Linux/PROCESSOR-SDK-AM437X: GPIO0_22 pinmux
Part Number: PROCESSOR-SDK-AM437X
Other Parts Discussed in Thread: AM4372, TLV320AIC3106, ADS7846, TPS65218, TPS63031
Tool/software: Linux
Hi support,
I hope to remove the GPIO0_22(spi2_clk) pin mux iniatialize from the am437x-gp-evm.dts file.  Could you please give me some help?
I set the GPIO0_22 output is high in u-boot and I hope this pin will keep output high until init my application startup in rcS file.  But I found this pin will become low when booting the linux kernel. I guess this pin is initialized by tscadc module, because it use the spi2 as the data interface. I don't know how to remove this pin mux(GPIO0_22) setting from the dts file, please give me some help.
  • The software team have been notified. They will respond here.
  • Hello xin,
    Please, find the 0x260 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) line in unused_pins: unused_pins node. You can remove this line or change it to 0x260 (PIN_OUTPUT_PULLUP | MUX_MODE9). You can use the PinMux Tool or refer to the TRM to check the address offsets.
    Kemal
  • Hi Kemal,
    there is no other setting for 0x260 except in "user_leds_default" section. It is strange that the GPIO0_22 become low when booting line kernel even if I set it as high in u-boot.
    Here is my dts file:
    /* AM437x GP EVM */
    /dts-v1/;
    #include "am4372.dtsi"
    #include <dt-bindings/pinctrl/am43xx.h>
    #include <dt-bindings/pwm/pwm.h>
    #include <dt-bindings/interrupt-controller/irq.h>
    #include <dt-bindings/input/input.h>
    model = "TI AM437x GP EVM";
    compatible = "ti,am437x-gp-evm","ti,am4372","ti,am43";
    aliases {
    display0 = &lcd0;
    serial1 = &uart1;
    serial2 = &uart2;
    serial3 = &uart3;
    serial4 = &uart4;
    serial5 = &uart5;
    evm_v3_3d: fixedregulator-v3_3d {
    compatible = "regulator-fixed";
    regulator-name = "evm_v3_3d";
    regulator-min-microvolt = <3300000>;
    regulator-max-microvolt = <3300000>;
    enable-active-high;
    #if 0
    vtt_fixed: fixedregulator-vtt {
    regulator-name = "vtt_fixed";
    regulator-min-microvolt = <1500000>;
    regulator-max-microvolt = <1500000>;
    regulator-always-on;
    regulator-boot-on;
    enable-active-high;
    gpio = <&gpio5 7 GPIO_ACTIVE_HIGH>;
    #endif
    vmmcwl_fixed: fixedregulator-mmcwl {
    regulator-name = "vmmcwl_fixed";
    regulator-min-microvolt = <1800000>;
    regulator-max-microvolt = <1800000>;
    gpio = <&gpio1 20 GPIO_ACTIVE_HIGH>;
    startup-delay-us = <70000>;
    enable-active-high;
    ads7846reg: ads7846-reg {
    regulator-name = "ads7846-reg";
    lcd_bl: backlight {
    compatible = "pwm-backlight";
    pwms = <&ecap0 0 50000 0>;
    brightness-levels = <0 8 16 32 64 96 128 160 192 224 255>;
    default-brightness-level = <6>;
    #if 0
    matrix_keypad: matrix_keypad@0 {
    compatible = "gpio-matrix-keypad";
    debounce-delay-ms = <5>;
    col-scan-delay-us = <2>;
    pinctrl-names = "default", "sleep";
    pinctrl-0 = <&matrix_keypad_default>;
    pinctrl-1 = <&matrix_keypad_sleep>;
    linux,wakeup;
    row-gpios = <&gpio0 3 GPIO_ACTIVE_HIGH /* Bank0, pin3 */
    &gpio4 3 GPIO_ACTIVE_HIGH /* Bank4, pin3 */
    &gpio4 2 GPIO_ACTIVE_HIGH>; /* Bank4, pin2 */
    col-gpios = <&gpio3 19 GPIO_ACTIVE_HIGH /* Bank3, pin19 */
    &gpio3 20 GPIO_ACTIVE_HIGH>; /* Bank3, pin20 */
    linux,keymap = <0x00000201 /* P1 */
    0x00010202 /* P2 */
    0x01000067 /* UP */
    0x0101006a /* RIGHT */
    0x02000069 /* LEFT */
    0x0201006c>; /* DOWN */
    #endif
    lcd0: display {
    compatible = "Innolux,Innolux_ZJ050NA-08C", "panel-dpi";
    label = "lcd";
    panel-timing {
    clock-frequency = <30000000>;
    hactive = <800>;
    vactive = <480>;
    hfront-porch = <40>;
    hback-porch = <88>;
    hsync-len = <1>;
    vback-porch = <32>;
    vfront-porch = <13>;
    vsync-len = <1>;
    hsync-active = <0>;
    vsync-active = <0>;
    de-active = <1>;
    pixelclk-active = <1>;
    port {
    lcd_in: endpoint {
    remote-endpoint = <&dpi_out>;
    kim {
    compatible = "kim";
    nshutdown_gpio = <48>; /* Bank1, pin16 */
    dev_name = "/dev/ttyS3";
    flow_cntrl = <1>;
    baud_rate = <3000000>;
    btwilink {
    compatible = "btwilink";
    sound0: sound@0 {
    compatible = "simple-audio-card";
    simple-audio-card,name = "AM437x-GP-EVM";
    simple-audio-card,widgets =
    "Microphone", "Microphone Jack",
    "Line", "Line In Jack",
    "Line", "Line Out Jack";
    simple-audio-card,routing =
    "LINE1L", "Line In Jack",
    "LINE1R", "Line In Jack",
    "MIC3L", "Microphone Jack",
    "MIC3R", "Microphone Jack",
    "Microphone Jack", "Mic Bias",
    "Line Out Jack", "LLOUT",
    "Line Out Jack", "RLOUT";
    simple-audio-card,format = "dsp_b";
    simple-audio-card,bitclock-master = <&link0_codec>;
    simple-audio-card,frame-master = <&link0_codec>;
    simple-audio-card,bitclock-inversion;
    simple-audio-card,cpu {
    sound-dai = <&mcasp1>;
    system-clock-frequency = <24000000>;
    link0_codec: simple-audio-card,codec {
    sound-dai = <&tlv320aic3106>;
    audio_mstrclk: mclk_osc {
    compatible = "fixed-clock";
    #clock-cells = <0>;
    leds {
    pinctrl-0 = <&user_leds_default>;
    pinctrl-1 = <&user_leds_sleep>;
    compatible = "gpio-leds";
    #if 0
    gpio_keys: user_keys@0 {
    compatible = "gpio-keys";
    #address-cells = <1>;
    #size-cells = <0>;
    autorepeat;
    pinctrl-names = "default";
    pinctrl-0 = <&user_keys_default>;
    button@0 {
    label = "user-key0";
    linux,code = <KEY_PROG1>;
    gpios = <&gpio3 7 GPIO_ACTIVE_LOW>;
    gpio-key,wakeup;
    button@1 {
    label = "user-key1";
    linux,code = <KEY_PROG2>;
    gpios = <&gpio3 8 GPIO_ACTIVE_LOW>;
    gpio-key,wakeup;
    #endif
    &am43xx_pinmux {
    pinctrl-0 = <&clkout2_pin>;
    ddr3_vtt_toggle_default: ddr_vtt_toggle_default {
    pinctrl-single,pins = <
    0x25C (DS0_PULL_UP_DOWN_EN | PIN_OUTPUT_PULLUP | DS0_FORCE_OFF_MODE | MUX_MODE7) /* spi0_cs0.gpio5_7 */
    i2c0_pins: i2c0_pins {
    0x188 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */
    0x18c (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */
    i2c1_pins_default: i2c1_pins_default {
    0x15c (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2) /* spi0_cs0.i2c1_scl */
    0x158 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2) /* spi0_d1.i2c1_sda */
    i2c1_pins_sleep: i2c1_pins_sleep {
    0x15c (PIN_INPUT_PULLUP | MUX_MODE7)
    0x158 (PIN_INPUT_PULLUP | MUX_MODE7)
    mmc1_pins: pinmux_mmc1_pins {
    0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */
    0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
    0x0f0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
    0x0f4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
    0x0f8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
    0x0fc (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
    0x160 (PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */
    mmc1_sleep_pins: pinmux_mmc1_sleep_pins {
    0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x104 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x0f0 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x0f4 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x0f8 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x0fc (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x160 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    emmc_pins_default: emmc_pins_default {
    0x00 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */
    0x04 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */
    0x08 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */
    0x0c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */
    0x10 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */
    0x14 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */
    0x18 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */
    0x1c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */
    0x80 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */
    0x84 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */
    emmc_pins_sleep: emmc_pins_sleep {
    0x00 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpio1_0 */
    0x04 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpio1_1 */
    0x08 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpio1_2 */
    0x0c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpio1_3 */
    0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */
    0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */
    0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */
    0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */
    0x80 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn1.gpio1_30 */
    0x84 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn2.gpio1_31 */
    ecap0_pins_default: backlight_pins_default {
    0x164 MUX_MODE0 /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out MODE0 */
    ecap0_pins_sleep: backlight_pins_sleep {
    0x164 MUX_MODE0
    cpsw_default: cpsw_default {
    /* Slave 1 */
    0x114 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txen.rgmii1_txen */
    0x118 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxdv.rgmii1_rxctl */
    0x11c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_txd3 */
    0x120 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_txd2 */
    0x124 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_txd1 */
