Tool/software: TI-RTOS
Hi team,
One of my customer would like to know about IPC between DSP, ARM and PCIe.
The concept is as like below :
They evaluated PCIe EP and RC controls based on ARM MPU.
They use PCIe as data sources and the data is sent to ARM. Then ARM send parsed data to DSP and the result is sent to DSP -> ARM -> PCIe.
They would like to use OCMC_RAM2 and RAM3 as shared memory for each PCIe-ARM and ARM-DSP.
And they would like to use 512KB in each RAM2 and RAM3 area, and need maximum performance.
Could you advise if there's example to start those IPC communication efficiently?
Thank you.
B.R.
Ernest Cho
