Hi Team,
We are using a custom board based on AM437x-sk design & using processor-sdk-02.00.02.11
We integrated 320*240 display to the custom board & got the following errors continuously.
[drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040
The above source of error is from drivers/gpu/drm/omapdrm/omap_plane.c file where
error_irq handler registration done in omap_plane_init module.
I want to know whether the error is due to any noise disturbance in SOC or
due to wrong interfacing in the software?
I have attached dts file and complete bootlog for your reference.
Thanks & Regards.
Arun Nehru A.V.
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.1.18-gbbe8cfc (root@arun) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #58 PREEMPT Sat Aug 27 10:34:48 IST 2016 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: TI AM437x SK EVM [ 0.000000] cma: Reserved 24 MiB at 0xbe800000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat c0924598, node_mem_map eeef9000 [ 0.000000] Normal zone: 1710 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 194560 pages, LIFO batch:31 [ 0.000000] HighMem zone: 67584 pages, LIFO batch:15 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (sgx neon ) [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260434 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00000000-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1004128K/1048576K available (6391K kernel code, 257K rwdata, 2408K rodata, 276K init, 235K bss, 19872K reserved, 24576K cma-reserved, 245760K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc08a005c (8801 kB) [ 0.000000] .init : 0xc08a1000 - 0xc08e6000 ( 276 kB) [ 0.000000] .data : 0xc08e6000 - 0xc09265c0 ( 258 kB) [ 0.000000] .bss : 0xc0929000 - 0xc0963d48 ( 236 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x7e430000 [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000062] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000109] clocksource timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000132] OMAP clocksource: timer1 at 24000000 Hz [ 0.002555] Console: colour dummy device 80x30 [ 0.002691] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.002702] This ensures that you still see kernel messages. Please [ 0.002707] update your kernel commandline. [ 0.002793] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664) [ 0.110605] pid_max: default: 32768 minimum: 301 [ 0.111096] Security Framework initialized [ 0.111289] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.111314] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.114726] Initializing cgroup subsys blkio [ 0.114859] Initializing cgroup subsys memory [ 0.115138] Initializing cgroup subsys devices [ 0.115188] Initializing cgroup subsys freezer [ 0.115245] Initializing cgroup subsys perf_event [ 0.115369] CPU: Testing write buffer coherency: ok [ 0.117740] Setting up static identity map for 0x80008200 - 0x80008270 [ 0.126306] devtmpfs: initialized [ 0.150427] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.236293] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.247133] pinctrl core: initialized pinctrl subsystem [ 0.253411] NET: Registered protocol family 16 [ 0.257550] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.290683] cpuidle: using governor ladder [ 0.320609] cpuidle: using governor menu [ 0.336416] gpiochip_add: registered GPIOs 0 to 31 on device: gpio [ 0.337192] OMAP GPIO hardware version 0.1 [ 0.340970] gpiochip_add: registered GPIOs 32 to 63 on device: gpio [ 0.343314] gpiochip_add: registered GPIOs 64 to 95 on device: gpio [ 0.345286] gpiochip_add: registered GPIOs 96 to 127 on device: gpio [ 0.367359] No ATAGs? [ 0.367544] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.367580] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.424736] edma 49000000.edma: TI EDMA DMA engine driver [ 0.427744] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0) [ 0.436752] vgaarb: loaded [ 0.438752] SCSI subsystem initialized [ 0.441529] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins, deferring probe [ 0.441739] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c1_pins, deferring probe [ 0.442144] media: Linux media interface: v0.10 [ 0.442322] Linux video capture interface: v2.00 [ 0.442456] pps_core: LinuxPPS API ver. 1 registered [ 0.442466] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.442525] PTP clock support registered [ 0.445314] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.446926] Advanced Linux Sound Architecture Driver Initialized. [ 0.449695] Switched to clocksource timer1 [ 0.475917] NET: Registered protocol family 2 [ 0.479112] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.479363] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.479570] TCP: Hash tables configured (established 8192 bind 8192) [ 0.480680] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.480756] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.481698] NET: Registered protocol family 1 [ 0.483800] RPC: Registered named UNIX socket transport module. [ 0.483845] RPC: Registered udp transport module. [ 0.483852] RPC: Registered tcp transport module. [ 0.483860] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.483996] PCI: CLS 0 bytes, default 64 [ 0.492955] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.493446] audit: initializing netlink subsys (disabled) [ 0.493825] audit: type=2000 audit(0.480:1): initialized [ 0.508541] VFS: Disk quotas dquot_6.6.0 [ 0.509350] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.515586] NFS: Registering the id_resolver key type [ 0.515936] Key type id_resolver registered [ 0.515950] Key type id_legacy registered [ 0.516189] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 0.523177] NET: Registered protocol family 38 [ 0.523520] bounce: pool size: 64 pages [ 0.523578] io scheduler noop registered [ 0.523595] io scheduler deadline registered [ 0.523877] io scheduler cfq registered (default) [ 0.532880] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796 [ 0.542360] pwm-backlight backlight: GPIO lookup for consumer enable [ 0.542443] pwm-backlight backlight: using device tree for GPIO lookup [ 0.542480] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]' [ 0.542496] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]' [ 0.542505] pwm-backlight backlight: using lookup tables for GPIO lookup [ 0.542525] pwm-backlight backlight: lookup for GPIO enable failed [ 0.542603] backlight supply power not found, using dummy regulator [ 0.548349] 4832a000.dss supply vdda_video not found, using dummy regulator [ 0.549091] OMAP DSS rev 2.0 [ 0.551572] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops) [ 0.555385] panel-dpi display: GPIO lookup for consumer enable [ 0.555437] panel-dpi display: using device tree for GPIO lookup [ 