I am using AM3352 processor and tlv320dac3100 codec.
I am using 24Mhz MCLK
I tried to play stereo file and measured BCLK, and WCLK clock and i got BCLK=704 khz and WCLK=22.05 khz.
But i am getting audio with some noise. I have also attached tlv320aic31xx.c, davinci-mcasp.c and tlv320aic31xx.h files.
Also give some suggetion/patch for mono file which i am not able to play with current tlv320aic31xx.c file.
Please, provide me proper configuration of tlv320dac3100 codec.
Ankit
/* * ALSA SoC McASP Audio Layer for TI DAVINCI processor * * Multi-channel Audio Serial Port Driver * * Author: Nirmal Pandey <n-pandey@ti.com>, * Suresh Rajashekara <suresh.r@ti.com> * Steve Chen <schen@.mvista.com> * * Copyright: (C) 2009 MontaVista Software, Inc., <source@mvista.com> * Copyright: (C) 2009 Texas Instruments, India * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ #include <linux/init.h> #include <linux/module.h> #include <linux/device.h> #include <linux/slab.h> #include <linux/delay.h> #include <linux/io.h> #include <linux/clk.h> #include <linux/pm_runtime.h> #include <linux/of.h> #include <linux/of_platform.h> #include <linux/of_device.h> #include <linux/platform_data/davinci_asp.h> #include <linux/math64.h> #include <sound/asoundef.h> #include <sound/core.h> #include <sound/pcm.h> #include <sound/pcm_params.h> #include <sound/initval.h> #include <sound/soc.h> #include <sound/dmaengine_pcm.h> #include <sound/omap-pcm.h> #include "edma-pcm.h" #include "davinci-mcasp.h" #define MCASP_MAX_AFIFO_DEPTH 64 static u32 context_regs[] = { DAVINCI_MCASP_TXFMCTL_REG, DAVINCI_MCASP_RXFMCTL_REG, DAVINCI_MCASP_TXFMT_REG, DAVINCI_MCASP_RXFMT_REG, DAVINCI_MCASP_ACLKXCTL_REG, DAVINCI_MCASP_ACLKRCTL_REG, DAVINCI_MCASP_AHCLKXCTL_REG, DAVINCI_MCASP_AHCLKRCTL_REG, DAVINCI_MCASP_PDIR_REG, DAVINCI_MCASP_RXMASK_REG, DAVINCI_MCASP_TXMASK_REG, DAVINCI_MCASP_RXTDM_REG, DAVINCI_MCASP_TXTDM_REG, }; struct davinci_mcasp_context { u32 config_regs[ARRAY_SIZE(context_regs)]; u32 afifo_regs[2]; /* for read/write fifo control registers */ u32 *xrsr_regs; /* for serializer configuration */ bool pm_state; }; struct davinci_mcasp_ruledata { struct davinci_mcasp *mcasp; int serializers; }; struct davinci_mcasp { struct snd_dmaengine_dai_dma_data dma_data[2]; void __iomem *base; u32 fifo_base; struct device *dev; struct snd_pcm_substream *substreams[2]; unsigned int dai_fmt; /* McASP specific data */ int tdm_slots; u8 op_mode; u8 num_serializer; u8 *serial_dir; u8 version; u8 bclk_div; u16 bclk_lrclk_ratio; int streams; u32 irq_request[2]; int dma_request[2]; int sysclk_freq; bool bclk_master; /* McASP FIFO related */ u8 txnumevt; u8 rxnumevt; bool dat_port; /* Used for comstraint setting on the second stream */ u32 channels; #ifdef CONFIG_PM_SLEEP struct davinci_mcasp_context context; #endif struct davinci_mcasp_ruledata ruledata[2]; struct snd_pcm_hw_constraint_list chconstr[2]; #if IS_ENABLED(CONFIG_DISPLAY_DRA7EVM_ENCODER_TPD12S015) bool is_mcasp8; u8 hdmi_sel_gpio; #endif }; static inline void mcasp_set_bits(struct davinci_mcasp *mcasp, u32 offset, u32 val) { void __iomem *reg = mcasp->base + offset; __raw_writel(__raw_readl(reg) | val, reg); } static inline void mcasp_clr_bits(struct davinci_mcasp *mcasp, u32 offset, u32 val) { void __iomem *reg = mcasp->base + offset; __raw_writel((__raw_readl(reg) & ~(val)), reg); } static inline void mcasp_mod_bits(struct davinci_mcasp *mcasp, u32 offset, u32 val, u32 mask) { void __iomem *reg = mcasp->base + offset; __raw_writel((__raw_readl(reg) & ~mask) | val, reg); } static inline void mcasp_set_reg(struct davinci_mcasp *mcasp, u32 offset, u32 val) { __raw_writel(val, mcasp->base + offset); } static inline u32 mcasp_get_reg(struct davinci_mcasp *mcasp, u32 offset) { return (u32)__raw_readl(mcasp->base + offset); } static void mcasp_set_ctl_reg(struct davinci_mcasp *mcasp, u32 ctl_reg, u32 val) { int i = 0; mcasp_set_bits(mcasp, ctl_reg, val); /* programming GBLCTL needs to read back from GBLCTL and verfiy */ /* loop count is to avoid the lock-up */ for (i = 0; i < 1000; i++) { if ((mcasp_get_reg(mcasp, ctl_reg) & val) == val) break; } if (i == 1000 && ((mcasp_get_reg(mcasp, ctl_reg) & val) != val)) printk(KERN_ERR "GBLCTL write error\n"); } static bool mcasp_is_synchronous(struct davinci_mcasp *mcasp) { u32 rxfmctl = mcasp_get_reg(mcasp, DAVINCI_MCASP_RXFMCTL_REG); u32 aclkxctl = mcasp_get_reg(mcasp, DAVINCI_MCASP_ACLKXCTL_REG); return !(aclkxctl & TX_ASYNC) && rxfmctl & AFSRE; } static void mcasp_start_rx(struct davinci_mcasp *mcasp) { if (mcasp->rxnumevt) { /* enable FIFO */ u32 reg = mcasp->fifo_base + MCASP_RFIFOCTL_OFFSET; mcasp_clr_bits(mcasp, reg, FIFO_ENABLE); mcasp_set_bits(mcasp, reg, FIFO_ENABLE); } /* Start clocks */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLR_REG, RXHCLKRST); mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLR_REG, RXCLKRST); /* * When ASYNC == 0 the transmit and receive sections operate * synchronously from the transmit clock and frame sync. We need to make * sure that the TX signlas are enabled when starting reception. */ if (mcasp_is_synchronous(mcasp)) { mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXHCLKRST); mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXCLKRST); } /* Activate serializer(s) */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLR_REG, RXSERCLR); /* Release RX state machine */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLR_REG, RXSMRST); /* Release Frame Sync generator */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLR_REG, RXFSRST); if (mcasp_is_synchronous(mcasp)) mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXFSRST); /* enable receive IRQs */ mcasp_set_bits(mcasp, DAVINCI_MCASP_EVTCTLR_REG, mcasp->irq_request[SNDRV_PCM_STREAM_CAPTURE]); } static void mcasp_start_tx(struct davinci_mcasp *mcasp) { u32 cnt; if (mcasp->txnumevt) { /* enable FIFO */ u32 reg = mcasp->fifo_base + MCASP_WFIFOCTL_OFFSET; mcasp_clr_bits(mcasp, reg, FIFO_ENABLE); mcasp_set_bits(mcasp, reg, FIFO_ENABLE); } /* Start clocks */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXHCLKRST); mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXCLKRST); /* Activate serializer(s) */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXSERCLR); /* wait for XDATA to be cleared */ cnt = 0; while (!(mcasp_get_reg(mcasp, DAVINCI_MCASP_TXSTAT_REG) & ~XRDATA) && (cnt < 100000)) cnt++; /* Release TX state machine */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXSMRST); /* Release Frame Sync generator */ mcasp_set_ctl_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, TXFSRST); /* enable transmit IRQs */ mcasp_set_bits(mcasp, DAVINCI_MCASP_EVTCTLX_REG, mcasp->irq_request[SNDRV_PCM_STREAM_PLAYBACK]); } static void davinci_mcasp_start(struct davinci_mcasp *mcasp, int stream) { mcasp->streams++; if (stream == SNDRV_PCM_STREAM_PLAYBACK) mcasp_start_tx(mcasp); else mcasp_start_rx(mcasp); } static void mcasp_stop_rx(struct davinci_mcasp *mcasp) { /* disable IRQ sources */ mcasp_clr_bits(mcasp, DAVINCI_MCASP_EVTCTLR_REG, mcasp->irq_request[SNDRV_PCM_STREAM_CAPTURE]); /* * In synchronous mode stop the TX clocks if no other stream is * running */ if (mcasp_is_synchronous(mcasp) && !mcasp->streams) mcasp_set_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, 0); mcasp_set_reg(mcasp, DAVINCI_MCASP_GBLCTLR_REG, 0); mcasp_set_reg(mcasp, DAVINCI_MCASP_RXSTAT_REG, 0xFFFFFFFF); if (mcasp->rxnumevt) { /* disable FIFO */ u32 reg = mcasp->fifo_base + MCASP_RFIFOCTL_OFFSET; mcasp_clr_bits(mcasp, reg, FIFO_ENABLE); } } static void mcasp_stop_tx(struct davinci_mcasp *mcasp) { u32 val = 0; /* disable IRQ sources */ mcasp_clr_bits(mcasp, DAVINCI_MCASP_EVTCTLX_REG, mcasp->irq_request[SNDRV_PCM_STREAM_PLAYBACK]); /* * In synchronous mode keep TX clocks running if the capture stream is * still running. */ if (mcasp_is_synchronous(mcasp) && mcasp->streams) val = TXHCLKRST | TXCLKRST | TXFSRST; mcasp_set_reg(mcasp, DAVINCI_MCASP_GBLCTLX_REG, val); mcasp_set_reg(mcasp, DAVINCI_MCASP_TXSTAT_REG, 0xFFFFFFFF); if (mcasp->txnumevt) { /* disable FIFO */ u32 reg = mcasp->fifo_base + MCASP_WFIFOCTL_OFFSET; mcasp_clr_bits(mcasp, reg, FIFO_ENABLE); } } static void davinci_mcasp_stop(struct davinci_mcasp *mcasp, int stream) { mcasp->streams--; if (stream == SNDRV_PCM_STREAM_PLAYBACK) mcasp_stop_tx(mcasp); else mcasp_stop_rx(mcasp); } static irqreturn_t davinci_mcasp_tx_irq_handler(int irq, void *data) { struct davinci_mcasp *mcasp = (struct davinci_mcasp *)data; struct snd_pcm_substream *substream; u32 irq_mask = mcasp->irq_request[SNDRV_PCM_STREAM_PLAYBACK]; u32 handled_mask = 0; u32 stat; stat = mcasp_get_reg(mcasp, DAVINCI_MCASP_TXSTAT_REG); if (stat & XUNDRN & irq_mask) { dev_warn(mcasp->dev, "Transmit buffer underflow\n"); handled_mask |= XUNDRN; substream = mcasp->substreams[SNDRV_PCM_STREAM_PLAYBACK]; if (substream) { snd_pcm_stream_lock_irq(substream); if (snd_pcm_running(substream)) snd_pcm_stop(substream, SNDRV_PCM_STATE_XRUN); snd_pcm_stream_unlock_irq(substream); } } if (!handled_mask) dev_warn(mcasp->dev, "unhandled tx event. txstat: 0x%08x\n", stat); if (stat & XRERR) handled_mask |= XRERR; /* Ack the handled event only */ mcasp_set_reg(mcasp, DAVINCI_MCASP_TXSTAT_REG, handled_mask); return IRQ_RETVAL(handled_mask); } static irqreturn_t davinci_mcasp_rx_irq_handler(int irq, void *data) { struct davinci_mcasp *mcasp = (struct davinci_mcasp *)data; struct snd_pcm_substream *substream; u32 irq_mask = mcasp->irq_request[SNDRV_PCM_STREAM_CAPTURE]; u32 handled_mask = 0; u32 stat; stat = mcasp_get_reg(mcasp, DAVINCI_MCASP_RXSTAT_REG); if (stat & ROVRN & irq_mask) { dev_warn(mcasp->dev, "Receive buffer overflow\n"); handled_mask |= ROVRN; substream = mcasp->substreams[SNDRV_PCM_STREAM_CAPTURE]; if (substream) { snd_pcm_stream_lock_irq(substream); if (snd_pcm_running(substream)) snd_pcm_stop(substream, SNDRV_PCM_STATE_XRUN); snd_pcm_stream_unlock_irq(substream); } } if (!handled_mask) dev_warn(mcasp->dev, "unhandled rx event. rxstat: 0x%08x\n", stat); if (stat & XRERR) handled_mask |= XRERR; /* Ack the handled event only */ mcasp_set_reg(mcasp, DAVINCI_MCASP_RXSTAT_REG, handled_mask); return IRQ_RETVAL(handled_mask); } static irqreturn_t davinci_mcasp_common_irq_handler(int irq, void *data) { struct davinci_mcasp *mcasp = (struct davinci_mcasp *)data; irqreturn_t ret = IRQ_NONE; if (mcasp->substreams[SNDRV_PCM_STREAM_PLAYBACK]) ret = davinci_mcasp_tx_irq_handler(irq, data); if (mcasp->substreams[SNDRV_PCM_STREAM_CAPTURE]) ret |= davinci_mcasp_rx_irq_handler(irq, data); return ret; } static int davinci_mcasp_set_dai_fmt(struct snd_soc_dai *cpu_dai, unsigned int fmt) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(cpu_dai); int ret = 0; u32 data_delay; bool fs_pol_rising; bool inv_fs = false; if (!fmt) return 0; pm_runtime_get_sync(mcasp->dev); switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) { case