because of an unknown issue with the "NIMU_BasicExample" (see ) I tried the same code (Source and Header Files) with the "NIMU_ICSS_BasicExample".
Here the situation is a bit different. Interestingly , the mentioned exception doesn't appear when I call connect().
But, now I get (6) as return value which says this is Error ENXIO. Referring to the Guide it says that I have to declare a special SocketOption, but I use StreamSocket Communication where this option should not be necessary. This is the result, when I create the respective task with a priority of "5".
Another very interesting thing is, that when I create the task with priority "4", then I don't get this return value. Additionally, I can't see any console information (system_printf is not activ?!).
However, the communication works with priority "4" and for me it would be interesting why?!
If I call the "TcpEchoServer" I get again this strange exception (as in the above mentioned post), when I come to the accept() in line 105.
This is also a bit confusing for me.
I will add the current source and main file for investigation.
/* * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include <stdio.h> #include <string.h> #include <stdlib.h> #include <debug.h> #include <xdc/std.h> #include <xdc/runtime/Error.h> #include <xdc/runtime/System.h> #include <xdc/runtime/knl/Cache.h> #include <xdc/runtime/Types.h> #include <xdc/runtime/Timestamp.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Task.h> #include <ti/sysbios/hal/Hwi.h> #include <ti/sysbios/hal/Core.h> #include <ti/ndk/inc/netmain.h> #include <ti/ndk/inc/stkmain.h> #include <ti/drv/pruss/soc/pruicss_v1.h> #include <ti/drv/icss_emac/icss_emacDrv.h> #include <ti/drv/uart/UART.h> #include <ti/drv/uart/UART_stdio.h> #include <ti/drv/icss_emac/test/src/tiemac_pruss_intc_mapping.h> #include <ti/drv/icss_emac/firmware/am335x/icss_emac_pru0_bin.h> #include <ti/drv/icss_emac/firmware/am335x/icss_emac_pru1_bin.h> #include <ti/transport/ndk/nimu_icss/nimu_icssEth.h> #include <ti/transport/ndk/nimu_icss/example/src/osdrv_ndkdeviceconfig.h> #include <ti/board/board.h> #include <ti/starterware/include/board.h> #include <ti/starterware/include/am335x/chipdb_defs.h> #include <ti/starterware/include/hw/soc_am335x.h> // Includes for socket communication #include "Socket.h" #define PRU0_FIRMWARE_NAME PRU0_FIRMWARE // name of the C struct in PRU header file #define PRU1_FIRMWARE_NAME PRU1_FIRMWARE // name of the C struct in PRU header file PRUICSS_Handle pruIcssHandle; ICSS_EmacHandle emachandle; ICSS_EmacHandle emachandle1; ICSS_EmacInitConfig* switchEmacCfg; ICSS_EmacInitConfig* switchEmacCfg1; uint8_t lclMac[6]; uint8_t lclMac1[6]; /************************************************************************/ /* constructors */ /************************************************************************/ void SOCCtrlGetPortMacAddr(uint32_t portNum, uint8_t *pMacAddr); uint8_t ICSSEmacDRVInit(ICSS_EmacHandle handle, uint8_t instance); extern ICSS_EmacBaseAddrCfgParams icss_EmacBaseAddrCfgParams[3]; void TaskSocketServer (UArg a0, UArg a1); void TaskSocketClient (UArg a0, UArg a1); /************************************************************************/ /* function definitions */ /************************************************************************/ /* * ======== stackInitHook ======== * hook called from ti_nkd_config_Global_stackThread() to run user setup code */ void stackInitHook(HANDLE hCfg) { CI_IPNET NA; CI_ROUTE RT; /* Static IP Address settings for interface 1 */ char *ipAddr = "192.168.2.3"; char *ipMask = "255.255.255.0"; char *ipGateway = "192.168.2.1"; /* Add IP address for interface 1 */ NA.IPAddr = inet_addr(ipAddr); NA.IPMask = inet_addr(ipMask); CfgAddEntry(hCfg, CFGTAG_IPNET, 1, 0, sizeof(CI_IPNET), (UINT8 *)&NA, 0 ); /* * Add gateway for interface 1 * --> I *think* the below should work but you may need different values ... */ bzero(&RT, sizeof(RT)); RT.IPDestAddr = 0; RT.IPDestMask = 0; RT.IPGateAddr = inet_addr(ipGateway); CfgAddEntry(hCfg, CFGTAG_ROUTE, 0, 0, sizeof(CI_ROUTE), (UINT8 *)&RT, 0); } /* PRUICSS objects */ PRUICSS_V1_Object prussObjects[2]; /* * ---task to initialize PRU--- */ Void taskPruss(UArg a0, UArg a1) { Uint8 firmwareLoad_done = FALSE; Uint8 count = 0; static Uint8 pktReceived = 0; while(GetNdkStatus(0)== NIMU_STAT_PROGRESS || GetNdkStatus(0)==NIMU_STAT_UNKNOWN) { Task_sleep(100); } PRUICSS_pruDisable(pruIcssHandle, ICSS_EMAC_PORT_1-1); PRUICSS_pruDisable(pruIcssHandle, ICSS_EMAC_PORT_2-1); if(PRUICSS_pruWriteMemory(pruIcssHandle,PRU_ICSS_IRAM(0) ,0, (uint32_t *) PRU0_FIRMWARE_NAME, sizeof(PRU0_FIRMWARE_NAME))) { if(PRUICSS_pruWriteMemory(pruIcssHandle,PRU_ICSS_IRAM(1) ,0, (uint32_t *) PRU1_FIRMWARE_NAME, sizeof(PRU1_FIRMWARE_NAME))) { firmwareLoad_done = TRUE; } } if( firmwareLoad_done) { PRUICSS_pruEnable(pruIcssHandle, ICSS_EMAC_PORT_1-1); PRUICSS_pruEnable(pruIcssHandle, ICSS_EMAC_PORT_2-1); } } /* * ======== main ======== */ int main() { Error_Block eb; Task_Params taskParams; int32_t ret; PRUICSS_Config *pruIcssCfg; Error_init(&eb); Board_initCfg cfg = BOARD_INIT_PLL| BOARD_INIT_MODULE_CLOCK | BOARD_INIT_DDR | BOARD_INIT_ICSS_PINMUX | BOARD_INIT_UART_STDIO | BOARD_INIT_ICSS_ETH_PHY; ret = Board_init(cfg); if (ret != BOARD_SOK) { UART_printf("main: Board_init returned error code: %d\n", ret); return -2; } ret = PRUICSS_socGetInitCfg(&pruIcssCfg); if (ret != PRUICSS_RETURN_SUCCESS) return (ret); pruIcssHandle = PRUICSS_create((PRUICSS_Config*) pruIcssCfg,PRUICCSS_INSTANCE_ONE); Task_Params_init(&taskParams); taskParams.priority = 15; taskParams.instance->name = "SwitchTask"; Task_create(taskPruss, &taskParams, &eb); /*Port I initializations*/ emachandle = (ICSS_EmacHandle)malloc(sizeof(ICSS_EmacConfig)); switchEmacCfg = (ICSS_EmacInitConfig*)malloc(sizeof(ICSS_EmacInitConfig)); if ((emachandle == NULL) || (switchEmacCfg == NULL)) { UART_printf("main: malloc returned null\n"); } switchEmacCfg->phyAddr[0]=BOARD_ICSS_EMAC_PORT0_PHY_ADDR; switchEmacCfg->portMask = ICSS_EMAC_MODE_MAC1; switchEmacCfg->ethPrioQueue = ICSS_EMAC_QUEUE1; switchEmacCfg->halfDuplexEnable = 1; switchEmacCfg->enableIntrPacing = ICSS_EMAC_ENABLE_PACING; switchEmacCfg->ICSS_EmacIntrPacingMode = ICSS_EMAC_INTR_PACING_MODE1; switchEmacCfg->pacingThreshold = 100; switchEmacCfg->learningEn = 0; switchEmacCfg->rxIntNum = 20; switchEmacCfg->linkIntNum=26; SOCCtrlGetPortMacAddr(1,lclMac); switchEmacCfg->macId = lclMac; ICSSEmacDRVInit(emachandle, 0); // ICSS_M instance 0 ((ICSS_EmacObject*)emachandle->object)->pruIcssHandle = pruIcssHandle; ((ICSS_EmacObject*)emachandle->object)->emacInitcfg = switchEmacCfg; /*PORT2 Initializations*/ emachandle1 = (ICSS_EmacHandle)malloc(sizeof(ICSS_EmacConfig)); switchEmacCfg1 = (ICSS_EmacInitConfig*)malloc(sizeof(ICSS_EmacInitConfig)); if ((emachandle1 == NULL) || (switchEmacCfg1 == NULL)) { UART_printf("main: malloc returned null\n"); } switchEmacCfg1->phyAddr[0]= BOARD_ICSS_EMAC_PORT1_PHY_ADDR; switchEmacCfg1->portMask = ICSS_EMAC_MODE_MAC2; switchEmacCfg1->ethPrioQueue = ICSS_EMAC_QUEUE3; switchEmacCfg1->halfDuplexEnable = 1; switchEmacCfg1->enableIntrPacing = ICSS_EMAC_DISABLE_PACING; switchEmacCfg1->pacingThreshold = 100; switchEmacCfg1->learningEn = 0; switchEmacCfg1->rxIntNum = 21; switchEmacCfg1->linkIntNum=27; SOCCtrlGetPortMacAddr(2,lclMac1); switchEmacCfg1->macId = lclMac1; ICSSEmacDRVInit(emachandle1,0); // ICSS_M instance 0 ((ICSS_EmacObject*)emachandle1->object)->pruIcssHandle = pruIcssHandle; ((ICSS_EmacObject*)emachandle1->object)->emacInitcfg = switchEmacCfg1; PRUICSS_IntcInitData pruss_intc_initdata = PRUSS_INTC_INITDATA; ICSS_EmacInit(emachandle,&pruss_intc_initdata,ICSS_EMAC_MODE_MAC1|ICSS_EMAC_MODE_DUALMAC); ICSS_EmacInit(emachandle1,&pruss_intc_initdata,ICSS_EMAC_MODE_MAC2|ICSS_EMAC_MODE_DUALMAC); Task_Params_init(&taskParams); taskParams.priority = 10; taskParams.instance->name = (char*)"port0_rxTaskFnc"; taskParams.stackSize = 0x1000; taskParams.arg0 = (UArg)emachandle; ((ICSS_EmacObject*)emachandle->object)->rxTaskHandle = Task_create(ICSS_EMacOsRxTaskFnc, &taskParams, NULL); if(((ICSS_EmacObject*)emachandle->object)->rxTaskHandle==NULL) { UART_printf("main: Task_create rturned NULL handle\n"); return -2; } Task_Params_init(&taskParams); taskParams.priority = 10; taskParams.instance->name = (char*)"port0_linkTaskFnc"; taskParams.stackSize = 0x1000; taskParams.arg0 = (UArg)emachandle; ((ICSS_EmacObject*)emachandle->object)->linkTaskHandle = Task_create((ti_sysbios_knl_Task_FuncPtr)ICSS_EMacOsLinkTaskFnc, &taskParams, NULL); if(((ICSS_EmacObject*)emachandle->object)->linkTaskHandle==NULL) { UART_printf("main: Task_create rturned NULL handle\n"); return -2; } Task_Params_init(&taskParams); taskParams.priority = 10; taskParams.instance->name = (char*)"port1_rxTaskFnc"; taskParams.stackSize = 0x1000; taskParams.arg0 = (UArg)emachandle1; ((ICSS_EmacObject*)emachandle1->object)->rxTaskHandle = Task_create(ICSS_EMacOsRxTaskFnc, &taskParams, NULL); if(((ICSS_EmacObject*)emachandle1->object)->rxTaskHandle==NULL) { UART_printf("main: Task_create rturned NULL handle\n"); return -2; } Task_Params_init(&taskParams); taskParams.priority = 10; taskParams.instance->name = (char*)"port1_linkTaskFnc"; taskParams.stackSize = 0x1000; taskParams.arg0 = (UArg)emachandle1; ((ICSS_EmacObject*)emachandle1->object)->linkTaskHandle = Task_create((ti_sysbios_knl_Task_FuncPtr)ICSS_EMacOsLinkTaskFnc, &taskParams, NULL); if(((ICSS_EmacObject*)emachandle1->object)->linkTaskHandle==NULL) { UART_printf("main: Task_create rturned NULL handle\n"); return -2; } if(OSDRV_addNetifEntry((NIMUInitFn)&EmacInit,emachandle) == 0) BIOS_exit(0); if(OSDRV_addNetifEntry((NIMUInitFn)&EmacInit,emachandle1) == 0) BIOS_exit(0); /* // TaskSocketServer // Create a Task with priority 5; // Task priority must be within the configured range of NDK priorities // and lower priority than kernel priority NDK tasks // Task_Handle hMyTaskServer; Error_init(&eb); Task_Params_init(&taskParams); taskParams.priority = 5; taskParams.instance->name = (char*)"TCP_Socket_Server"; taskParams.stackSize = 4096; hMyTaskServer = Task_create (TaskSocketServer , &taskParams, &eb); if (hMyTaskServer == NULL) { UART_printf("main: Task_create TaskSocketServer failed\n"); } */ // TaskSockerClient // Create a Task with priority 5; // Task priority must be within the configured range of NDK priorities // and lower priority than kernel priority NDK tasks // Task_Handle hMyTaskClient; Error_init(&eb); Task_Params_init(&taskParams); taskParams.priority = 4; taskParams.stackSize = 4096; taskParams.instance->name = (char*)"TCP_Socket_Client"; hMyTaskClient = Task_create (TaskSocketClient , &taskParams, &eb); if (hMyTaskClient == NULL) { UART_printf("main: Task_create TaskSocketClient failed\n"); } System_printf("\n<<< Starting BIOS >>>\n"); BIOS_start(); return(0); } #define CONTROL_MAC_ID_LO(n) (0x630 + (n * 8)) #define CONTROL_MAC_ID_HI(n) (0x634 + (n * 8)) void SOCCtrlGetPortMacAddr(uint32_t portNum, uint8_t *pMacAddr) { uint32_t slavePortNum = portNum - 1U; pMacAddr[5U] = (HW_RD_REG32(SOC_CONTROL_REGS + CONTROL_MAC_ID_LO(slavePortNum)) >> 8U) & 0xFFU; pMacAddr[4U] = (HW_RD_REG32(SOC_CONTROL_REGS + CONTROL_MAC_ID_LO(slavePortNum))) & 0xFF; pMacAddr[3U] = (HW_RD_REG32(SOC_CONTROL_REGS + CONTROL_MAC_ID_HI(slavePortNum)) >> 24U) & 0xFFU; pMacAddr[2U] = (HW_RD_REG32(SOC_CONTROL_REGS + CONTROL_MAC_ID_HI(slavePortNum)) >> 16U) & 0xFFU; pMacAddr[1U] = (HW_RD_REG32(SOC_CONTROL_REGS + CONTROL_MAC_ID_HI(slavePortNum)) >> 8U) & 0xFFU; pMacAddr[0U] = (HW_RD_REG32(SOC_CONTROL_REGS + CONTROL_MAC_ID_HI(slavePortNum))) & 0xFFU; } uint8_t ICSSEmacDRVInit(ICSS_EmacHandle handle, uint8_t instance) { /* LLD attributes mallocs */ handle->object = (ICSS_EmacObject*)malloc(sizeof(ICSS_EmacObject)); handle->hwAttrs= (ICSS_EmacHwAttrs*)malloc(sizeof(ICSS_EmacHwAttrs)); /* Callback mallocs */ ICSS_EmacCallBackObject* callBackObj = (ICSS_EmacCallBackObject*)malloc(sizeof(ICSS_EmacCallBackObject)); callBackObj->learningExCallBack=(ICSS_EmacCallBackConfig*)malloc(sizeof(ICSS_EmacCallBackConfig)); callBackObj->rxRTCallBack=(ICSS_EmacCallBackConfig*)malloc(sizeof(ICSS_EmacCallBackConfig)); callBackObj->rxCallBack=(ICSS_EmacCallBackConfig*)malloc(sizeof(ICSS_EmacCallBackConfig)); callBackObj->txCallBack=(ICSS_EmacCallBackConfig*)malloc(sizeof(ICSS_EmacCallBackConfig)); ((ICSS_EmacObject*)handle->object)->callBackHandle = callBackObj; /*Allocate memory for learning*/ ((ICSS_EmacObject*)handle->object)->macTablePtr = (HashTable_t*)malloc(NUM_PORTS * sizeof(HashTable_t)); /*Allocate memory for PRU Statistics*/ ((ICSS_EmacObject*)handle->object)->pruStat = (ICSS_EmacPruStatistics_t*)malloc(NUM_PORTS * sizeof(ICSS_EmacPruStatistics_t)); /*Allocate memory for Host Statistics*/ ((ICSS_EmacObject*)handle->object)->hostStat = (ICSS_EmacHostStatistics_t*)malloc(NUM_PORTS * sizeof(ICSS_EmacHostStatistics_t)); /*Allocate memory for Storm Prevention*/ ((ICSS_EmacObject*)handle->object)->stormPrevPtr = (stormPrevention_t*)malloc(NUM_PORTS * sizeof(stormPrevention_t)); /* Base address initialization */ if(NULL == ((ICSS_EmacHwAttrs*)handle->hwAttrs)->emacBaseAddrCfg) { ((ICSS_EmacHwAttrs*)handle->hwAttrs)->emacBaseAddrCfg = (ICSS_EmacBaseAddressHandle_T)malloc(sizeof(ICSS_EmacBaseAddrCfgParams)); } ICSS_EmacBaseAddressHandle_T emacBaseAddr = ((ICSS_EmacHwAttrs*)handle->hwAttrs)->emacBaseAddrCfg; emacBaseAddr->dataRam0BaseAddr = icss_EmacBaseAddrCfgParams[instance].dataRam0BaseAddr; emacBaseAddr->dataRam1BaseAddr = icss_EmacBaseAddrCfgParams[instance].dataRam1BaseAddr; /* Restricting l3OcmcBaseAddr to 0x40xxxx00. * This is done because L3 OCMC Base Address must be 256 byte aligned and to support OCMC memory usage for Linux Power Management. */ emacBaseAddr->l3OcmcBaseAddr = (((icss_EmacBaseAddrCfgParams[instance].l3OcmcBaseAddr)&0xFFFF00)|0x40000000); emacBaseAddr->prussCfgRegs = icss_EmacBaseAddrCfgParams[instance].prussCfgRegs; emacBaseAddr->prussIepRegs = icss_EmacBaseAddrCfgParams[instance].prussIepRegs; emacBaseAddr->prussIntcRegs = icss_EmacBaseAddrCfgParams[instance].prussIntcRegs; emacBaseAddr->prussMiiMdioRegs = icss_EmacBaseAddrCfgParams[instance].prussMiiMdioRegs; emacBaseAddr->prussMiiRtCfgRegsBaseAddr = icss_EmacBaseAddrCfgParams[instance].prussMiiRtCfgRegsBaseAddr; emacBaseAddr->prussPru0CtrlRegs = icss_EmacBaseAddrCfgParams[instance].prussPru0CtrlRegs; emacBaseAddr->prussPru1CtrlRegs = icss_EmacBaseAddrCfgParams[instance].prussPru1CtrlRegs; emacBaseAddr->sharedDataRamBaseAddr = icss_EmacBaseAddrCfgParams[instance].sharedDataRamBaseAddr; return 0; } /** * \name TaskSocketServer * \Task to call the socket function in SocketServer.c * \param a0 * \param a1 * \return none * */ void TaskSocketServer (UArg a0, UArg a1) { System_printf("<< enter TaskSocketServer() >>\n"); // define IP-Addr. IPN IPAddrExt; IPN IPAddrLocal; IPAddrExt = inet_addr("192.168.1.10"); //PC IPAddrLocal = inet_addr("192.168.1.4"); //ICEV2 board // call function EchoTcpServer(IPAddrLocal, IPAddrExt); System_printf("<< closing TaskSocketServer() >>\n"); Task_exit(); } /** * \name TaskSocketClient * \Task to call the socket function in SocketClient.c * \param a0 * \param a1 * \return none * */ void TaskSocketClient (UArg a0, UArg a1) { System_printf("<< enter TaskSocketClient() >>\n"); // define IP-Addr. IPN IPAddrExt; IPN IPAddrLocal; IPAddrExt = inet_addr("192.168.1.10"); //PC IPAddrLocal = inet_addr("192.168.1.4"); //ICEV2 board // call function EchoTcpClient(IPAddrLocal, IPAddrExt); System_printf("<< closing TaskSocketClient() >>\n"); Task_exit(); }
/* * Socket.c * * Created on: 17. Mai 2017 * Author: PirklbauerMa */ /* ========================================================================== */ /* Includes */ /* ========================================================================== */ #include <xdc/std.h> #include <xdc/runtime/System.h> #include <ti/sysbios/knl/Task.h> #include <ti/ndk/inc/bsd/sys/socket.h> #include "ti/ndk/inc/bsd/socketndk.h" // The following header should not be included referring to the NDK Reference Guide // No header of the ti/ndk/inc should be included /* #include "ti/ndk/inc/socketndk.h" #include "ti/ndk//inc/os/osif.h" #include "ti/ndk/inc/usertype.h" */ /* ========================================================================== */ /* Constructors */ /* ========================================================================== */ void EchoTcpClient( IPN IPAddrLocal, IPN IPAddrExt ) { SOCKET s = INVALID_SOCKET; struct sockaddr_in sinExt; struct sockaddr_in sinLocal; int i, received, sent, error, val, buffersize ,ret = 0; char *pBuf = 0; char *pBufTest = 0; struct timeval timeout; buffersize = 2048; System_printf("\n== Start TCP Echo Client Test ==\n"); // Allocate the file descriptor environment for this Task ret = fdOpenSession( (HANDLE)Task_self() ); if (ret = 0){ System_printf("failed to create file descriptor session!"); goto leave; } else if (ret = 1) { System_printf("= File Descriptor session opened successfully =\n");} // Create test socket s = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP); // returns a file descriptor representing the socket if( s == INVALID_SOCKET ){ // INVALID_SOCKET stands for -1 System_printf("failed socket create (%d)\n",fdError()); goto leave; } else{ System_printf("= Socket created successfully =\n");} // Prepare address for connect bzero( &sinExt, sizeof(struct sockaddr_in) ); sinExt.sin_family = AF_INET; sinExt.sin_addr.s_addr = IPAddrExt; // Var.2 to set IP Addr. PC sinExt.sin_port = htons(54216); // Port PC //inet_aton("192.168.1.10", &sinExt.sin_addr.s_addr); // Var.1 to set IP Addr. PC // Configure our Tx and Rx timeout to be 5 seconds timeout.tv_sec = 5; timeout.tv_usec = 0; // Set send timeout ret = setsockopt( s, SOL_SOCKET, SO_SNDTIMEO, &timeout, sizeof( timeout ) ); if (ret < 0 ){ System_printf("failed set socket option (%d)\n",fdError()); goto leave; } else if (ret = 0) { System_printf("= Socket Option set successfully =\n");} // Set receive timeout ret = setsockopt( s, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof( timeout ) ); if (ret < 0 ){ System_printf("failed set socket option (%d)\n",fdError()); goto leave; } else if (ret = 0) { System_printf("= Socket Option set successfully =\n");} // Connect socket - &sinExt is the pointer to the serv_addr ret = connect( s , (PSA) &sinExt, sizeof(sinExt)); if( ret < 0 ){ error = fdError(); System_printf("\nfailed connect (%d)\n", error); goto leave; } else if (ret = 0) { System_printf("= Socket connected successfully =\n");} // Allocate a working buffer and testing buffer if( !(pBuf = malloc( buffersize )) ) { System_printf("failed buffer allocation\n"); goto leave; } if( !(pBufTest = malloc( buffersize )) ) { System_printf("failed test buffer allocation\n"); goto leave; } // Fill buffer with a test pattern for(i=0; i<buffersize; i++) { *(pBuf+i) = (char)i; } // // Send the buffer - return is the amount of successfully sent bytes sent = send( s, pBuf, buffersize, 0 ); if( ret < 0 ) { System_printf("send failed (%d)\n",fdError()); goto leave; } // Try and receive the test pattern back - returns the number of bytes received .. data is in Buffer in pBufTest received = recv( s, pBufTest, buffersize, MSG_WAITALL ); if( received < 0 ) { System_printf("recv failed (%d)\n",fdError()); goto leave; } // Verify reception size and pattern if( sent != received ) { System_printf("received %d (not %d) bytes\n",received, sent); goto leave; } for(i=0; i<buffersize; i++) if( *(pBufTest+i) != (char)i ) { System_printf("verify failed at byte %d\n",i); break; } // If here, the test passed if( received==sent ) System_printf("passed\n"); leave: if( pBuf ) free( pBuf ); if( pBufTest ) free( pBufTest ); if( s != INVALID_SOCKET ) fdClose( s ); System_printf("== End TCP Echo Client Test ==\n\n"); // Free the file descriptor environment for this Task fdCloseSession( (HANDLE)Task_self() ); }
