I've just build a new system for Beaglebone Black with Yocto, meta-ti and meta-qt5.
SGX drivers are loaded, Qt5 GLES2 examples are running fine with -platform eglfs.
The only problem is that video files are extremely slow in eglfs (under 1 fps). I've opened some .avi file in Media Player Example from Qt and ran it with GST_DEBUG=2 environment variable.
Here is the output:
xcb_connection_has_error() returned true
0:00:11.039354959 670 0x4be00 WARN pulse pulsesink.c:615:gst_pulseringbuffer_open_device:<audiosink-actual-sink-pulse> error: Failed to connect: Connection refused
0:00:11.071349168 670 0x4be00 WARN basesrc gstbasesrc.c:3489:gst_base_src_start_complete:<source> pad not activated yet
0:00:11.077873501 670 0x4be00 WARN basesrc gstbasesrc.c:3489:gst_base_src_start_complete:<source> pad not activated yet
0:00:11.159736793 670 0x1c6290 WARN alsa conf.c:4817:snd_config_expand: alsalib error: Unknown parameters {AES0 0x02 AES1 0x82 AES2 0x00 AES3 0x02}
0:00:11.160655293 670 0x1c6290 WARN alsa pcm.c:2450:snd_pcm_open_noupdate: alsalib error: Unknown PCM default:{AES0 0x02 AES1 0x82 AES2 0x00 AES3 0x02}
0:00:11.330111876 670 0xb1512ac0 ERROR h264parse gsth264parse.c:2444:gst_h264_parse_set_caps: video/x-h264 caps with codec_data but no stream-format=avc
0:00:15.296070960 670 0xb1705830 WARN basesink gstbasesink.c:2854:gst_base_sink_is_too_late:<qgstvideorenderersink0> warning: A lot of buffers are being dropped.
0:00:15.296832168 670 0xb1705830 WARN basesink gstbasesink.c:2854:gst_base_sink_is_too_late:<qgstvideorenderersink0> warning: There may be a timestamping problem, or this computer is too slow.
Warning: "A lot of buffers are being dropped."
Sound is playing fine. All GStreamer1.0 packages are installed. Any ideas how to fix tis issue or playing video is not supported in EGLFS?
gfx_check.sh output:
WSEGL settings
[default]
WindowSystem=libpvrDRMWSEGL.so
DisableHWTQTextureUpload=1
DefaultPixelFormat=RGB565
ARM CPU information
processor : 0
model name : ARMv7 Processor rev 2 (v7l)
BogoMIPS : 298.84
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc08
CPU revision : 2
Hardware : Generic AM33XX (Flattened Device Tree)
Revision : 0000
Serial : 0000000000000000
SGX driver information
Version SGX_DDK sgxddk MAIN@3699939 (release) omap_linux
System Version String: SGX revision = 125
Framebuffer settings
mode "1280x720"
geometry 1280 720 1280 720 16
timings 0 0 0 0 0 0 0
accel true
rgba 5/11,6/5,5/0,0/0
endmode
Frame buffer device information:
Name :
Address : 0x9e900000
Type : PACKED PIXELS
Visual : TRUECOLOR
XPanStep : 1
YPanStep : 1
YWrapStep : 0
LineLength : 2560
Accelerator : No
Rotation settings
0
Kernel Module information
Module Size Used by
bluetooth 328754 4
bc_example 7326 0
snd_usb_audio 139564 0
snd_hwdep 6043 1 snd_usb_audio
snd_usbmidi_lib 20376 1 snd_usb_audio
snd_rawmidi 22968 1 snd_usbmidi_lib
usbtouchscreen 5791 0
usbhid 20953 0
musb_dsps 8235 0
musb_hdrc 42682 1 musb_dsps
usbcore 194528 5 snd_usb_audio,musb_hdrc,usbtouchscreen,snd_usbmidi_lib,usbhid
pru_rproc 11646 0
pruss_intc 7163 1 pru_rproc
ecb 1909 0
sha256_generic 9503 0
hmac 2735 0
md5 1897 0
sha1_generic 2557 0
snd_soc_simple_card 7648 0
sha1_arm_neon 6261 0
sha1_arm 3862 1 sha1_arm_neon
wkup_m3_ipc 7651 0
pvrsrvkm 403200 1 bc_example
wkup_m3_rproc 3599 1
pruss 10892 1 pru_rproc
omap_aes_driver 19163 0
omap_sham 21513 0
remoteproc 26989 4 pruss,wkup_m3_rproc,pru_rproc,wkup_m3_ipc
virtio 7678 1 remoteproc
virtio_ring 12175 1 remoteproc
omap_rng 4482 0
rng_core 7685 1 omap_rng
musb_am335x 1426 0
omap_wdt 4634 0
Boot settings
console=ttyO0,115200n8 consoleblank=0 root=PARTUUID=ac45843e-02 rw rootfstype=ext4 rootwait
Linux Kernel version
Linux beaglebone 4.4.23-g4cd9d100e6 #2 PREEMPT Thu Oct 20 22:23:28 CEST 2016 armv7l armv7l armv7l GNU/Linux
Como