    0x128 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_txd0 */
    0x12c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txclk.rmii1_tclk */
    0x130 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxclk.rmii1_rclk */
    0x134 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rxd3 */
    0x138 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rxd2 */
    0x13c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rxd1 */
    0x140 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rxd0 */
    /* Slave 2 */
    0x40 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a0.rgmii2_tctl */
    0x44 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a1.rgmii2_rctl */
    0x48 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a2.rgmii2_td3 */
    0x4c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a3.rgmii2_td2 */
    0x50 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a4.rgmii2_td1 */
    0x54 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a5.rgmii2_td0 */
    0x58 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a6.rgmii2_tclk */
    0x5c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a7.rgmii2_rclk */
    0x60 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a8.rgmii2_rd3 */
    0x64 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a9.rgmii2_rd2 */
    0x68 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a10.rgmii2_rd1 */
    0x6c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a11.rgmii2_rd0 */
    cpsw_sleep: cpsw_sleep {
    /* Slave 1 reset value */
    0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x134 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x138 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x13c (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x140 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    /* Slave 2 reset value*/
    0x40 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x50 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x5c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x60 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x6c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    davinci_mdio_default: davinci_mdio_default {
    /* MDIO */
    0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */
    0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */
    davinci_mdio_sleep: davinci_mdio_sleep {
    /* MDIO reset value */
    0x148 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x14c (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    nand_flash_x8_default: nand_flash_x8_default {
    0x0 (PIN_INPUT | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */
    0x4 (PIN_INPUT | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */
    0x8 (PIN_INPUT | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */
    0xc (PIN_INPUT | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */
    0x10 (PIN_INPUT | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */
    0x14 (PIN_INPUT | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */
    0x18 (PIN_INPUT | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */
    0x1c (PIN_INPUT | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */
    0x70 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */
    0x74 (PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpmc_wpn */
    0x7c (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */
    0x90 (PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */
    0x94 (PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */
    0x98 (PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */
    0x9c (PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */
    nand_flash_x8_sleep: nand_flash_x8_sleep {
    0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpmc_ad0 */
    0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpmc_ad1 */
    0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpmc_ad2 */
    0xc (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpmc_ad3 */
    0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpmc_ad4 */
    0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpmc_ad5 */
    0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpmc_ad6 */
    0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpmc_ad7 */
    0x70 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_wait0.gpmc_wait0 */
    0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wpn.gpmc_wpn */
    0x7c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_csn0.gpmc_csn0 */
    0x90 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_advn_ale.gpmc_advn_ale */
    0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_oen_ren.gpmc_oen_ren */
    0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wen.gpmc_wen */