/* * Socket.c * * Created on: 17. Mai 2017 * Author: PirklbauerMa */ /* ========================================================================== */ /* Includes */ /* ========================================================================== */ #include <xdc/std.h> #include <xdc/runtime/System.h> #include <ti/sysbios/knl/Task.h> #include <ti/ndk/inc/bsd/sys/socket.h> #include "ti/ndk/inc/bsd/socketndk.h" // The following header should not be included referring to the NDK Reference Guide // No header of the ti/ndk/inc should be included /* #include "ti/ndk/inc/socketndk.h" #include "ti/ndk//inc/os/osif.h" #include "ti/ndk/inc/usertype.h" */ /* ========================================================================== */ /* Constructors */ /* ========================================================================== */ void EchoTcpServer( IPN IPAddrLocal, IPN IPAddrExt ) { SOCKET s = INVALID_SOCKET; struct sockaddr sinExt; struct sockaddr_in sinLocal; int i, error, val, ret = 0; char *pBuf = 0; struct timeval timeout; char test[4096]; // Allocate the file descriptor environment for this Task ret = fdOpenSession( (HANDLE)Task_self() ); if (ret = 0) { System_printf("failed to create file descriptor session!"); goto leave; } System_printf("\n== Start TCP Echo Server Test ==\n"); // Create test socket s = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP); // returns a file descriptor representing the socket if( s == INVALID_SOCKET ) // INVALID_SOCKET stands for -1 { System_printf("failed socket create (%d)\n",fdError()); goto leave; } // Prepare address for connect //bzero( &sinExt, sizeof(struct sockaddr_in) ); //sinExt.sin_family = AF_INET; //inet_aton("192.168.1.10", &sinExt.sin_addr.s_addr); // Var.1 to set IP Addr. PC //sinExt.sin_addr.s_addr = IPAddrExt; // Var.2 to set IP Addr. PC //sinExt.sin_port = htons(54216); // Port PC // Prepare address for listening bzero( &sinLocal, sizeof(struct sockaddr_in) ); sinLocal.sin_family = AF_INET; //inet_aton("192.168.1.4", &sinLocal.sin_addr.s_addr); // Var.1 to set IP Addr. ICEV2 sinLocal.sin_addr.s_addr = IPAddrLocal; // Var.2 to set IP Addr. ICEV2 sinLocal.sin_port = htons(23); // Port ICEV2 //sinExt.sin_port = htons(7); // Port ICEV2 // Configure our Tx and Rx timeout to be 5 seconds timeout.tv_sec = 5; timeout.tv_usec = 0; // Set send timeout ret = setsockopt( s, SOL_SOCKET, SO_SNDTIMEO, &timeout, sizeof( timeout ) ); if (ret < 0 ) { System_printf("failed set socket option (%d)\n",fdError()); goto leave; } // Set receive timeout ret = setsockopt( s, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof( timeout ) ); if (ret < 0 ) { System_printf("failed set socket option (%d)\n",fdError()); goto leave; } // [PIM 20170522] Test bind() function for a port ret = bind( s, (PSA) &sinLocal, sizeof(sinLocal)); if( ret < 0 ) { System_printf("failed to bind port (%d)\n",fdError()); goto leave; } // [PIM 20170522] Test listen() function for a port ret = listen( s, 10); if( ret < 0 ) { System_printf("failed to listen (%d)\n",fdError()); goto leave; } // [PIM 20170522] Test accept() function for a port ret = accept( s , &sinExt, sizeof(sinExt)); // writes address from connecting entity in sinExt if( ret < 0 ) { System_printf("failed to accept (%d)\n",fdError()); goto leave; } goto leave; leave: if( pBuf ) free( pBuf ); if( s != INVALID_SOCKET ) fdClose( s ); System_printf("== End TCP Echo Server Test ==\n\n"); // Free the file descriptor environment for this Task fdCloseSession( (HANDLE)Task_self() ); }
