HI, Miguel,
Welcome to E2E, thanks for your interest in our products!
Regarding your question, there is a post in the forum where the procedure to implement this application is explained, so you can use it as reference.Please take a look to this post.
-Diego Meléndez López
Audio Applications Engineer
Hi, Miguel,
Unfortunately the creation of custom blocks, like a separate decimation filter, is not supported in PurePath Studio. The method you describe is actually the same provided in the post I referenced before, where the filters within the miniDSP are used.
Hi Diego,
Thank you for your reply.
That is unfortunate. I was hoping to achieve a more optimal decimation filter, but thank you for your help.
Best Regards
Miguel Carvalho
Hi Diego,
Regarding the post you referred to:
I am battling to understand the Decimation step in the process flow. The setup involves setting up a AOSR = 32, therefore I would assume there is a decimation filter with a factor of 32 somewhere to achieve the 192kHz Sampling Rate ? What am I missing here? Is there any decimation happening before the miniDSP?
Best Regards
Miguel Carvalho
