In one of our working system, i2c driver had crashed. This problem occurred when we were doing 4 video calls. Please note as mentioned in dmesg that we are using linux-3.14.26 kernel. We have connected one external RTC clock on this I2C bus. Why such problem may occur? Kindly resolve this problem.
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.14.26-gb9df364-dirty (rajdeepvaghasiya@localhost.localdomain) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 Wed Sep 14 15:37:08 IST 2016 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: MATRIX: ETERNITY_NEV3 [ 0.000000] cma: CMA: reserved 16 MiB at 8e800000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] On node 0 totalpages: 65280 [ 0.000000] free_area_init_node: node 0, pgdat c070b90c, node_mem_map cfbbb000 [ 0.000000] Normal zone: 512 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 65280 pages, LIFO batch:15 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64768 [ 0.000000] Kernel command line: console=ttyO0,115200n8 consoleblank=0 init=/etc/preinit root=ubi0:rootfs rw ubi.mtd=9,2048 noinitrd rootfstype=ubifs rootflags=sync user_debug=31 mem=256M mtdparts=omap2-nand.0:128k(SPL),128k(SPL.backup1),128k(SPL.backup2),128k(SPL.backup3),1m(U-Boot),512k(U-Boot-Env),1m(dtb),8m(Recv-Kernel),20m(Recv-Fs),16m(data),8m(Kernel),-(Rootfs) ethaddr=00:1B:09:02:91:59 [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 234892K/261120K available (5052K kernel code, 241K rwdata, 1676K rodata, 208K init, 202K bss, 26228K reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc069a550 (6730 kB) [ 0.000000] .init : 0xc069b000 - 0xc06cf02c ( 209 kB) [ 0.000000] .data : 0xc06d0000 - 0xc070c640 ( 242 kB) [ 0.000000] .bss : 0xc070c640 - 0xc073f058 ( 203 kB) [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: timer2 at 25000000 Hz [ 0.000014] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 171798691800ns [ 0.000031] OMAP clocksource: timer1 at 25000000 Hz [ 0.000280] Console: colour dummy device 80x30 [ 0.000305] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216) [ 0.089521] pid_max: default: 32768 minimum: 301 [ 0.089616] Security Framework initialized [ 0.089672] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089681] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.095927] CPU: Testing write buffer coherency: ok [ 0.096296] Setting up static identity map for 0x804c9c60 - 0x804c9cb8 [ 0.097202] devtmpfs: initialized [ 0.099125] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.101300] ------------[ cut here ]------------ [ 0.101343] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2568 _init+0x3cc/0x418() [ 0.101352] omap_hwmod: rtc: doesn't have mpu register target base [ 0.101357] Modules linked in: [ 0.101374] CPU: 0 PID: 1 Comm: swapper Not tainted 3.14.26-gb9df364-dirty #1 [ 0.101426] [<c0013bc8>] (unwind_backtrace) from [<c0011120>] (show_stack+0x10/0x14) [ 0.101457] [<c0011120>] (show_stack) from [<c0033aec>] (warn_slowpath_common+0x64/0x84) [ 0.101474] [<c0033aec>] (warn_slowpath_common) from [<c0033ba0>] (warn_slowpath_fmt+0x30/0x40) [ 0.101489] [<c0033ba0>] (warn_slowpath_fmt) from [<c06a54c4>] (_init+0x3cc/0x418) [ 0.101518] [<c06a54c4>] (_init) from [<c0023bfc>] (omap_hwmod_for_each+0x30/0x5c) [ 0.101535] [<c0023bfc>] (omap_hwmod_for_each) from [<c06a5a50>] (__omap_hwmod_setup_all+0x24/0x40) [ 