Other Parts Discussed in Thread: TPA3118D2, TLV431
we are using TPA3123D2 chip for our current design, we are referring TPA3123D2 evaluation model as the design reference .
May i know the reason behind using 4.7K ohm resistor across each ROUT and LOUT wrt to AGND.
As our understanding these two resistor work as a minimum load to the amplifier? Is it correct?
Note:we are facing heating issue of the amplifier for very less duration, Since we have missed 4.7KOhm across the two channel, after fixing these two resistor we have reduced the heating issue.
Namith