    0x9c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_be0n_cle.gpmc_be0n_cle */
    dss_pinctrl_default: dss_pinctrl_default {
    0x020 (PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 8 -> DSS DATA 23 */
    0x024 (PIN_OUTPUT_PULLUP | MUX_MODE1)
    0x028 (PIN_OUTPUT_PULLUP | MUX_MODE1)
    0x02c (PIN_OUTPUT_PULLUP | MUX_MODE1)
    0x030 (PIN_OUTPUT_PULLUP | MUX_MODE1)
    0x034 (PIN_OUTPUT_PULLUP | MUX_MODE1)
    0x038 (PIN_OUTPUT_PULLUP | MUX_MODE1)
    0x03c (PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 15 -> DSS DATA 16 */
    0x0a0 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 0 */
    0x0a4 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0a8 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0ac (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0b0 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0b4 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0b8 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0bc (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0c0 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0c4 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0c8 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0cc (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0d0 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0d4 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0d8 (PIN_OUTPUT_PULLUP | MUX_MODE0)
    0x0dc (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 15 */
    0x0e0 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS VSYNC */
    0x0e4 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS HSYNC */
    0x0e8 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS PCLK */
    0x0ec (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS AC BIAS EN */
    dss_pinctrl_sleep: dss_pinctrl_sleep {
    0x020 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x024 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x028 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x02C (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x030 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x034 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x038 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x03C (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0A0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0A4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0A8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0AC (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0B0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0B4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0B8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0BC (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0C0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0C4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0C8 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0CC (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0D0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0D4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0D8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7)
    0x0DC (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0E0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0E4 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0E8 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x0EC (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    lcd_pins: lcd_pins {
    /* GPIO 5_8 to select LCD / HDMI */
    /*0x238 (PIN_OUTPUT_PULLUP | MUX_MODE7)*/
    mmc3_pins_default: pinmux_mmc3_pins_default {
    0x8c (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_clk.mmc2_clk */
    0x88 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_csn3.mmc2_cmd */
    0x44 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a1.mmc2_dat0 */
    0x48 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a2.mmc2_dat1 */
    0x4c (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a3.mmc2_dat2 */
    0x78 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_be1n.mmc2_dat3 */
    mmc3_pins_sleep: pinmux_mmc3_pins_sleep {
    0x8c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_clk.mmc2_clk */
    0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn3.mmc2_cmd */
    0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a1.mmc2_dat0 */
    0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a2.mmc2_dat1 */
    0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a3.mmc2_dat2 */
    0x78 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_be1n.mmc2_dat3 */
    wlan_pins_default: pinmux_wlan_pins_default {
    0x50 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a4.gpio1_20 WL_EN */
    0x5c (PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7) /* gpmc_a7.gpio1_23 WL_IRQ*/