0.555475] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display[0]' [ 0.555491] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display[0]' [ 0.555499] panel-dpi display: using lookup tables for GPIO lookup [ 0.555519] panel-dpi display: lookup for GPIO enable failed [ 0.555603] *************** Analogics: Inside panel_dpi_probe_of *************** [ 0.558255] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 0.562957] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.571674] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 0.571767] omap8250 44e09000.serial: GPIO lookup for consumer enable [ 0.571786] omap8250 44e09000.serial: using device tree for GPIO lookup [ 0.571821] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp/serial@44e09000[0]' [ 0.571831] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp/serial@44e09000[0]' [ 0.571841] omap8250 44e09000.serial: using lookup tables for GPIO lookup [ 0.571856] omap8250 44e09000.serial: lookup for GPIO enable failed [ 0.573990] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250 [ 1.283529] console [ttyS0] enabled [ 1.289337] omap8250 48022000.serial: No clock speed specified: using default: 48000000 [ 1.297757] omap8250 48022000.serial: GPIO lookup for consumer enable [ 1.297770] omap8250 48022000.serial: using device tree for GPIO lookup [ 1.297800] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp/serial@48022000[0]' [ 1.297809] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp/serial@48022000[0]' [ 1.297819] omap8250 48022000.serial: using lookup tables for GPIO lookup [ 1.297831] omap8250 48022000.serial: lookup for GPIO enable failed [ 1.299528] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250 [ 1.312789] [drm] Initialized drm 1.1.0 20060810 [ 1.358677] brd: module loaded [ 1.381172] loop: module loaded [ 1.395039] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.470000] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [ 1.476264] davinci_mdio 4a101000.mdio: detected phy mask fffffffe [ 1.486559] libphy: 4a101000.mdio: probed [ 1.491259] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720 [ 1.504076] cpsw 4a100000.ethernet: Random MACID = ae:3a:83:c6:6a:e6 [ 1.519232] mousedev: PS/2 mouse device common for all mice [ 1.528053] input: ti-tsc as /devices/platform/44000000.ocp/44e0d000.tscadc/TI-am335x-tsc/input/input0 [ 1.539434] i2c /dev entries driver [ 1.548500] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.548557] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.548878] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) [ 1.549365] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.554479] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 1.554499] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.554523] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' [ 1.554536] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' [ 1.554546] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 1.554564] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed [ 1.581914] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd [ 1.581981] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup [ 1.582015] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@47810000[0]' [ 1.582031] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@47810000[0]' [ 1.582041] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup [ 1.582058] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed [ 1.582078] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp [ 1.582085] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup [ 1.582091] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@47810000[0]' [ 1.582098] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@47810000[0]' [ 1.582107] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup [ 1.582113] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed [ 1.583157] /ocp/mmc@47810000: could not get #dma-cells for /ocp/l4_wkup@44c00000/prcm@1f0000/clocks/mux_synctimer32k_ck [ 1.594873] omap_hsmmc 47810000.mmc: unable to obtain RX DMA engine channel 0 [ 1.631432] ledtrig-cpu: registered to indicate activity on CPUs [ 1.641457] remoteproc0: wkup_m3 is available [ 1.646083] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 1.655471] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 1.684195] oprofile: no performance counters [ 1.689220] oprofile: using timer interrupt. [ 1.695427] Initializing XFRM netlink socket [ 1.700515] NET: Registered protocol family 17 [ 1.705319] NET: Registered protocol family 15 [ 1.710568] Key type dns_resolver registered [ 1.715944] omap_voltage_late_init: Voltage driver support not added [ 1.724869] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517 [ 1.733986] cpu cpu0: cpu0 clock notifier not ready, retry [ 1.741259] ThumbEE CPU extension supported. [ 1.745740] Registering SWP/SWPB emulation handler [ 1.765298] omapdrm omapdrm.0: DMM not available, disable DMM support [ 1.776223] ********* Analogics ******* gfx [ 1.776223] : type=1********** [ 1.785180] ********* Analogics ******* vid1 [ 1.785180] : type=0********** [ 1.793184] ********* Analogics ******* vid2 [ 1.793184] : type=0********** [ 1.800961] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.807668] [drm] No driver support for vblank timestamp query. [ 1.861263] Console: switching to colour frame buffer device 40x30 [ 1.883289] omapdrm omapdrm.0: fb0: omapdrm frame buffer device [ 1.889282] omapdrm omapdrm.0: registered panic notifier [ 1.919782] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0 [ 1.988565] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz [ 2.002986] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz [ 2.016027] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 2.016101] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 2.016417] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) [ 2.016821] omap_hsmmc 48060000.mmc: Got CD GPIO [ 2.022141] remoteproc0: powering up wkup_m3 [ 2.026807] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 219803 [ 2.034304] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 2.034324] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 2.034354] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' [ 2.034366] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' [ 2.034372] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 2.034395] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed [ 2.038693] remoteproc0: remote processor wkup_m3 is now up [ 2.038754] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x191 [ 2.074011] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22 [ 2.091034] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22 [ 2.106842] hctosys: unable to open rtc device (rtc0) [ 2.137341] vmmcwl_fixed: disabling [ 2.142517] ALSA device list: [ 2.145651] No