0.101550] [<c06a5a50>] (__omap_hwmod_setup_all) from [<c0008850>] (do_one_initcall+0xe4/0x140) [ 0.101576] [<c0008850>] (do_one_initcall) from [<c069bb44>] (kernel_init_freeable+0xe8/0x1b0) [ 0.101600] [<c069bb44>] (kernel_init_freeable) from [<c04c33a0>] (kernel_init+0x8/0xec) [ 0.101616] [<c04c33a0>] (kernel_init) from [<c000e458>] (ret_from_fork+0x14/0x3c) [ 0.101664] ---[ end trace f862c5e48e2c78c0 ]--- [ 0.105626] omap_hwmod: tptc0 using broken dt data from edma [ 0.105692] omap_hwmod: tptc1 using broken dt data from edma [ 0.105753] omap_hwmod: tptc2 using broken dt data from edma [ 0.109808] omap_hwmod: debugss: _wait_target_disable failed [ 0.165265] pinctrl core: initialized pinctrl subsystem [ 0.166137] regulator-dummy: no parameters [ 0.167808] NET: Registered protocol family 16 [ 0.169786] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.171513] cpuidle: using governor ladder [ 0.171528] cpuidle: using governor menu [ 0.177483] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered [ 0.178739] platform 49000000.edma: alias fck already exists [ 0.178761] platform 49000000.edma: alias fck already exists [ 0.178774] platform 49000000.edma: alias fck already exists [ 0.179804] OMAP GPIO hardware version 0.1 [ 0.187806] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe [ 0.187838] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral [ 0.188954] MATRIX NEV3: Registering i2c_board_info at Bus number 1 [ 0.189479] No ATAGs? [ 0.189541] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.206535] bio: create slab <bio-0> at 0 [ 0.218862] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [ 0.220199] SCSI subsystem initialized [ 0.221038] usbcore: registered new interface driver usbfs [ 0.221207] usbcore: registered new interface driver hub [ 0.221419] usbcore: registered new device driver usb [ 0.222070] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/i2c1_pins_default, deferring probe [ 0.222096] platform 4802a000.i2c: Driver omap_i2c requests probe deferral [ 0.222385] pps_core: LinuxPPS API ver. 1 registered [ 0.222394] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.222500] PTP clock support registered [ 0.223797] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.225066] Switched to clocksource timer1 [ 0.241680] NET: Registered protocol family 2 [ 0.242500] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.242536] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.242563] TCP: Hash tables configured (established 2048 bind 2048) [ 0.242647] TCP: reno registered [ 0.242659] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.242676] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.242893] NET: Registered protocol family 1 [ 0.243200] RPC: Registered named UNIX socket transport module. [ 0.243210] RPC: Registered udp transport module. [ 0.243215] RPC: Registered tcp transport module. [ 0.243222] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.244249] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available [ 0.246731] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.248244] VFS: Disk quotas dquot_6.5.2 [ 0.248308] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.248836] NFS: Registering the id_resolver key type [ 0.248912] Key type id_resolver registered [ 0.248919] Key type id_legacy registered [ 0.248977] msgmni has been set to 490 [ 0.250212] io scheduler noop registered [ 0.250226] io scheduler deadline registered [ 0.250254] io scheduler cfq registered (default) [ 0.251703] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.252882] omap_uart 44e09000.serial: no wakeirq for uart0 [ 0.253044] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0 [ 0.888280] console [ttyO0] enabled [ 0.892626] omap_uart 48022000.serial: no wakeirq for uart0 [ 0.898573] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a OMAP UART1 [ 0.908751] omap_uart 48024000.serial: no wakeirq for uart0 [ 0.914696] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a OMAP UART2 [ 0.925532] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 0.942226] brd: module loaded [ 0.950669] loop: module loaded [ 0.955053] mtdoops: mtd device (mtddev=name/number) must be supplied [ 0.963485] of_dma_request_slave_channel: dma-names property of node '/ocp/spi@481a0000' missing or empty [ 0.973643] spi spi1.0: not using DMA for McSPI [ 0.978716] m25p80 spi1.0: found s25fl129p1, expected m25p80 [ 0.984625] m25p80 spi1.0: s25fl129p1 (16384 Kbytes) [ 0.992083] PPP generic driver version 2.4.2 [ 0.996981] PPP BSD Compression module registered [ 1.001927] PPP Deflate Compression module registered [ 1.007274] PPP MPPE Compression module registered [ 1.012263] NET: Registered protocol family 24 [ 1.017595] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.024401] ehci-omap: OMAP-EHCI Host Controller driver [ 1.030073] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.036799] usbcore: registered new interface driver cdc_acm [ 1.042693] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.051221] usbcore: registered new interface driver usblp [ 1.057088] usbcore: registered new interface driver cdc_wdm [ 1.063107] usbcore: registered new interface driver usbtmc [ 1.069128] usbcore: registered new interface driver usb-storage [ 1.075546] usbcore: registered new interface driver usbtest [ 1.083107] 47401300.usb-phy supply vcc not found, using dummy regulator [ 1.092350] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) [ 1.092369] musb-hdrc: MHDRC RTL version 2.0 [ 1.092378] musb-hdrc: setup fifo_mode 4 [ 1.092396] musb-hdrc: 28/31 max ep, 16384/16384 memory [ 1.092494] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver [ 1.098941] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1 [ 1.107303] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.114377] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.121919] usb usb1: Product: MUSB HDRC host driver [ 1.127099] usb usb1: Manufacturer: Linux 3.14.26-gb9df364-dirty musb-hcd [ 1.134168] usb usb1: SerialNumber: musb-hdrc.0.auto [ 1.140231] hub 1-0:1.0: USB hub found [ 1.144179] hub 1-0:1.0: 1 port detected [ 1.149314] 47401b00.usb-phy supply vcc not found, using dummy regulator [ 1.158510] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) [ 1.158527] musb-hdrc: MHDRC RTL version 2.0 [ 1.158535] musb-hdrc: setup fifo_mode 4 [ 1.158549] musb-hdrc: 28/31 max ep, 16384/16384 memory [ 1.158642] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 1.165027] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 2 [ 1.173463] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.180556] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.188090] usb usb2: Product: MUSB HDRC host driver [ 1.193260] usb usb2: Manufacturer: Linux 3.14.26-gb9df364-dirty musb-hcd [ 1.200337] usb usb2: SerialNumber: musb-hdrc.1.auto [ 1.206619] hub 2-0:1.0: USB hub found [ 1.210561] hub 2-0:1.0: 1 port detected [ 1.227592] i2c /dev entries driver [ 1.232185] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 1.244109] usbcore: registered new interface driver usbhid [ 1.249968] usbhid: USB HID core driver [ 1.254152] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral [ 1.262434] oprofile: using arm/armv7 [ 1.266395] Netfilter messages via NETLINK v0.30. [ 1.271320] nf_conntrack version 0.5.0 (3926 buckets, 15704 max) [ 1.277801] ctnetlink v0.93: registering with nfnetlink. [ 1.283606] ipip: IPv4 over IPv4 tunneling driver [ 1.289957] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.295751] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully [ 1.302472] TCP: cubic registered [ 1.305976] Initializing XFRM netlink socket [ 1.310494] NET: Registered protocol family 10 [ 1.316210] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.322119] sit: IPv6 over IPv4 tunneling driver [ 1.328513] NET: Registered protocol family 17 [ 1.333230] NET: Registered protocol family 15 [ 1.338010] Bridge firewalling registered [ 1.342245] 8021q: 802.1Q VLAN Support v1.8 [ 1.346716] Key type dns_resolver registered [ 1.352336] PM: Voltage scaling data blob not provided from DT. [ 1.358712] PM: no-rtc available, rtc-only mode disabled. [ 1.364386] ThumbEE CPU extension supported. [ 1.370320] regulator-dummy: disabling [ 1.374617] omap-gpmc 50000000.gpmc: GPMC revision 6.0 [ 1.380078] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000 [ 1.387610] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xf1 [ 1.394296] nand: AMD/Spansion S34ML01G2 [ 1.398449] nand: 128MiB, SLC, page size: 2048, OOB size: 64 [ 1.404341] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme [ 1.409936] 12 cmdlinepart partitions found on MTD device omap2-nand.0 [ 1.416744] Creating 12 MTD partitions on "omap2-nand.0": [ 1.422373] 0x000000000000-0x000000020000 : "SPL" [ 1.428998] 0x000000020000-0x000000040000 : "SPL.backup1" [ 1.436095] 0x000000040000-0x000000060000 : "SPL.backup2" [ 1.443073] 0x000000060000-0x000000080000 : "SPL.backup3" [ 1.450110] 0x000000080000-0x000000180000 : "U-Boot" [ 1.457385] 0x000000180000-0x000000200000 : "U-Boot-Env" [ 1.464665] 0x000000200000-0x000000300000 : "dtb" [ 1.471728] 0x000000300000-0x000000b00000 : "Recv-Kernel" [ 1.485282] 0x000000b00000-0x000001f00000 : "Recv-Fs" [ 1.508160] 0x000001f00000-0x000002f00000 : "data" [ 1.527553] 0x000002f00000-0x000003700000 : "Kernel" [ 1.540526] 0x000003700000-0x000008000000 : "Rootfs" [ 1.611330] rtc-s35390a 1-0030: rtc core: registered rtc-s35390a as rtc0 [ 1.618445] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz [ 1.624640] remoteproc0: wkup_m3 is available [ 1.629343] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 1.638684] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 1.649780] remoteproc0: powering up wkup_m3 [ 1.654327] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 154412 [ 1.662195] PM: CM3 Firmware Version = 0x190 [ 1.666774] remoteproc0: remote processor wkup_m3 is now up [ 1.673236] UBI: attaching mtd9 to ubi0 [ 1.774012] UBI: scanning is finished [ 1.784256] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 7, need 20 [ 1.796035] UBI: attached mtd9 (name "Recv-Fs", size 20 MiB) to ubi0 [ 