    0x40 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a0.gpio1_16 BT_EN*/
    wlan_pins_sleep: pinmux_wlan_pins_sleep {
    0x40 (PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_a0.gpio1_16 BT_EN*/
    uart1_pins: uart1_pins {
    0x180 (PIN_INPUT | MUX_MODE0) /* uart1_rxd.uart1_rxd */
    0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */
    uart2_pins: uart2_pins {
    0x10c (PIN_INPUT | MUX_MODE6) /* mii1_crs.uart2_rxd */
    0x110 (PIN_OUTPUT_PULLDOWN | MUX_MODE6) /* mii1_rx_er.uart2_txd */
    uart3_pins: uart3_pins {
    0x228 (PIN_INPUT | MUX_MODE0) /* uart3_rxd.uart3_rxd */
    0x22c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_txd.uart3_txd */
    uart4_pins: uart4_pins {
    0x168 (PIN_INPUT | MUX_MODE1) /* uart0_ctsn.uart4_rxd */
    0x16c (PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* uart0_rtsn.uart4_txd */
    uart5_pins: uart5_pins {
    0x108 (PIN_INPUT | MUX_MODE3) /* mii1_col.uart5_rxd */
    0x144 (PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* rmii1_refclk.uart5_txd */
    mcasp1_pins: mcasp1_pins {
    0x108 (PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 */
    0x10c (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_crs.mcasp1_aclkx */
    0x110 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rxerr.mcasp1_fsx */
    0x144 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 */
    mcasp1_sleep_pins: mcasp1_sleep_pins {
    0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x10c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x110 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x144 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    vpfe0_pins_default: vpfe0_pins_default {
    0x1B0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_hd mode 0*/
    0x1B4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_vd mode 0*/
    0x1C0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_pclk mode 0*/
    0x1C8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data9 mode 0*/
    0x208 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data0 mode 0*/
    0x20C (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data1 mode 0*/
    0x210 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data2 mode 0*/
    0x214 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data3 mode 0*/
    0x218 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data4 mode 0*/
    0x21C (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data5 mode 0*/
    0x220 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data6 mode 0*/
    0x224 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data7 mode 0*/
    vpfe0_pins_sleep: vpfe0_pins_sleep {
    0x1B0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_hd mode 0*/
    0x1B4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_vd mode 0*/
    0x1C0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_pclk mode 0*/
    0x1C8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data9 mode 0*/
    0x208 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data0 mode 0*/
    0x20C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data1 mode 0*/
    0x210 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data2 mode 0*/
    0x214 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data3 mode 0*/
    0x218 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data4 mode 0*/
    0x21C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data5 mode 0*/
    0x220 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data6 mode 0*/
    0x224 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data7 mode 0*/
    vpfe1_pins_default: vpfe1_pins_default {
    0x1CC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data9 mode 0*/
    0x1D0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data8 mode 0*/
    0x1D4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_hd mode 0*/
    0x1D8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_vd mode 0*/
    0x1DC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_pclk mode 0*/
    0x1E8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data0 mode 0*/
    0x1EC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data1 mode 0*/
    0x1F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data2 mode 0*/
    0x1F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data3 mode 0*/
    0x1F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data4 mode 0*/
    0x1FC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data5 mode 0*/
    0x200 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data6 mode 0*/
    0x204 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data7 mode 0*/
    vpfe1_pins_sleep: vpfe1_pins_sleep {
    0x1CC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data9 mode 0*/
