why the code of startware can't work in the ICE board,the case used is Mcspi,the code will be in a loop,when write enable.I hope you can perform an experiment and then give a solution.Thank you very much.By the way,we are heavy buyers from China.
Sorry,the video is so blurry,i can't know how to work with,can you supply a HD video,and is there a SDK based on the IDE of IAR?
And then,after i install,in the packages directory,i can't find the MyExampleProjects directory,as shown in the figure of the accessory.
Thank you all the same,Looking forward to your reply !
After watching the video,why there is a MyExampleProjects directory in the packages directory,but i did't get the directory,do i need to create it myself?
Then,how to get the document which you refer to in the video?
Can you send me a example about the usage of spi1?I imitate the configuration of spi0 but not work!
When i configure the spi1,what i have changed as follows:
