Hi Sirs,
We are supporting customer to generate TAS5825 CFG to support 16 bit left-justified format. We can bring up the TAS5825 in this audio mode with 0x33 = 0x30 update by Direct I2C or Register Map:
However, we found that the PPC3's system integration page does not dump 0x33 data. We can rework CFG by adding those two lines manually, however, we don't know the correct location to insert them. We found that TAS5825 can decode LJ data properly only if we add them to the last line of the CFG (please refer to the enclosed CFG before and after reworked).
w 98 00 00
w 98 33 30
TAS5825_PPC3_Example_Before Rework.cfg
TAS5825_PPC3_LJ_Reworked.cfg
Would you please advise the correct location to write 0x33 commands. Nice to have PPC3 update to support data format option officially.
Thank you and Best regards,
Wayne Chen
10/16/2018