    0x1D0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data8 mode 0*/
    0x1D4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_hd mode 0*/
    0x1D8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_vd mode 0*/
    0x1DC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_pclk mode 0*/
    0x1E8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data0 mode 0*/
    0x1EC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data1 mode 0*/
    0x1F0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data2 mode 0*/
    0x1F4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data3 mode 0*/
    0x1F8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data4 mode 0*/
    0x1FC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data5 mode 0*/
    0x200 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data6 mode 0*/
    0x204 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data7 mode 0*/
    uart0_pins_default: uart0_pins_default {
    0x170 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_rxd.uart0_rxd */
    0x174 (PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
    uart0_pins_sleep: uart0_pins_sleep {
    0x168 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)
    0x16C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)
    0x174 (PIN_INPUT_PULLDOWN | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
    matrix_keypad_default: matrix_keypad_default {
    0x1a4 (PIN_OUTPUT | MUX_MODE7)
    0x1a8 (PIN_OUTPUT | MUX_MODE7)
    0x1ac (PIN_INPUT | PULL_DISABLE | MUX_MODE9) /* mcasp0_ahclkx.gpio0_3 */
    matrix_keypad_sleep: matrix_keypad_sleep {
    0x1a4 (PULL_UP | MUX_MODE7)
    0x1a8 (PULL_UP | MUX_MODE7)
    usb2_phy1_default: usb2_phy1_default {
    0x2c0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE0)
    usb2_phy1_sleep: usb2_phy1_sleep {
    0x2c0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    usb2_phy2_default: usb2_phy2_default {
    0x2c4 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE0)
    usb2_phy2_sleep: usb2_phy2_sleep {
    0x2c4 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
    user_leds_default: user_leds_default {
    0x264 ( PIN_OUTPUT_PULLUP | MUX_MODE9 ) /* (P22) spi2_d0.gpio0[20] */
    0x268 ( PIN_OUTPUT_PULLUP | MUX_MODE9 ) /* (P20) spi2_d1.gpio0[21] TP RESET*/
    0x260 ( PIN_OUTPUT_PULLUP | MUX_MODE9 ) /* (N20) spi2_sclk.gpio0[22] */
    0x26c ( PIN_OUTPUT_PULLUP | MUX_MODE9 ) /* (T23) spi2_cs0.gpio0[23] */
    user_leds_sleep: user_leds_sleep {
    0x238 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpio5_8.gpio5_8 */
    0x23c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpio5_9.gpio5_9 */
    user_keys_default: user_keys_default {
    0x2A4 (PIN_INPUT_PULLUP | MUX_MODE7) /* emu0.gpio3_7 */
    0x2A8 (PIN_INPUT_PULLUP | MUX_MODE7) /* emu1.gpio3_8 */
    ads7846_pins: ads7846_pins {
    0x25c (PIN_INPUT_PULLUP | MUX_MODE7) /* spi4_cs0..gpio5_7 */
    edt_ft5x06_pins: edt_ft5x06_pins {
    gt_911_pins: gt_911_pins {
    0x25c (PIN_INPUT | MUX_MODE7) /* spi4_cs0..gpio5_7 */
    i2c2_pins: i2c2_pins {
    0x154 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2) /* spi0_d0.i2c2_scl */
    0x150 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2) /* spi0_sclk.i2c2_sda */
    clkout2_pin: clkout2_pin {
    debugss_pins: pinmux_debugss_pins {
    0x290 (PIN_INPUT_PULLDOWN)
    0x294 (PIN_INPUT_PULLDOWN)
    0x298 (PIN_INPUT_PULLDOWN)
    0x29C (PIN_INPUT_PULLDOWN)
    0x2A0 (PIN_INPUT_PULLDOWN)
    /*0x2A4 (PIN_INPUT_PULLDOWN)*/
    /*0x2A8 (PIN_INPUT_PULLDOWN)*/
    unused_pins: unused_pins {
    0x6C (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x150 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x154 (PIN_INPUT_PULLDOWN | MUX_MODE0)
    0x24C (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x250 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x254 (PIN_INPUT | PULL_DISABLE | MUX_MODE7)
    0x270 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x278 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x27C (PIN_INPUT | PULL_DISABLE)
    0x2C8 (PIN_INPUT_PULLDOWN)
    0x2D4 (PIN_INPUT_PULLDOWN)
    0x2D8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2DC (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2E0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2E4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2E8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2EC (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2F0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2F4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2F8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x2FC (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x300 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x304 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x308 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x30C (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x310 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x314 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    0x318 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    &i2c0 {