soundcards found. [ 2.153908] Waiting for root device PARTUUID=00000000-02... [ 2.180024] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.191864] mmc0: new high speed SDHC card at address aaaa [ 2.201264] mmcblk0: mmc0:aaaa SS08G 7.40 GiB [ 2.210978] mmcblk0: p1 p2 p3 [ 2.297014] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.306334] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 2.320767] devtmpfs: mounted [ 2.327449] Freeing unused kernel memory: 276K (c08a1000 - c08e6000) [ 2.662247] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered [ 2.715022] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 2.721991] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 3.277143] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 3.284250] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 3.290746] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 4.362412] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 4.369110] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 4.375750] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 4.665892] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 4.672948] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 6.859605] random: nonblocking pool is initialized [ 8.027600] omap_plane_error_irq: 5279 callbacks suppressed [ 8.033594] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 8.040494] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 8.367770] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 8.374840] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 8.381362] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 8.459263] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 8.466300] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 9.072379] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 9.079075] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 9.104204] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 11.198697] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 11.866705] EXT3-fs (mmcblk0p3): error: couldn't mount because of unsupported optional features (240) [ 11.884000] EXT2-fs (mmcblk0p3): error: couldn't mount because of unsupported optional features (240) [ 11.917113] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) >[ 13.544886] udev[347]: starting version 167 [ 13.552241] omap_plane_error_irq: 7785 callbacks suppressed [ 13.558088] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 13.564821] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 13.597739] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 13.604889] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 14.219331] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 14.226425] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 14.250075] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 14.257228] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 14.266295] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 14.273098] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 16.927375] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 17.116069] ov2659 1-0030: GPIO lookup for consumer pwrdn [ 17.116169] ov2659 1-0030: using device tree for GPIO lookup [ 17.116208] of_get_named_gpiod_flags: can't parse 'pwrdn-gpios' property of node '/ocp/i2c@4802a000/ov2659@30[0]' [ 17.116230] of_get_named_gpiod_flags: can't parse 'pwrdn-gpio' property of node '/ocp/i2c@4802a000/ov2659@30[0]' [ 17.116240] ov2659 1-0030: using lookup tables for GPIO lookup [ 17.116256] ov2659 1-0030: lookup for GPIO pwrdn failed [ 17.152560] omap_rtc 44e3e000.rtc: already running [ 17.326755] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ 18.120565] omap_i2c 4802a000.i2c: timeout waiting for bus ready [ 18.126988] ov2659 1-0030: Sensor soft reset failed [ 18.295507] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp/i2c@4802a000/tlv320aic3106@1b[0]' [ 18.317021] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 19.350364] omap_i2c 4802a000.i2c: timeout waiting for bus ready [ 19.356774] lis3lv02d: unknown sensor type 0x92 [ 19.471237] lis3lv02d_i2c: probe of 1-0018 failed with error -22 [ 19.507684] omap_plane_error_irq: 13527 callbacks suppressed [ 19.513677] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 19.520609] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.119688] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.126875] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.659953] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.667088] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.702395] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.709088] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.715767] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.874804] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 20.905802] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1 [ 21.317183] omap-des 53701000.des: OMAP DES hw accel rev: 0.33 [ 21.619476] omap-sham 53100000.sham: hw accel on OMAP rev 0.0 [ 21.668938] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@0[0]' - status (0) [ 21.953820] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@1[0]' - status (0) [ 21.955067] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@2[0]' - status (0) [ 21.955737] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@3[0]' - status (0) [ 22.346399] PM: bootloader does not support rtc-only! [ 22.734101] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [ 22.734195] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [ 22.926260] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 23.038452] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1 [ 25.094441] omap_plane_error_irq: 9505 callbacks suppressed [ 25.100395] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 25.107156] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 25.848724] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 25.855892] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 25.951948] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 25.958748] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 25.966210] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 26.003950] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 26.011017] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 26.017451] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 30.131496] omap_plane_error_irq: 6992 callbacks suppressed [ 30.137474] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 30.144198] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 30.169713] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 30.176845] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 30.183964] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 31.342581] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 