Other Parts Discussed in Thread: SYSBIOS,
Dear TI,
I'm looking at the host_linux/simple_buffer_example/host/app.c and I'm also looking at the below website with message Q instructions.
I'm noticing things like the instructions (website) indicate things like a sync object, while I'm not seeing that in the example, and the registering of the heap... when I do a search of the heap id I find in other examples they use the register heap, but in this one you just define it to be 0.
based on the website instructions/for message Q I'm 'confused' what I should be doing, when and where and why? The only thing I 'notice' is that when I do a search its the one that is hosted on DSP/BIOS that registers the heap, while the one on the host_linux doesn't... does the use of the heap change based on OS? Why isn't this indicated in the webstie docs on it?
Anyways, I think what I need is some clear documentation that tells me what functions to call under what circumstance. The webstie link attached seems to step me thorugh it, but because I see differences in the example codes... it needs explanation why they can DROP these features... It's not clear from the webstie documentation alone what I should do.
Thanks very much.