    status = "okay";
    pinctrl-0 = <&i2c0_pins>;
    clock-frequency = <100000>;
    tps65218: tps65218@24 {
    reg = <0x24>;
    compatible = "ti,tps65218";
    interrupts = <GIC_SPI 7 IRQ_TYPE_NONE>; /* NMIn */
    interrupt-parent = <&gic>;
    interrupt-controller;
    #interrupt-cells = <2>;
    dcdc1: regulator-dcdc1 {
    compatible = "ti,tps65218-dcdc1";
    regulator-name = "vdd_core";
    regulator-min-microvolt = <912000>;
    regulator-max-microvolt = <1144000>;
    regulator-boot-on;
    dcdc2: regulator-dcdc2 {
    compatible = "ti,tps65218-dcdc2";
    regulator-name = "vdd_mpu";
    regulator-max-microvolt = <1378000>;
    regulator-boot-on;
    dcdc3: regulator-dcdc3 {
    compatible = "ti,tps65218-dcdc3";
    regulator-name = "vdcdc3";
    regulator-boot-on;
    regulator-state-mem {
    regulator-on-in-suspend;
    regulator-state-disk {
    regulator-off-in-suspend;
    dcdc5: regulator-dcdc5 {
    compatible = "ti,tps65218-dcdc5";
    regulator-name = "v1_0bat";
    regulator-min-microvolt = <1000000>;
    regulator-max-microvolt = <1000000>;
    regulator-boot-on;
    dcdc6: regulator-dcdc6 {
    compatible = "ti,tps65218-dcdc6";
    regulator-name = "v1_8bat";
    regulator-boot-on;
    ldo1: regulator-ldo1 {
    compatible = "ti,tps65218-ldo1";
    regulator-boot-on;
    ov5640@3c {
    compatible = "ti,ov5640";
    reg = <0x3c>;
    clocks = <&audio_mstrclk>;
    clock-names = "xvclk";
    port {
    ov5640_0: endpoint {
    remote-endpoint = <&vpfe1_ep>;
    link-frequencies = /bits/ 64 <70000000>;
    &i2c1 {
    status = "okay";
    pinctrl-0 = <&i2c1_pins_default>;
    pinctrl-1 = <&i2c1_pins_sleep>;
    tlv320aic3106: tlv320aic3106@18 {
    #sound-dai-cells = <0>;
    compatible = "ti,tlv320aic3106";
    reg = <0x18>;
    ai3x-micbias-vg = <1>; /* MICBIAS output is powered to 2.0V */
    status = "okay";
    /* Regulators */
    IOVDD-supply = <&evm_v3_3d>; /* V3_3D -> <tps63031> EN: V1_8D -> VBAT */
    AVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
    DRVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
    DVDD-supply = <&ldo1>; /* V1_8D -> LDO1 */
    mt9m001@5d {
    compatible = "ti,mt9m001";
    reg = <0x5d>;
    port {
    mt9m001_1: endpoint {
    remote-endpoint = <&vpfe0_ep>;
    mclk-frequency = <24000000>;
    gt_911@14 {
    compatible = "xin,gt_911";
    reg = <0x14>;
    pinctrl-0 = <&gt_911_pins>;
    interrupt-parent = <&gpio5>;
    interrupts = <7 0>;
    &i2c2 {
    status = "okay";
    pinctrl-0 = <&i2c2_pins>;
    eeprom@50 {
    compatible = "24c04";
    reg = <0x50>;
    pagesize = <16>;
    &epwmss0 {
    status = "okay";
    &tscadc {
    status = "okay";
    tsc {
    ti,wires = <4>;
    ti,x-plate-resistance = <200>;
    ti,coordinate-readouts = <5>;
    ti,wire-config = <0x01 0x10 0x23 0x32>;
    ti,charge-delay = <0x800>;
    adc {
    ti,adc-channels = <4 5 6 7>;
    &ecap0 {
    status = "okay";
    pinctrl-0 = <&ecap0_pins_default>;
    pinctrl-1 = <&ecap0_pins_sleep>;
    &gpio0 {
    status = "okay";
    &gpio1 {
    status = "okay";
    &gpio2 {
    status = "okay";
    &gpio3 {
    status = "okay";
    &gpio4 {
    status = "okay";
    &gpio5 {
    status = "okay";
    ti,no-reset-on-init;
    &mmc1 {
    status = "okay";
    vmmc-supply = <&evm_v3_3d>;
    bus-width = <4>;
    pinctrl-0 = <&mmc1_pins>;
    pinctrl-1 = <&mmc1_sleep_pins>;
    cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
    /* eMMC sits on mmc2 */
    &mmc2 {
    status = "disabled"; /* Disable GPMC/NAND when enabling mmc2 */
    bus-width = <8>;
    pinctrl-0 = <&emmc_pins_default>;
    pinctrl-1 = <&emmc_pins_sleep>;
    ti,non-removable;
    #if 0
    &mmc3 {
    status = "okay";
    * These are on the crossbar and are outlined in the
    * xbar-event-map element. Using GPIO0 and GPIO1 direct
    * mapped events.
    dmas = <&edma 22
    &edma 23>;
    dma-names = "tx", "rx";
    vmmc-supply = <&vmmcwl_fixed>;
    bus-width = <4>;
    pinctrl-0 = <&mmc3_pins_default>;
    pinctrl-1 = <&mmc3_pins_sleep>;
    cap-power-off-card;
    keep-power-in-suspend;
    ti,non-removable;
    #size-cells = <0>;
    wlcore: wlcore@0 {
    compatible = "ti,wlcore";
    reg = <2>;
    interrupt-parent = <&gpio1>;
    interrupts = <23 IRQ_TYPE_LEVEL_HIGH>;
    #endif
    &edma {
    ti,edma-xbar-event-map = /bits/ 16 <1 22
    2 23>;
    #if 0
    &uart1 {