SND_SOC_DAIFMT_DSP_A: mcasp_clr_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXDUR); mcasp_clr_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRDUR); /* 1st data bit occur one ACLK cycle after the frame sync */ data_delay = 1; break; case SND_SOC_DAIFMT_DSP_B: case SND_SOC_DAIFMT_AC97: mcasp_clr_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXDUR); mcasp_clr_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRDUR); /* No delay after FS */ data_delay = 0; break; case SND_SOC_DAIFMT_I2S: /* configure a full-word SYNC pulse (LRCLK) */ mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXDUR); mcasp_set_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRDUR); /* 1st data bit occur one ACLK cycle after the frame sync */ data_delay = 1; /* FS need to be inverted */ inv_fs = true; break; case SND_SOC_DAIFMT_LEFT_J: /* configure a full-word SYNC pulse (LRCLK) */ mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXDUR); mcasp_set_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRDUR); /* No delay after FS */ data_delay = 0; break; default: ret = -EINVAL; goto out; } mcasp_mod_bits(mcasp, DAVINCI_MCASP_TXFMT_REG, FSXDLY(data_delay), FSXDLY(3)); mcasp_mod_bits(mcasp, DAVINCI_MCASP_RXFMT_REG, FSRDLY(data_delay), FSRDLY(3)); switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { case SND_SOC_DAIFMT_CBS_CFS: /* codec is clock and frame slave */ mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXE); mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, AFSXE); mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRE); mcasp_set_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, AFSRE); mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, ACLKX | ACLKR); mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AFSX | AFSR); mcasp->bclk_master = 1; break; case SND_SOC_DAIFMT_CBS_CFM: /* codec is clock slave and frame master */ mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, AFSXE); mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, AFSRE); mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, ACLKX | ACLKR); mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AFSX | AFSR); mcasp->bclk_master = 1; break; case SND_SOC_DAIFMT_CBM_CFS: /* codec is clock master and frame slave */ mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXE); mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, AFSXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRE); mcasp_set_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, AFSRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDIR_REG, ACLKX | ACLKR); mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AFSX | AFSR); mcasp->bclk_master = 0; break; case SND_SOC_DAIFMT_CBM_CFM: /* codec is clock and frame master */ /* mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, AFSXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, AFSRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDIR_REG, ACLKX | AHCLKX | AFSX | ACLKR | AHCLKR | AFSR); mcasp->bclk_master = 0; */ mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, AFSXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, AFSRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDIR_REG, ACLKX | AFSX ); mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AHCLKX ); mcasp->bclk_master = 0; break; default: ret = -EINVAL; goto out; } switch (fmt & SND_SOC_DAIFMT_INV_MASK) { case SND_SOC_DAIFMT_IB_NF: mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXPOL); mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRPOL); fs_pol_rising = true; break; case SND_SOC_DAIFMT_NB_IF: mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXPOL); mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRPOL); fs_pol_rising = false; break; case SND_SOC_DAIFMT_IB_IF: mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXPOL); mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRPOL); fs_pol_rising = false; break; case SND_SOC_DAIFMT_NB_NF: mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXPOL); mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRPOL); fs_pol_rising = true; break; default: ret = -EINVAL; goto out; } if (inv_fs) fs_pol_rising = !fs_pol_rising; if (fs_pol_rising) { mcasp_clr_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXPOL); mcasp_clr_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRPOL); } else { mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXPOL); mcasp_set_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRPOL); } mcasp->dai_fmt = fmt; out: pm_runtime_put(mcasp->dev); return ret; } static int __davinci_mcasp_set_clkdiv(struct snd_soc_dai *dai, int div_id, int div, bool explicit) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(dai); pm_runtime_get_sync(mcasp->dev); switch (div_id) { case 0: /* MCLK divider */ mcasp_mod_bits(mcasp, DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXDIV(div - 1), AHCLKXDIV_MASK); mcasp_mod_bits(mcasp, DAVINCI_MCASP_AHCLKRCTL_REG, AHCLKRDIV(div - 1), AHCLKRDIV_MASK); break; case 1: /* BCLK divider */ mcasp_mod_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXDIV(div - 1), ACLKXDIV_MASK); mcasp_mod_bits(mcasp, DAVINCI_MCASP_ACLKRCTL_REG, ACLKRDIV(div - 1), ACLKRDIV_MASK); if (explicit) mcasp->bclk_div = div; break; case 2: /* BCLK/LRCLK ratio */ mcasp->bclk_lrclk_ratio = div; break; default: return -EINVAL; } pm_runtime_put(mcasp->dev); return 0; } static int davinci_mcasp_set_clkdiv(struct snd_soc_dai *dai, int div_id, int div) { return __davinci_mcasp_set_clkdiv(dai, div_id, div, 1); } static int davinci_mcasp_set_sysclk(struct snd_soc_dai *dai, int clk_id, unsigned int freq, int dir) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(dai); pm_runtime_get_sync(mcasp->dev); if (dir == SND_SOC_CLOCK_OUT) { mcasp_set_bits(mcasp, DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXE); mcasp_set_bits(mcasp, DAVINCI_MCASP_AHCLKRCTL_REG, AHCLKRE); mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AHCLKX); } else { mcasp_clr_bits(mcasp, DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_AHCLKRCTL_REG, AHCLKRE); mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AHCLKX); } mcasp->sysclk_freq = freq; pm_runtime_put(mcasp->dev); return 0; } static int davinci_config_channel_size(struct davinci_mcasp *mcasp, int word_length) { u32 fmt; u32 tx_rotate = (word_length / 4) & 0x7; u32 mask = (1ULL << word_length) - 1; /* * For captured data we should not rotate, inversion and masking is * enoguh to get the data to the right position: * Format data from bus after reverse (XRBUF) * S16_LE: |LSB|MSB|xxx|xxx| |xxx|xxx|MSB|LSB| * S24_3LE: |LSB|DAT|MSB|xxx| |xxx|MSB|DAT|LSB| * S24_LE: |LSB|DAT|MSB|xxx| |xxx|MSB|DAT|LSB| * S32_LE: |LSB|DAT|DAT|MSB| |MSB|DAT|DAT|LSB| */ u32 rx_rotate = 0; /* * if s BCLK-to-LRCLK ratio has been configured via the set_clkdiv() * callback, take it into account here. That allows us to for example * send 32 bits per channel to the codec, while only 16 of them carry * audio payload. * The clock ratio is given for a full period of data (for I2S format * both left and right channels), so it has to be divided by number of * tdm-slots (for I2S - divided by 2). */ if (mcasp->bclk_lrclk_ratio) { u32 slot_length = mcasp->bclk_lrclk_ratio / mcasp->tdm_slots; /* * When we have more bclk then it is needed for the data, we * need to use the rotation to move the received samples to have * correct alignment. */ rx_rotate = (slot_length - word_length) / 4; word_length = slot_length; } /* mapping of the XSSZ bit-field as described in the datasheet */ fmt = (word_length >> 1) - 1; if (mcasp->op_mode != DAVINCI_MCASP_DIT_MODE) { mcasp_mod_bits(mcasp, DAVINCI_MCASP_RXFMT_REG, RXSSZ(fmt), RXSSZ(0x0F)); mcasp_mod_bits(mcasp, DAVINCI_MCASP_TXFMT_REG, TXSSZ(fmt), TXSSZ(0x0F)); mcasp_mod_bits(mcasp, DAVINCI_MCASP_TXFMT_REG, TXROT(tx_rotate), TXROT(7)); mcasp_mod_bits(mcasp, DAVINCI_MCASP_RXFMT_REG, RXROT(rx_rotate), RXROT(7)); mcasp_set_reg(mcasp, DAVINCI_MCASP_RXMASK_REG, mask); } mcasp_set_reg(mcasp, DAVINCI_MCASP_TXMASK_REG, mask); return 0; } static int mcasp_common_hw_param(struct davinci_mcasp *mcasp, int stream, int period_words, int channels) { struct snd_dmaengine_dai_dma_data *dma_data = &mcasp->dma_data[stream]; int i; u8 tx_ser = 0; u8 rx_ser = 0; u8 slots = mcasp->tdm_slots; u8 max_active_serializers = (channels + slots - 1) / slots; int active_serializers, numevt; u32 reg; /* Default configuration */ if (mcasp->version < MCASP_VERSION_3) mcasp_set_bits(mcasp, DAVINCI_MCASP_PWREMUMGT_REG, MCASP_SOFT); /* All PINS as McASP */ mcasp_set_reg(mcasp, DAVINCI_MCASP_PFUNC_REG, 0x00000000); if (stream == SNDRV_PCM_STREAM_PLAYBACK) { mcasp_set_reg(mcasp, DAVINCI_MCASP_TXSTAT_REG, 0xFFFFFFFF); mcasp_clr_bits(mcasp, DAVINCI_MCASP_XEVTCTL_REG, TXDATADMADIS); } else { mcasp_set_reg(mcasp, DAVINCI_MCASP_RXSTAT_REG, 0xFFFFFFFF); mcasp_clr_bits(mcasp, DAVINCI_MCASP_REVTCTL_REG, RXDATADMADIS); } for (i = 0; i < mcasp->num_serializer; i++) { mcasp_set_bits(mcasp, DAVINCI_MCASP_XRSRCTL_REG(i), mcasp->serial_dir[i]); if (mcasp->serial_dir[i] == TX_MODE && tx_ser < max_active_serializers) { mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AXR(i)); mcasp_mod_bits(mcasp, DAVINCI_MCASP_XRSRCTL_REG(i), DISMOD_LOW, DISMOD_MASK); tx_ser++; } else if (mcasp->serial_dir[i] == RX_MODE && rx_ser < max_active_serializers) { mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDIR_REG, AXR(i)); rx_ser++; } else { mcasp_mod_bits(mcasp, DAVINCI_MCASP_XRSRCTL_REG(i), SRMOD_INACTIVE, SRMOD_MASK); } } if (stream == SNDRV_PCM_STREAM_PLAYBACK) { active_serializers = tx_ser; numevt = mcasp->txnumevt; reg = mcasp->fifo_base + MCASP_WFIFOCTL_OFFSET; } else { active_serializers = rx_ser; numevt = mcasp->rxnumevt; reg = mcasp->fifo_base + MCASP_RFIFOCTL_OFFSET; } if (active_serializers < max_active_serializers) { dev_warn(mcasp->dev, "stream has more channels (%d) than are " "enabled in mcasp (%d)\n", channels, active_serializers * slots); return -EINVAL; } /* AFIFO is not in use */ if (!numevt) { /* Configure the burst size for platform drivers */ if (active_serializers > 1) { /* * If more than one serializers are in use we have one * DMA request to provide data for all serializers. * For example if three serializers are enabled the DMA * need to transfer three words per DMA request. */ dma_data->maxburst = active_serializers; } else { dma_data->maxburst = 0; } return 0; } if (period_words % active_serializers) { dev_err(mcasp->dev, "Invalid combination of period words and " "active serializers: %d, %d\n", period_words, active_serializers); return -EINVAL; } /* * Calculate the optimal AFIFO depth for platform side: * The number of words for numevt need to be in steps of active * serializers. */ numevt = (numevt / active_serializers) * active_serializers; while (period_words % numevt && numevt > 0) numevt -= active_serializers; if (numevt <= 0) numevt = active_serializers; mcasp_mod_bits(mcasp, reg, active_serializers, NUMDMA_MASK); mcasp_mod_bits(mcasp, reg, NUMEVT(numevt), NUMEVT_MASK); /* Configure the burst size for platform drivers */ if (numevt == 1) numevt = 0; dma_data->maxburst = numevt; return 0; } static int mcasp_i2s_hw_param(struct davinci_mcasp *mcasp, int stream, int channels) { int i, active_slots; int total_slots; int active_serializers; u32 mask = 0; u32 busel = 0; total_slots = mcasp->tdm_slots; /* * If more than one serializer is needed, then use them with * their specified tdm_slots count. Otherwise, one serializer * can cope with the transaction using as many slots as channels * in the stream, requires channels symmetry */ active_serializers = (channels + total_slots - 1) / total_slots; if (active_serializers == 1) active_slots = channels; else active_slots = total_slots; for (i = 0; i < active_slots; i++) mask |= (1 << i); mcasp_clr_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, TX_ASYNC); if (!mcasp->dat_port) busel = TXSEL; mcasp_set_reg(mcasp, DAVINCI_MCASP_TXTDM_REG, mask); mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMT_REG, busel | TXORD); mcasp_mod_bits(mcasp, DAVINCI_MCASP_TXFMCTL_REG, FSXMOD(total_slots), FSXMOD(0x1FF)); mcasp_set_reg(mcasp, DAVINCI_MCASP_RXTDM_REG, mask); mcasp_set_bits(mcasp, DAVINCI_MCASP_RXFMT_REG, busel | RXORD); mcasp_mod_bits(mcasp, DAVINCI_MCASP_RXFMCTL_REG, FSRMOD(total_slots), FSRMOD(0x1FF)); return 0; } /* S/PDIF */ static int mcasp_dit_hw_param(struct davinci_mcasp *mcasp, unsigned int rate) { u32 cs_value = 0; u8 *cs_bytes = (u8*) &cs_value; /* Set the TX format : 24 bit right rotation, 32 bit slot, Pad 0 and LSB first */ mcasp_set_bits(mcasp, DAVINCI_MCASP_TXFMT_REG, TXROT(6) | TXSSZ(15)); /* Set TX frame synch : DIT Mode, 1 bit width, internal, rising edge */ mcasp_set_reg(mcasp, DAVINCI_MCASP_TXFMCTL_REG, AFSXE | FSXMOD(0x180)); /* Set the TX tdm : for all the slots */ mcasp_set_reg(mcasp, DAVINCI_MCASP_TXTDM_REG, 0xFFFFFFFF); /* Set the TX clock controls : div = 1 and internal */ mcasp_set_bits(mcasp, DAVINCI_MCASP_ACLKXCTL_REG, ACLKXE | TX_ASYNC); mcasp_clr_bits(mcasp, DAVINCI_MCASP_XEVTCTL_REG, TXDATADMADIS); /* Only 44100 and 48000 are valid, both have the same setting */ mcasp_set_bits(mcasp, DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXDIV(3)); /* Enable the DIT */ mcasp_set_bits(mcasp, DAVINCI_MCASP_TXDITCTL_REG, DITEN); /* Set S/PDIF channel status bits */ cs_bytes[0] = IEC958_AES0_CON_NOT_COPYRIGHT; cs_bytes[1] = IEC958_AES1_CON_PCM_CODER; switch (rate) { case 22050: cs_bytes[3] |= IEC958_AES3_CON_FS_22050; break; case 24000: cs_bytes[3] |= IEC958_AES3_CON_FS_24000; break; case 32000: cs_bytes[3] |= IEC958_AES3_CON_FS_32000; break; case 44100: cs_bytes[3] |= IEC958_AES3_CON_FS_44100; break; case 48000: cs_bytes[3] |= IEC958_AES3_CON_FS_48000; break; case 88200: cs_bytes[3] |= IEC958_AES3_CON_FS_88200; break; case 96000: cs_bytes[3] |= IEC958_AES3_CON_FS_96000; break; case 176400: cs_bytes[3] |= IEC958_AES3_CON_FS_176400; break; case 192000: cs_bytes[3] |= IEC958_AES3_CON_FS_192000; break; default: printk(KERN_WARNING "unsupported sampling rate: %d\n", rate); return -EINVAL; } mcasp_set_reg(mcasp, DAVINCI_MCASP_DITCSRA_REG, cs_value); mcasp_set_reg(mcasp, DAVINCI_MCASP_DITCSRB_REG, cs_value); return 0; } static int davinci_mcasp_calc_clk_div(struct davinci_mcasp *mcasp, unsigned int bclk_freq, int *error_ppm) { int div = mcasp->sysclk_freq / bclk_freq; int rem = mcasp->sysclk_freq % bclk_freq; if (rem != 0) { if (div == 0 || ((mcasp->sysclk_freq / div) - bclk_freq) > (bclk_freq - (mcasp->sysclk_freq / (div+1)))) { div++; rem = rem - bclk_freq; } } if (error_ppm) *error_ppm = (div*1000000 + (int)div64_long(1000000LL*rem, (int)bclk_freq)) /div - 1000000; return div; } static int davinci_mcasp_hw_params(struct snd_pcm_substream *substream, struct snd_pcm_hw_params *params, struct snd_soc_dai *cpu_dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(cpu_dai); int word_length; int channels = params_channels(params); int period_size = params_period_size(params); int ret; /* * If mcasp is BCLK master, and a BCLK divider was not provided by * the machine driver, we need to calculate the ratio. */ if (mcasp->bclk_master && mcasp->bclk_div == 0 && mcasp->sysclk_freq) { int slots = mcasp->tdm_slots; int rate = params_rate(params); int sbits = params_width(params); int ppm, div; div = davinci_mcasp_calc_clk_div(mcasp, rate*sbits*slots, &ppm); if (ppm) dev_info(mcasp->dev, "Sample-rate is off by %d PPM\n", ppm); __davinci_mcasp_set_clkdiv(cpu_dai, 1, div, 0); } ret = mcasp_common_hw_param(mcasp, substream->stream, period_size * channels, channels); if (ret) return ret; if (mcasp->op_mode == DAVINCI_MCASP_DIT_MODE) ret = mcasp_dit_hw_param(mcasp, params_rate(params)); else ret = mcasp_i2s_hw_param(mcasp, substream->stream, channels); if (ret) return ret; switch (params_format(params)) { case SNDRV_PCM_FORMAT_U8: case SNDRV_PCM_FORMAT_S8: word_length = 8; break; case SNDRV_PCM_FORMAT_U16_LE: case SNDRV_PCM_FORMAT_S16_LE: word_length = 16; break; case SNDRV_PCM_FORMAT_U24_3LE: case SNDRV_PCM_FORMAT_S24_3LE: word_length = 24; break; case SNDRV_PCM_FORMAT_U24_LE: case SNDRV_PCM_FORMAT_S24_LE: word_length = 24; break; case SNDRV_PCM_FORMAT_U32_LE: case SNDRV_PCM_FORMAT_S32_LE: word_length = 32; break; default: printk(KERN_WARNING "davinci-mcasp: unsupported PCM format"); return -EINVAL; } davinci_config_channel_size(mcasp, word_length); if (mcasp->op_mode == DAVINCI_MCASP_IIS_MODE) mcasp->channels = channels; return davinci_mcasp_set_dai_fmt(cpu_dai, mcasp->dai_fmt); } static int davinci_mcasp_trigger(struct snd_pcm_substream *substream, int cmd, struct snd_soc_dai *cpu_dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(cpu_dai); int ret = 0; switch (cmd) { case SNDRV_PCM_TRIGGER_RESUME: case SNDRV_PCM_TRIGGER_START: case SNDRV_PCM_TRIGGER_PAUSE_RELEASE: davinci_mcasp_start(mcasp, substream->stream); break; case SNDRV_PCM_TRIGGER_SUSPEND: case SNDRV_PCM_TRIGGER_STOP: case SNDRV_PCM_TRIGGER_PAUSE_PUSH: davinci_mcasp_stop(mcasp, substream->stream); break; default: ret = -EINVAL; } return ret; } static const unsigned int davinci_mcasp_dai_rates[] = { 8000, 11025, 16000, 22050, 32000, 44100, 48000, 64000, 88200, 96000, 176400, 192000, }; #define DAVINCI_MAX_RATE_ERROR_PPM 1000 static int davinci_mcasp_hw_rule_rate(struct snd_pcm_hw_params *params, struct snd_pcm_hw_rule *rule) { struct davinci_mcasp_ruledata *rd = rule->private; struct snd_interval *ri = hw_param_interval(params, SNDRV_PCM_HW_PARAM_RATE); int sbits = params_width(params); int slots = rd->mcasp->tdm_slots; struct snd_interval range; int i; snd_interval_any(&range); range.empty = 1; for (i = 0; i < ARRAY_SIZE(davinci_mcasp_dai_rates); i++) { if (snd_interval_test(ri, davinci_mcasp_dai_rates[i])) { uint bclk_freq = sbits*slots* davinci_mcasp_dai_rates[i]; int ppm; davinci_mcasp_calc_clk_div(rd->mcasp, bclk_freq, &ppm); if (abs(ppm) < DAVINCI_MAX_RATE_ERROR_PPM) { if (range.empty) { range.min = davinci_mcasp_dai_rates[i]; range.empty = 0; } range.max = davinci_mcasp_dai_rates[i]; } } } dev_dbg(rd->mcasp->dev, "Frequencies %d-%d -> %d-%d for %d sbits and %d tdm slots\n", ri->min, ri->max, range.min, range.max, sbits, slots); return snd_interval_refine(hw_param_interval(params, rule->var), &range); } static int davinci_mcasp_hw_rule_format(struct snd_pcm_hw_params *params, struct snd_pcm_hw_rule *rule) { struct davinci_mcasp_ruledata *rd = rule->private; struct snd_mask *fmt = hw_param_mask(params, SNDRV_PCM_HW_PARAM_FORMAT); struct snd_mask nfmt; int rate = params_rate(params); int slots = rd->mcasp->tdm_slots; int i, count = 0; snd_mask_none(&nfmt); for (i = 0; i < SNDRV_PCM_FORMAT_LAST; i++) { if (snd_mask_test(fmt, i)) { uint bclk_freq = snd_pcm_format_width(i)*slots*rate; int ppm; davinci_mcasp_calc_clk_div(rd->mcasp, bclk_freq, &ppm); if (abs(ppm) < DAVINCI_MAX_RATE_ERROR_PPM) { snd_mask_set(&nfmt, i); count++; } } } dev_dbg(rd->mcasp->dev, "%d possible sample format for %d Hz and %d tdm slots\n", count, rate, slots); return snd_mask_refine(fmt, &nfmt); } static int davinci_mcasp_startup(struct snd_pcm_substream *substream, struct snd_soc_dai *cpu_dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(cpu_dai); struct davinci_mcasp_ruledata *ruledata = &mcasp->ruledata[substream->stream]; u32 max_channels = 0; int i, dir; mcasp->substreams[substream->stream] = substream; if (mcasp->op_mode == DAVINCI_MCASP_DIT_MODE) return 0; /* * Limit the maximum allowed channels for the first stream: * number of serializers for the direction * tdm slots per serializer */ if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK) dir = TX_MODE; else dir = RX_MODE; for (i = 0; i < mcasp->num_serializer; i++) { if (mcasp->serial_dir[i] == dir) max_channels++; } ruledata->serializers = max_channels; max_channels *= mcasp->tdm_slots; /* * If the already active stream has less channels than the calculated * limnit based on the seirializers * tdm_slots, we need to use that as * a constraint for the second stream. * Otherwise (first stream or less allowed channels) we use the * calculated constraint. */ if (mcasp->channels && mcasp->channels < max_channels) max_channels = mcasp->channels; snd_pcm_hw_constraint_minmax(substream->runtime, SNDRV_PCM_HW_PARAM_CHANNELS, 2, max_channels); if (mcasp->chconstr[substream->stream].count) snd_pcm_hw_constraint_list(substream->runtime, 0, SNDRV_PCM_HW_PARAM_CHANNELS, &mcasp->chconstr[substream->stream]); /* * If we rely on implicit BCLK divider setting we should * set constraints based on what we can provide. */ if (mcasp->bclk_master && mcasp->bclk_div == 0 && mcasp->sysclk_freq) { int ret; ruledata->mcasp = mcasp; ret = snd_pcm_hw_rule_add(substream->runtime, 0, SNDRV_PCM_HW_PARAM_RATE, davinci_mcasp_hw_rule_rate, ruledata, SNDRV_PCM_HW_PARAM_FORMAT, -1); if (ret) return ret; ret = snd_pcm_hw_rule_add(substream->runtime, 0, SNDRV_PCM_HW_PARAM_FORMAT, davinci_mcasp_hw_rule_format, ruledata, SNDRV_PCM_HW_PARAM_RATE, -1); if (ret) return ret; } return 0; } static void davinci_mcasp_shutdown(struct snd_pcm_substream *substream, struct snd_soc_dai *cpu_dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(cpu_dai); mcasp->substreams[substream->stream] = NULL; if (mcasp->op_mode == DAVINCI_MCASP_DIT_MODE) return; if (!cpu_dai->active) mcasp->channels = 0; } static const struct snd_soc_dai_ops davinci_mcasp_dai_ops = { .startup = davinci_mcasp_startup, .shutdown = davinci_mcasp_shutdown, .trigger = davinci_mcasp_trigger, .hw_params = davinci_mcasp_hw_params, .set_fmt = davinci_mcasp_set_dai_fmt, .set_clkdiv = davinci_mcasp_set_clkdiv, .set_sysclk = davinci_mcasp_set_sysclk, }; static int davinci_mcasp_dai_probe(struct snd_soc_dai *dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(dai); dai->playback_dma_data = &mcasp->dma_data[SNDRV_PCM_STREAM_PLAYBACK]; dai->capture_dma_data = &mcasp->dma_data[SNDRV_PCM_STREAM_CAPTURE]; return 0; } #ifdef CONFIG_PM_SLEEP static int davinci_mcasp_suspend(struct snd_soc_dai *dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(dai); struct davinci_mcasp_context *context = &mcasp->context; u32 reg; int i; context->pm_state = pm_runtime_active(mcasp->dev); if (!context->pm_state) pm_runtime_get_sync(mcasp->dev); for (i = 0; i < ARRAY_SIZE(context_regs); i++) context->config_regs[i] = mcasp_get_reg(mcasp, context_regs[i]); if (mcasp->txnumevt) { reg = mcasp->fifo_base + MCASP_WFIFOCTL_OFFSET; context->afifo_regs[0] = mcasp_get_reg(mcasp, reg); } if (mcasp->rxnumevt) { reg = mcasp->fifo_base + MCASP_RFIFOCTL_OFFSET; context->afifo_regs[1] = mcasp_get_reg(mcasp, reg); } for (i = 0; i < mcasp->num_serializer; i++) context->xrsr_regs[i] = mcasp_get_reg(mcasp, DAVINCI_MCASP_XRSRCTL_REG(i)); pm_runtime_put_sync(mcasp->dev); return 0; } static int davinci_mcasp_resume(struct snd_soc_dai *dai) { struct davinci_mcasp *mcasp = snd_soc_dai_get_drvdata(dai); struct davinci_mcasp_context *context = &mcasp->context; u32 reg; int i; pm_runtime_get_sync(mcasp->dev); for (i = 0; i < ARRAY_SIZE(context_regs); i++) mcasp_set_reg(mcasp, context_regs[i], context->config_regs[i]); if (mcasp->txnumevt) { reg = mcasp->fifo_base + MCASP_WFIFOCTL_OFFSET; mcasp_set_reg(mcasp, reg, context->afifo_regs[0]); } if (mcasp->rxnumevt) { reg = mcasp->fifo_base + MCASP_RFIFOCTL_OFFSET; mcasp_set_reg(mcasp, reg, context->afifo_regs[1]); } for (i = 0; i < mcasp->num_serializer; i++) mcasp_set_reg(mcasp, DAVINCI_MCASP_XRSRCTL_REG(i), context->xrsr_regs[i]); if (!context->pm_state) pm_runtime_put_sync(mcasp->dev); return 0; } #else #define davinci_mcasp_suspend NULL #define davinci_mcasp_resume NULL #endif #define DAVINCI_MCASP_RATES SNDRV_PCM_RATE_8000_192000 #define DAVINCI_MCASP_PCM_FMTS (SNDRV_PCM_FMTBIT_S8 | \ SNDRV_PCM_FMTBIT_U8 | \ SNDRV_PCM_FMTBIT_S16_LE | \ SNDRV_PCM_FMTBIT_U16_LE | \ SNDRV_PCM_FMTBIT_S24_LE | \ SNDRV_PCM_FMTBIT_U24_LE | \ SNDRV_PCM_FMTBIT_S24_3LE | \ SNDRV_PCM_FMTBIT_U24_3LE | \ SNDRV_PCM_FMTBIT_S32_LE | \ SNDRV_PCM_FMTBIT_U32_LE) static struct snd_soc_dai_driver davinci_mcasp_dai[] = { { .name = "davinci-mcasp.0", .probe = davinci_mcasp_dai_probe, .suspend = davinci_mcasp_suspend, .resume = davinci_mcasp_resume, .playback = { .channels_min = 2, .channels_max = 32 * 16, .rates = DAVINCI_MCASP_RATES, .formats = DAVINCI_MCASP_PCM_FMTS, }, .capture = { .channels_min = 2, .channels_max = 32 * 16, .rates = DAVINCI_MCASP_RATES, .formats = DAVINCI_MCASP_PCM_FMTS, }, .ops = &davinci_mcasp_dai_ops, .symmetric_samplebits = 1, }, { .name = "davinci-mcasp.1", .probe = davinci_mcasp_dai_probe, .playback = { .channels_min = 1, .channels_max = 384, .rates = DAVINCI_MCASP_RATES, .formats = DAVINCI_MCASP_PCM_FMTS, }, .ops = &davinci_mcasp_dai_ops, }, }; static const struct snd_soc_component_driver davinci_mcasp_component = { .name = "davinci-mcasp", }; /* Some HW specific values and defaults. The rest is filled in from DT. */ static struct davinci_mcasp_pdata dm646x_mcasp_pdata = { .tx_dma_offset = 0x400, .rx_dma_offset = 0x400, .version = MCASP_VERSION_1, }; static struct davinci_mcasp_pdata da830_mcasp_pdata = { .tx_dma_offset = 0x2000, .rx_dma_offset = 0x2000, .version = MCASP_VERSION_2, }; static struct davinci_mcasp_pdata am33xx_mcasp_pdata = { .tx_dma_offset = 0, .rx_dma_offset = 0, .version = MCASP_VERSION_3, }; static struct davinci_mcasp_pdata dra7_mcasp_pdata = { .tx_dma_offset = 0x200, .rx_dma_offset = 0x284, .version = MCASP_VERSION_4, }; static const struct of_device_id mcasp_dt_ids[] = { { .compatible = "ti,dm646x-mcasp-audio", .data = &dm646x_mcasp_pdata, }, { .compatible = "ti,da830-mcasp-audio", .data = &da830_mcasp_pdata, }, { .compatible = "ti,am33xx-mcasp-audio", .data = &am33xx_mcasp_pdata, }, { .compatible = "ti,dra7-mcasp-audio", .data = &dra7_mcasp_pdata, }, { /* sentinel */ } }; MODULE_DEVICE_TABLE(of, mcasp_dt_ids); static int mcasp_reparent_fck(struct platform_device *pdev) { struct device_node *node = pdev->dev.of_node; struct clk *gfclk, *parent_clk; const char *parent_name; int ret; if (!node) return 0; parent_name = of_get_property(node, "fck_parent", NULL); if (!parent_name) return 0; gfclk = clk_get(&pdev->dev, "fck"); if (IS_ERR(gfclk)) { dev_err(&pdev->dev, "failed to get fck\n"); return PTR_ERR(gfclk); } parent_clk = clk_get(NULL, parent_name); if (IS_ERR(parent_clk)) { dev_err(&pdev->dev, "failed to get parent clock\n"); ret = PTR_ERR(parent_clk); goto err1; } ret = clk_set_parent(gfclk, parent_clk); if (ret) { dev_err(&pdev->dev, "failed to reparent fck\n"); goto err2; } err2: clk_put(parent_clk); err1: clk_put(gfclk); return ret; } static struct davinci_mcasp_pdata *davinci_mcasp_set_pdata_from_of( struct platform_device *pdev) { struct device_node *np = pdev->dev.of_node; struct davinci_mcasp_pdata *pdata = NULL; const struct of_device_id *match = of_match_device(mcasp_dt_ids, &pdev->dev); struct of_phandle_args dma_spec; const u32 *of_serial_dir32; u32 val; int i, ret = 0; if (pdev->dev.platform_data) { pdata = pdev->dev.platform_data; return pdata; } else if (match) { pdata = (struct davinci_mcasp_pdata*) match->data; } else { /* control shouldn't reach here. something is wrong */ ret = -EINVAL; goto nodata; } ret = of_property_read_u32(np, "op-mode", &val); if (ret >= 0) pdata->op_mode = val; ret = of_property_read_u32(np, "tdm-slots", &val); if (ret >= 0) { if (val < 2 || val > 32) { dev_err(&pdev->dev, "tdm-slots must be in rage [2-32]\n"); ret = -EINVAL; goto nodata; } pdata->tdm_slots = val; } of_serial_dir32 = of_get_property(np, "serial-dir", &val); val /= sizeof(u32); if (of_serial_dir32) { u8 *of_serial_dir = devm_kzalloc(&pdev->dev, (sizeof(*of_serial_dir) * val), GFP_KERNEL); if (!of_serial_dir) { ret = -ENOMEM; goto nodata; } for (i = 0; i < val; i++) of_serial_dir[i] = be32_to_cpup(&of_serial_dir32[i]); pdata->num_serializer = val; pdata->serial_dir = of_serial_dir; } ret = of_property_match_string(np, "dma-names", "tx"); if (ret < 0) goto nodata; ret = of_parse_phandle_with_args(np, "dmas", "#dma-cells", ret, &dma_spec); if (ret < 0) goto nodata; pdata->tx_dma_channel = dma_spec.args[0]; /* RX is not valid in DIT mode */ if (pdata->op_mode != DAVINCI_MCASP_DIT_MODE) { ret = of_property_match_string(np, "dma-names", "rx"); if (ret < 0) goto nodata; ret = of_parse_phandle_with_args(np, "dmas", "#dma-cells", ret, &dma_spec); if (ret < 0) goto nodata; pdata->rx_dma_channel = dma_spec.args[0]; } ret = of_property_read_u32(np, "tx-num-evt", &val); if (ret >= 0) pdata->txnumevt = val; ret = of_property_read_u32(np, "rx-num-evt", &val); if (ret >= 0) pdata->rxnumevt = val; ret = of_property_read_u32(np, "sram-size-playback", &val); if (ret >= 0) pdata->sram_size_playback = val; ret = of_property_read_u32(np, "sram-size-capture", &val); if (ret >= 0) pdata->sram_size_capture = val; return pdata; nodata: if (ret < 0) { dev_err(&pdev->dev, "Error populating platform data, err %d\n", ret); pdata = NULL; } return pdata; } /* All serializers must have equal number of channels */ static int davinci_mcasp_ch_constraint(struct davinci_mcasp *mcasp, struct snd_pcm_hw_constraint_list *cl, int serializers) { unsigned int *list; int i, count = 0; if (serializers <= 1) return 0; list = devm_kzalloc(mcasp->dev, sizeof(unsigned int) * (mcasp->tdm_slots + serializers - 2), GFP_KERNEL); if (!list) return -ENOMEM; for (i = 2; i <= mcasp->tdm_slots; i++) list[count++] = i; for (i = 2; i <= serializers; i++) list[count++] = i*mcasp->tdm_slots; cl->count = count; cl->list = list; return 0; } static int davinci_mcasp_init_ch_constraints(struct davinci_mcasp *mcasp) { int rx_serializers = 0, tx_serializers = 0, ret, i; for (i = 0; i < mcasp->num_serializer; i++) if (mcasp->serial_dir[i] == TX_MODE) tx_serializers++; else if (mcasp->serial_dir[i] == RX_MODE) rx_serializers++; ret = davinci_mcasp_ch_constraint(mcasp, &mcasp->chconstr[ SNDRV_PCM_STREAM_PLAYBACK], tx_serializers); if (ret) return ret; ret = davinci_mcasp_ch_constraint(mcasp, &mcasp->chconstr[ SNDRV_PCM_STREAM_CAPTURE], rx_serializers); return ret; } enum { PCM_EDMA, PCM_SDMA, }; static const char *sdma_prefix = "ti,omap"; static int davinci_mcasp_get_dma_type(struct davinci_mcasp *mcasp) { struct dma_chan *chan; const char *tmp; int ret = PCM_EDMA; if (!mcasp->dev->of_node) return PCM_EDMA; tmp = mcasp->dma_data[SNDRV_PCM_STREAM_PLAYBACK].filter_data; chan = dma_request_slave_channel_reason(mcasp->dev, tmp); if (IS_ERR(chan)) { if (PTR_ERR(chan) != -EPROBE_DEFER) dev_err(mcasp->dev, "Can't verify DMA configuration (%ld)\n", PTR_ERR(chan)); return PTR_ERR(chan); } BUG_ON(!chan->device || !chan->device->dev); if (chan->device->dev->of_node) ret = of_property_read_string(chan->device->dev->of_node, "compatible", &tmp); else dev_dbg(mcasp->dev, "DMA controller has no of-node\n"); dma_release_channel(chan); if (ret) return ret; dev_dbg(mcasp->dev, "DMA controller compatible = \"%s\"\n", tmp); if (!strncmp(tmp, sdma_prefix, strlen(sdma_prefix))) return PCM_SDMA; return PCM_EDMA; } #if IS_ENABLED(CONFIG_DISPLAY_DRA7EVM_ENCODER_TPD12S015) #define DRA7_MCASP_HDMI_SEL_GPIO (1 << 2) int dra7_mcasp_hdmi_gpio_get(struct platform_device *pdev) { struct davinci_mcasp *mcasp; if (!pdev) return -EPROBE_DEFER; mcasp = dev_get_drvdata(&pdev->dev); if (!mcasp) return -EPROBE_DEFER; if (!mcasp->is_mcasp8) return 0; pm_runtime_get_sync(mcasp->dev); /* First set the direction to output */ mcasp_set_bits(mcasp, DAVINCI_MCASP_PDIR_REG, DRA7_MCASP_HDMI_SEL_GPIO); /* then set the PDOUT */ if (mcasp->hdmi_sel_gpio) mcasp_set_bits(mcasp, DAVINCI_MCASP_PDOUT_REG, DRA7_MCASP_HDMI_SEL_GPIO); else mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDOUT_REG, DRA7_MCASP_HDMI_SEL_GPIO); /* at last, change the function to GPIO mode */ mcasp_set_bits(mcasp, DAVINCI_MCASP_PFUNC_REG, DRA7_MCASP_HDMI_SEL_GPIO); return 0; } EXPORT_SYMBOL(dra7_mcasp_hdmi_gpio_get); int dra7_mcasp_hdmi_gpio_put(struct platform_device *pdev) { struct davinci_mcasp *mcasp; if (!pdev) return -EPROBE_DEFER; mcasp = dev_get_drvdata(&pdev->dev); if (!mcasp) return -EPROBE_DEFER; if (!mcasp->is_mcasp8) return 0; /* Set the pin as McASP pin */ mcasp_clr_bits(mcasp, DAVINCI_MCASP_PFUNC_REG, DRA7_MCASP_HDMI_SEL_GPIO); pm_runtime_put_sync(mcasp->dev); return 0; } EXPORT_SYMBOL(dra7_mcasp_hdmi_gpio_put); int dra7_mcasp_hdmi_gpio_set(struct platform_device *pdev, bool high) { struct davinci_mcasp *mcasp; if (!pdev) return -EPROBE_DEFER; mcasp = dev_get_drvdata(&pdev->dev); if (!mcasp) return -EPROBE_DEFER; if (!mcasp->is_mcasp8) return 0; if (!pm_runtime_active(mcasp->dev)) { dev_warn(mcasp->dev, "mcasp8 is not enabled!\n"); return -ENODEV; } if (mcasp->hdmi_sel_gpio == high) return 0; mcasp->hdmi_sel_gpio = high; if (mcasp->hdmi_sel_gpio) mcasp_set_bits(mcasp, DAVINCI_MCASP_PDOUT_REG, DRA7_MCASP_HDMI_SEL_GPIO); else mcasp_clr_bits(mcasp, DAVINCI_MCASP_PDOUT_REG, DRA7_MCASP_HDMI_SEL_GPIO); return 0; } EXPORT_SYMBOL(dra7_mcasp_hdmi_gpio_set); #endif /* CONFIG_DISPLAY_DRA7EVM_ENCODER_TPD12S015 */ static int davinci_mcasp_probe(struct platform_device *pdev) { struct snd_dmaengine_dai_dma_data *dma_data; struct resource *mem, *ioarea, *res, *dat; struct davinci_mcasp_pdata *pdata; struct davinci_mcasp *mcasp; char *irq_name; int *dma; int irq; int ret; if (!pdev->dev.platform_data && !pdev->dev.of_node) { dev_err(&pdev->dev, "No platform data supplied\n"); return -EINVAL; } mcasp = devm_kzalloc(&pdev->dev, sizeof(struct davinci_mcasp), GFP_KERNEL); if (!mcasp) return -ENOMEM; pdata = davinci_mcasp_set_pdata_from_of(pdev); if (!pdata) { dev_err(&pdev->dev, "no platform data\n"); return -EINVAL; } mem = platform_get_resource_byname(pdev, IORESOURCE_MEM, "mpu"); if (!mem) { dev_warn(mcasp->dev, "\"mpu\" mem resource not found, using index 0\n"); mem = platform_get_resource(pdev, IORESOURCE_MEM, 0); if (!mem) { dev_err(&pdev->dev, "no mem resource?\n"); return -ENODEV; } } #if IS_ENABLED(CONFIG_DISPLAY_DRA7EVM_ENCODER_TPD12S015) if (pdata->version == MCASP_VERSION_4 && mem->start == 0x4847c000) mcasp->is_mcasp8 = true; #endif ioarea = devm_request_mem_region(&pdev->dev, mem->start, resource_size(mem), pdev->name); if (!ioarea) { dev_err(&pdev->dev, "Audio region already claimed\n"); return -EBUSY; } pm_runtime_enable(&pdev->dev); mcasp->base = devm_ioremap(&pdev->dev, mem->start, resource_size(mem)); if (!mcasp->base) { dev_err(&pdev->dev, "ioremap failed\n"); ret = -ENOMEM; goto err; } mcasp->op_mode = pdata->op_mode; /* sanity check for tdm slots parameter */ if (mcasp->op_mode == DAVINCI_MCASP_IIS_MODE) { if (pdata->tdm_slots < 2) { dev_err(&pdev->dev, "invalid tdm slots: %d\n", pdata->tdm_slots); mcasp->tdm_slots = 2; } else if (pdata->tdm_slots > 32) { dev_err(&pdev->dev, "invalid tdm slots: %d\n", pdata->tdm_slots); mcasp->tdm_slots = 32; } else { mcasp->tdm_slots = pdata->tdm_slots; } } mcasp->num_serializer = pdata->num_serializer; #ifdef CONFIG_PM_SLEEP mcasp->context.xrsr_regs = devm_kzalloc(&pdev->dev, sizeof(u32) * mcasp->num_serializer, GFP_KERNEL); #endif mcasp->serial_dir = pdata->serial_dir; mcasp->version = pdata->version; mcasp->txnumevt = pdata->txnumevt; mcasp->rxnumevt = pdata->rxnumevt; mcasp->dev = &pdev->dev; irq = platform_get_irq_byname(pdev, "common"); if (irq >= 0) { irq_name = devm_kasprintf(&pdev->dev, GFP_KERNEL, "%s_common\n", dev_name(&pdev->dev)); ret = devm_request_threaded_irq(&pdev->dev, irq, NULL, davinci_mcasp_common_irq_handler, IRQF_ONESHOT | IRQF_SHARED, irq_name, mcasp); if (ret) { dev_err(&pdev->dev, "common IRQ request failed\n"); goto err; } mcasp->irq_request[SNDRV_PCM_STREAM_PLAYBACK] = XUNDRN; mcasp->irq_request[SNDRV_PCM_STREAM_CAPTURE] = ROVRN; } irq = platform_get_irq_byname(pdev, "rx"); if (irq >= 0) { irq_name = devm_kasprintf(&pdev->dev, GFP_KERNEL, "%s_rx\n", dev_name(&pdev->dev)); ret = devm_request_threaded_irq(&pdev->dev, irq, NULL, davinci_mcasp_rx_irq_handler, IRQF_ONESHOT, irq_name, mcasp); if (ret) { dev_err(&pdev->dev, "RX IRQ request failed\n"); goto err; } mcasp->irq_request[SNDRV_PCM_STREAM_CAPTURE] = ROVRN; } irq = platform_get_irq_byname(pdev, "tx"); if (irq >= 0) { irq_name = devm_kasprintf(&pdev->dev, GFP_KERNEL, "%s_tx\n", dev_name(&pdev->dev)); ret = devm_request_threaded_irq(&pdev->dev, irq, NULL, davinci_mcasp_tx_irq_handler, IRQF_ONESHOT, irq_name, mcasp); if (ret) { dev_err(&pdev->dev, "TX IRQ request failed\n"); goto err; } mcasp->irq_request[SNDRV_PCM_STREAM_PLAYBACK] = XUNDRN; } dat = platform_get_resource_byname(pdev, IORESOURCE_MEM, "dat"); if (dat) mcasp->dat_port = true; dma_data = &mcasp->dma_data[SNDRV_PCM_STREAM_PLAYBACK]; if (dat) dma_data->addr = dat->start; else dma_data->addr = mem->start + pdata->tx_dma_offset; dma = &mcasp->dma_request[SNDRV_PCM_STREAM_PLAYBACK]; res = platform_get_resource(pdev, IORESOURCE_DMA, 0); if (res) *dma = res->start; else *dma = pdata->tx_dma_channel; /* dmaengine filter data for DT and non-DT boot */ if (pdev->dev.of_node) dma_data->filter_data = "tx"; else dma_data->filter_data = dma; /* RX is not valid in DIT mode */ if (mcasp->op_mode != DAVINCI_MCASP_DIT_MODE) { dma_data = &mcasp->dma_data[SNDRV_PCM_STREAM_CAPTURE]; if (dat) dma_data->addr = dat->start; else dma_data->addr = mem->start + pdata->rx_dma_offset; dma = &mcasp->dma_request[SNDRV_PCM_STREAM_CAPTURE]; res = platform_get_resource(pdev, IORESOURCE_DMA, 1); if (res) *dma = res->start; else *dma = pdata->rx_dma_channel; /* dmaengine filter data for DT and non-DT boot */ if (pdev->dev.of_node) dma_data->filter_data = "rx"; else dma_data->filter_data = dma; } if (mcasp->version < MCASP_VERSION_3) { mcasp->fifo_base = DAVINCI_MCASP_V2_AFIFO_BASE; /* dma_params->dma_addr is pointing to the data port address */ mcasp->dat_port = true; } else { mcasp->fifo_base = DAVINCI_MCASP_V3_AFIFO_BASE; } ret = davinci_mcasp_init_ch_constraints(mcasp); if (ret) goto err; dev_set_drvdata(&pdev->dev, mcasp); mcasp_reparent_fck(pdev); if (mcasp->version == MCASP_VERSION_4) { u32 rev; pm_runtime_get_sync(mcasp->dev); rev = mcasp_get_reg(mcasp, DAVINCI_MCASP_PID_REG) & MCASP_V4_REV_MASK; pm_runtime_put(mcasp->dev); if (rev < MCASP_V4_REV(3, 3)) { /* * ERRATA i868: to avoid race condition between DMA and * AFIFO events the R/WNUMEVT need to be set to be * less-than-equal to 32 words. */ if (mcasp->txnumevt) mcasp->txnumevt = 32; if (mcasp->rxnumevt) mcasp->rxnumevt = 32; if (mcasp->txnumevt || mcasp->rxnumevt) dev_info(&pdev->dev, "ERRATA i868 workaround is enabled\n"); } } ret = devm_snd_soc_register_component(&pdev->dev, &davinci_mcasp_component, &davinci_mcasp_dai[pdata->op_mode], 1); if (ret != 0) goto err; ret = davinci_mcasp_get_dma_type(mcasp); switch (ret) { case PCM_EDMA: #if IS_BUILTIN(CONFIG_SND_EDMA_SOC) || \ (IS_MODULE(CONFIG_SND_DAVINCI_SOC_MCASP) && \ IS_MODULE(CONFIG_SND_EDMA_SOC)) ret = edma_pcm_platform_register(&pdev->dev); #else dev_err(&pdev->dev, "Missing SND_EDMA_SOC\n"); ret = -EINVAL; goto err; #endif break; case PCM_SDMA: #if IS_BUILTIN(CONFIG_SND_OMAP_SOC) || \ (IS_MODULE(CONFIG_SND_DAVINCI_SOC_MCASP) && \ IS_MODULE(CONFIG_SND_OMAP_SOC)) ret = omap_pcm_platform_register(&pdev->dev); #else dev_err(&pdev->dev, "Missing SND_SDMA_SOC\n"); ret = -EINVAL; goto err; #endif break; default: dev_err(&pdev->dev, "No DMA controller found (%d)\n", ret); case -EPROBE_DEFER: goto err; break; } if (ret) { dev_err(&pdev->dev, "register PCM failed: %d\n", ret); goto err; } return 0; err: pm_runtime_disable(&pdev->dev); return ret; } static int davinci_mcasp_remove(struct platform_device *pdev) { pm_runtime_disable(&pdev->dev); return 0; } static struct platform_driver davinci_mcasp_driver = { .probe = davinci_mcasp_probe, .remove = davinci_mcasp_remove, .driver = { .name = "davinci-mcasp", .of_match_table = mcasp_dt_ids, }, }; module_platform_driver(davinci_mcasp_driver); MODULE_AUTHOR("Steve Chen"); MODULE_DESCRIPTION("TI DAVINCI McASP SoC Interface"); MODULE_LICENSE("GPL");
/* * ALSA SoC TLV320AIC31XX codec driver * * Copyright (C) 2014 Texas Instruments, Inc. * * Author: Jyri Sarha <jsarha@ti.com> * * Based on ground work by: Ajit Kulkarni <x0175765@ti.com> * * This package is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. * * THIS PACKAGE IS PROVIDED AS IS AND WITHOUT ANY EXPRESS OR * IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED * WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE. * * The TLV320AIC31xx series of audio codec is a low-power, highly integrated * high performance codec which provides a stereo DAC, a mono ADC, * and mono/stereo Class-D speaker driver. */ #include <linux/module.h> #include <linux/moduleparam.h> #include <linux/init.h> #include <linux/delay.h> #include <linux/pm.h> #include <linux/i2c.h> #include <linux/gpio.h> #include <linux/regulator/consumer.h> #include <linux/of.h> #include <linux/of_gpio.h> #include <linux/slab.h> #include <sound/core.h> #include <sound/pcm.h> #include <sound/pcm_params.h> #include <sound/soc.h> #include <sound/initval.h> #include <sound/tlv.h> #include <dt-bindings/sound/tlv320aic31xx-micbias.h> #include "tlv320aic31xx.h" static const struct reg_default aic31xx_reg_defaults[] = { { AIC31XX_CLKMUX, 0x00 }, { AIC31XX_PLLPR, 0x11 }, { AIC31XX_PLLJ, 0x04 }, { AIC31XX_PLLDMSB, 0x00 }, { AIC31XX_PLLDLSB, 0x00 }, { AIC31XX_NDAC, 0x01 }, { AIC31XX_MDAC, 0x01 }, { AIC31XX_DOSRMSB, 0x00 }, { AIC31XX_DOSRLSB, 0x80 }, { AIC31XX_NADC, 0x01 }, { AIC31XX_MADC, 0x01 }, { AIC31XX_AOSR, 0x80 }, { AIC31XX_IFACE1, 0x00 }, { AIC31XX_DATA_OFFSET, 0x00 }, { AIC31XX_IFACE2, 0x00 }, { AIC31XX_BCLKN, 0x01 }, { AIC31XX_DACSETUP, 0x14 }, { AIC31XX_DACMUTE, 0x0c }, { AIC31XX_LDACVOL, 0x00 }, { AIC31XX_RDACVOL, 0x00 }, { AIC31XX_ADCSETUP, 0x00 }, { AIC31XX_ADCFGA, 0x80 }, { AIC31XX_ADCVOL, 0x00 }, { AIC31XX_HPDRIVER, 0x04 }, { AIC31XX_SPKAMP, 0x06 }, { AIC31XX_DACMIXERROUTE, 0x00 }, { AIC31XX_LANALOGHPL, 0x7f }, { AIC31XX_RANALOGHPR, 0x7f }, { AIC31XX_LANALOGSPL, 0x7f }, { AIC31XX_RANALOGSPR, 0x7f }, { AIC31XX_HPLGAIN, 0x02 }, { AIC31XX_HPRGAIN, 0x02 }, { AIC31XX_SPLGAIN, 0x00 }, { AIC31XX_SPRGAIN, 0x00 }, { AIC31XX_MICBIAS, 0x00 }, { AIC31XX_MICPGA, 0x80 }, { AIC31XX_MICPGAPI, 0x00 }, { AIC31XX_MICPGAMI, 0x00 }, }; static bool aic31xx_volatile(struct device *dev, unsigned int reg) { switch (reg) { case AIC31XX_PAGECTL: /* regmap implementation requires this */ case AIC31XX_RESET: /* always clears after write */ case AIC31XX_OT_FLAG: case AIC31XX_ADCFLAG: case AIC31XX_DACFLAG1: case AIC31XX_DACFLAG2: case AIC31XX_OFFLAG: /* Sticky interrupt flags */ case AIC31XX_INTRDACFLAG: /* Sticky interrupt flags */ case AIC31XX_INTRADCFLAG: /* Sticky interrupt flags */ case AIC31XX_INTRDACFLAG2: case AIC31XX_INTRADCFLAG2: return true; } return false; } static bool aic31xx_writeable(struct device *dev, unsigned int reg) { switch (reg) { case AIC31XX_OT_FLAG: case AIC31XX_ADCFLAG: case AIC31XX_DACFLAG1: case AIC31XX_DACFLAG2: case AIC31XX_OFFLAG: /* Sticky interrupt flags */ case AIC31XX_INTRDACFLAG: /* Sticky interrupt flags */ case AIC31XX_INTRADCFLAG: /* Sticky interrupt flags */ case AIC31XX_INTRDACFLAG2: case AIC31XX_INTRADCFLAG2: return false; } return true; } static const struct regmap_range_cfg aic31xx_ranges[] = { { .range_min = 0, .range_max = 12 * 128, .selector_reg = AIC31XX_PAGECTL, .selector_mask = 0xff, .selector_shift = 0, .window_start = 0, .window_len = 128, }, }; static const struct regmap_config aic31xx_i2c_regmap = { .reg_bits = 8, .val_bits = 8, .writeable_reg = aic31xx_writeable, .volatile_reg = aic31xx_volatile, .reg_defaults = aic31xx_reg_defaults, .num_reg_defaults = ARRAY_SIZE(aic31xx_reg_defaults), .cache_type = REGCACHE_RBTREE, .ranges = aic31xx_ranges, .num_ranges = ARRAY_SIZE(aic31xx_ranges), .max_register = 12 * 128, }; #define AIC31XX_NUM_SUPPLIES 6 static const char * const aic31xx_supply_names[AIC31XX_NUM_SUPPLIES] = { "HPVDD", "SPRVDD", "SPLVDD", "AVDD", "IOVDD", "DVDD", }; struct aic31xx_disable_nb { struct notifier_block nb; struct aic31xx_priv *aic31xx; }; struct aic31xx_priv { struct snd_soc_codec *codec; u8 i2c_regs_status; struct device *dev; struct regmap *regmap; struct aic31xx_pdata pdata; struct regulator_bulk_data supplies[AIC31XX_NUM_SUPPLIES]; struct aic31xx_disable_nb disable_nb[AIC31XX_NUM_SUPPLIES]; unsigned int sysclk; u8 p_div; int rate_div_line; }; struct aic31xx_rate_divs { u32 mclk_p; u32 rate; u8 pll_j; u16 pll_d; u16 dosr; u8 ndac; u8 mdac; u8 aosr; u8 nadc; u8 madc; }; /* ADC dividers can be disabled by cofiguring them to 0 */ static const struct aic31xx_rate_divs aic31xx_divs[] = { /* mclk/p rate pll: j d dosr ndac mdac aors nadc madc */ /* 8k rate */ {12000000, 8000, 8, 1920, 128, 48, 2, 128, 48, 2}, {12000000, 8000, 8, 1920, 128, 32, 3, 128, 32, 3}, {12500000, 8000, 7, 8643, 128, 48, 2, 128, 48, 2}, /* 11.025k rate */ {12000000, 11025, 7, 5264, 128, 32, 2, 128, 32, 2}, {12000000, 11025, 8, 4672, 128, 24, 3, 128, 24, 3}, {12500000, 11025, 7, 2253, 128, 32, 2, 128, 32, 2}, /* 16k rate */ {12000000, 16000, 8, 1920, 128, 24, 2, 128, 24, 2}, {12000000, 16000, 8, 1920, 128, 16, 3, 128, 16, 3}, {12500000, 16000, 7, 8643, 128, 24, 2, 128, 24, 2}, /* 22.05k rate */ {12000000, 22050, 7, 5264, 128, 16, 2, 128, 16, 2}, {12000000, 22050, 8, 4672, 128, 12, 3, 128, 12, 3}, {12500000, 22050, 7, 2253, 128, 16, 2, 128, 16, 2}, /* 32k rate */ {12000000, 32000, 8, 1920, 128, 12, 2, 128, 12, 2}, {12000000, 32000, 8, 1920, 128, 8, 3, 128, 8, 3}, {12500000, 32000, 7, 8643, 128, 12, 2, 128, 12, 2}, /* 44.1k rate */ {12000000, 44100, 7, 5264, 128, 8, 2, 128, 8, 2}, {12000000, 44100, 8, 4672, 128, 6, 3, 128, 6, 3}, {12500000, 44100, 7, 2253, 128, 8, 2, 128, 8, 2}, /* 48k rate */ {12000000, 48000, 8, 1920, 128, 8, 2, 128, 8, 2}, {12000000, 48000, 7, 6800, 96, 5, 4, 96, 5, 4}, {12500000, 48000, 7, 8643, 128, 8, 2, 128, 8, 2}, /* 88.2k rate */ {12000000, 88200, 7, 5264, 64, 8, 2, 64, 8, 2}, {12000000, 88200, 8, 4672, 64, 6, 3, 64, 6, 3}, {12500000, 88200, 7, 2253, 64, 8, 2, 64, 8, 2}, /* 96k rate */ {12000000, 96000, 8, 1920, 64, 8, 2, 64, 8, 2}, {12000000, 96000, 7, 6800, 48, 5, 4, 48, 5, 4}, {12500000, 96000, 7, 8643, 64, 8, 2, 64, 8, 2}, /* 176.4k rate */ {12000000, 176400, 7, 5264, 32, 8, 2, 32, 8, 2}, {12000000, 176400, 8, 4672, 32, 6, 3, 32, 6, 3}, {12500000, 176400, 7, 2253, 32, 8, 2, 32, 8, 2}, /* 192k rate */ {12000000, 192000, 8, 1920, 32, 8, 2, 32, 8, 2}, {12000000, 192000, 7, 6800, 24, 5, 4, 24, 5, 4}, {12500000, 192000, 7, 8643, 32, 8, 2, 32, 8, 2}, }; static const char * const ldac_in_text[] = { "Off", "Left Data", "Right Data", "Mono" }; static const char * const rdac_in_text[] = { "Off", "Right Data", "Left Data", "Mono" }; static SOC_ENUM_SINGLE_DECL(ldac_in_enum, AIC31XX_DACSETUP, 4, ldac_in_text); static SOC_ENUM_SINGLE_DECL(rdac_in_enum, AIC31XX_DACSETUP, 2, rdac_in_text); static const char * const mic_select_text[] = { "Off", "FFR 10 Ohm", "FFR 20 Ohm", "FFR 40 Ohm" }; static SOC_ENUM_SINGLE_DECL(mic1lp_p_enum, AIC31XX_MICPGAPI, 6, mic_select_text); static SOC_ENUM_SINGLE_DECL(mic1rp_p_enum, AIC31XX_MICPGAPI, 4, mic_select_text); static SOC_ENUM_SINGLE_DECL(mic1lm_p_enum, AIC31XX_MICPGAPI, 2, mic_select_text); static SOC_ENUM_SINGLE_DECL(cm_m_enum, AIC31XX_MICPGAMI, 6, mic_select_text); static SOC_ENUM_SINGLE_DECL(mic1lm_m_enum, AIC31XX_MICPGAMI, 4, mic_select_text); static const DECLARE_TLV_DB_SCALE(dac_vol_tlv, -6350, 50, 0); static const DECLARE_TLV_DB_SCALE(adc_fgain_tlv, 0, 10, 0); static const DECLARE_TLV_DB_SCALE(adc_cgain_tlv, -2000, 50, 0); static const DECLARE_TLV_DB_SCALE(mic_pga_tlv, 0, 50, 0); static const DECLARE_TLV_DB_SCALE(hp_drv_tlv, 0, 100, 0); static const DECLARE_TLV_DB_SCALE(class_D_drv_tlv, 600, 600, 0); static const DECLARE_TLV_DB_SCALE(hp_vol_tlv, -6350, 50, 0); static const DECLARE_TLV_DB_SCALE(sp_vol_tlv, -6350, 50, 0); /* * controls to be exported to the user space */ static const struct snd_kcontrol_new aic31xx_snd_controls[] = { SOC_DOUBLE_R_S_TLV("DAC Playback Volume", AIC31XX_LDACVOL, AIC31XX_RDACVOL, 0, -127, 48, 7, 0, dac_vol_tlv), SOC_SINGLE_TLV("ADC Fine Capture Volume", AIC31XX_ADCFGA, 4, 4, 1, adc_fgain_tlv), SOC_SINGLE("ADC Capture Switch", AIC31XX_ADCFGA, 7, 1, 1), SOC_DOUBLE_R_S_TLV("ADC Capture Volume", AIC31XX_ADCVOL, AIC31XX_ADCVOL, 0, -24, 40, 6, 0, adc_cgain_tlv), SOC_SINGLE_TLV("Mic PGA Capture Volume", AIC31XX_MICPGA, 0, 119, 0, mic_pga_tlv), SOC_DOUBLE_R("HP Driver Playback Switch", AIC31XX_HPLGAIN, AIC31XX_HPRGAIN, 2, 1, 0), SOC_DOUBLE_R_TLV("HP Driver Playback Volume", AIC31XX_HPLGAIN, AIC31XX_HPRGAIN, 3, 0x09, 0, hp_drv_tlv), SOC_DOUBLE_R_TLV("HP Analog Playback Volume", AIC31XX_LANALOGHPL, AIC31XX_RANALOGHPR, 0, 0x7F, 1, hp_vol_tlv), }; static const struct snd_kcontrol_new aic311x_snd_controls[] = { SOC_DOUBLE_R("Speaker Driver Playback Switch", AIC31XX_SPLGAIN, AIC31XX_SPRGAIN, 2, 1, 0), SOC_DOUBLE_R_TLV("Speaker Driver Playback Volume", AIC31XX_SPLGAIN, AIC31XX_SPRGAIN, 3, 3, 0, class_D_drv_tlv), SOC_DOUBLE_R_TLV("Speaker Analog Playback Volume", AIC31XX_LANALOGSPL, AIC31XX_RANALOGSPR, 0, 0x7F, 1, sp_vol_tlv), }; static const struct snd_kcontrol_new aic310x_snd_controls[] = { SOC_SINGLE("Speaker Driver Playback Switch", AIC31XX_SPLGAIN, 2, 1, 0), SOC_SINGLE_TLV("Speaker Driver Playback Volume", AIC31XX_SPLGAIN, 3, 3, 0, class_D_drv_tlv), SOC_SINGLE_TLV("Speaker Analog Playback Volume", AIC31XX_LANALOGSPL, 0, 0x7F, 1, sp_vol_tlv), }; static const struct snd_kcontrol_new ldac_in_control = SOC_DAPM_ENUM("DAC Left Input", ldac_in_enum); static const struct snd_kcontrol_new rdac_in_control = SOC_DAPM_ENUM("DAC Right Input", rdac_in_enum); static int aic31xx_wait_bits(struct aic31xx_priv *aic31xx, unsigned int reg, unsigned int mask, unsigned int wbits, int sleep, int count) { unsigned int bits; int counter = count; int ret = regmap_read(aic31xx->regmap, reg, &bits); while ((bits & mask) != wbits && counter && !ret) { usleep_range(sleep, sleep * 2); ret = regmap_read(aic31xx->regmap, reg, &bits); counter--; } if ((bits & mask) != wbits) { dev_err(aic31xx->dev, "%s: Failed! 0x%x was 0x%x expected 0x%x (%d, 0x%x, %d us)\n", __func__, reg, bits, wbits, ret, mask, (count - counter) * sleep); ret = -1; } return ret; } #define WIDGET_BIT(reg, shift) (((shift) << 8) | (reg)) static int aic31xx_dapm_power_event(struct snd_soc_dapm_widget *w, struct snd_kcontrol *kcontrol, int event) { struct snd_soc_codec *codec = snd_soc_dapm_to_codec(w->dapm); struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); unsigned int reg = AIC31XX_DACFLAG1; unsigned int mask; switch (WIDGET_BIT(w->reg, w->shift)) { case WIDGET_BIT(AIC31XX_DACSETUP, 7): mask = AIC31XX_LDACPWRSTATUS_MASK; break; case WIDGET_BIT(AIC31XX_DACSETUP, 6): mask = AIC31XX_RDACPWRSTATUS_MASK; break; case WIDGET_BIT(AIC31XX_HPDRIVER, 7): mask = AIC31XX_HPLDRVPWRSTATUS_MASK; break; case WIDGET_BIT(AIC31XX_HPDRIVER, 6): mask = AIC31XX_HPRDRVPWRSTATUS_MASK; break; case WIDGET_BIT(AIC31XX_SPKAMP, 7): mask = AIC31XX_SPLDRVPWRSTATUS_MASK; break; case WIDGET_BIT(AIC31XX_SPKAMP, 6): mask = AIC31XX_SPRDRVPWRSTATUS_MASK; break; case WIDGET_BIT(AIC31XX_ADCSETUP, 7): mask = AIC31XX_ADCPWRSTATUS_MASK; reg = AIC31XX_ADCFLAG; break; default: dev_err(codec->dev, "Unknown widget '%s' calling %s\n", w->name, __func__); return -EINVAL; } switch (event) { case SND_SOC_DAPM_POST_PMU: return aic31xx_wait_bits(aic31xx, reg, mask, mask, 5000, 100); case SND_SOC_DAPM_POST_PMD: return aic31xx_wait_bits(aic31xx, reg, mask, 0, 5000, 100); default: dev_dbg(codec->dev, "Unhandled dapm widget event %d from %s\n", event, w->name); } return 0; } static const struct snd_kcontrol_new left_output_switches[] = { SOC_DAPM_SINGLE("From Left DAC", AIC31XX_DACMIXERROUTE, 6, 1, 0), SOC_DAPM_SINGLE("From MIC1LP", AIC31XX_DACMIXERROUTE, 5, 1, 0), SOC_DAPM_SINGLE("From MIC1RP", AIC31XX_DACMIXERROUTE, 4, 1, 0), }; static const struct snd_kcontrol_new right_output_switches[] = { SOC_DAPM_SINGLE("From Right DAC", AIC31XX_DACMIXERROUTE, 2, 1, 0), SOC_DAPM_SINGLE("From MIC1RP", AIC31XX_DACMIXERROUTE, 1, 1, 0), }; static const struct snd_kcontrol_new p_term_mic1lp = SOC_DAPM_ENUM("MIC1LP P-Terminal", mic1lp_p_enum); static const struct snd_kcontrol_new p_term_mic1rp = SOC_DAPM_ENUM("MIC1RP P-Terminal", mic1rp_p_enum); static const struct snd_kcontrol_new p_term_mic1lm = SOC_DAPM_ENUM("MIC1LM P-Terminal", mic1lm_p_enum); static const struct snd_kcontrol_new m_term_mic1lm = SOC_DAPM_ENUM("MIC1LM M-Terminal", mic1lm_m_enum); static const struct snd_kcontrol_new aic31xx_dapm_hpl_switch = SOC_DAPM_SINGLE("Switch", AIC31XX_LANALOGHPL, 7, 1, 0); static const struct snd_kcontrol_new aic31xx_dapm_hpr_switch = SOC_DAPM_SINGLE("Switch", AIC31XX_RANALOGHPR, 7, 1, 0); static const struct snd_kcontrol_new aic31xx_dapm_spl_switch = SOC_DAPM_SINGLE("Switch", AIC31XX_LANALOGSPL, 7, 1, 0); static const struct snd_kcontrol_new aic31xx_dapm_spr_switch = SOC_DAPM_SINGLE("Switch", AIC31XX_RANALOGSPR, 7, 1, 0); static int mic_bias_event(struct snd_soc_dapm_widget *w, struct snd_kcontrol *kcontrol, int event) { struct snd_soc_codec *codec = snd_soc_dapm_to_codec(w->dapm); struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); switch (event) { case SND_SOC_DAPM_POST_PMU: /* change mic bias voltage to user defined */ snd_soc_update_bits(codec, AIC31XX_MICBIAS, AIC31XX_MICBIAS_MASK, aic31xx->pdata.micbias_vg << AIC31XX_MICBIAS_SHIFT); dev_dbg(codec->dev, "%s: turned on\n", __func__); break; case SND_SOC_DAPM_PRE_PMD: /* turn mic bias off */ snd_soc_update_bits(codec, AIC31XX_MICBIAS, AIC31XX_MICBIAS_MASK, 0); dev_dbg(codec->dev, "%s: turned off\n", __func__); break; } return 0; } static const struct snd_soc_dapm_widget aic31xx_dapm_widgets[] = { SND_SOC_DAPM_AIF_IN("DAC IN", "DAC Playback", 0, SND_SOC_NOPM, 0, 0), SND_SOC_DAPM_MUX("DAC Left Input", SND_SOC_NOPM, 0, 0, &ldac_in_control), SND_SOC_DAPM_MUX("DAC Right Input", SND_SOC_NOPM, 0, 0, &rdac_in_control), /* DACs */ SND_SOC_DAPM_DAC_E("DAC Left", "Left Playback", AIC31XX_DACSETUP, 7, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_POST_PMD), SND_SOC_DAPM_DAC_E("DAC Right", "Right Playback", AIC31XX_DACSETUP, 6, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_POST_PMD), /* Output Mixers */ SND_SOC_DAPM_MIXER("Output Left", SND_SOC_NOPM, 0, 0, left_output_switches, ARRAY_SIZE(left_output_switches)), SND_SOC_DAPM_MIXER("Output Right", SND_SOC_NOPM, 0, 0, right_output_switches, ARRAY_SIZE(right_output_switches)), SND_SOC_DAPM_SWITCH("HP Left", SND_SOC_NOPM, 0, 0, &aic31xx_dapm_hpl_switch), SND_SOC_DAPM_SWITCH("HP Right", SND_SOC_NOPM, 0, 0, &aic31xx_dapm_hpr_switch), /* Output drivers */ SND_SOC_DAPM_OUT_DRV_E("HPL Driver", AIC31XX_HPDRIVER, 7, 0, NULL, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMD | SND_SOC_DAPM_POST_PMU), SND_SOC_DAPM_OUT_DRV_E("HPR