31.349400] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 31.356006] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 31.375025] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 31.381985] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 33.696457] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 0, 0 [ 35.396866] omap_plane_error_irq: 4614 callbacks suppressed [ 35.402854] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.409820] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.423621] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.430416] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.452205] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.458883] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.546236] usbcore: registered new interface driver usbfs [ 35.567126] usbcore: registered new interface driver hub [ 35.584736] usbcore: registered new device driver usb [ 35.629891] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.637066] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.649396] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.656368] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 35.746687] dwc3 48390000.usb: otg: primary host xhci-hcd.0.auto registered [ 35.754705] dwc3 48390000.usb: otg: shared host xhci-hcd.0.auto registered [ 35.761884] dwc3 48390000.usb: otg: can't start till gadget registers [ 35.769215] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 35.775105] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 35.790645] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x00210010 [ 35.800127] xhci-hcd xhci-hcd.1.auto: irq 229, io mem 0x483d0000 [ 35.807071] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 35.814592] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 35.822254] usb usb1: Product: xHCI Host Controller [ 35.827201] usb usb1: Manufacturer: Linux 4.1.18-gbbe8cfc xhci-hcd [ 35.833505] usb usb1: SerialNumber: xhci-hcd.1.auto [ 35.854651] hub 1-0:1.0: USB hub found [ 35.859032] hub 1-0:1.0: 1 port detected [ 35.865876] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 35.871951] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 35.880143] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 35.888660] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 35.900182] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 35.907616] usb usb2: Product: xHCI Host Controller [ 35.912709] usb usb2: Manufacturer: Linux 4.1.18-gbbe8cfc xhci-hcd [ 35.918950] usb usb2: SerialNumber: xhci-hcd.1.auto [ 35.936142] hub 2-0:1.0: USB hub found [ 35.941010] hub 2-0:1.0: 1 port detected [ 36.469415] udc 48390000.usb: registering UDC driver [g_ether] [ 36.543233] using random self ethernet address [ 36.547989] using random host ethernet address [ 36.574985] usb0: HOST MAC 5a:31:a5:5c:80:4f [ 36.589674] usb0: MAC 8e:b7:59:83:ca:66 [ 36.595068] using random self ethernet address [ 36.599865] using random host ethernet address [ 36.604532] g_ether gadget: adding config #2 'RNDIS'/bf24a910 [ 36.604589] rndis_register: configNr = 0 [ 36.604607] g_ether gadget: adding 'rndis'/ee09c600 to config 'RNDIS'/bf24a910 [ 36.604809] rndis_set_param_medium: 0 0 [ 36.604825] g_ether gadget: RNDIS: dual speed IN/ep1in OUT/ep1out NOTIFY/ep2in [ 36.604841] g_ether gadget: cfg 2/bf24a910 speeds: high full [ 36.604850] g_ether gadget: interface 0 = rndis/ee09c600 [ 36.604856] g_ether gadget: interface 1 = rndis/ee09c600 [ 36.604892] g_ether gadget: adding config #1 'CDC Ethernet (ECM)'/bf24a864 [ 36.604948] g_ether gadget: adding 'cdc_ethernet'/ee09c540 to config 'CDC Ethernet (ECM)'/bf24a864 [ 36.605000] g_ether gadget: CDC Ethernet: dual speed IN/ep1in OUT/ep1out NOTIFY/ep2in [ 36.605015] g_ether gadget: cfg 1/bf24a864 speeds: high full [ 36.605021] g_ether gadget: interface 0 = cdc_ethernet/ee09c540 [ 36.605027] g_ether gadget: interface 1 = cdc_ethernet/ee09c540 [ 36.605062] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 36.612116] g_ether gadget: g_ether ready [ 36.616269] dwc3 48390000.usb: otg: gadget gadget registered [ 36.700392] usb0: eth_open [ 36.729423] usb0: stop stats: rx/tx 0/0, errs 0/0 [ 36.789139] usb0: eth_open [ 40.736563] omap_plane_error_irq: 3327 callbacks suppressed [ 40.742540] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 40.749373] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 40.818803] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 40.825893] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.145754] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.152842] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.168743] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.175737] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.182565] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.190185] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 41.294077] NET: Registered protocol family 10 [ 41.305860] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ 44.324314] usb0: stop stats: rx/tx 0/0, errs 0/0 [ 44.455127] usb0: eth_open [ 44.456333] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ 46.615794] omap_plane_error_irq: 5431 callbacks suppressed [ 46.621690] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 46.628516] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 46.780760] net eth0: initializing cpsw version 1.15 (0) [ 46.788419] net eth0: phy found : id is : 0x7c0f1 [ 46.801407] libphy: PHY 4a101000.mdio:01 not found [ 46.806446] net eth0: phy 4a101000.mdio:01 not found on slave 1 [ 46.855200] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 110.679867] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 110.687002] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 110.693521] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 111.024047] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 111.031063] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 114.039135] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 114.046216] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 114.052733] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 114.059581] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040 [ 114.066121] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040
/* * Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /* AM437x SK EVM */ /dts-v1/; #include "am4372.dtsi" #include <dt-bindings/pinctrl/am43xx.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/irq.h> / { model = "TI AM437x SK EVM"; compatible = "ti,am437x-sk-evm","ti,am4372","ti,am43"; aliases { display0 = &lcd0; }; backlight { compatible = "pwm-backlight"; /* default values commented by arun analogics */ /* pwms = <&ecap0 0 50000 PWM_POLARITY_INVERTED>; */ pwms = <&ecap0 0 50000 0>; brightness-levels = <0 51 53 56 62 75 101 152 255>; default-brightness-level = <8>; }; sound { compatible = "simple-audio-card"; simple-audio-card,name = "AM437x-SK-EVM"; simple-audio-card,widgets = "Headphone", "Headphone Jack"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound_master>; simple-audio-card,frame-master = <&sound_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp1>; }; sound_master: simple-audio-card,codec { sound-dai = <&tlv320aic3106>; system-clock-frequency = <24000000>; }; }; /*default keypad commented by arun analogics */ /* matrix_keypad: matrix_keypad@0 { compatible = "gpio-matrix-keypad"; pinctrl-names = "default"; /* pinctrl-0 = <&matrix_keypad_pins>; debounce-delay-ms = <5>; col-scan-delay-us = <5>; row-gpios = <&gpio5 5 GPIO_ACTIVE_HIGH /* Bank5, pin5 &gpio5 6 GPIO_ACTIVE_HIGH>; /* Bank5, pin6 col-gpios = <&gpio5 13 GPIO_ACTIVE_HIGH /* Bank5, pin13 &gpio5 4 GPIO_ACTIVE_HIGH>; /* Bank5, pin4 linux,keymap = < MATRIX_KEY(0, 0, KEY_DOWN) MATRIX_KEY(0, 1, KEY_RIGHT) MATRIX_KEY(1, 0, KEY_LEFT) MATRIX_KEY(1, 1, KEY_UP) >; }; */ leds { compatible = "gpio-leds"; pinctrl-names = "default"; /* pinctrl-0 = <&leds_pins>; */ led@0 { label = "am437x-sk:red:heartbeat"; gpios = <&gpio5 0 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 0 */ linux,default-trigger = "heartbeat"; default-state = "off"; }; led@1 { label = "am437x-sk:green:mmc1"; gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 1 */ linux,default-trigger = "mmc0"; default-state = "off"; }; led@2 { label = "am437x-sk:blue:cpu0"; gpios = <&gpio5 2 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 2 */ linux,default-trigger = "cpu0"; default-state = "off"; }; led@3 { label = "am437x-sk:blue:usr3"; gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 3 */ default-state = "off"; }; }; /*Defualt display values commented by analogics */ /* lcd0: display { compatible = "newhaven,nhd-4.3-480272ef-atxl", "panel-dpi"; label = "lcd"; pinctrl-names = "default"; pinctrl-0 = <&lcd_pins>; enable-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; panel-timing { clock-frequency = <9000000>; hactive = <480>; vactive = <272>; hfront-porch = <2>; hback-porch = <2>; hsync-len = <41>; vfront-porch = <2>; vback-porch = <2>; vsync-len = <10>; hsync-active = <0>; vsync-active = <0>; de-active = <1>; pixelclk-active = <1>; }; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; */ /* new display values added by arun analogics */ lcd0: display { compatible = "Analogics,SKAT035GT-09-TP", "panel-dpi"; label = "lcd"; /* pinctrl-names = "default"; pinctrl-0 = <&lcd_pins>; enable-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;*/ panel-timing { clock-frequency = <6500000>; hactive = <320>; vactive = <240>; hfront-porch = <18>; hback-porch = <65>; hsync-len = <1>; vfront-porch = <4>; vback-porch = <15>; vsync-len = <2>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <1>; }; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; vmmcwl_fixed: fixedregulator-mmcwl { compatible = "regulator-fixed"; regulator-name = "vmmcwl_fixed"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; gpio = <&gpio4 8 GPIO_ACTIVE_HIGH>; enable-active-high; }; }; &am43xx_pinmux { /* matrix pinmux commented by arun analogics */ /* matrix_keypad_pins: matrix_keypad_pins { pinctrl-single,pins = < 0x24c (PIN_OUTPUT | MUX_MODE7) // gpio5_13.gpio5_13 0x250 (PIN_OUTPUT | MUX_MODE7) // spi4_sclk.gpio5_4 0x254 (PIN_INPUT | MUX_MODE7) // spi4_d0.gpio5_5 0x258 (PIN_INPUT | MUX_MODE7) // spi4_d1.gpio5_5 >; }; */ /* leds_pins: leds_pins { pinctrl-single,pins = < 0x228 (PIN_OUTPUT | MUX_MODE7) // uart3_rxd.gpio5_2 0x22c (PIN_OUTPUT | MUX_MODE7) // uart3_txd.gpio5_3 0x230 (PIN_OUTPUT | MUX_MODE7) // uart3_ctsn.gpio5_0 0x234 (PIN_OUTPUT | MUX_MODE7) // uart3_rtsn.gpio5_1 >; }; */ i2c0_pins: i2c0_pins { pinctrl-single,pins = < 0x188 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */ 0x18c (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */ >; }; /* i2c1_pins: i2c1_pins { pinctrl-single,pins = < 0x15c (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) // spi0_cs0.i2c1_scl 0x158 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) // spi0_d1.i2c1_sda >; }; */ /* i2c1 pinmux added by analogics */ i2c1_pins: i2c1_pins { pinctrl-single,pins = < 0x16c (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) /* spi0_cs0.i2c1_scl */ 0x168 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) /* spi0_d1.i2c1_sda */ >; }; /* mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < 0x0f0 (PIN_INPUT | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 0x0f4 (PIN_INPUT | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 0x0f8 (PIN_INPUT | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 0x0fc (PIN_INPUT | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 0x100 (PIN_INPUT | MUX_MODE0) /* mmc0_clk.mmc0_clk 0x104 (PIN_INPUT | MUX_MODE0) /* mmc0_cmd.mmc0_cmd 0x160 (PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 >; }; */ /* MMC1 pinmux added by analogics*/ mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < 0x80 ( PIN_INPUT | MUX_MODE2 ) /* (B9) gpmc_csn1.mmc1_clk */ 0x84 ( PIN_OUTPUT | MUX_MODE2 ) /* (F10) gpmc_csn2.mmc1_cmd */ 0x20 ( PIN_INPUT | MUX_MODE2 ) /* (B10) gpmc_ad8.mmc1_dat0 */ 0x24 ( PIN_INPUT | MUX_MODE2 ) /* (A10) gpmc_ad9.mmc1_dat1 */ 0x28 ( PIN_INPUT | MUX_MODE2 ) /* (F11) gpmc_ad10.mmc1_dat2 */ 0x2c ( PIN_INPUT | MUX_MODE2 ) /* (D11) gpmc_ad11.mmc1_dat3 */ 0x30 ( PIN_INPUT | MUX_MODE2 ) /* (E11) gpmc_ad12.mmc1_dat4 */ 0x34 ( PIN_INPUT | MUX_MODE2 ) /* (C11) gpmc_ad13.mmc1_dat5 */ 0x38 ( PIN_INPUT | MUX_MODE2 ) /* (B11) gpmc_ad14.mmc1_dat6 */ 0x3c ( PIN_INPUT | MUX_MODE2 ) /* (A11) gpmc_ad15.mmc1_dat7 */ >; }; ecap0_pins: backlight_pins { pinctrl-single,pins = < 0x164 (PIN_OUTPUT | MUX_MODE0) /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out */ >; }; /* default pinmux commented by analogics */ /* edt_ft5306_ts_pins: edt_ft5306_ts_pins { pinctrl-single,pins = < 0x74 (PIN_INPUT | MUX_MODE7) // gpmc_wpn.gpio0_31 0x78 (PIN_OUTPUT | MUX_MODE7) // gpmc_be1n.gpio1_28 >; }; */ vpfe0_pins_default: vpfe0_pins_default { pinctrl-single,pins = < 0x1b0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_hd mode 0*/ 0x1b4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_vd mode 0*/ 0x1b8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_field mode 0*/ 0x1bc (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_wen mode 0*/ 0x1c0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_pclk mode 0*/ 0x1c4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data8 mode 0*/ 0x1c8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data9 mode 0*/ 0x208 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data0 mode 0*/ 0x20c (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data1 mode 0*/ 0x210 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data2 mode 0*/ 0x214 