1.802661] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 1.809762] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 512 [ 1.816659] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 1.823816] UBI: good PEBs: 160, bad PEBs: 0, corrupted PEBs: 0 [ 1.829986] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 1.837427] UBI: max/mean erase counter: 7/1, WL threshold: 4096, image sequence number: 656601578 [ 1.846764] UBI: available PEBs: 0, total reserved PEBs: 160, PEBs reserved for bad PEB handling: 7 [ 1.856815] UBI: background thread "ubi_bgt0d" started, PID 722 [ 1.925116] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [ 1.931478] davinci_mdio 4a101000.mdio: detected phy mask ffffff7e [ 1.939120] libphy: 4a101000.mdio: probed [ 1.943306] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver unknown [ 1.951744] davinci_mdio 4a101000.mdio: phy[7]: device 4a101000.mdio:07, driver unknown [ 1.960654] cpsw 4a100000.ethernet: Detected MACID = 00:1b:09:02:91:59 [ 1.969476] rtc-s35390a 1-0030: setting system clock to 2016-09-29 03:01:06 UTC (1475118066) [ 1.982274] UBIFS: parse sync [ 2.001749] UBIFS: background thread "ubifs_bgt0_0" started, PID 736 [ 2.025049] UBIFS: recovery needed [ 2.128124] UBIFS: recovery completed [ 2.132087] UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 2.138372] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 2.147896] UBIFS: FS size: 17522688 bytes (16 MiB, 138 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs) [ 2.157957] UBIFS: reserved for root: 0 bytes (0 KiB) [ 2.163222] UBIFS: media format: w4/r0 (latest is w4/r0), UUID D0B55590-4203-45B6-A888-7BF20DA17BFF, small LPT model [ 2.175112] VFS: Mounted root (ubifs filesystem) on device 0:13. [ 2.181643] Freeing unused kernel memory: 208K (c069b000 - c06cf000) [ 4.614277] UBI: attaching mtd12 to ubi1 [ 4.971176] UBI: scanning is finished [ 4.983071] UBI: attached mtd12 (name "Rootfs", size 73 MiB) to ubi1 [ 4.989750] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 4.996828] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 512 [ 5.003715] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 5.010882] UBI: good PEBs: 584, bad PEBs: 0, corrupted PEBs: 0 [ 5.017051] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 5.024483] UBI: max/mean erase counter: 34/14, WL threshold: 4096, image sequence number: 2089560987 [ 5.034092] UBI: available PEBs: 0, total reserved PEBs: 584, PEBs reserved for bad PEB handling: 20 [ 5.043627] UBI: background thread "ubi_bgt1d" started, PID 754 [ 5.074963] UBIFS: background thread "ubifs_bgt1_0" started, PID 757 [ 5.098174] UBIFS: recovery needed [ 5.514451] UBIFS: recovery completed [ 5.518475] UBIFS: mounted UBI device 1, volume 0, name "rootfs" [ 5.524735] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 5.534267] UBIFS: FS size: 69709824 bytes (66 MiB, 549 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs) [ 5.544331] UBIFS: reserved for root: 0 bytes (0 KiB) [ 5.549605] UBIFS: media format: w4/r0 (latest is w4/r0), UUID C2A731FF-58F6-44B3-A51A-1DD92DDFA016, small LPT model [ 6.064901] net eth0: initializing cpsw version 1.12 (0) [ 6.145500] net eth0: phy found : id is : 0x221560 [ 6.157734] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 6.163818] 8021q: adding VLAN 0 to HW filter on device eth0 [ 6.210986] usbcore: registered new interface driver usbserial [ 6.217307] usbcore: registered new interface driver usbserial_generic [ 6.224257] usbserial: USB Serial support registered for generic [ 6.286986] Drv_Leds: Info: Date: Sep 20 2016 Time: 11:05:41 [ 6.331078] Drv_GPIO: Info: Date--1: Sep 12 2016 Time: 19:49:38 [ 6.373278] Drv_PWDJMP: Info: Date: Sep 12 2016 Time: 18:16:29 [ 6.415893] Drv_DspHpi: Info: Date: Sep 12 2016 Time: 18:16:31 [ 6.422115] Drv_DspHpi: Info: SETUP_CS2_BASEADDR = 11000000 [ 6.428079] Drv_DspHpi :INFO: DspHpi module inserted successfully [ 6.470100] Drv_Test: Info: Date: Sep 12 2016 Time: 18:16:30 [ 6.512941] VoipHpi_Drv: Info: Date: Sep 12 2016 Time: 18:16:32 [ 6.519522] VoipHpi_Drv :INFO: VOPP HPI module inserted successfully [ 6.561861] wdt_drv: Info: Date: Sep 12 2016 Time: 18:16:30 [ 7.605753] Drv_GPIO:Info: USB set/reset gpioData: 1 [ 7.605753] [ 7.612636] Drv_GPIO:Info: De-Activate USB Supply [ 8.145843] libphy: 4a101000.mdio:07 - Link is Up - 100/Full [ 8.151782] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 8.635771] Drv_GPIO:Info: USB set/reset gpioData: 0 [ 8.635771] [ 8.642584] Drv_GPIO:Info: Activate USB Supply [ 16.781328] UBI: attaching mtd10 to ubi2 [ 16.862962] UBI: scanning is finished [ 16.887546] UBI: attached mtd10 (name "data", size 16 MiB) to ubi2 [ 16.894002] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes [ 16.901180] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 512 [ 16.908078] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096 [ 16.915245] UBI: good PEBs: 128, bad PEBs: 0, corrupted PEBs: 0 [ 16.921408] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 [ 16.928849] UBI: max/mean erase counter: 28/18, WL threshold: 4096, image sequence number: 1467812758 [ 16.938459] UBI: available PEBs: 0, total reserved PEBs: 128, PEBs reserved for bad PEB handling: 20 [ 16.947996] UBI: background thread "ubi_bgt2d" started, PID 879 [ 16.994839] UBIFS: background thread "ubifs_bgt2_0" started, PID 882 [ 17.018256] UBIFS: recovery needed [ 17.158290] UBIFS: recovery completed [ 17.162261] UBIFS: mounted UBI device 2, volume 0, name "data" [ 17.168446] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 17.178059] UBIFS: FS size: 11935744 bytes (11 MiB, 94 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs) [ 17.187979] UBIFS: reserved for root: 563754 bytes (550 KiB) [ 17.193879] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 53882EBF-4A2E-4558-8FD0-9E68A6FE6ABC, small LPT model [ 18.412193] net eth0: initializing cpsw version 1.12 (0) [ 18.495502] net eth0: phy found : id is : 0x221560 [ 18.505275] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 18.511359] 8021q: adding VLAN 0 to HW filter on device eth0 [ 21.495666] libphy: 4a101000.mdio:07 - Link is Up - 100/Full [ 21.501624] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 30.719530] VoipHpi_Drv :Info: voiphpi open [ 30.725980] Drv_DspHpi : INFO:dsphpi_open [ 30.830936] VoipHpi_Drv :INFO: DSP_IOCTL_HOLD_RESET [ 30.855145] VoipHpi_Drv :INFO: DSP_IOCTL_LEAVE_RESET [ 33.475908] Drv_DspHpi : INFO: dsphpi_close [ 33.551486] Drv_GPIO: Info: gpio_open [ 33.571456] Drv_DspHpi : INFO:dsphpi_open [ 39.086364] Drv_Leds :Info: Leds open [ 39.092775] Drv_PWDJMP :Info: PasswordJumper open [ 39.101925] Drv_GPIO: Info: gpio_open [ 41.650830] random: dnsmasq urandom read with 63 bits of entropy available [ 148.375193] random: nonblocking