Driver", AIC31XX_HPDRIVER, 6, 0, NULL, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMD | SND_SOC_DAPM_POST_PMU), /* ADC */ SND_SOC_DAPM_ADC_E("ADC", "Capture", AIC31XX_ADCSETUP, 7, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_POST_PMD), /* Input Selection to MIC_PGA */ SND_SOC_DAPM_MUX("MIC1LP P-Terminal", SND_SOC_NOPM, 0, 0, &p_term_mic1lp), SND_SOC_DAPM_MUX("MIC1RP P-Terminal", SND_SOC_NOPM, 0, 0, &p_term_mic1rp), SND_SOC_DAPM_MUX("MIC1LM P-Terminal", SND_SOC_NOPM, 0, 0, &p_term_mic1lm), SND_SOC_DAPM_MUX("MIC1LM M-Terminal", SND_SOC_NOPM, 0, 0, &m_term_mic1lm), /* Enabling & Disabling MIC Gain Ctl */ SND_SOC_DAPM_PGA("MIC_GAIN_CTL", AIC31XX_MICPGA, 7, 1, NULL, 0), /* Mic Bias */ SND_SOC_DAPM_SUPPLY("MICBIAS", SND_SOC_NOPM, 0, 0, mic_bias_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_PRE_PMD), /* Outputs */ SND_SOC_DAPM_OUTPUT("HPL"), SND_SOC_DAPM_OUTPUT("HPR"), /* Inputs */ SND_SOC_DAPM_INPUT("MIC1LP"), SND_SOC_DAPM_INPUT("MIC1RP"), SND_SOC_DAPM_INPUT("MIC1LM"), }; static const struct snd_soc_dapm_widget aic311x_dapm_widgets[] = { /* AIC3111 and AIC3110 have stereo class-D amplifier */ SND_SOC_DAPM_OUT_DRV_E("SPL ClassD", AIC31XX_SPKAMP, 7, 0, NULL, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_POST_PMD), SND_SOC_DAPM_OUT_DRV_E("SPR ClassD", AIC31XX_SPKAMP, 6, 0, NULL, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_POST_PMD), SND_SOC_DAPM_SWITCH("Speaker Left", SND_SOC_NOPM, 0, 0, &aic31xx_dapm_spl_switch), SND_SOC_DAPM_SWITCH("Speaker Right", SND_SOC_NOPM, 0, 0, &aic31xx_dapm_spr_switch), SND_SOC_DAPM_OUTPUT("SPL"), SND_SOC_DAPM_OUTPUT("SPR"), }; /* AIC3100 and AIC3120 have only mono class-D amplifier */ static const struct snd_soc_dapm_widget aic310x_dapm_widgets[] = { SND_SOC_DAPM_OUT_DRV_E("SPK ClassD", AIC31XX_SPKAMP, 7, 0, NULL, 0, aic31xx_dapm_power_event, SND_SOC_DAPM_POST_PMU | SND_SOC_DAPM_POST_PMD), SND_SOC_DAPM_SWITCH("Speaker", SND_SOC_NOPM, 0, 0, &aic31xx_dapm_spl_switch), SND_SOC_DAPM_OUTPUT("SPK"), }; static const struct snd_soc_dapm_route aic31xx_audio_map[] = { /* DAC Input Routing */ {"DAC Left Input", "Left Data", "DAC IN"}, {"DAC Left Input", "Right Data", "DAC IN"}, {"DAC Left Input", "Mono", "DAC IN"}, {"DAC Right Input", "Left Data", "DAC IN"}, {"DAC Right Input", "Right Data", "DAC IN"}, {"DAC Right Input", "Mono", "DAC IN"}, {"DAC Left", NULL, "DAC Left Input"}, {"DAC Right", NULL, "DAC Right Input"}, /* Mic input */ {"MIC1LP P-Terminal", "FFR 10 Ohm", "MIC1LP"}, {"MIC1LP P-Terminal", "FFR 20 Ohm", "MIC1LP"}, {"MIC1LP P-Terminal", "FFR 40 Ohm", "MIC1LP"}, {"MIC1RP P-Terminal", "FFR 10 Ohm", "MIC1RP"}, {"MIC1RP P-Terminal", "FFR 20 Ohm", "MIC1RP"}, {"MIC1RP P-Terminal", "FFR 40 Ohm", "MIC1RP"}, {"MIC1LM P-Terminal", "FFR 10 Ohm", "MIC1LM"}, {"MIC1LM P-Terminal", "FFR 20 Ohm", "MIC1LM"}, {"MIC1LM P-Terminal", "FFR 40 Ohm", "MIC1LM"}, {"MIC1LM M-Terminal", "FFR 10 Ohm", "MIC1LM"}, {"MIC1LM M-Terminal", "FFR 20 Ohm", "MIC1LM"}, {"MIC1LM M-Terminal", "FFR 40 Ohm", "MIC1LM"}, {"MIC_GAIN_CTL", NULL, "MIC1LP P-Terminal"}, {"MIC_GAIN_CTL", NULL, "MIC1RP P-Terminal"}, {"MIC_GAIN_CTL", NULL, "MIC1LM P-Terminal"}, {"MIC_GAIN_CTL", NULL, "MIC1LM M-Terminal"}, {"ADC", NULL, "MIC_GAIN_CTL"}, /* Left Output */ {"Output Left", "From Left DAC", "DAC Left"}, {"Output Left", "From MIC1LP", "MIC1LP"}, {"Output Left", "From MIC1RP", "MIC1RP"}, /* Right Output */ {"Output Right", "From Right DAC", "DAC Right"}, {"Output Right", "From MIC1RP", "MIC1RP"}, /* HPL path */ {"HP Left", "Switch", "Output Left"}, {"HPL Driver", NULL, "HP Left"}, {"HPL", NULL, "HPL Driver"}, /* HPR path */ {"HP Right", "Switch", "Output Right"}, {"HPR Driver", NULL, "HP Right"}, {"HPR", NULL, "HPR Driver"}, }; static const struct snd_soc_dapm_route aic311x_audio_map[] = { /* SP L path */ {"Speaker Left", "Switch", "Output Left"}, {"SPL ClassD", NULL, "Speaker Left"}, {"SPL", NULL, "SPL ClassD"}, /* SP R path */ {"Speaker Right", "Switch", "Output Right"}, {"SPR ClassD", NULL, "Speaker Right"}, {"SPR", NULL, "SPR ClassD"}, }; static const struct snd_soc_dapm_route aic310x_audio_map[] = { /* SP L path */ {"Speaker", "Switch", "Output Left"}, {"SPK ClassD", NULL, "Speaker"}, {"SPK", NULL, "SPK ClassD"}, }; static int aic31xx_add_controls(struct snd_soc_codec *codec) { int ret = 0; struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); if (aic31xx->pdata.codec_type & AIC31XX_STEREO_CLASS_D_BIT) ret = snd_soc_add_codec_controls( codec, aic311x_snd_controls, ARRAY_SIZE(aic311x_snd_controls)); else ret = snd_soc_add_codec_controls( codec, aic310x_snd_controls, ARRAY_SIZE(aic310x_snd_controls)); return ret; } static int aic31xx_add_widgets(struct snd_soc_codec *codec) { struct snd_soc_dapm_context *dapm = &codec->dapm; struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int ret = 0; if (aic31xx->pdata.codec_type & AIC31XX_STEREO_CLASS_D_BIT) { ret = snd_soc_dapm_new_controls( dapm, aic311x_dapm_widgets, ARRAY_SIZE(aic311x_dapm_widgets)); if (ret) return ret; ret = snd_soc_dapm_add_routes(dapm, aic311x_audio_map, ARRAY_SIZE(aic311x_audio_map)); if (ret) return ret; } else { ret = snd_soc_dapm_new_controls( dapm, aic310x_dapm_widgets, ARRAY_SIZE(aic310x_dapm_widgets)); if (ret) return ret; ret = snd_soc_dapm_add_routes(dapm, aic310x_audio_map, ARRAY_SIZE(aic310x_audio_map)); if (ret) return ret; } return 0; } static int aic31xx_setup_pll(struct snd_soc_codec *codec, struct snd_pcm_hw_params *params) { struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int bclk_score = snd_soc_params_to_frame_size(params); int mclk_p = aic31xx->sysclk / aic31xx->p_div; int bclk_n = 0; int match = -1; int i; /* Use PLL as CODEC_CLKIN and DAC_CLK as BDIV_CLKIN */ snd_soc_update_bits(codec, AIC31XX_CLKMUX, AIC31XX_CODEC_CLKIN_MASK, AIC31XX_CODEC_CLKIN_PLL); snd_soc_update_bits(codec, AIC31XX_IFACE2, AIC31XX_BDIVCLK_MASK, AIC31XX_DAC2BCLK); for (i = 0; i < ARRAY_SIZE(aic31xx_divs); i++) { if (aic31xx_divs[i].rate == params_rate(params) && aic31xx_divs[i].mclk_p == mclk_p) { int s = (aic31xx_divs[i].dosr * aic31xx_divs[i].mdac) % snd_soc_params_to_frame_size(params); int bn = (aic31xx_divs[i].dosr * aic31xx_divs[i].mdac) / snd_soc_params_to_frame_size(params); if (s < bclk_score && bn > 0) { match = i; bclk_n = bn; bclk_score = s; } } } if (match == -1) { dev_err(codec->dev, "%s: Sample rate (%u) and format not supported\n", __func__, params_rate(params)); /* See bellow for details how fix this. */ return -EINVAL; } if (bclk_score != 0) { dev_warn(codec->dev, "Can not produce exact bitclock"); /* This is fine if using dsp format, but if using i2s there may be trouble. To fix the issue edit the aic31xx_divs table for your mclk and sample rate. Details can be found from: http://www.ti.com/lit/ds/symlink/tlv320aic3100.pdf Section: 5.6 CLOCK Generation and PLL */ } i = match; /* PLL configuration */ snd_soc_update_bits(codec, AIC31XX_PLLPR, AIC31XX_PLL_MASK, (aic31xx->p_div << 4) | 0x01); snd_soc_write(codec, AIC31XX_PLLJ, aic31xx_divs[i].pll_j); snd_soc_write(codec, AIC31XX_PLLDMSB, aic31xx_divs[i].pll_d >> 8); snd_soc_write(codec, AIC31XX_PLLDLSB, aic31xx_divs[i].pll_d & 0xff); /* DAC dividers configuration */ snd_soc_update_bits(codec, AIC31XX_NDAC, AIC31XX_PLL_MASK, aic31xx_divs[i].ndac); snd_soc_update_bits(codec, AIC31XX_MDAC, AIC31XX_PLL_MASK, aic31xx_divs[i].mdac); snd_soc_write(codec, AIC31XX_DOSRMSB, aic31xx_divs[i].dosr >> 8); snd_soc_write(codec, AIC31XX_DOSRLSB, aic31xx_divs[i].dosr & 0xff); #if 0 /* ADC dividers configuration. Write reset value 1 if not used. */ snd_soc_update_bits(codec, AIC31XX_NADC, AIC31XX_PLL_MASK, aic31xx_divs[i].nadc ? aic31xx_divs[i].nadc : 1); snd_soc_update_bits(codec, AIC31XX_MADC, AIC31XX_PLL_MASK, aic31xx_divs[i].madc ? aic31xx_divs[i].madc : 1); #endif snd_soc_write(codec, AIC31XX_AOSR, aic31xx_divs[i].aosr); /* Bit clock divider configuration. */ snd_soc_update_bits(codec, AIC31XX_BCLKN, AIC31XX_PLL_MASK, bclk_n); aic31xx->rate_div_line = i; dev_dbg(codec->dev, "pll %d.%04d/%d dosr %d n %d m %d aosr %d n %d m %d bclk_n %d\n", aic31xx_divs[i].pll_j, aic31xx_divs[i].pll_d, aic31xx->p_div, aic31xx_divs[i].dosr, aic31xx_divs[i].ndac, aic31xx_divs[i].mdac, aic31xx_divs[i].aosr, aic31xx_divs[i].nadc, aic31xx_divs[i].madc, bclk_n); #if 1 // Switch on PLL snd_soc_update_bits(codec, AIC31XX_PLLPR, 0x80, 0x80); snd_soc_update_bits(codec, AIC31XX_NDAC, 0x80, 0x80); snd_soc_update_bits(codec, AIC31XX_MDAC, 0x80, 0x80); snd_soc_update_bits(codec, AIC31XX_BCLKN , 0x80, 0x80); // snd_soc_update_bits(codec, AIC31XX_CLKOUTMVAL, 0x80, 0x80); // snd_soc_update_bits(codec, AIC31XX_GPIO1, 0x1f, 0x10); //DAC Data-Path Setup snd_soc_update_bits(codec, AIC31XX_DACSETUP, 0xFF, 0xD4); // Turn on Class-D speaker amplifier snd_soc_update_bits(codec, AIC31XX_SPKAMP, 0x80, 0x80); // Left-channel analog volume control output is routed to class-D output driver. snd_soc_update_bits(codec, AIC31XX_LANALOGSPL, 0xFF, 0x92); //Setup DAC_L and DAC_R Output Mixer Routing snd_soc_update_bits(codec, AIC31XX_DACMIXERROUTE, 0xFF, 0x40); //Setup Class-D speaker driver (SPK) snd_soc_update_bits(codec, AIC31XX_SPLGAIN, 0xFF, 0x1C); #endif return 0; } static int aic31xx_hw_params(struct snd_pcm_substream *substream, struct snd_pcm_hw_params *params, struct snd_soc_dai *dai) { struct snd_soc_codec *codec = dai->codec; u8 data = 0; dev_dbg(codec->dev, "## %s: width %d rate %d\n", __func__, params_width(params), params_rate(params)); switch (params_width(params)) { case 16: break; case 20: data = (AIC31XX_WORD_LEN_20BITS << AIC31XX_IFACE1_DATALEN_SHIFT); break; case 24: data = (AIC31XX_WORD_LEN_24BITS << AIC31XX_IFACE1_DATALEN_SHIFT); break; case 32: data = (AIC31XX_WORD_LEN_32BITS << AIC31XX_IFACE1_DATALEN_SHIFT); break; default: dev_err(codec->dev, "%s: Unsupported width %d\n", __func__, params_width(params)); return -EINVAL; } snd_soc_update_bits(codec, AIC31XX_IFACE1, AIC31XX_IFACE1_DATALEN_MASK, data); return aic31xx_setup_pll(codec, params); } static int aic31xx_dac_mute(struct snd_soc_dai *codec_dai, int mute) { struct snd_soc_codec *codec = codec_dai->codec; if (mute) { snd_soc_update_bits(codec, AIC31XX_DACMUTE, AIC31XX_DACMUTE_MASK, AIC31XX_DACMUTE_MASK); } else { snd_soc_update_bits(codec, AIC31XX_DACMUTE, AIC31XX_DACMUTE_MASK, 0x0); } return 0; } static int aic31xx_set_dai_fmt(struct snd_soc_dai *codec_dai, unsigned int fmt) { struct snd_soc_codec *codec = codec_dai->codec; u8 iface_reg1 = 0; u8 iface_reg2 = 0; u8 dsp_a_val = 0; dev_dbg(codec->dev, "## %s: fmt = 0x%x\n", __func__, fmt); /* set master/slave audio interface */ switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { case SND_SOC_DAIFMT_CBM_CFM: iface_reg1 |= AIC31XX_BCLK_MASTER | AIC31XX_WCLK_MASTER; break; default: dev_alert(codec->dev, "Invalid DAI master/slave interface\n"); return -EINVAL; } /* interface format */ switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) { case