    status = "okay";
    pinctrl-0 = <&uart1_pins>;
    &uart2 {
    status = "okay";
    pinctrl-0 = <&uart2_pins>;
    #endif
    &uart3 {
    status = "okay";
    pinctrl-0 = <&uart3_pins>;
    #if 0
    &uart4 {
    status = "okay";
    pinctrl-0 = <&uart4_pins>;
    #endif
    #if 0
    &uart5 {
    status = "okay";
    pinctrl-0 = <&uart5_pins>;
    #endif
    &dwc3_1 {
    pinctrl-0 = <&usb2_phy1_default>;
    pinctrl-1 = <&usb2_phy1_sleep>;
    &usb2_phy1 {
    status = "okay";
    &usb1 {
    dr_mode = "otg";
    status = "okay";
    &dwc3_2 {
    pinctrl-0 = <&usb2_phy2_default>;
    pinctrl-1 = <&usb2_phy2_sleep>;
    &usb2_phy2 {
    status = "okay";
    &usb2 {
    dr_mode = "host";
    status = "okay";
    &mac {
    /* slaves = <1>; */
    pinctrl-0 = <&cpsw_default>;
    pinctrl-1 = <&cpsw_sleep>;
    dual_emac;
    status = "okay";
    &davinci_mdio {
    pinctrl-0 = <&davinci_mdio_default>;
    pinctrl-1 = <&davinci_mdio_sleep>;
    status = "okay";
    &cpsw_emac0 {
    phy_id = <&davinci_mdio>, <4>;
    phy-mode = "rgmii";
    &cpsw_emac1 {
    phy_id = <&davinci_mdio>, <5>;
    phy-mode = "rgmii";
    &elm {
    status = "okay";
    &gpmc {
    * When enabling GPMC, disable eMMC and set
    * SelEMMCorNAND to output-low
    status = "okay";
    pinctrl-0 = <&nand_flash_x8_default>;
    pinctrl-1 = <&nand_flash_x8_sleep>;
    ranges = <0 0 0x08000000 0x01000000>; /* CS0 space. Min partition = 16MB */
    nand@0,0 {
    compatible = "ti,omap2-nand";
    reg = <0 0 4>; /* device IO registers */
    interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
    ready-gpio = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */
    ti,nand-ecc-opt = "bch16";
    ti,elm-id = <&elm>;
    nand-bus-width = <8>;
    gpmc,device-width = <1>;
    gpmc,sync-clk-ps = <0>;
    gpmc,cs-on-ns = <0>;
    gpmc,cs-rd-off-ns = <40>;
    gpmc,cs-wr-off-ns = <40>;
    gpmc,adv-on-ns = <0>;
    gpmc,adv-rd-off-ns = <25>;
    gpmc,adv-wr-off-ns = <25>;
    gpmc,we-on-ns = <0>;
    gpmc,we-off-ns = <20>;
    gpmc,oe-on-ns = <3>;
    gpmc,oe-off-ns = <30>;
    gpmc,access-ns = <30>;
    gpmc,rd-cycle-ns = <40>;
    gpmc,wr-cycle-ns = <40>;
    gpmc,bus-turnaround-ns = <0>;
    gpmc,cycle2cycle-delay-ns = <0>;
    gpmc,clk-activation-ns = <0>;
    gpmc,wr-access-ns = <40>;
    gpmc,wr-data-mux-bus-ns = <0>;
    /* MTD partition table */
    /* All SPL-* partitions are sized to minimal length
    * which can be independently programmable. For
    * NAND flash this is equal to size of erase-block */
    #size-cells = <1>;
    partition@0 {
    label = "NAND.SPL";
    reg = <0x00000000 0x00040000>;
    partition@1 {
    label = "NAND.SPL.backup1";
    reg = <0x00040000 0x00040000>;
    partition@2 {
    label = "NAND.SPL.backup2";
    reg = <0x00080000 0x00040000>;
    partition@3 {
    label = "NAND.SPL.backup3";
    reg = <0x000c0000 0x00040000>;
    partition@4 {
    label = "NAND.u-boot-spl-os";
    reg = <0x00100000 0x00080000>;
    partition@5 {
    label = "NAND.u-boot";
    reg = <0x00180000 0x00100000>;
    partition@6 {
    label = "NAND.u-boot-env";
    reg = <0x00280000 0x00040000>;
    partition@7 {
    label = "NAND.u-boot-env.backup1";
    reg = <0x002c0000 0x00040000>;
    partition@8 {
    label = "NAND.kernel";
    reg = <0x00300000 0x00700000>;
    partition@9 {
    label = "NAND.file-system";
    reg = <0x00a00000 0x1f600000>;
    &uart0 {
    status = "okay";
    pinctrl-0 = <&uart0_pins_default>;
    pinctrl-1 = <&uart0_pins_sleep>;
    &dss {
    status = "ok";
    pinctrl-0 = <&dss_pinctrl_default>;
    pinctrl-1 = <&dss_pinctrl_sleep>;
    port {
    dpi_out: endpoint@0 {
    remote-endpoint = <&lcd_in>;
    data-lines = <24>;
    &mcasp1 {
    pinctrl-0 = <&mcasp1_pins>;
    pinctrl-1 = <&mcasp1_sleep_pins>;
    status = "okay";
    op-mode = <0>; /* MCASP_IIS_MODE */
    tdm-slots = <2>;
    /* 4 serializers */
    serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
    0 0 1 2
    tx-num-evt = <32>;
    rx-num-evt = <32>;
    &cpu {
    cpu0-supply = <&dcdc2>;
    &rtc {
    status = "okay";
    &wkup_m3 {
    ti,set-io-isolation;
    ti,scale-data-fw = "am43x-evm-scale-data.bin";
    &vpfe1 {
    status = "okay";
    pinctrl-0 = <&vpfe1_pins_default>;
    pinctrl-1 = <&vpfe1_pins_sleep>;
    /* Camera port */
    port {
    vpfe1_ep: endpoint {
    remote-endpoint = <&ov5640_0>;
    ti,am437x-vpfe-interface = <0>;
    bus-width = <8>;
    hsync-active = <0>;
    vsync-active = <0>;
    &vpfe0 {
    status = "okay";
    pinctrl-0 = <&vpfe0_pins_default>;
    pinctrl-1 = <&vpfe0_pins_sleep>;
    /* Camera port */
    port {
    vpfe0_ep: endpoint {
    remote-endpoint = <&mt9m001_1>;
    bus-width = <8>;
    hsync-active = <0>;
    vsync-active = <0>;
