1.How to simply configure the register so that the power amplifier works properly, can sound immediately.
2.How do i config the SAP contorl register input format is TDM mode .there is no TDM mode.
Please provide the clock frequencies used for MCLK, SCLK, and FSYNC.
The information that you gave is not enough to provide you the correct configuration. Please provide the frequency of the MCLK, SCLK, and FSYNC clocks for your TDM configuration.
The clocks look good and the register setting are correct per your description. Now, I have more questions and requests.
There is no problem about the code you posted ealier and these register values. Would you also check channel status register 0x0F?
For easiler analysis, i would propose you to read back all the register value from 0x00 to 0x13.