SND_SOC_DAIFMT_I2S: break; case SND_SOC_DAIFMT_DSP_A: dsp_a_val = 0x1; case SND_SOC_DAIFMT_DSP_B: /* NOTE: BCLKINV bit value 1 equas NB and 0 equals IB */ switch (fmt & SND_SOC_DAIFMT_INV_MASK) { case SND_SOC_DAIFMT_NB_NF: iface_reg2 |= AIC31XX_BCLKINV_MASK; break; case SND_SOC_DAIFMT_IB_NF: break; default: return -EINVAL; } iface_reg1 |= (AIC31XX_DSP_MODE << AIC31XX_IFACE1_DATATYPE_SHIFT); break; case SND_SOC_DAIFMT_RIGHT_J: iface_reg1 |= (AIC31XX_RIGHT_JUSTIFIED_MODE << AIC31XX_IFACE1_DATATYPE_SHIFT); break; case SND_SOC_DAIFMT_LEFT_J: iface_reg1 |= (AIC31XX_LEFT_JUSTIFIED_MODE << AIC31XX_IFACE1_DATATYPE_SHIFT); break; default: dev_err(codec->dev, "Invalid DAI interface format\n"); return -EINVAL; } snd_soc_update_bits(codec, AIC31XX_IFACE1, AIC31XX_IFACE1_DATATYPE_MASK | AIC31XX_IFACE1_MASTER_MASK, iface_reg1); snd_soc_update_bits(codec, AIC31XX_DATA_OFFSET, AIC31XX_DATA_OFFSET_MASK, dsp_a_val); snd_soc_update_bits(codec, AIC31XX_IFACE2, AIC31XX_BCLKINV_MASK, iface_reg2); return 0; } static int aic31xx_set_dai_sysclk(struct snd_soc_dai *codec_dai, int clk_id, unsigned int freq, int dir) { struct snd_soc_codec *codec = codec_dai->codec; struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int i; dev_dbg(codec->dev, "## %s: clk_id = %d, freq = %d, dir = %d\n", __func__, clk_id, freq, dir); for (i = 1; freq/i > 20000000 && i < 8; i++) ; if (freq/i > 20000000) { dev_err(aic31xx->dev, "%s: Too high mclk frequency %u\n", __func__, freq); return -EINVAL; } aic31xx->p_div = i; for (i = 0; i < ARRAY_SIZE(aic31xx_divs) && aic31xx_divs[i].mclk_p != freq/aic31xx->p_div; i++) ; if (i == ARRAY_SIZE(aic31xx_divs)) { dev_err(aic31xx->dev, "%s: Unsupported frequency %d\n", __func__, freq); return -EINVAL; } /* set clock on MCLK, BCLK, or GPIO1 as PLL input */ snd_soc_update_bits(codec, AIC31XX_CLKMUX, AIC31XX_PLL_CLKIN_MASK, clk_id << AIC31XX_PLL_CLKIN_SHIFT); aic31xx->sysclk = freq; return 0; } static int aic31xx_regulator_event(struct notifier_block *nb, unsigned long event, void *data) { struct aic31xx_disable_nb *disable_nb = container_of(nb, struct aic31xx_disable_nb, nb); struct aic31xx_priv *aic31xx = disable_nb->aic31xx; if (event & REGULATOR_EVENT_DISABLE) { /* * Put codec to reset and as at least one of the * supplies was disabled. */ if (gpio_is_valid(aic31xx->pdata.gpio_reset)) gpio_set_value(aic31xx->pdata.gpio_reset, 0); regcache_mark_dirty(aic31xx->regmap); dev_dbg(aic31xx->dev, "## %s: DISABLE received\n", __func__); } return 0; } static void aic31xx_clk_on(struct snd_soc_codec *codec) { struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); u8 mask = AIC31XX_PM_MASK; u8 on = AIC31XX_PM_MASK; dev_dbg(codec->dev, "codec clock -> on (rate %d)\n", aic31xx_divs[aic31xx->rate_div_line].rate); snd_soc_update_bits(codec, AIC31XX_PLLPR, mask, on); mdelay(10); snd_soc_update_bits(codec, AIC31XX_NDAC, mask, on); snd_soc_update_bits(codec, AIC31XX_MDAC, mask, on); #if 0 if (aic31xx_divs[aic31xx->rate_div_line].nadc) snd_soc_update_bits(codec, AIC31XX_NADC, mask, on); if (aic31xx_divs[aic31xx->rate_div_line].madc) snd_soc_update_bits(codec, AIC31XX_MADC, mask, on); #endif snd_soc_update_bits(codec, AIC31XX_BCLKN, mask, on); } static void aic31xx_clk_off(struct snd_soc_codec *codec) { u8 mask = AIC31XX_PM_MASK; u8 off = 0; dev_dbg(codec->dev, "codec clock -> off\n"); snd_soc_update_bits(codec, AIC31XX_BCLKN, mask, off); snd_soc_update_bits(codec, AIC31XX_MADC, mask, off); snd_soc_update_bits(codec, AIC31XX_NADC, mask, off); snd_soc_update_bits(codec, AIC31XX_MDAC, mask, off); snd_soc_update_bits(codec, AIC31XX_NDAC, mask, off); snd_soc_update_bits(codec, AIC31XX_PLLPR, mask, off); } static int aic31xx_power_on(struct snd_soc_codec *codec) { struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int ret = 0; ret = regulator_bulk_enable(ARRAY_SIZE(aic31xx->supplies), aic31xx->supplies); if (ret) return ret; if (gpio_is_valid(aic31xx->pdata.gpio_reset)) { gpio_set_value(aic31xx->pdata.gpio_reset, 1); udelay(100); } regcache_cache_only(aic31xx->regmap, false); ret = regcache_sync(aic31xx->regmap); if (ret != 0) { dev_err(codec->dev, "Failed to restore cache: %d\n", ret); regcache_cache_only(aic31xx->regmap, true); regulator_bulk_disable(ARRAY_SIZE(aic31xx->supplies), aic31xx->supplies); return ret; } return 0; } static int aic31xx_power_off(struct snd_soc_codec *codec) { struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int ret = 0; regcache_cache_only(aic31xx->regmap, true); ret = regulator_bulk_disable(ARRAY_SIZE(aic31xx->supplies), aic31xx->supplies); return ret; } static int aic31xx_set_bias_level(struct snd_soc_codec *codec, enum snd_soc_bias_level level) { dev_dbg(codec->dev, "## %s: %d -> %d\n", __func__, codec->dapm.bias_level, level); switch (level) { case SND_SOC_BIAS_ON: break; case SND_SOC_BIAS_PREPARE: if (codec->dapm.bias_level == SND_SOC_BIAS_STANDBY) aic31xx_clk_on(codec); break; case SND_SOC_BIAS_STANDBY: switch (codec->dapm.bias_level) { case SND_SOC_BIAS_OFF: aic31xx_power_on(codec); break; case SND_SOC_BIAS_PREPARE: aic31xx_clk_off(codec); break; default: BUG(); } break; case SND_SOC_BIAS_OFF: if (codec->dapm.bias_level == SND_SOC_BIAS_STANDBY) aic31xx_power_off(codec); break; } codec->dapm.bias_level = level; return 0; } static int aic31xx_codec_probe(struct snd_soc_codec *codec) { int ret = 0; struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int i; dev_dbg(aic31xx->dev, "## %s\n", __func__); aic31xx = snd_soc_codec_get_drvdata(codec); aic31xx->codec = codec; for (i = 0; i < ARRAY_SIZE(aic31xx->supplies); i++) { aic31xx->disable_nb[i].nb.notifier_call = aic31xx_regulator_event; aic31xx->disable_nb[i].aic31xx = aic31xx; ret = regulator_register_notifier(aic31xx->supplies[i].consumer, &aic31xx->disable_nb[i].nb); if (ret) { dev_err(codec->dev, "Failed to request regulator notifier: %d\n", ret); return ret; } } regcache_cache_only(aic31xx->regmap, true); regcache_mark_dirty(aic31xx->regmap); ret = aic31xx_add_controls(codec); if (ret) return ret; ret = aic31xx_add_widgets(codec); return ret; } static int aic31xx_codec_remove(struct snd_soc_codec *codec) { struct aic31xx_priv *aic31xx = snd_soc_codec_get_drvdata(codec); int i; for (i = 0; i < ARRAY_SIZE(aic31xx->supplies); i++) regulator_unregister_notifier(aic31xx->supplies[i].consumer, &aic31xx->disable_nb[i].nb); return 0; } static struct snd_soc_codec_driver soc_codec_driver_aic31xx = { .probe = aic31xx_codec_probe, .remove = aic31xx_codec_remove, .set_bias_level = aic31xx_set_bias_level, .suspend_bias_off = true, .controls = aic31xx_snd_controls, .num_controls = ARRAY_SIZE(aic31xx_snd_controls), .dapm_widgets = aic31xx_dapm_widgets, .num_dapm_widgets = ARRAY_SIZE(aic31xx_dapm_widgets), .dapm_routes = aic31xx_audio_map, .num_dapm_routes = ARRAY_SIZE(aic31xx_audio_map), }; static struct snd_soc_dai_ops aic31xx_dai_ops = { .hw_params = aic31xx_hw_params, .set_sysclk = aic31xx_set_dai_sysclk, .set_fmt = aic31xx_set_dai_fmt, .digital_mute = aic31xx_dac_mute, }; static struct snd_soc_dai_driver aic31xx_dai_driver[] = { { .name = "tlv320aic31xx-hifi", .playback = { .stream_name = "Playback", .channels_min = 1, .channels_max = 2, .rates = AIC31XX_RATES, .formats = AIC31XX_FORMATS, }, .capture = { .stream_name = "Capture", .channels_min = 1, .channels_max = 2, .rates = AIC31XX_RATES, .formats = AIC31XX_FORMATS, }, .ops = &aic31xx_dai_ops, .symmetric_rates = 1, } }; #if defined(CONFIG_OF) static const struct of_device_id tlv320aic31xx_of_match[] = { { .compatible = "ti,tlv320aic310x" }, { .compatible = "ti,tlv320aic311x" }, { .compatible = "ti,tlv320aic3100" }, { .compatible = "ti,tlv320aic3110" }, { .compatible = "ti,tlv320aic3120" }, { .compatible = "ti,tlv320aic3111" }, {}, }; MODULE_DEVICE_TABLE(of, tlv320aic31xx_of_match); static void aic31xx_pdata_from_of(struct aic31xx_priv *aic31xx) { struct device_node *np = aic31xx->dev->of_node; unsigned int value = MICBIAS_2_0V; int ret; of_property_read_u32(np, "ai31xx-micbias-vg", &value); switch (value) { case MICBIAS_2_0V: case MICBIAS_2_5V: case MICBIAS_AVDDV: aic31xx->pdata.micbias_vg = value; break; default: dev_err(aic31xx->dev, "Bad ai31xx-micbias-vg value %d DT\n", value); aic31xx->pdata.micbias_vg = MICBIAS_2_0V; } ret = of_get_named_gpio(np, "gpio-reset", 0); if (ret > 0) aic31xx->pdata.gpio_reset = ret; } #else /* CONFIG_OF */ static void aic31xx_pdata_from_of(struct aic31xx_priv *aic31xx) { } #endif /* CONFIG_OF */ static int aic31xx_device_init(struct aic31xx_priv *aic31xx) { int ret, i; dev_set_drvdata(aic31xx->dev, aic31xx); if (dev_get_platdata(aic31xx->dev)) memcpy(&aic31xx->pdata, dev_get_platdata(aic31xx->dev), sizeof(aic31xx->pdata)); else if (aic31xx->dev->of_node) aic31xx_pdata_from_of(aic31xx); if (aic31xx->pdata.gpio_reset) { ret = devm_gpio_request_one(aic31xx->dev, aic31xx->pdata.gpio_reset, GPIOF_OUT_INIT_HIGH, "aic31xx-reset-pin"); if (ret < 0) { dev_err(aic31xx->dev, "not able to acquire gpio\n"); return ret; } } for (i = 0; i < ARRAY_SIZE(aic31xx->supplies); i++) aic31xx->supplies[i].supply = aic31xx_supply_names[i]; ret = devm_regulator_bulk_get(aic31xx->dev, ARRAY_SIZE(aic31xx->supplies), aic31xx->supplies); if (ret != 0) dev_err(aic31xx->dev, "Failed to request supplies: %d\n", ret); return ret; } static int aic31xx_i2c_probe(struct i2c_client *i2c, const struct i2c_device_id *id) { struct aic31xx_priv *aic31xx; int ret; const struct regmap_config *regmap_config; dev_dbg(&i2c->dev, "## %s: %s codec_type = %d\n", __func__, id->name, (int) id->driver_data); regmap_config = &aic31xx_i2c_regmap; aic31xx = devm_kzalloc(&i2c->dev, sizeof(*aic31xx), GFP_KERNEL); if (aic31xx == NULL) return -ENOMEM; aic31xx->regmap = devm_regmap_init_i2c(i2c, regmap_config); if (IS_ERR(aic31xx->regmap)) { ret = PTR_ERR(aic31xx->regmap); dev_err(&i2c->dev, "Failed to allocate register map: %d\n", ret); return ret; } aic31xx->dev = &i2c->dev; aic31xx->pdata.codec_type = id->driver_data; ret = aic31xx_device_init(aic31xx); if (ret) return ret; return snd_soc_register_codec(&i2c->dev, &soc_codec_driver_aic31xx, aic31xx_dai_driver, ARRAY_SIZE(aic31xx_dai_driver)); } static int aic31xx_i2c_remove(struct i2c_client *i2c) { snd_soc_unregister_codec(&i2c->dev); return 0; } static const struct i2c_device_id aic31xx_i2c_id[] = { { "tlv320aic310x", AIC3100 }, { "tlv320aic311x", AIC3110 }, { "tlv320aic3100", AIC3100 }, { "tlv320aic3110", AIC3110 }, { "tlv320aic3120", AIC3120 }, { "tlv320aic3111", AIC3111 }, { } }; MODULE_DEVICE_TABLE(i2c, aic31xx_i2c_id); static struct i2c_driver aic31xx_i2c_driver = { .driver = { .name = "tlv320aic31xx-codec", .owner = THIS_MODULE, .of_match_table = of_match_ptr(tlv320aic31xx_of_match), }, .probe = aic31xx_i2c_probe, .remove = aic31xx_i2c_remove, .id_table = aic31xx_i2c_id, }; module_i2c_driver(aic31xx_i2c_driver); MODULE_DESCRIPTION("ASoC TLV320AIC3111 codec driver"); MODULE_AUTHOR("Jyri Sarha"); MODULE_LICENSE("GPL");
