.xem4 DSP_FW_GEN=dra7xx-c66x-dsp.xe66 DSP_FW=dra7-dsp1-fw.xe66 XDC_VERSION=xdctools_3_30_06_67 FC_VERSION=framework_components_3_40_01_04 PLATFORM_IPC=DRA7XX LINUXUTILS_VERSION=4_10_01_02 # Cross compiler used for building linux and u-boot TOOLCHAIN_INSTALL_DIR=$(HOME)/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux CROSS_COMPILE_PREFIX=$(TOOLCHAIN_INSTALL_DIR)/bin/arm-linux-gnueabihf- # The installation directory of the SDK. GLSDK_INSTALL_DIR=$(shell pwd) # The directory that points to your kernel source directory. LINUXKERNEL_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/board-support/linux KERNEL_INSTALL_DIR=$(LINUXKERNEL_INSTALL_DIR) # The directory that points to the SGX kernel module sources. SGX_KERNEL_MODULE_PATH=$(GLSDK_INSTALL_DIR)/board-support/external-linux-kernel-modules/omap5-sgx-ddk-linux/eurasia_km/eurasiacon/build/linux2/omap5430_linux # The directory that points to your u-boot source directory. UBOOT_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/board-support/u-boot # The directory that points to your ARM Code Gen tools directory TMS470CGTOOLPATH_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/ti-devkit/ti-cgt-arm_5.2.4 # The directory where the Code Gen is installed. CODEGEN_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/ti-devkit/cgt6x_7_4_13 # The directory that points to the bios tools directory. BIOSTOOLSROOT_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources # The directory that points to your bios source directory. BIOS_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources/bios_$(BIOS_VERSION) # The directory that points to your bios source directory. XDC_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources/$(XDC_VERSION) # The directory that points to your ipc source directory. IPC_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources/ipc_$(IPC_VERSION) # The directory that points to your ipumm source directory. IPUMM_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources/ipumm_$(IPUMM_VERSION) # The directory that points to your dsp source directory. DSPDCE_INSTALL_DIR=$(GLSDK_INSTALL_DIR)/component-sources/dspdce_$(DSPDCE_VERSION) # Directory where linux utils is installed LINUXUTILS_INSTALL_DIR=${GLSDK_INSTALL_DIR}/component-sources/linuxutils_${LINUXUTILS_VERSION} # Kernel/U-Boot build variables LINUXKERNEL_BUILD_VARS = ARCH=arm CROSS_COMPILE=$(CROSS_COMPILE_PREFIX) UBOOT_BUILD_VARS = CROSS_COMPILE=$(CROSS_COMPILE_PREFIX) # Where to copy the resulting executables EXEC_DIR=$(HOME)/install/$(PLATFORM) # IPC variables IPC_BUILD_VARS = TMS470CGTOOLPATH=$(TMS470CGTOOLPATH_INSTALL_DIR) \ BIOSTOOLSROOT=$(BIOSTOOLSROOT_INSTALL_DIR) \ C66XCGTOOLSPATH=$(CODEGEN_INSTALL_DIR) \ XDCVERSION=$(XDC_VERSION) \ XDC_INSTALL_DIR=$(BIOSTOOLSROOT_INSTALL_DIR)/$(XDC_VERSION) \ BIOS_INSTALL_DIR=$(BIOS_INSTALL_DIR) # IPUMM build variables IPUMM_BUILD_VARS = BIOSTOOLSROOT=$(BIOSTOOLSROOT_INSTALL_DIR) \ IPCSRC=$(IPC_INSTALL_DIR) \ TMS470CGTOOLPATH=$(TMS470CGTOOLPATH_INSTALL_DIR) \ BIOSVERSION=bios_$(BIOS_VERSION) \ XDCVERSION=$(XDC_VERSION) \ XDC_INSTALL_DIR=$(BIOSTOOLSROOT_INSTALL_DIR)/$(XDC_VERSION) \ FCVERSION=$(FC_VERSION) \ TRACELEVEL=1 \ HWVERSION=$(REVISION) # DSPDCE build variables DSPDCE_BUILD_VARS = BIOSTOOLSROOT=$(BIOSTOOLSROOT_INSTALL_DIR) \ IPCSRC=$(IPC_INSTALL_DIR) \ IPCVERSION=ipc_$(IPC_VERSION) \ BIOSVERSION=bios_$(BIOS_VERSION) \ XDCVERSION=$(XDC_VERSION) \ FCVERSION=$(FC_VERSION) \ C66XCGTOOLSPATH=$(CODEGEN_INSTALL_DIR) \ PLATFORM=$(REVISION) # CMEM build variables # Arguments for building the kernel module CMEM_KO_BUILD_VARS = ARCH=arm TOOLCHAIN_PREFIX=$(CROSS_COMPILE_PREFIX) \ KERNEL_INSTALL_DIR=${KERNEL_INSTALL_DIR} CMEM_CONFIG_VARS = ARCH=arm TOOLCHAIN_PREFIX=$(CROSS_COMPILE_PREFIX) \ CC=$(CROSS_COMPILE_PREFIX)gcc --host=arm-linux-gnueabihf
Hope this helps.
Yordan