pool is initialized [ 487.975446] [sched_delayed] sched: RT throttling activated [ 497.012552] omap_i2c 4802a000.i2c: controller timed out [ 516.011104] omap_i2c 4802a000.i2c: controller timed out [ 549.907662] Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa02a02c [ 549.922289] Internal error: : 1028 [#1] ARM [ 549.930152] Modules linked in: watchdog(O) vopp(O) test(O) dsphpi(O) pwdjmp(O) gpio(O) leds(O) usbserial [ 549.948865] CPU: 0 PID: 705 Comm: irq/87-4802a000 Tainted: G W O 3.14.26-gb9df364-dirty #1 [ 549.965504] task: ce2d6800 ti: ce31c000 task.ti: ce31c000 [ 549.975878] PC is at omap_i2c_isr_thread+0x3c/0x318 [ 549.985079] LR is at irq_thread_fn+0x1c/0x34 [ 549.993191] pc : [<c035a25c>] lr : [<c005dc60>] psr: 20000093 [ 549.993191] sp : ce31df10 ip : 00000000 fp : 00000065 [ 550.014433] r10: 00000010 r9 : 00000216 r8 : 00004000 [ 550.024218] r7 : 00000008 r6 : 00000004 r5 : 20000013 r4 : ce312410 [ 550.036374] r3 : fa02a02c r2 : fa02a000 r1 : 0000002c r0 : 00000057 [ 550.048551] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 550.062310] Control: 10c5387d Table: 8e6c0019 DAC: 00000015 [ 550.073047] Process irq/87-4802a000 (pid: 705, stack limit = 0xce31c238) [ 550.085518] Stack: (0xce31df10 to 0xce31e000) [ 550.093802] df00: c035a220 ce318600 ce31c000 ce006d00 [ 550.109111] df20: ce006d00 ce006d54 00000000 c005dc44 00000000 c005dc60 ce318600 ce31c000 [ 550.124413] df40: 00000001 c005da64 00000000 c005db8c ce3185c0 00000000 ce3185c0 ce318600 [ 550.139715] df60: c005d988 00000000 00000000 c004b3cc ffffffff 00000000 ffffffff ce318600 [ 550.155025] df80: 00000000 ce31df84 ce31df84 00000000 ce31df90 ce31df90 ce31dfac ce3185c0 [ 550.170317] dfa0: c004b310 00000000 00000000 c000e458 00000000 00000000 00000000 00000000 [ 550.185601] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 550.200895] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff [ 550.216396] [<c035a25c>] (omap_i2c_isr_thread) from [<c005dc60>] (irq_thread_fn+0x1c/0x34) [ 550.232012] [<c005dc60>] (irq_thread_fn) from [<c005da64>] (irq_thread+0xdc/0x124) [ 550.246330] [<c005da64>] (irq_thread) from [<c004b3cc>] (kthread+0xbc/0xd8) [ 550.259520] [<c004b3cc>] (kthread) from [<c000e458>] (ret_from_fork+0x14/0x3c) [ 550.273089] Code: e594300c e5942004 e5d11001 e0823311 (e1d320b0) [ 550.284508] ---[ end trace f862c5e48e2c78c2 ]--- [ 550.321794] Unable to handle kernel paging request at virtual address fffffff0 [ 550.346839] pgd = c0004000 [ 550.353628] [fffffff0] *pgd=8fef6821, *pte=00000000, *ppte=00000000 [ 550.376939] Internal error: Oops: 17 [#2] ARM [ 550.385178] Modules linked in: watchdog(O) vopp(O) test(O) dsphpi(O) pwdjmp(O) gpio(O) leds(O) usbserial [ 550.403911] CPU: 0 PID: 705 Comm: irq/87-4802a000 Tainted: G D W O 3.14.26-gb9df364-dirty #1 [ 550.420632] task: ce2d6800 ti: ce31c000 task.ti: ce31c000 [ 550.430898] PC is at kthread_data+0x4/0xc [ 550.438629] LR is at irq_thread_dtor+0x28/0xb8 [ 550.447114] pc : [<c004b724>] lr : [<c005dbb4>] psr: 20000113 [ 550.447114] sp : ce31dd90 ip : ce31df84 fp : 60000193 [ 550.468492] r10: 00001028 r9 : ce2d6800 r8 : ce31c000 [ 550.478334] r7 : c070ee1c r6 : ce2d6800 r5 : ce2d6800 r4 : ce2d6b38 [ 550.490567] r3 : 00000000 r2 : ce31dd90 r1 : ce31df48 r0 : ce2d6800 [ 550.502813] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 550.516189] Control: 10c5387d Table: 8e6c0019 DAC: 00000015 [ 550.526991] Process irq/87-4802a000 (pid: 705, stack limit = 0xce31c238) [ 550.539533] Stack: (0xce31dd90 to 0xce31e000) [ 550.547853] dd80: c005db8c ce2d6b38 00000000 c0048bdc [ 550.563262] dda0: 00000033 0000000b ce31dec8 ce2d6800 00000000 c0034fe0 ce31ddc8 00000001 [ 550.578669] ddc0: 60000193 c04c4bb0 c05e2ee4 c06e75a4 ce31dec8 c070c844 ce31dec8 ce31c000 [ 550.594072] dde0: 0000000b c06dd8d0 ce2d6800 00001028 60000193 c0011334 ce31c238 0000000b [ 550.609478] de00: c05dcc34 00001028 00000007 c06de314 fa02a02c ce31dec8 00000216 00000010 [ 550.624872] de20: 00000065 c000843c 00000000 00000001 00000007 00000000 00000000 fa02a02c [ 550.640279] de40: ce2d6800 c06e6e80 ce31c000 c06e6e80 c04cd7c8 ce2d6970 01669760 00000069 [ 550.655689] de60: 01669760 00000069 00000000 ce2d6800 c00557ec c06e6e80 c00096d4 ffffffff [ 550.671093] de80: 00000000 c004e3a4 ce07401c ce2d6800 ce061400 00000000 c06e6e80 c004e458 [ 550.686498] dea0: 00000000 ce061430 00000000 ce2d6800 c035a25c 20000093 ffffffff ce31defc [ 550.701908] dec0: 00004000 c0011b18 00000057 0000002c fa02a000 fa02a02c ce312410 20000013 [ 550.717309] dee0: 00000004 00000008 00004000 00000216 00000010 00000065 00000000 ce31df10 [ 550.732717] df00: c005dc60 c035a25c 20000093 ffffffff c035a220 ce318600 ce31c000 ce006d00 [ 550.748119] df20: ce006d00 ce006d54 00000000 c005dc44 00000000 c005dc60 ce318600 ce31c000 [ 550.763520] df40: 00000001 c005da64 00000000 c005db8c ce3185c0 00000000 ce3185c0 ce318600 [ 550.778918] df60: c005d988 00000000 00000000 c004b3cc ffffffff 00000000 ffffffff ce318600 [ 550.794320] df80: 00000000 ce31df84 ce31df84 00000001 ce31df90 ce31df90 ce31dfac ce3185c0 [ 550.809711] dfa0: c004b310 00000000 00000000 c000e458 00000000 00000000 00000000 00000000 [ 550.825096] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 550.840488] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff [ 550.856058] [<c004b724>] (kthread_data) from [<c005dbb4>] (irq_thread_dtor+0x28/0xb8) [ 550.870911] [<c005dbb4>] (irq_thread_dtor) from [<c0048bdc>] (task_work_run+0x94/0xac) [ 550.885987] [<c0048bdc>] (task_work_run) from [<c0034fe0>] (do_exit+0x238/0x7fc) [ 550.900096] [<c0034fe0>] (do_exit) from [<c0011334>] (die+0x210/0x244) [ 550.912512] [<c0011334>] (die) from [<c000843c>] (do_DataAbort+0x8c/0x9c) [ 550.925418] [<c000843c>] (do_DataAbort) from [<c0011b18>] (__dabt_svc+0x38/0x60) [ 550.939230] Exception stack(0xce31dec8 to 0xce31df10) [ 550.948861] dec0: 00000057 0000002c fa02a000 fa02a02c ce312410 20000013 [ 550.964253] dee0: 00000004 00000008 00004000 00000216 00000010 00000065 00000000 ce31df10 [ 550.979557] df00: c005dc60 c035a25c 20000093 ffffffff [ 550.989397] [<c0011b18>] (__dabt_svc) from [<c035a25c>] (omap_i2c_isr_thread+0x3c/0x318) [ 551.004714] [<c035a25c>] (omap_i2c_isr_thread) from [<c005dc60>] (irq_thread_fn+0x1c/0x34) [ 551.020339] [<c005dc60>] (irq_thread_fn) from [<c005da64>] (irq_thread+0xdc/0x124) [ 551.034701] [<c005da64>] (irq_thread) from [<c004b3cc>] (kthread+0xbc/0xd8) [ 551.047910] [<c004b3cc>] (kthread) from [<c000e458>] (ret_from_fork+0x14/0x3c) [ 551.061544] Code: e5130018 e7e00150 e12fff1e e59031c8 (e5130010) [ 551.102642] ---[ end trace f862c5e48e2c78c3 ]--- [ 551.115103] Fixing recursive fault but reboot is needed! [ 552.836515] omap_i2c 4802a000.i2c: controller timed out [ 553.996452] omap_i2c 4802a000.i2c: controller timed out
