will the Regulator Output Voltage (PV1) level affects the Quiescent current?
higher output = higher Quiescent current????
Hi Mototw,
Quiescent current depends on the difference between VDD and PV1.
This information is provided in data sheet, section 8.2.2.12 . Although no current measurements are provided as there would be several different values for each voltage difference.
For quiescent current levels you can check Electrical Characteristics tables.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