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data3 mode 0*/ 0x218 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data4 mode 0*/ 0x21c (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data5 mode 0*/ 0x220 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data6 mode 0*/ 0x224 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data7 mode 0*/ >; }; vpfe0_pins_sleep: vpfe0_pins_sleep { pinctrl-single,pins = < 0x1b0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1b4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1b8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1bc (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1c0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1c4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1c8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x208 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x20c (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x210 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x214 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x218 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x21c (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x220 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x224 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) >; }; clkout1_pin: pinmux_clkout1_pin { pinctrl-single,pins = < 0x270 (PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* XDMA_EVENT_INTR0/CLKOUT1 */ >; }; /* default pinmux commented by analogics */ /* cpsw_default: cpsw_default { pinctrl-single,pins = < // Slave 1 0x12c (PIN_OUTPUT | MUX_MODE2) /* mii1_txclk.rmii1_tclk 0x114 (PIN_OUTPUT | MUX_MODE2) /* mii1_txen.rgmii1_tctl 0x128 (PIN_OUTPUT | MUX_MODE2) /* mii1_txd0.rgmii1_td0 0x124 (PIN_OUTPUT | MUX_MODE2) /* mii1_txd1.rgmii1_td1 0x120 (PIN_OUTPUT | MUX_MODE2) /* mii1_txd0.rgmii1_td2 0x11c (PIN_OUTPUT | MUX_MODE2) /* mii1_txd1.rgmii1_td3 0x130 (PIN_INPUT | MUX_MODE2) /* mii1_rxclk.rmii1_rclk 0x118 (PIN_INPUT | MUX_MODE2) /* mii1_rxdv.rgmii1_rctl 0x140 (PIN_INPUT | MUX_MODE2) /* mii1_rxd0.rgmii1_rd0 0x13c (PIN_INPUT | MUX_MODE2) /* mii1_rxd1.rgmii1_rd1 0x138 (PIN_INPUT | MUX_MODE2) /* mii1_rxd0.rgmii1_rd2 0x134 (PIN_INPUT | MUX_MODE2) /* mii1_rxd1.rgmii1_rd3 // Slave 2 0x58 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a6.rgmii2_tclk 0x40 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a0.rgmii2_tctl 0x54 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a5.rgmii2_td0 0x50 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a4.rgmii2_td1 0x4c (PIN_OUTPUT | MUX_MODE2) /* gpmc_a3.rgmii2_td2 0x48 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a2.rgmii2_td3 0x5c (PIN_INPUT | MUX_MODE2) /* gpmc_a7.rgmii2_rclk 0x44 (PIN_INPUT | MUX_MODE2) /* gpmc_a1.rgmii2_rtcl 0x6c (PIN_INPUT | MUX_MODE2) /* gpmc_a11.rgmii2_rd0 0x68 (PIN_INPUT | MUX_MODE2) /* gpmc_a10.rgmii2_rd1 0x64 (PIN_INPUT | MUX_MODE2) /* gpmc_a9.rgmii2_rd2 0x60 (PIN_INPUT | MUX_MODE2) /* gpmc_a8.rgmii2_rd3 >; }; cpsw_sleep: cpsw_sleep { pinctrl-single,pins = < // Slave 1 reset value 0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x140 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x13c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x138 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x134 (PIN_INPUT_PULLDOWN | MUX_MODE7) // Slave 2 reset value 0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x40 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x50 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x5c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x6c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x60 (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; */ /* cpsw pinmux added by analogics */ cpsw_default: cpsw_pins_default { pinctrl-single,pins = < 0x10c ( PIN_INPUT_PULLUP | MUX_MODE1 ) /* (B14) mii1_crs.rmii1_crs_dv */ 0x110 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) /* (B13) mii1_rx_er.rmii1_rxer */ 0x114 ( PIN_OUTPUT | MUX_MODE1 ) /* (A13) mii1_tx_en.rmii1_txen */ 0x128 ( PIN_OUTPUT | MUX_MODE1 ) /* (B15) mii1_txd0.rmii1_txd0 */ 0x124 ( PIN_OUTPUT | MUX_MODE1 ) /* (A14) mii1_txd1.rmii1_txd1 */ 0x140 ( PIN_INPUT_PULLUP | MUX_MODE1 ) /* (F17) mii1_rxd0.rmii1_rxd0 */ 0x13c ( PIN_INPUT_PULLUP | MUX_MODE1 ) /* (B16) mii1_rxd1.rmii1_rxd1 */ 0x144 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (A16) rmii1_ref_clk.rmii1_refclk */ >; }; cpsw_sleep: cpsw_pins_sleep { pinctrl-single,pins = < 0x10c /* (B14) mii1_crs.rmii1_crs_dv */ 0x110 /* (B13) mii1_rx_er.rmii1_rxer */ 0x114 /* (A13) mii1_tx_en.rmii1_txen */ 0x128 /* (B15) mii1_txd0.rmii1_txd0 */ 0x124 /* (A14) mii1_txd1.rmii1_txd1 */ 0x140 /* (F17) mii1_rxd0.rmii1_rxd0 */ 0x13c /* (B16) mii1_rxd1.rmii1_rxd1 */ 0x144 /* (A16) rmii1_ref_clk.rmii1_refclk */ >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < /* MDIO */ 0x148 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ 0x14c (PIN_OUTPUT | MUX_MODE0) /* mdio_clk.mdio_clk */ >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < /* MDIO reset value */ 0x148 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x14c (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; /* default pinmux commented by analogics */ /* dss_pins: dss_pins { pinctrl-single,pins = < 0x020 (PIN_OUTPUT | MUX_MODE1) /* gpmc ad 8 -> DSS DATA 23 0x024 (PIN_OUTPUT | MUX_MODE1) 0x028 (PIN_OUTPUT | MUX_MODE1) 0x02c (PIN_OUTPUT | MUX_MODE1) 0x030 (PIN_OUTPUT | MUX_MODE1) 0x034 (PIN_OUTPUT | MUX_MODE1) 0x038 (PIN_OUTPUT | MUX_MODE1) 0x03c (PIN_OUTPUT | MUX_MODE1) /* gpmc ad 15 -> DSS DATA 16 0x0a0 (PIN_OUTPUT | MUX_MODE0) /* DSS DATA 0 0x0a4 (PIN_OUTPUT | MUX_MODE0) 0x0a8 (PIN_OUTPUT | MUX_MODE0) 0x0ac (PIN_OUTPUT | MUX_MODE0) 0x0b0 (PIN_OUTPUT | MUX_MODE0) 0x0b4 (PIN_OUTPUT | MUX_MODE0) 0x0b8 (PIN_OUTPUT | MUX_MODE0) 0x0bc (PIN_OUTPUT | MUX_MODE0) 0x0c0 (PIN_OUTPUT | MUX_MODE0) 0x0c4 (PIN_OUTPUT | MUX_MODE0) 0x0c8 (PIN_OUTPUT | MUX_MODE0) 0x0cc (PIN_OUTPUT | MUX_MODE0) 0x0d0 (PIN_OUTPUT | MUX_MODE0) 0x0d4 (PIN_OUTPUT | MUX_MODE0) 0x0d8 (PIN_OUTPUT | MUX_MODE0) 0x0dc (PIN_OUTPUT | MUX_MODE0) /* DSS DATA 15 0x0e0 (PIN_OUTPUT | MUX_MODE0) /* DSS VSYNC 0x0e4 (PIN_OUTPUT | MUX_MODE0) /* DSS HSYNC 0x0e8 (PIN_OUTPUT | MUX_MODE0) /* DSS PCLK 0x0ec (PIN_OUTPUT | MUX_MODE0) /* DSS AC BIAS EN >; }; */ /* display pinmux added by analogics */ dss_pins: dss_pins_default { pinctrl-single,pins = < 0xe0 ( PIN_OUTPUT | MUX_MODE0 ) /* (B23) dss_vsync.dss_vsync */ 0xe4 ( PIN_OUTPUT | MUX_MODE0 ) /* (A23) dss_hsync.dss_hsync */ 0xe8 ( PIN_OUTPUT | MUX_MODE0 ) /* (A22) dss_pclk.dss_pclk */ 0xec ( PIN_OUTPUT | MUX_MODE0 ) /* (A24) dss_ac_bias_en.dss_ac_bias_en */ 0xa0 ( PIN_OUTPUT | MUX_MODE0 ) /* (B22) dss_data0.dss_data0 */ 0xa4 ( PIN_OUTPUT | MUX_MODE0 ) /* (A21) dss_data1.dss_data1 */ 0xa8 ( PIN_OUTPUT | MUX_MODE0 ) /* (B21) dss_data2.dss_data2 */ 0xac ( PIN_OUTPUT | MUX_MODE0 ) /* (C21) dss_data3.dss_data3 */ 0xb0 ( PIN_OUTPUT | MUX_MODE0 ) /* (A20) dss_data4.dss_data4 */ 0xb4 ( PIN_OUTPUT | MUX_MODE0 ) /* (B20) dss_data5.dss_data5 */ 0xb8 ( PIN_OUTPUT | MUX_MODE0 ) /* (C20) dss_data6.dss_data6 */ 0xbc ( PIN_OUTPUT | MUX_MODE0 ) /* (E19) dss_data7.dss_data7 */ 0xc0 ( PIN_OUTPUT | MUX_MODE0 ) /* (A19) dss_data8.dss_data8 */ 0xc4 ( PIN_OUTPUT | MUX_MODE0 ) /* (B19) dss_data9.dss_data9 */ 0xc8 ( PIN_OUTPUT | MUX_MODE0 ) /* (A18) dss_data10.dss_data10 */ 0xcc ( PIN_OUTPUT | MUX_MODE0 ) /* (B18) dss_data11.dss_data11 */ 0xd0 ( PIN_OUTPUT | MUX_MODE0 ) /* (C19) dss_data12.dss_data12 */ 0xd4 ( PIN_OUTPUT | MUX_MODE0 ) /* (D19) dss_data13.dss_data13 */ 0xd8 ( PIN_OUTPUT | MUX_MODE0 ) /* (C17) dss_data14.dss_data14 */ 0xdc ( PIN_OUTPUT | MUX_MODE0 ) /* (D17) dss_data15.dss_data15 */ 0x274 ( PIN_INPUT | MUX_MODE7 ) /* (C24) xdma_event_intr1.gpio0[20] Display Reset Pin */ >; }; dss_pins_sleep: dss_pins_sleep { pinctrl-single,pins = < 0xe0 ( PIN_OUTPUT | MUX_MODE0 ) /* (B23) dss_vsync.dss_vsync */ 0xe4 ( PIN_OUTPUT | MUX_MODE0 ) /* (A23) dss_hsync.dss_hsync */ 0xe8 ( PIN_OUTPUT | MUX_MODE0 ) /* (A22) dss_pclk.dss_pclk */ 0xec ( PIN_OUTPUT | MUX_MODE0 ) /* (A24) dss_ac_bias_en.dss_ac_bias_en */ 0xa0 ( PIN_OUTPUT | MUX_MODE0 ) /* (B22) dss_data0.dss_data0 */ 0xa4 ( PIN_OUTPUT | MUX_MODE0 ) /* (A21) dss_data1.dss_data1 */ 0xa8 ( PIN_OUTPUT | MUX_MODE0 ) /* (B21) dss_data2.dss_data2 */ 0xac ( PIN_OUTPUT | MUX_MODE0 ) /* (C21) dss_data3.dss_data3 */ 0xb0 ( PIN_OUTPUT | MUX_MODE0 ) /* (A20) dss_data4.dss_data4 */ 0xb4 ( PIN_OUTPUT | MUX_MODE0 ) /* (B20) dss_data5.dss_data5 */ 0xb8 ( PIN_OUTPUT | MUX_MODE0 ) /* (C20) dss_data6.dss_data6 */ 0xbc ( PIN_OUTPUT | MUX_MODE0 ) /* (E19) dss_data7.dss_data7 */ 0xc0 ( PIN_OUTPUT | MUX_MODE0 ) /* (A19) dss_data8.dss_data8 */ 0xc4 ( PIN_OUTPUT | MUX_MODE0 ) /* (B19) dss_data9.dss_data9 */ 0xc8 ( PIN_OUTPUT | MUX_MODE0 ) /* (A18) dss_data10.dss_data10 */ 0xcc ( PIN_OUTPUT | MUX_MODE0 ) /* (B18) dss_data11.dss_data11 */ 0xd0 ( PIN_OUTPUT | MUX_MODE0 ) /* (C19) dss_data12.dss_data12 */ 0xd4 ( PIN_OUTPUT | MUX_MODE0 ) /* (D19) dss_data13.dss_data13 */ 0xd8 ( PIN_OUTPUT | MUX_MODE0 ) /* (C17) dss_data14.dss_data14 */ 0xdc ( PIN_OUTPUT | MUX_MODE0 ) /* (D17) dss_data15.dss_data15 */ 0x274 ( PIN_INPUT | MUX_MODE7 ) /* (C24) xdma_event_intr1.gpio0[20] Display Reset Pin */ >; }; /* default pinmux commented by analogics */ /* qspi_pins: qspi_pins { pinctrl-single,pins = < 0x7c (PIN_OUTPUT | MUX_MODE3) /* gpmc_csn0.qspi_csn 0x88 (PIN_OUTPUT | MUX_MODE2) /* gpmc_csn3.qspi_clk 0x90 (PIN_INPUT | MUX_MODE3) /* gpmc_advn_ale.qspi_d0 0x94 (PIN_INPUT | MUX_MODE3) /* gpmc_oen_ren.qspi_d1 0x98 (PIN_INPUT | MUX_MODE3) /* gpmc_wen.qspi_d2 0x9c (PIN_INPUT | MUX_MODE3) /* gpmc_be0n_cle.qspi_d3 >; }; */ /* default pinmux commented by analogics */ /* mcasp1_pins: mcasp1_pins { pinctrl-single,pins = < 0x10c (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_crs.mcasp1_aclkx 0x110 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rxerr.mcasp1_fsx 0x108 (PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 0x144 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 >; }; */ /* mcasp1 added by analogics */ mcasp1_pins: mcasp_1_pins_default { pinctrl-single,pins = < 0x1a0 ( PIN_INPUT | MUX_MODE3 ) /* (L23) mcasp0_aclkr.mcasp1_aclkx */ 0x1a4 ( PIN_INPUT | MUX_MODE3 ) /* (K23) mcasp0_fsr.mcasp1_fsx */ 0x1a8 ( PIN_INPUT | MUX_MODE3 ) /* (M25) mcasp0_axr1.mcasp1_axr0 */ 0x1ac ( PIN_INPUT | MUX_MODE3 ) /* (L24) mcasp0_ahclkx.mcasp1_axr1 */ >; }; lcd_pins: lcd_pins { pinctrl-single,pins = < 0x1c (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpcm_ad7.gpio1_7 */ >; }; usb1_pins: usb1_pins { pinctrl-single,pins = < 0x2c0 (PIN_OUTPUT | MUX_MODE0) /* usb0_drvvbus.usb0_drvvbus */ >; }; usb2_pins: usb2_pins { pinctrl-single,pins = < 0x2c4 (PIN_OUTPUT | MUX_MODE0) /* usb0_drvvbus.usb0_drvvbus */ >; }; mmc3_pins_default: pinmux_mmc3_pins_default { pinctrl-single,pins = < 0x1f0 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AD21) cam1_data2.mmc2_clk */ 0x1f4 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AE22) cam1_data3.mmc2_cmd */ 0x1f8 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AD22) cam1_data4.mmc2_dat0 */ 0x1fc (PIN_INPUT_PULLUP | MUX_MODE3) /* (AE23) cam1_data5.mmc2_dat1 */ 0x200 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AD23) cam1_data6.mmc2_dat2 */ 0x204 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AE24) cam1_data7.mmc2_dat3 */ >; }; mmc3_pins_sleep: pinmux_mmc3_pins_sleep { pinctrl-single,pins = < 0x1f0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD21) cam1_data2.mmc2_clk */ 0x1f4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE22) cam1_data3.mmc2_cmd */ 0x1f8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD22) cam1_data4.mmc2_dat0 */ 0x1fc (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE23) cam1_data5.mmc2_dat1 */ 0x200 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD23) cam1_data6.mmc2_dat2 */ 0x204 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE24) cam1_data7.mmc2_dat3 */ >; }; wlan_pins_default: pinmux_wlan_pins_default { pinctrl-single,pins = < 0x1d0 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* cam1_data8.gpio4_8 WL_EN */ 0x1e4 (PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7) /* cam1_wen.gpio4_13 WL_IRQ */ >; }; wlan_pins_sleep: pinmux_wlan_pins_sleep { pinctrl-single,pins = < 0x1d0 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* cam1_data8.gpio4_8 WL_EN */ 0x1e4 (PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7) /* cam1_wen.gpio4_13 WL_IRQ */ >; }; uart1_bt_pins_default: pinmux_uart1_bt_pins_default { pinctrl-single,pins = < 0x180 (PIN_INPUT | MUX_MODE0) /* uart1_rxd.uart1_rxd */ 0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */ 0x178 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_ctsn.uart1_ctsn */ 0x17c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_rtsn.uart1_rtsn */ 0x1cc (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* cam1_data9.gpiop BT_EN */ >; }; uart1_bt_pins_sleep: pinmux_uart1_bt_pins_sleep { pinctrl-single,pins = < 0x180 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_rxd.uart1_rxd */ 0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_txd.uart1_txd */ 0x178 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_ctsn.uart1_ctsn */ 0x17c (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_rtsn.uart1_rtsn */ 0x1cc (PIN_OUTPUT_PULLUP | MUX_MODE7) /* cam1_data9.gpio4_7 BT_EN */ >; }; }; &i2c0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; clock-frequency = <100000>; tps@24 { compatible = "ti,tps65218"; reg = <0x24>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; dcdc1: regulator-dcdc1 { compatible = "ti,tps65218-dcdc1"; /* VDD_CORE limits min of OPP50 and max of OPP100 */ regulator-name = "vdd_core"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1144000>; regulator-boot-on; regulator-always-on; }; dcdc2: regulator-dcdc2 { compatible = "ti,tps65218-dcdc2"; /* VDD_MPU limits min of OPP50 and max of OPP_NITRO */ regulator-name = "vdd_mpu"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; }; dcdc3: regulator-dcdc3 { compatible = "ti,tps65218-dcdc3"; regulator-name = "vdds_ddr"; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; regulator-state-disk { regulator-off-in-suspend; }; }; dcdc4: regulator-dcdc4 { compatible = "ti,tps65218-dcdc4"; regulator-name = "v3_3d"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; dcdc5: regulator-dcdc5 { compatible = "ti,tps65218-dcdc5"; regulator-name = "v1_0bat"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; dcdc6: regulator-dcdc6 { compatible = "ti,tps65218-dcdc6"; regulator-name = "v1_8bat"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; ldo1: regulator-ldo1 { compatible = "ti,tps65218-ldo1"; regulator-name = "v1_8d"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; /*Power Button Disabled by analogics */ /* power-button { compatible = "ti,tps65218-pwrbutton"; status = "okay"; interrupts = <3 IRQ_TYPE_EDGE_BOTH>; };*/ }; at24@50 { compatible = "at24,24c256"; pagesize = <64>; reg = <0x50>; }; }; &i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; clock-frequency = <400000>; ov2659@30 { compatible = "ovti,ov2659"; reg = <0x30>; pinctrl-names = "default"; pinctrl-0 = <&clkout1_pin>; clocks = <&clkout1_mux_ck>; clock-names = "xvclk"; assigned-clocks = <&clkout1_mux_ck>; assigned-clock-parents = <&clkout1_osc_div_ck>; port { ov2659_1: endpoint { remote-endpoint = <&vpfe0_ep>; link-frequencies = /bits/ 64 <70000000>; }; }; }; /* edt-ft5306@38 { status = "okay"; compatible = "edt,edt-ft5306", "edt,edt-ft5x06"; pinctrl-names = "default"; /*pinctrl-0 = <&edt_ft5306_ts_pins>; reg = <0x38>; interrupt-parent = <&gpio0>; interrupts = <31 0>; reset-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>; touchscreen-size-x = <480>; touchscreen-size-y = <272>; }; */ tlv320aic3106: tlv320aic3106@1b { #sound-dai-cells = <0>; compatible = "ti,tlv320aic3106"; reg = <0x1b>; status = "okay"; /* Regulators */ AVDD-supply = <&dcdc4>; IOVDD-supply = <&dcdc4>; DRVDD-supply = <&dcdc4>; DVDD-supply = <&ldo1>; }; lis331dlh@18 { compatible = "st,lis331dlh"; reg = <0x18>; status = "okay"; Vdd-supply = <&dcdc4>; Vdd_IO-supply = <&dcdc4>; interrupts-extended = <&gpio1 6 0>, <&gpio2 1 0>; }; }; &epwmss0 { status = "okay"; }; &ecap0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ecap0_pins>; }; &gpio0 { status = "okay"; }; &gpio1 { status = "okay"; }; &gpio4 { status = "okay"; }; &gpio5 { status = "okay"; }; &mmc1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; vmmc-supply = <&dcdc4>; bus-width = <4>; cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>; }; &uart1 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart1_bt_pins_default>; pinctrl-1 = <&uart1_bt_pins_sleep>; }; &mmc3 { status = "okay"; /* these are on the crossbar and are outlined in the xbar-event-map element */ dmas = <&edma 30 &edma 31>; dma-names = "tx", "rx"; vmmc-supply = <&vmmcwl_fixed>; bus-width = <4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mmc3_pins_default>; pinctrl-1 = <&mmc3_pins_sleep>; cap-power-off-card; keep-power-in-suspend; ti,non-removable; #address-cells = <1>; #size-cells = <0>; wlcore: wlcore@0 { compatible = "ti,wl1835"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&wlan_pins_default>; pinctrl-1 = <&wlan_pins_sleep>; reg = <2>; interrupt-parent = <&gpio4>; interrupts = <13 IRQ_TYPE_LEVEL_HIGH>; }; }; &edma { ti,edma-xbar-event-map = /bits/ 16 <1 30 2 31>; }; &usb2_phy1 { status = "okay"; }; &usb1 { dr_mode = "otg"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&usb1_pins>; }; &usb2_phy2 { status = "okay"; }; &usb2 { dr_mode = "host"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&usb2_pins>; }; &qspi { status = "okay"; pinctrl-names = "default"; /*pinctrl-0 = <&qspi_pins>; */ spi-max-frequency = <48000000>; m25p80@0 { compatible = "mx66l51235l"; spi-max-frequency = <48000000>; reg = <0>; spi-cpol; spi-cpha; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; #address-cells = <1>; #size-cells = <1>; /* MTD partition table. * The ROM checks the first 512KiB * for a valid file to boot(XIP). */ partition@0 { label = "QSPI.U_BOOT"; reg = <0x00000000 0x000080000>; }; partition@1 { label = "QSPI.U_BOOT.backup"; reg = <0x00080000 0x00080000>; }; partition@2 { label = "QSPI.U-BOOT-SPL_OS"; reg = <0x00100000 0x00010000>; }; partition@3 { label = "QSPI.U_BOOT_ENV"; reg = <0x00110000 0x00010000>; }; partition@4 { label = "QSPI.U-BOOT-ENV.backup"; reg = <0x00120000 0x00010000>; }; partition@5 { label = "QSPI.KERNEL"; reg = <0x00130000 0x0800000>; }; partition@6 { label = "QSPI.FILESYSTEM"; reg = <0x00930000 0x36D0000>; }; }; }; &mac { pinctrl-names = "default", "sleep"; pinctrl-0 = <&cpsw_default>; pinctrl-1 = <&cpsw_sleep>; /* dual emac commented by analogics */ /*dual_emac = <1>; */ status = "okay"; }; &davinci_mdio { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; status = "okay"; }; &cpsw_emac0 { /* phy_id = <&davinci_mdio>, <4>; */ phy_id = <&davinci_mdio>, <0>; /* rgmii mode commented by analogics */ /*phy-mode = "rgmii"; */ phy-mode = "rmii"; dual_emac_res_vlan = <1>; }; &cpsw_emac1 { /* phy_id = <&davinci_mdio>, <5>; */ phy_id = <&davinci_mdio>, <1>; /* rgmii mode commented by analogics */ /* phy-mode = "rgmii"; */ phy-mode = "rmii"; dual_emac_res_vlan = <2>; }; &elm { status = "okay"; }; &mcasp1 { #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcasp1_pins>; status = "okay"; op-mode = <0>; tdm-slots = <2>; serial-dir = < 0 0 1 2 >; tx-num-evt = <1>; rx-num-evt = <1>; }; &dss { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&dss_pins>; pinctrl-1 = <&dss_pins_sleep>; port { dpi_out: endpoint@0 { remote-endpoint = <&lcd_in>; /* data-lines = <24>; */ data-lines = <16>; }; }; }; /* touchscreen & ADC values added by arun analogics */ &tscadc { status = "okay"; tsc { ti,wires = <4>; ti,x-plate-resistance = <200>; ti,coordinate-readouts = <5>; ti,wire-config = <0x00 0x11 0x22 0x33>; /* ti,wire-config = <0x00 0x13 0x21 0x32>; */ ti,x-axis = <0 240 1>; ti,y-axis = <0 320 1>; ti,charge-delay = <0x400>; }; adc { ti,adc-channels = <4 5 6 7>; }; }; &rtc { status = "okay"; ext-clk-src; }; &wdt { status = "okay"; }; &cpu { cpu0-supply = <&dcdc2>; }; &vpfe0 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&vpfe0_pins_default>; pinctrl-1 = <&vpfe0_pins_sleep>; /* Camera port */ port { vpfe0_ep: endpoint { remote-endpoint = <&ov2659_1>; ti,am437x-vpfe-interface = <0>; bus-width = <8>; hsync-active = <0>; vsync-active = <0>; }; }; }; &wkup_m3_ipc { ti,scale-data-fw = "am43x-evm-scale-data.bin"; }; &sgx { status = "okay"; };
